这是coder engine log
# Fail, CE_DEBUG=1
root@DM6467:/opt/video_copy# CE_DEBUG=1 ./video_copy.x470MV in.dat /dev/null
App-> Application started.
@0,290,093us: [+6 T:0x00004000] CE - Engine_init> CE debugging on (CE_DEBUG=1; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
DSP-side configuration mismatch/failure
0 -> success
Positive value -> DSP-side failure code.
(Uint32) -1 -> DSP-side component was not initialized.
DRV configuration status [0xffffffff]
IPS configuration status [0xffffffff]
POOL configuration status [0xffffffff]
MPCS configuration status [0xffffffff]
MPLIST configuration status [0xffffffff]
MQT configuration status [0xffffffff]
RINGIO configuration status [0xffffffff]
@11,316,898us: [+7 T:0x00004002] OP - Processor_create_d> Loading and starting DSP server 'video_copy.x64P' FAILED, status=[0x80008052] (look for error code 'DSP_EBASE + 0x52' in dsplink*/packages/dsplink/gpp/inc/errbase.h)
@11,317,215us: [+6 T:0x00004002] OP - Processor_delete_d> Closing remote transport FAILED, status=0x80008000.
@11,317,394us: [+6 T:0x00004002] OP - Processor_delete_d> Stopping DSP FAILED, status=0x80008000
@11,331,544us: [+6 T:0x00004000] CE - rserverOpen: can't start 'video_copy.x64P'; Processor_create failed
CEapp-> ERROR: can't open engine video_copy
App-> Application FAILED.
# Fail, CE_DEBUG=2
root@DM6467:/opt/video_copy# CE_DEBUG=2 ./video_copy.x470MV in.dat /dev/null
@0,278,339us: [+4 T:0x00004000] OG - Global_init> This program was built with the following packages:
@0,278,645us: [+4 T:0x00004000] OG - package gnu.targets.rts470MV (/opt/dvsdk_1_40_02_33/xdc_3_00_06/packages/gnu/targets/rts470MV/) [1,0,0,0,1203621000516]
@0,278,785us: [+4 T:0x00004000] OG - package ti.xdais.dm (/opt/dvsdk_1_40_02_33/xdais_6_10_01/packages/ti/xdais/dm/) [1,0,4,1210262746529]
@0,278,909us: [+4 T:0x00004000] OG - package ti.xdais (/opt/dvsdk_1_40_02_33/xdais_6_10_01/packages/ti/xdais/) [1,2,1,1210262742149]
@0,279,050us: [+4 T:0x00004000] OG - package ti.sdo.utils.trace (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/utils/trace/) [1,0,0,1220943366422]
@0,279,185us: [+4 T:0x00004000] OG - package ti.sdo.ce.utils.xdm (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/utils/xdm/) [1,0,1,1220951322616]
@0,279,316us: [+4 T:0x00004000] OG - package ti.sdo.fc.dman3 (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/fc/dman3/) [1,0,3,1220943053023]
@0,279,442us: [+4 T:0x00004000] OG - package ti.sdo.fc.acpy3 (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/fc/acpy3/) [1,0,2,1220943014135]
@0,279,571us: [+4 T:0x00004000] OG - package dsplink.gpp (/opt/dvsdk_1_40_02_33/dsplink-davinci-v1.50-prebuilt/packages/dsplink/gpp/) [3,0,0]
@0,279,689us: [+4 T:0x00004000] OG - package ti.sdo.linuxutils.cmem (/opt/dvsdk_1_40_02_33/cmem_2_10/packages/ti/sdo/linuxutils/cmem/) [2,0,1,1204929560755]
@0,279,814us: [+4 T:0x00004000] OG - package ti.catalog.c470 (/opt/dvsdk_1_40_02_33/xdc_3_00_06/packages/ti/catalog/c470/) [1,0,1,0,1203561761475]
@0,279,934us: [+4 T:0x00004000] OG - package ti.catalog.c6000 (/opt/dvsdk_1_40_02_33/xdc_3_00_06/packages/ti/catalog/c6000/) [1,0,0,0,1203561781695]
@0,280,467us: [+4 T:0x00004000] OG - package ti.platforms.evmDM6467 (/opt/dvsdk_1_40_02_33/bios_5_32_01/packages/ti/platforms/evmDM6467/) [1,0,0,0,1192229633217]
@0,280,647us: [+4 T:0x00004000] OG - package ti.sdo.ce.osal (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/osal/) [2,0,2,1220951127739]
@0,280,784us: [+4 T:0x00004000] OG - package ti.sdo.ce.ipc (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/) [2,0,1,1220951085787]
@0,280,909us: [+4 T:0x00004000] OG - package ti.sdo.ce.alg (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/alg/) [1,0,1,1220950781938]
@0,281,031us: [+4 T:0x00004000] OG - package ti.sdo.ce.osal.linux (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/osal/linux/) [2,0,1,1220951140072]
@0,281,159us: [+4 T:0x00004000] OG - package ti.sdo.ce.ipc.dsplink (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/dsplink/) [2,0,1,1220951096818]
@0,281,286us: [+4 T:0x00004000] OG - package ti.sdo.ce (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/) [1,0,6,1220950771473]
@0,281,403us: [+4 T:0x00004000] OG - package ti.sdo.ce.video (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/video/) [1,0,3,1220951334122]
@0,281,525us: [+4 T:0x00004000] OG - package ti.codecs.viddec_copy (/home/xn/nfs/opt/video_copy/ti/codecs/viddec_copy/) []
@0,281,634us: [+4 T:0x00004000] OG - package ti.codecs.videnc_copy (/home/xn/nfs/opt/video_copy/ti/codecs/videnc_copy/) []
@0,281,742us: [+4 T:0x00004000] OG - package ti.sdo.ce.bioslog (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/bioslog/) [1,0,1,1220950800329]
@0,281,867us: [+4 T:0x00004000] OG - package ti.sdo.ce.utils.trace (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/utils/trace/) [1,0,1,1220951317087]
@0,281,995us: [+4 T:0x00004000] OG - package ti.apps.video_copy (/home/xn/nfs/opt/video_copy/ti/apps/video_copy/) []
@0,282,551us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0,282,701us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x3f508]
@0,282,813us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0,282,912us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x3f520]
@0,283,021us: [+0 T:0x00004000] OT - Thread_create> Enter (fxn=0x14464, attrs=0x0)
@0,482,349us: [+0 T:0x00004000] OT - Thread_create> Exit (task=0x3f558)
@0,482,527us: [+0 T:0x00004000] ti.sdo.ce.alg - ALG_init> Enter
@0,482,635us: [+0 T:0x00004000] ti.sdo.ce.alg - ALG_init> Exit
@0,482,814us: [+6 T:0x00004000] CE - Engine_init> CE debugging on (CE_DEBUG=2; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
@0,483,013us: [+0 T:0x00004000] CS - Server_init()
@0,483,108us: [+0 T:0x00004000] CS - Server_init> Global_useLinkArbiter = 0
@0,483,336us: [+0 T:0x00004000] CE - Engine_open> Enter('video_copy', 0x0, 0xbefffd64)
@0,483,503us: [+0 T:0x00004000] CE - rserverOpen('video_copy.x64P'), count = 0
@0,483,636us: [+0 T:0x00004000] OP - Processor_create> Enter(imageName='video_copy.x64P', linkCfg='(null)', attrs=0xbefffd68)
@0,483,829us: [+0 T:0x00004000] OP - doCmd> Enter (cmdId=1, proc=0x417c0)
@0,483,942us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f508]
@0,484,064us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f508]
@0,484,171us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f520] timeout[0xffffffff]
@0,484,492us: [+1 T:0x00004002] OP - daemon> thread created.
