你好,我使用的devkit8600开发板,仿照starterware02.00.00.07上的usb_host_msc工程修改了代码,现在枚举部分已经正常,可以正常读取设备的描述符。枚举成功后调用下面这个函数依据端点描述符来创建PIPE:
static void *
USBHMSCOpen(tUSBHostDevice *pDevice, unsigned int ulInstance)
int iIdx;
tEndpointDescriptor *pEndpointDescriptor;
tInterfaceDescriptor *pInterface;
tUSBHMSCInstance *sUSBHMSCDevice;
sUSBHMSCDevice = (tUSBHMSCInstance *)ulInstance;
unsigned int ulIndex = sUSBHMSCDevice->ulIndex;
// Don't allow the device to be opened without closing first.
if(sUSBHMSCDevice->pDevice)
return(0);
// Save the device pointer.
sUSBHMSCDevice->pDevice = pDevice;
// Get the interface descriptor.
pInterface = USBDescGetInterface(pDevice->pConfigDescriptor, 0, 0);
// Loop through the endpoints of the device.
for(iIdx = 0; iIdx < 3; iIdx++)
// Get the first endpoint descriptor.
pEndpointDescriptor =
USBDescGetInterfaceEndpoint(pInterface, iIdx,
pDevice->ulConfigDescriptorSize);
// If no more endpoints then break out.
if(pEndpointDescriptor == 0)
break;
// See if this is a bulk endpoint.
if((pEndpointDescriptor->bmAttributes & USB_EP_ATTR_TYPE_M) ==
USB_EP_ATTR_BULK)
// See if this is bulk IN or bulk OUT.
if(pEndpointDescriptor->bEndpointAddress & USB_EP_DESC_IN)
// Allocate the USB Pipe for this Bulk IN endpoint.
sUSBHMSCDevice->ulBulkInPipe =
USBHCDPipeAllocSize(ulIndex, USBHCD_PIPE_BULK_IN_DMA,
pDevice->ulAddress,
pEndpointDescriptor->wMaxPacketSize,
0);
// Configure the USB pipe as a Bulk IN endpoint.
USBHCDPipeConfig(ulIndex, sUSBHMSCDevice->ulBulkInPipe,
0,
USB_EP_DESC_NUM_M));
else
// Allocate the USB Pipe for this Bulk OUT endpoint.
sUSBHMSCDevice->ulBulkOutPipe =
USBHCDPipeAllocSize(ulIndex, USBHCD_PIPE_BULK_OUT_DMA,
pDevice->ulAddress,
0);
// Configure the USB pipe as a Bulk OUT endpoint.
USBHCDPipeConfig(ulIndex, sUSBHMSCDevice->ulBulkOutPipe,
0,
// If the callback exists, call it with an Open event.
if(sUSBHMSCDevice->pfnCallback != 0)
sUSBHMSCDevice->pfnCallback((unsigned int)sUSBHMSCDevice,
MSC_EVENT_OPEN, 0);
// Return the only instance of this device.
return(sUSBHMSCDevice);
之后再调用接口 USBHCDPipeRead(unsigned int ulIndex, unsigned int ulPipe,unsigned char *pucData, unsigned int ulSize)来读取设备数据时,总是在:
else if(g_sUSBHCD[ulIndex].ulUSBHIntEvents & INT_EVENT_BABBLE_FAULT)
// Update the Pipe status
g_sUSBHCD[ulIndex].USBINPipes[ulPipeIdx].eState = PIPE_ERROR;
printf("INT_EVENT_BABBLE_FAULT\n");
continue;
这里打印BABBLE这个错误,并且一直循环,不能成功的使用bulk-in来读取usb设备上的数据,请问我在哪里的使用有问题吗? 谢谢。