@0,484,611us: [+0 T:0x00004002] OP - getCmd_d> Enter (proc=0xbe7ffaec)
@0,484,710us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f508] timeout[0xffffffff]
@0,484,822us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f508] status[0]
@0,484,925us: [+0 T:0x00004002] OP - getCmd_d> Exit (result=1)
@0,485,031us: [+0 T:0x00004002] OP - Processor_create_d> Enter(proc=0x417c0)
@0,485,128us: [+2 T:0x00004002] OP - Processor_create_d> Initializing DSP PROC...
@0,485,232us: [+2 T:0x00004002] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'video_copy.x64P']
@0,485,386us: [+2 T:0x00004002] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, shared=1
@0,485,548us: [+2 T:0x00004002] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x100000, shared=1
@0,485,700us: [+2 T:0x00004002] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x8ff00000, sizeInBytes=0x80, shared=0
@0,485,845us: [+2 T:0x00004002] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x88000000, sizeInBytes=0x7a00000, shared=0
@0,485,993us: [+2 T:0x00004002] OP - Processor_create_d> DOPOWERCONTROL was=0; now=0
@0,487,780us: [+2 T:0x00004002] OP - Processor_create_d> Attaching to DSP PROC...
@0,495,440us: [+2 T:0x00004002] OP - Processor_create_d> Opening MSGQ pool...
@0,495,829us: [+2 T:0x00004002] OP - Processor_create_d> Loading video_copy.x64P on DSP (1 args)...
@0,516,647us: [+2 T:0x00004002] OP - Processor_create_d> Starting DSP PROC...
0 -> success
@11,513,027us: [+7 T:0x00004002] OP - Processor_create_d> Loading and starting DSP server 'video_copy.x64P' FAILED, status=[0x80008052] (look for error code 'DSP_EBASE + 0x52' in dsplink*/packages/dsplink/gpp/inc/errbase.h)
@11,513,259us: [+0 T:0x00004002] OP - Processor_delete_d> Enter (proc=0x417c0)
@11,513,389us: [+2 T:0x00004002] OP - Processor_delete_d> Closing remote transport...
@11,513,546us: [+6 T:0x00004002] OP - Processor_delete_d> Closing remote transport FAILED, status=0x80008000.
@11,513,674us: [+2 T:0x00004002] OP - Processor_delete_d> Stopping DSP...
@11,513,790us: [+6 T:0x00004002] OP - Processor_delete_d> Stopping DSP FAILED, status=0x80008000
@11,513,902us: [+2 T:0x00004002] OP - Processor_delete_d> Closing pool...
@11,514,256us: [+2 T:0x00004002] OP - Processor_delete_d> Detaching from DSP...
@11,527,505us: [+2 T:0x00004002] OP - Processor_delete_d> Destroying DSP... (object, that is)
@11,528,270us: [+0 T:0x00004002] OP - Processor_delete_d> return
@11,528,411us: [+2 T:0x00004002] OP - Processor_create_d> return (0)
@11,528,514us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f520]
@11,528,666us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f520] status[0]
@11,528,791us: [+0 T:0x00004000] OP - doCmd> Exit (result=2)
@11,528,883us: [+0 T:0x00004000] OP - Processor_delete> Enter(proc=0x417c0)
@11,528,979us: [+1 T:0x00004000] OP - Processor_delete(0x417c0) freeing object ...
@11,529,079us: [+0 T:0x00004000] OP - Processor_delete> return.
@11,529,166us: [+6 T:0x00004000] CE - rserverOpen: can't start 'video_copy.x64P'; Processor_create failed
@11,529,273us: [+0 T:0x00004000] CE - rserverOpen('video_copy.x64P'): 0x0 done.
@11,529,366us: [+0 T:0x00004000] CE - Engine_close(0x41790)
@11,529,460us: [+0 T:0x00004000] CE - Engine_open> return(0)
@11,529,922us: [+0 T:0x00004000] OP - doCmd> Enter (cmdId=3, proc=0x0)
@11,530,105us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f508]
@11,530,218us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f508]
@11,530,317us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f520] timeout[0xffffffff]
@11,530,449us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f520]
@11,530,560us: [+0 T:0x00004002] OP - getCmd_d> Enter (proc=0xbe7ffaec)
@11,530,655us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f508] timeout[0xffffffff]
@11,530,761us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f508] status[0]
@11,530,863us: [+0 T:0x00004002] OP - getCmd_d> Exit (result=3)
@11,530,948us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f520]
@11,531,092us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f520] status[0]
@11,531,213us: [+0 T:0x00004000] OP - doCmd> Exit (result=1)
@11,531,304us: [+0 T:0x00004000] OT - Thread_delete> Enter (task=0x3f558)
@11,531,442us: [+4 T:0x00004000] OT - Thread_delete> pthread_cancel (0x0)
@11,531,766us: [+4 T:0x00004000] OT - Thread_delete> pthread_join (0x0)
@11,531,896us: [+0 T:0x00004000] OT - Thread_delete> Exit (task=0x3f558)
@11,531,997us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x3f508]
@11,532,123us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
@11,532,219us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x3f520]
@11,532,324us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
# Fail, CE_DEBUG=3
root@DM6467:/opt/video_copy# CE_DEBUG=3 ./video_copy.x470MV in.dat /dev/null
@0,668,472us: [+4 T:0x00004000 S:0xbefffd64] OG - Global_init> This program was built with the following packages:
@0,668,919us: [+4 T:0x00004000 S:0xbefffd64] OG - package gnu.targets.rts470MV (/opt/dvsdk_1_40_02_33/xdc_3_00_06/packages/gnu/targets/rts470MV/) [1,0,0,0,1203621000516]
@0,669,155us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.xdais.dm (/opt/dvsdk_1_40_02_33/xdais_6_10_01/packages/ti/xdais/dm/) [1,0,4,1210262746529]
@0,669,321us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.xdais (/opt/dvsdk_1_40_02_33/xdais_6_10_01/packages/ti/xdais/) [1,2,1,1210262742149]
@0,669,540us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.utils.trace (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/utils/trace/) [1,0,0,1220943366422]
@0,669,713us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.ce.utils.xdm (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/utils/xdm/) [1,0,1,1220951322616]
@0,669,867us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.fc.dman3 (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/fc/dman3/) [1,0,3,1220943053023]
@0,670,402us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.fc.acpy3 (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/fc/acpy3/) [1,0,2,1220943014135]
@0,670,588us: [+4 T:0x00004000 S:0xbefffd64] OG - package dsplink.gpp (/opt/dvsdk_1_40_02_33/dsplink-davinci-v1.50-prebuilt/packages/dsplink/gpp/) [3,0,0]
@0,670,824us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.linuxutils.cmem (/opt/dvsdk_1_40_02_33/cmem_2_10/packages/ti/sdo/linuxutils/cmem/) [2,0,1,1204929560755]
@0,670,984us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.catalog.c470 (/opt/dvsdk_1_40_02_33/xdc_3_00_06/packages/ti/catalog/c470/) [1,0,1,0,1203561761475]
@0,671,133us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.catalog.c6000 (/opt/dvsdk_1_40_02_33/xdc_3_00_06/packages/ti/catalog/c6000/) [1,0,0,0,1203561781695]
@0,671,278us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.platforms.evmDM6467 (/opt/dvsdk_1_40_02_33/bios_5_32_01/packages/ti/platforms/evmDM6467/) [1,0,0,0,1192229633217]
@0,671,430us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.ce.osal (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/osal/) [2,0,2,1220951127739]
@0,671,577us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.ce.ipc (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/) [2,0,1,1220951085787]
@0,671,786us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.ce.alg (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/alg/) [1,0,1,1220950781938]
@0,671,939us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.ce.osal.linux (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/osal/linux/) [2,0,1,1220951140072]
@0,672,096us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.ce.ipc.dsplink (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/dsplink/) [2,0,1,1220951096818]
@0,672,252us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.ce (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/) [1,0,6,1220950771473]
@0,672,413us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.ce.video (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/video/) [1,0,3,1220951334122]
@0,672,568us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.codecs.viddec_copy (/home/xn/nfs/opt/video_copy/ti/codecs/viddec_copy/) []
@0,672,702us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.codecs.videnc_copy (/home/xn/nfs/opt/video_copy/ti/codecs/videnc_copy/) []
@0,672,834us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.ce.bioslog (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/bioslog/) [1,0,1,1220950800329]
@0,672,982us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.sdo.ce.utils.trace (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/utils/trace/) [1,0,1,1220951317087]
@0,673,135us: [+4 T:0x00004000 S:0xbefffd64] OG - package ti.apps.video_copy (/home/xn/nfs/opt/video_copy/ti/apps/video_copy/) []
@0,673,333us: [+0 T:0x00004000 S:0xbefffd6c] OG - Global_atexit> enter (fxn=0x19958)
@0,871,841us: [+0 T:0x00004000 S:0xbefffd6c] OG - Global_atexit> enter (fxn=0x18df0)
@0,872,061us: [+0 T:0x00004000 S:0xbefffd3c] OM - Memory_alloc> Enter(0x18)
@0,872,226us: [+0 T:0x00004000 S:0xbefffd3c] OM - Memory_alloc> return (0x3f438)
@0,872,515us: [+0 T:0x00004000 S:0xbefffd5c] OG - Global_atexit> enter (fxn=0x176d8)
@0,872,731us: [+0 T:0x00004000 S:0xbefffd3c] OM - Memory_alloc> Enter(0x18)
@0,872,868us: [+0 T:0x00004000 S:0xbefffd3c] OM - Memory_alloc> return (0x3f488)
@0,872,989us: [+0 T:0x00004000 S:0xbefffd5c] OG - Global_atexit> enter (fxn=0x15324)
@0,873,156us: [+0 T:0x00004000 S:0xbefffd64] OG - Global_atexit> enter (fxn=0x18474)
@0,873,335us: [+0 T:0x00004000 S:0xbefffd4c] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0,873,488us: [+0 T:0x00004000 S:0xbefffd34] OM - Memory_alloc> Enter(0x14)
@0,873,613us: [+0 T:0x00004000 S:0xbefffd34] OM - Memory_alloc> return (0x3f508)
@0,873,748us: [+0 T:0x00004000 S:0xbefffd4c] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x3f508]
@0,873,878us: [+0 T:0x00004000 S:0xbefffd4c] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0,873,991us: [+0 T:0x00004000 S:0xbefffd34] OM - Memory_alloc> Enter(0x14)
@0,874,108us: [+0 T:0x00004000 S:0xbefffd34] OM - Memory_alloc> return (0x3f520)
@0,874,222us: [+0 T:0x00004000 S:0xbefffd4c] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x3f520]
@0,874,344us: [+0 T:0x00004000 S:0xbefffd34] OM - Memory_alloc> Enter(0x18)
@0,874,458us: [+0 T:0x00004000 S:0xbefffd34] OM - Memory_alloc> return (0x3f538)
@0,874,574us: [+0 T:0x00004000 S:0xbefffd34] OT - Thread_create> Enter (fxn=0x14464, attrs=0x0)
@0,874,693us: [+0 T:0x00004000 S:0xbefffd1c] OM - Memory_alloc> Enter(0x64)
@0,874,806us: [+0 T:0x00004000 S:0xbefffd1c] OM - Memory_alloc> return (0x3f558)
@0,875,575us: [+0 T:0x00004000 S:0xbefffd34] OT - Thread_create> Exit (task=0x3f558)
@0,875,732us: [+0 T:0x00004000 S:0xbefffd6c] OG - Global_atexit> enter (fxn=0x14024)
@0,875,880us: [+0 T:0x00004000 S:0xbefffd6c] OG - Global_atexit> enter (fxn=0x16118)
@0,876,037us: [+0 T:0x00004000 S:0xbefffd54] ti.sdo.ce.alg - ALG_init> Enter
@0,876,160us: [+0 T:0x00004000 S:0xbefffd44] OG - Global_atexit> enter (fxn=0x1a320)
@0,876,286us: [+0 T:0x00004000 S:0xbefffd74] ti.sdo.ce.alg - ALG_init> Exit
@0,876,398us: [+0 T:0x00004000 S:0xbefffd6c] OG - Global_atexit> enter (fxn=0x19dc0)
@0,876,532us: [+0 T:0x00004000 S:0xbefffd44] OM - Memory_alloc> Enter(0x18)
@0,876,659us: [+0 T:0x00004000 S:0xbefffd44] OM - Memory_alloc> return (0x41690)
@0,876,799us: [+0 T:0x00004000 S:0xbefffd6c] OG - Global_atexit> enter (fxn=0x185d8)
@0,876,990us: [+6 T:0x00004000 S:0xbefffd6c] CE - Engine_init> CE debugging on (CE_DEBUG=3; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
@0,877,150us: [+0 T:0x00004000 S:0xbefffd5c] OG - Global_atexit> enter (fxn=0x11064)
@0,877,277us: [+0 T:0x00004000 S:0xbefffd3c] OM - Memory_alloc> Enter(0x18)
@0,877,399us: [+0 T:0x00004000 S:0xbefffd3c] OM - Memory_alloc> return (0x416d0)
@0,877,520us: [+0 T:0x00004000 S:0xbefffd3c] OM - Memory_alloc> Enter(0x18)
@0,877,638us: [+0 T:0x00004000 S:0xbefffd3c] OM - Memory_alloc> return (0x416f0)
@0,877,754us: [+0 T:0x00004000 S:0xbefffd3c] OM - Memory_alloc> Enter(0x18)
@0,877,874us: [+0 T:0x00004000 S:0xbefffd3c] OM - Memory_alloc> return (0x41710)
@0,878,038us: [+0 T:0x00004000 S:0xbefffd6c] CS - Server_init()
@0,878,157us: [+0 T:0x00004000 S:0xbefffd6c] CS - Server_init> Global_useLinkArbiter = 0
@0,878,281us: [+0 T:0x00004000 S:0xbefffd6c] OG - Global_atexit> enter (fxn=0xfbb4)
@0,878,476us: [+0 T:0x00004000 S:0xbefffd7c] OG - Global_atexit> enter (fxn=0xcc54)
@0,878,670us: [+0 T:0x00004000 S:0xbefffd1c] CE - Engine_open> Enter('video_copy', 0x0, 0xbefffd64)
@0,878,843us: [+0 T:0x00004000 S:0xbefffd04] OM - Memory_alloc> Enter(0x2c)
@0,878,971us: [+0 T:0x00004000 S:0xbefffd04] OM - Memory_alloc> return (0x41790)
@0,879,096us: [+0 T:0x00004000 S:0xbefffd1c] CE - rserverOpen('video_copy.x64P'), count = 0
@1,077,878us: [+0 T:0x00004000 S:0xbefffce4] OP - Processor_create> Enter(imageName='video_copy.x64P', linkCfg='(null)', attrs=0xbefffd68)
@1,078,100us: [+0 T:0x00004000 S:0xbefffccc] OM - Memory_alloc> Enter(0x24)
@1,078,244us: [+0 T:0x00004000 S:0xbefffccc] OM - Memory_alloc> return (0x41848)
@1,078,372us: [+0 T:0x00004000 S:0xbefffcc4] OP - doCmd> Enter (cmdId=1, proc=0x41848)
@1,078,497us: [+0 T:0x00004000 S:0xbefffcb4] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f508]
@1,078,640us: [+0 T:0x00004000 S:0xbefffcc4] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f508]
@1,078,772us: [+0 T:0x00004000 S:0xbefffca4] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f520] timeout[0xffffffff]
@1,080,050us: [+1 T:0x00004002 S:0xbe7ffa74] OP - daemon> thread created.
@1,080,195us: [+0 T:0x00004002 S:0xbe7ffa74] OP - getCmd_d> Enter (proc=0xbe7ffaec)
@1,080,320us: [+0 T:0x00004002 S:0xbe7ffa54] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f508] timeout[0xffffffff]
@1,080,458us: [+0 T:0x00004002 S:0xbe7ffa54] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f508] status[0]
@1,080,588us: [+0 T:0x00004002 S:0xbe7ffa74] OP - getCmd_d> Exit (result=1)
@1,080,702us: [+0 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Enter(proc=0x41848)
@1,080,822us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Initializing DSP PROC...
@1,080,949us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'video_copy.x64P']
@1,081,097us: [+0 T:0x00004002 S:0xbe7ffa5c] OM - Memory_alloc> Enter(0xe0)
@1,081,247us: [+0 T:0x00004002 S:0xbe7ffa5c] OM - Memory_alloc> return (0x41870)
@1,081,396us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, shared=1
@1,081,583us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x100000, shared=1
@1,081,756us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x8ff00000, sizeInBytes=0x80, shared=0
@1,081,928us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x88000000, sizeInBytes=0x7a00000, shared=0
@1,082,102us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> DOPOWERCONTROL was=0; now=0
@1,083,903us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Attaching to DSP PROC...
@1,091,615us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Opening MSGQ pool...
@1,092,033us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Loading video_copy.x64P on DSP (1 args)...
@1,112,848us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Starting DSP PROC...
0 -> success
@12,117,889us: [+7 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Loading and starting DSP server 'video_copy.x64P' FAILED, status=[0x80008052] (look for error code 'DSP_EBASE + 0x52' in dsplink*/packages/dsplink/gpp/inc/errbase.h)
@12,118,150us: [+0 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Enter (proc=0x41848)
@12,118,307us: [+2 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Closing remote transport...
@12,118,490us: [+6 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Closing remote transport FAILED, status=0x80008000.
@12,118,645us: [+2 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Stopping DSP...
@12,118,789us: [+6 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Stopping DSP FAILED, status=0x80008000
@12,118,929us: [+2 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Closing pool...
@12,119,311us: [+2 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Detaching from DSP...
@12,132,582us: [+2 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Destroying DSP... (object, that is)
@12,133,400us: [+0 T:0x00004002 S:0xbe7ffa2c] OM - Memory_free> Enter(0x41870, 0x0)
@12,133,565us: [+0 T:0x00004002 S:0xbe7ffa2c] OM - Memory_free> return (0x1)
@12,133,691us: [+0 T:0x00004002 S:0xbe7ffa74] OP - Processor_delete_d> return
@12,133,805us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> return (0)
@12,133,924us: [+0 T:0x00004002 S:0xbe7ffa64] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f520]
@12,134,102us: [+0 T:0x00004000 S:0xbefffca4] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f520] status[0]
@12,134,251us: [+0 T:0x00004000 S:0xbefffcc4] OP - doCmd> Exit (result=2)
@12,134,367us: [+0 T:0x00004000 S:0xbefffcd4] OP - Processor_delete> Enter(proc=0x41848)
@12,134,487us: [+1 T:0x00004000 S:0xbefffcd4] OP - Processor_delete(0x41848) freeing object ...
@12,134,606us: [+0 T:0x00004000 S:0xbefffcac] OM - Memory_free> Enter(0x41848, 0x24)
@12,134,727us: [+0 T:0x00004000 S:0xbefffcac] OM - Memory_free> return (0x1)
@12,134,839us: [+0 T:0x00004000 S:0xbefffce4] OP - Processor_delete> return.
@12,134,973us: [+6 T:0x00004000 S:0xbefffd1c] CE - rserverOpen: can't start 'video_copy.x64P'; Processor_create failed
@12,135,107us: [+0 T:0x00004000 S:0xbefffd1c] CE - rserverOpen('video_copy.x64P'): 0x0 done.
@12,135,227us: [+0 T:0x00004000 S:0xbefffcfc] CE - Engine_close(0x41790)
@12,135,344us: [+0 T:0x00004000 S:0xbefffcf4] OM - Memory_free> Enter(0x41790, 0x2c)
@12,135,467us: [+0 T:0x00004000 S:0xbefffcf4] OM - Memory_free> return (0x1)
@12,135,582us: [+0 T:0x00004000 S:0xbefffd1c] CE - Engine_open> return(0)
@12,136,003us: [+0 T:0x00004000 S:0xbefffdb4] OG - Global_exit> enter
@12,136,128us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0xcc54()...
@12,136,271us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0xfbb4()...
@12,136,402us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0x11064()...
@12,136,544us: [+0 T:0x00004000 S:0xbefffd7c] OM - Memory_free> Enter(0x416d0, 0x18)
@12,136,697us: [+0 T:0x00004000 S:0xbefffd7c] OM - Memory_free> return (0x1)
@12,136,813us: [+0 T:0x00004000 S:0xbefffd7c] OM - Memory_free> Enter(0x416f0, 0x18)
@12,136,930us: [+0 T:0x00004000 S:0xbefffd7c] OM - Memory_free> return (0x1)
@12,137,042us: [+0 T:0x00004000 S:0xbefffd7c] OM - Memory_free> Enter(0x41710, 0x18)
@12,137,162us: [+0 T:0x00004000 S:0xbefffd7c] OM - Memory_free> return (0x1)
@12,137,275us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0x185d8()...
@12,137,397us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0x19dc0()...
@12,137,521us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0x1a320()...
@12,137,644us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0x16118()...
@12,137,765us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0x14024()...
@12,137,887us: [+0 T:0x00004000 S:0xbefffd7c] OP - doCmd> Enter (cmdId=3, proc=0x0)
@12,138,002us: [+0 T:0x00004000 S:0xbefffd6c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f508]
@12,138,127us: [+0 T:0x00004000 S:0xbefffd7c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f508]
@12,138,270us: [+0 T:0x00004000 S:0xbefffd5c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f520] timeout[0xffffffff]
@12,138,433us: [+0 T:0x00004002 S:0xbe7ffa74] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f520]
@12,138,571us: [+0 T:0x00004002 S:0xbe7ffa74] OP - getCmd_d> Enter (proc=0xbe7ffaec)
@12,337,680us: [+0 T:0x00004002 S:0xbe7ffa54] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f508] timeout[0xffffffff]
@12,337,841us: [+0 T:0x00004002 S:0xbe7ffa54] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f508] status[0]
@12,337,977us: [+0 T:0x00004002 S:0xbe7ffa74] OP - getCmd_d> Exit (result=3)
@12,338,092us: [+0 T:0x00004002 S:0xbe7ffa64] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f520]
@12,338,238us: [+0 T:0x00004002 S:0xbe7ffa74] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f520]
@12,338,473us: [+0 T:0x00004000 S:0xbefffd5c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f520] status[0]
@12,338,633us: [+0 T:0x00004000 S:0xbefffd7c] OP - doCmd> Exit (result=1)
@12,338,750us: [+0 T:0x00004000 S:0xbefffd84] OT - Thread_delete> Enter (task=0x3f558)
@12,338,901us: [+4 T:0x00004000 S:0xbefffd84] OT - Thread_delete> pthread_cancel (0x3)
@12,339,047us: [+4 T:0x00004000 S:0xbefffd84] OT - Thread_delete> pthread_join (0x0)
@12,339,173us: [+0 T:0x00004000 S:0xbefffd5c] OM - Memory_free> Enter(0x3f558, 0x64)
@12,339,317us: [+0 T:0x00004000 S:0xbefffd5c] OM - Memory_free> return (0x1)
@12,339,436us: [+0 T:0x00004000 S:0xbefffd9c] OT - Thread_delete> Exit (task=0x3f558)
@12,339,555us: [+0 T:0x00004000 S:0xbefffd8c] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x3f508]
@12,339,697us: [+0 T:0x00004000 S:0xbefffd64] OM - Memory_free> Enter(0x3f508, 0x14)
@12,339,829us: [+0 T:0x00004000 S:0xbefffd64] OM - Memory_free> return (0x1)
@12,339,945us: [+0 T:0x00004000 S:0xbefffd9c] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
@12,344,071us: [+0 T:0x00004000 S:0xbefffd8c] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x3f520]
@12,344,222us: [+0 T:0x00004000 S:0xbefffd64] OM - Memory_free> Enter(0x3f520, 0x14)
@12,344,378us: [+0 T:0x00004000 S:0xbefffd64] OM - Memory_free> return (0x1)
@12,344,496us: [+0 T:0x00004000 S:0xbefffd9c] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
@12,344,610us: [+0 T:0x00004000 S:0xbefffd74] OM - Memory_free> Enter(0x3f538, 0x18)
@12,344,732us: [+0 T:0x00004000 S:0xbefffd74] OM - Memory_free> return (0x1)
@12,344,847us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0x18474()...
@12,345,118us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0x15324()...
@12,345,272us: [+0 T:0x00004000 S:0xbefffd8c] OM - Memory_free> Enter(0x3f488, 0x18)
@12,345,402us: [+0 T:0x00004000 S:0xbefffd8c] OM - Memory_free> return (0x1)
@12,345,521us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0x176d8()...
@12,345,660us: [+0 T:0x00004000 S:0xbefffd74] OM - Memory_free> Enter(0x3f438, 0x18)
@12,345,789us: [+0 T:0x00004000 S:0xbefffd74] OM - Memory_free> return (0x1)
@12,345,905us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0x18df0()...
@12,346,055us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0x19958()...
@12,346,178us: [+2 T:0x00004000 S:0xbefffdb4] OG - Global_exit> calling function *0x187fc()...
# Success, CE_DEBUG=1
@0,039,804us: [+6 T:0x00004000] CE - Engine_init> CE debugging on (CE_DEBUG=1; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
[DSP] @0x00000252:[T:0x00000000] servers.video_copy.evmDM6467 - main> Welcome to DSP server's main().
TraceUtil_start> note: CE_DEBUG env. var is set, so TraceUtil is not active (unset CE_DEBUG if you need TraceUtil)
CEapp-> Allocating contiguous buffer for 'input data' of size 1024...
CEapp-> Allocating contiguous buffer for 'encoded data' of size 1024...
CEapp-> Allocating contiguous buffer for 'output data' of size 1024...
App-> Processing frame 0...
App-> Processing frame 1...
App-> Processing frame 2...
App-> Processing frame 3...
App-> Finished encoding and decoding 4 frames
App-> Application finished successfully.
# Success, CE_DEBUG=2
@0,178,358us: [+4 T:0x00004000] OG - Global_init> This program was built with the following packages:
@0,178,662us: [+4 T:0x00004000] OG - package gnu.targets.rts470MV (/opt/dvsdk_1_40_02_33/xdc_3_00_06/packages/gnu/targets/rts470MV/) [1,0,0,0,1203621000516]
@0,178,805us: [+4 T:0x00004000] OG - package ti.xdais.dm (/opt/dvsdk_1_40_02_33/xdais_6_10_01/packages/ti/xdais/dm/) [1,0,4,1210262746529]
@0,178,928us: [+4 T:0x00004000] OG - package ti.xdais (/opt/dvsdk_1_40_02_33/xdais_6_10_01/packages/ti/xdais/) [1,2,1,1210262742149]
@0,179,066us: [+4 T:0x00004000] OG - package ti.sdo.utils.trace (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/utils/trace/) [1,0,0,1220943366422]
@0,179,202us: [+4 T:0x00004000] OG - package ti.sdo.ce.utils.xdm (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/utils/xdm/) [1,0,1,1220951322616]
@0,179,332us: [+4 T:0x00004000] OG - package ti.sdo.fc.dman3 (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/fc/dman3/) [1,0,3,1220943053023]
@0,179,461us: [+4 T:0x00004000] OG - package ti.sdo.fc.acpy3 (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/fc/acpy3/) [1,0,2,1220943014135]
@0,179,588us: [+4 T:0x00004000] OG - package dsplink.gpp (/opt/dvsdk_1_40_02_33/dsplink-davinci-v1.50-prebuilt/packages/dsplink/gpp/) [3,0,0]
@0,179,707us: [+4 T:0x00004000] OG - package ti.sdo.linuxutils.cmem (/opt/dvsdk_1_40_02_33/cmem_2_10/packages/ti/sdo/linuxutils/cmem/) [2,0,1,1204929560755]
@0,179,833us: [+4 T:0x00004000] OG - package ti.catalog.c470 (/opt/dvsdk_1_40_02_33/xdc_3_00_06/packages/ti/catalog/c470/) [1,0,1,0,1203561761475]
@0,179,954us: [+4 T:0x00004000] OG - package ti.catalog.c6000 (/opt/dvsdk_1_40_02_33/xdc_3_00_06/packages/ti/catalog/c6000/) [1,0,0,0,1203561781695]
@0,180,479us: [+4 T:0x00004000] OG - package ti.platforms.evmDM6467 (/opt/dvsdk_1_40_02_33/bios_5_32_01/packages/ti/platforms/evmDM6467/) [1,0,0,0,1192229633217]
@0,180,660us: [+4 T:0x00004000] OG - package ti.sdo.ce.osal (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/osal/) [2,0,2,1220951127739]
@0,180,797us: [+4 T:0x00004000] OG - package ti.sdo.ce.ipc (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/) [2,0,1,1220951085787]
@0,180,923us: [+4 T:0x00004000] OG - package ti.sdo.ce.alg (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/alg/) [1,0,1,1220950781938]
@0,181,047us: [+4 T:0x00004000] OG - package ti.sdo.ce.osal.linux (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/osal/linux/) [2,0,1,1220951140072]
@0,181,177us: [+4 T:0x00004000] OG - package ti.sdo.ce.ipc.dsplink (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/dsplink/) [2,0,1,1220951096818]
@0,181,307us: [+4 T:0x00004000] OG - package ti.sdo.ce (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/) [1,0,6,1220950771473]
@0,181,426us: [+4 T:0x00004000] OG - package ti.sdo.ce.video (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/video/) [1,0,3,1220951334122]
@0,181,549us: [+4 T:0x00004000] OG - package ti.codecs.viddec_copy (/home/xn/nfs/opt/video_copy/ti/codecs/viddec_copy/) []
@0,181,659us: [+4 T:0x00004000] OG - package ti.codecs.videnc_copy (/home/xn/nfs/opt/video_copy/ti/codecs/videnc_copy/) []
@0,181,768us: [+4 T:0x00004000] OG - package ti.sdo.ce.bioslog (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/bioslog/) [1,0,1,1220950800329]
@0,181,893us: [+4 T:0x00004000] OG - package ti.sdo.ce.utils.trace (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/utils/trace/) [1,0,1,1220951317087]
@0,182,021us: [+4 T:0x00004000] OG - package ti.apps.video_copy (/home/xn/nfs/opt/video_copy/ti/apps/video_copy/) []
@0,182,576us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0,182,725us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x3f508]
@0,182,839us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0,182,939us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x3f520]
@0,183,050us: [+0 T:0x00004000] OT - Thread_create> Enter (fxn=0x14464, attrs=0x0)
@0,382,366us: [+0 T:0x00004000] OT - Thread_create> Exit (task=0x3f558)
@0,382,547us: [+0 T:0x00004000] ti.sdo.ce.alg - ALG_init> Enter
@0,382,655us: [+0 T:0x00004000] ti.sdo.ce.alg - ALG_init> Exit
@0,382,832us: [+6 T:0x00004000] CE - Engine_init> CE debugging on (CE_DEBUG=2; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
@0,383,030us: [+0 T:0x00004000] CS - Server_init()
@0,383,127us: [+0 T:0x00004000] CS - Server_init> Global_useLinkArbiter = 0
@0,383,362us: [+0 T:0x00004000] CE - Engine_open> Enter('video_copy', 0x0, 0xbefffd64)
@0,383,528us: [+0 T:0x00004000] CE - rserverOpen('video_copy.x64P'), count = 0
@0,383,662us: [+0 T:0x00004000] OP - Processor_create> Enter(imageName='video_copy.x64P', linkCfg='(null)', attrs=0xbefffd68)
@0,383,856us: [+0 T:0x00004000] OP - doCmd> Enter (cmdId=1, proc=0x417c0)
@0,383,972us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f508]
@0,384,092us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f508]
@0,384,201us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f520] timeout[0xffffffff]
@0,384,525us: [+1 T:0x00004002] OP - daemon> thread created.
@0,384,645us: [+0 T:0x00004002] OP - getCmd_d> Enter (proc=0xbe7ffaec)
@0,384,746us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f508] timeout[0xffffffff]
@0,384,858us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f508] status[0]
@0,384,961us: [+0 T:0x00004002] OP - getCmd_d> Exit (result=1)
@0,385,073us: [+0 T:0x00004002] OP - Processor_create_d> Enter(proc=0x417c0)
@0,385,170us: [+2 T:0x00004002] OP - Processor_create_d> Initializing DSP PROC...
@0,385,271us: [+2 T:0x00004002] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'video_copy.x64P']
@0,385,423us: [+2 T:0x00004002] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, shared=1
@0,385,585us: [+2 T:0x00004002] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x100000, shared=1
@0,385,736us: [+2 T:0x00004002] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x8ff00000, sizeInBytes=0x80, shared=0
@0,385,883us: [+2 T:0x00004002] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x88000000, sizeInBytes=0x7a00000, shared=0
@0,386,029us: [+2 T:0x00004002] OP - Processor_create_d> DOPOWERCONTROL was=0; now=0
@0,387,817us: [+2 T:0x00004002] OP - Processor_create_d> Attaching to DSP PROC...
@0,395,481us: [+2 T:0x00004002] OP - Processor_create_d> Opening MSGQ pool...
@0,395,875us: [+2 T:0x00004002] OP - Processor_create_d> Loading video_copy.x64P on DSP (1 args)...
@0,417,071us: [+2 T:0x00004002] OP - Processor_create_d> Starting DSP PROC...
@0,426,600us: [+2 T:0x00004002] OP - Processor_create_d> Opening remote transport...
@0,427,006us: [+2 T:0x00004002] OP - Processor_create_d> return (1)
@0,427,136us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f520]
@0,427,297us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f520] status[0]
@0,427,422us: [+0 T:0x00004000] OP - doCmd> Exit (result=1)
@0,427,511us: [+0 T:0x00004000] OP - Processor_create> return (0x417c0)
@0,427,604us: [+0 T:0x00004000] CE - rserverOpen('video_copy.x64P'): 0x3e60c done.
@0,431,881us: [+0 T:0x00004000] CE - checkServer(0x41790)
@0,432,146us: [+0 T:0x00004000] CE - rmsInit> RMS initialized(0x41790); CE_DEBUG on, setting DSP trace mask to *+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3
@0,432,325us: [+0 T:0x00004000] CE - Engine_setTrace> Enter(engine=0x41790, mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3')
@0,432,483us: [+1 T:0x00004000] CE - Engine_setTrace> Requesting DSP set trace ...
@0,432,641us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f520]
@0,432,764us: [+0 T:0x00004002] OP - getCmd_d> Enter (proc=0xbe7ffaec)
@0,432,864us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f508] timeout[0xffffffff]
@0,437,653us: [+0 T:0x00004000] CE - Engine_setTrace> return(0)
[DSP] @0x00000251:[T:0x00000000] servers.video_copy.evmDM6467 - main> Welcome to DSP server's main().
[DSP] @0,023,802tk: [+0 T:0x8fa4578c] OG - Global_setSpecialTrace> enter(mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3')
[DSP] @0,024,528tk: [+4 T:0x8fa4578c] OG - Global_setSpecialTrace> This program was built with the following packages:
[DSP] @0,025,012tk: [+4 T:0x8fa4578c] OG - package ti.targets.rts6000 (/opt/dvsdk_1_40_02_33/xdc_3_00_06/packages/ti/targets/rts6000/) [1,0,0,0,1203621186754]
[DSP] @0,025,661tk: [+4 T:0x8fa4578c] OG - package ti.sdo.fc.dman3 (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/fc/dman3/) [1,0,3,1220943053023]
[DSP] @0,026,338tk: [+4 T:0x8fa4578c] OG - package ti.rtdx (/opt/dvsdk_1_40_02_33/bios_5_32_01/packages/ti/rtdx/) [2,0,0,1,1194024051755]
[DSP] @0,026,926tk: [+4 T:0x8fa4578c] OG - package ti.psl (/opt/dvsdk_1_40_02_33/bios_5_32_01/packages/ti/psl/) [5,0,0,0,0]
[DSP] @0,027,446tk: [+4 T:0x8fa4578c] OG - package ti.bios (/opt/dvsdk_1_40_02_33/bios_5_32_01/packages/ti/bios/) [5,2,4,9,1193960176642]
[DSP] @0,028,013tk: [+4 T:0x8fa4578c] OG - package ti.sdo.fc.dskt2 (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/fc/dskt2/) [1,0,4,1220943095081]
[DSP] @0,028,688tk: [+4 T:0x8fa4578c] OG - package ti.xdais.dm (/opt/dvsdk_1_40_02_33/xdais_6_10_01/packages/ti/xdais/dm/) [1,0,4,1210262746529]
[DSP] @0,029,298tk: [+4 T:0x8fa4578c] OG - package ti.xdais (/opt/dvsdk_1_40_02_33/xdais_6_10_01/packages/ti/xdais/) [1,2,1,1210262742149]
[DSP] @0,029,870tk: [+4 T:0x8fa4578c] OG - package ti.sdo.ce.node (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/node/) [1,0,0,1220951122176]
[DSP] @0,030,508tk: [+4 T:0x8fa4578c] OG - package ti.sdo.ce.ipc.dsplink.dsp (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2,0,1,1220951102696]
[DSP] @0,031,247tk: [+4 T:0x8fa4578c] OG - package ti.sdo.utils.trace (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/utils/trace/) [1,0,0,1220943366422]
[DSP] @0,031,947tk: [+4 T:0x8fa4578c] OG - package ti.sdo.ce.utils.xdm (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/utils/xdm/) [1,0,1,1220951322616]
[DSP] @0,032,624tk: [+4 T:0x8fa4578c] OG - package ti.sdo.fc.acpy3 (/opt/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/fc/acpy3/) [1,0,2,1220943014135]
[DSP] @0,033,301tk: [+4 T:0x8fa4578c] OG - package dsplink.dsp (/opt/dvsdk_1_40_02_33/dsplink-davinci-v1.50-prebuilt/packages/dsplink/dsp/) [1,3,0]
[DSP] @0,033,927tk: [+4 T:0x8fa4578c] OG - package ti.bios.utils (/opt/dvsdk_1_40_02_33/biosutils_1_01_00/packages/ti/bios/utils/) [2,0,1,0,1191891830609]
[DSP] @0,034,558tk: [+4 T:0x8fa4578c] OG - package ti.catalog.c6000 (/opt/dvsdk_1_40_02_33/xdc_3_00_06/packages/ti/catalog/c6000/) [1,0,0,0,1203561781695]
[DSP] @0,035,188tk: [+4 T:0x8fa4578c] OG - package ti.platforms.evmDM6467 (/opt/dvsdk_1_40_02_33/bios_5_32_01/packages/ti/platforms/evmDM6467/) [1,0,0,0,1192229633217]
[DSP] @0,035,882tk: [+4 T:0x8fa4578c] OG - package ti.sdo.ce.osal (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/osal/) [2,0,2,1220951127739]
[DSP] @0,036,524tk: [+4 T:0x8fa4578c] OG - package ti.sdo.ce.ipc (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/) [2,0,1,1220951085787]
[DSP] @0,037,158tk: [+4 T:0x8fa4578c] OG - package ti.sdo.ce.alg (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/alg/) [1,0,1,1220950781938]
[DSP] @0,037,790tk: [+4 T:0x8fa4578c] OG - package ti.sdo.ce.osal.bios (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/osal/bios/) [2,0,1,1220951133740]
[DSP] @0,038,485tk: [+4 T:0x8fa4578c] OG - package ti.sdo.ce.ipc.bios (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/bios/) [2,0,1,1220951091097]
[DSP] @0,039,156tk: [+4 T:0x8fa4578c] OG - package ti.sdo.ce (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/) [1,0,6,1220950771473]
[DSP] @0,039,761tk: [+4 T:0x8fa4578c] OG - package ti.sdo.ce.bioslog (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/bioslog/) [1,0,1,1220950800329]
[DSP] @0,040,423tk: [+4 T:0x8fa4578c] OG - package ti.sdo.ce.video (/opt/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/video/) [1,0,3,1220951334122]
[DSP] @0,041,089tk: [+4 T:0x8fa4578c] OG - package ti.codecs.viddec_copy (/home/xn/nfs/opt/video_copy/ti/codecs/viddec_copy/) []
[DSP] @0,041,624tk: [+4 T:0x8fa4578c] OG - package ti.codecs.videnc_copy (/home/xn/nfs/opt/video_copy/ti/codecs/videnc_copy/) []
[DSP] @0,042,160tk: [+4 T:0x8fa4578c] OG - package ti.servers.video_copy (/home/xn/nfs/opt/video_copy/ti/servers/video_copy/) []
[DSP] @0,042,694tk: [+0 T:0x8fa4578c] OG - Global_setSpecialTrace> return
@0,846,134us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [4882]
@0,846,247us: [+0 T:0x00004000] CE - Engine_open> return(268176)
@0,846,471us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_create> Enter (engine=0x41790, name='videnc_copy', params=0x0)
@0,846,632us: [+0 T:0x00004000] CV - VISA_create(0x41790, 'videnc_copy', 0x0, 0x828, 'ti.sdo.ce.video.IVIDENC')
@0,846,759us: [+0 T:0x00004000] CV - VISA_create2(0x41790, 'videnc_copy', 0x0, 0x0, 0x828, 'ti.sdo.ce.video.IVIDENC')
@0,846,902us: [+0 T:0x00004000] CE - Engine_createNode(0x41790, 'videnc_copy', 828, 0x0, 0x0, 0xbefffd68)
@0,850,162us: [+4 T:0x00004000] CE - Engine_createNode> created node(stdIn=0x2, stdOut=0x10001, msgq=0x41aa0, algName='videnc_copy', rmsNode=0x8fa46678, algHandle=0x8fa46758)
[DSP] @1,643,545tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0x18)
[DSP] @1,643,909tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa46678)
[DSP] @1,644,250tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0xe)
[DSP] @1,644,566tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa46690)
[DSP] @1,644,911tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0x20)
[DSP] @1,645,233tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa466a0)
[DSP] @1,645,569tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0x24)
[DSP] @1,645,889tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa466c0)
[DSP] @1,646,283tk: [+0 T:0x8fa4578c] ti.sdo.ce.video.VIDENC - VIDENC_create> Enter (engine=0x0, name='videnc_copy', params=0x0)
[DSP] @1,646,832tk: [+0 T:0x8fa4578c] CV - VISA_create(0x0, 'videnc_copy', 0x0, 0x828, 'ti.sdo.ce.video.IVIDENC')
[DSP] @1,647,331tk: [+0 T:0x8fa4578c] CV - VISA_create2(0x0, 'videnc_copy', 0x0, 0x0, 0x828, 'ti.sdo.ce.video.IVIDENC')
[DSP] @1,647,868tk: [+0 T:0x8fa4578c] CE - Engine_open> Enter('local', 0x8fa45c8c, 0x33c)
[DSP] @1,648,265tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0x2c)
[DSP] @1,648,630tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa46728)
[DSP] @1,648,978tk: [+0 T:0x8fa4578c] CE - Engine_open> return(-1885051096)
[DSP] @1,649,327tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0x30)
[DSP] @1,649,653tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa46758)
[DSP] @1,649,990tk: [+0 T:0x8fa4578c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8fa6eb74, idma3Fxns=0x0, params=0x0, attrs=0x8fa45da0)
[DSP] @1,650,616tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0x10)
[DSP] @1,650,956tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa46788)
[DSP] @1,651,373tk: [+0 T:0x8fa4578c] ti.codecs.videnc_copy - VIDENCCOPY_TI_alloc(0x0, 0x8fa45c48, 0x8fa46b08)
[DSP] @1,651,896tk: [+0 T:0x8fa4578c] ti.codecs.videnc_copy - VIDENCCOPY_TI_initObj(0x88000250, 0x8fa46b08, 0x0, 0x0)
[DSP] @1,652,410tk: [+0 T:0x8fa4578c] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x8fa46788)
[DSP] @1,652,838tk: [+0 T:0x8fa4578c] ti.sdo.ce.video.VIDENC - VIDENC_create> return (0x8fa46758)
[DSP] @1,653,291tk: [+4 T:0x8fa4578c] OT - Thread_create > name: "videnc_copy#0", pri: -1, stack size: 9216, stack seg: 0
@0,856,130us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [2288]
@0,856,241us: [+2 T:0x00004000] CE - Engine_createNode> Returning 0x419e0
@0,856,390us: [+5 T:0x00004000] CV - VISA_create> remote codec created (name='videnc_copy', localQueueID=0x10001, remoteQueueID=0x0002)
@0,856,534us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_create> return (0x41a68)
@0,856,662us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_create> Enter (engine=0x41790, name='viddec_copy', params=0x0)
@1,054,931us: [+0 T:0x00004000] CV - VISA_create(0x41790, 'viddec_copy', 0x0, 0x836, 'ti.sdo.ce.video.IVIDDEC')
@1,055,069us: [+0 T:0x00004000] CV - VISA_create2(0x41790, 'viddec_copy', 0x0, 0x0, 0x836, 'ti.sdo.ce.video.IVIDDEC')
@1,055,220us: [+0 T:0x00004000] CE - Engine_createNode(0x41790, 'viddec_copy', 836, 0x0, 0x0, 0xbefffd68)
@1,058,048us: [+4 T:0x00004000] CE - Engine_createNode> created node(stdIn=0x3, stdOut=0x10002, msgq=0x41b50, algName='viddec_copy', rmsNode=0x8fa48ff8, algHandle=0x8fa49090)
[DSP] @2,457,249tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0x18)
[DSP] @2,457,585tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa48ff8)
[DSP] @2,457,921tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0xe)
[DSP] @2,458,237tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa49010)
[DSP] @2,458,602tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0x20)
[DSP] @2,458,923tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa49020)
[DSP] @2,459,259tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0x24)
[DSP] @2,459,579tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa49040)
[DSP] @2,459,958tk: [+0 T:0x8fa4578c] ti.sdo.ce.video.VIDDEC - VIDDEC_create> Enter (engine=0x0, name='viddec_copy', params=0x0)
[DSP] @2,460,493tk: [+0 T:0x8fa4578c] CV - VISA_create(0x0, 'viddec_copy', 0x0, 0x836, 'ti.sdo.ce.video.IVIDDEC')
[DSP] @2,461,038tk: [+0 T:0x8fa4578c] CV - VISA_create2(0x0, 'viddec_copy', 0x0, 0x0, 0x836, 'ti.sdo.ce.video.IVIDDEC')
[DSP] @2,461,587tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0x30)
[DSP] @2,461,914tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa49090)
[DSP] @2,462,251tk: [+0 T:0x8fa4578c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8fa6eb1c, idma3Fxns=0x0, params=0x0, attrs=0x8fa45da0)
[DSP] @2,462,875tk: [+0 T:0x8fa4578c] OM - Memory_alloc> Enter(size=0x10)
[DSP] @2,463,216tk: [+0 T:0x8fa4578c] OM - Memory_alloc> return (0x8fa490c0)
[DSP] @2,463,598tk: [+0 T:0x8fa4578c] ti.codecs.viddec_copy - VIDDECCOPY_TI_alloc(0x0, 0x8fa490d0, 0x0)
[DSP] @2,464,080tk: [+0 T:0x8fa4578c] ti.codecs.viddec_copy - VIDDECCOPY_TI_initObj(0x88000258, 0x0, 0x0, 0x8fa76cd0)
[DSP] @2,464,594tk: [+0 T:0x8fa4578c] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x8fa490c0)
[DSP] @2,465,021tk: [+0 T:0x8fa4578c] ti.sdo.ce.video.VIDDEC - VIDDEC_create> return (0x8fa49090)
[DSP] @2,465,478tk: [+4 T:0x8fa4578c] OT - Thread_create > name: "viddec_copy#1", pri: -1, stack size: 9216, stack seg: 0
@1,063,285us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [1964]
@1,063,399us: [+2 T:0x00004000] CE - Engine_createNode> Returning 0x41b28
@1,063,546us: [+5 T:0x00004000] CV - VISA_create> remote codec created (name='viddec_copy', localQueueID=0x10002, remoteQueueID=0x0003)
@1,063,692us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_create> return (0x41af0)
@1,063,948us: [+4 T:0x00004000] OM - Memory_contigAlloc> CMEM_alloc(1024) = 0x4001c000.
@1,064,077us: [+4 T:0x00004000] OM - Memory_contigAlloc> CMEM_getPhys(0x4001c000) = 0x87fff000.
@1,064,323us: [+4 T:0x00004000] OM - Memory_contigAlloc> CMEM_alloc(1024) = 0x4001d000.
@1,064,452us: [+4 T:0x00004000] OM - Memory_contigAlloc> CMEM_getPhys(0x4001d000) = 0x87ffe000.
@1,064,704us: [+4 T:0x00004000] OM - Memory_contigAlloc> CMEM_alloc(1024) = 0x401fe000.
@1,064,834us: [+4 T:0x00004000] OM - Memory_contigAlloc> CMEM_getPhys(0x401fe000) = 0x87ffd000.
@1,064,984us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_control> Enter (handle=0x41a68, id=0, params=0xbefffd80, status=0xbefffcf0
@1,065,161us: [+5 T:0x00004000] CV - VISA_allocMsg> Allocating message for messageId=0x00020008
@1,065,281us: [+0 T:0x00004000] CV - VISA_call(visa=0x41a68, msg=0x4018f880): messageId=0x00020008, command=0x1
[DSP] @2,495,631tk: [+5 T:0x8fa46ba4] CN - NODE> 0x8fa466a0(videnc_copy#0) call(algHandle=0x8fa46758, msg=0x8fe04880); messageId=0x00020008
[DSP] @2,496,249tk: [+0 T:0x8fa46ba4] ti.sdo.ce.video.VIDENC - VIDENC_control> Enter (handle=0x8fa46758, id=0, params=0x8fe048b4, status=0x8fe048dc
[DSP] @2,496,900tk: [+5 T:0x8fa46ba4] CV - VISA_enter(visa=0x8fa46758): algHandle = 0x8fa46788
[DSP] @2,497,317tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(handle=0x8fa46788)
[DSP] @2,497,805tk: [+0 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_activate(0x88000250)
[DSP] @2,498,214tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> return
[DSP] @2,498,602tk: [+0 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_control(0x88000250, 0x0, 0x8fe048b4, 0x8fe048dc)
[DSP] @2,499,150tk: [+5 T:0x8fa46ba4] CV - VISA_exit(visa=0x8fa46758): algHandle = 0x8fa46788
[DSP] @2,499,562tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(handle=0x8fa46788)
[DSP] @2,500,045tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> return
[DSP] @2,500,443tk: [+0 T:0x8fa46ba4] ti.sdo.ce.video.VIDENC - VIDENC_control> Exit (handle=0x8fa46758, retVal=0x0)
[DSP] @2,500,934tk: [+5 T:0x8fa46ba4] CN - NODE> returned from call(algHandle=0x8fa46758, msg=0x8fe04880); messageId=0x00020008
@1,268,977us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [1347]
@1,269,087us: [+0 T:0x00004000] CV - VISA_call Completed: messageId=0x00020008, command=0x1, return(status=0)
@1,269,206us: [+5 T:0x00004000] CV - VISA_freeMsg(0x41a68, 0x4018f880): Freeing message with messageId=0x00020008
@1,269,342us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_control> Exit (handle=0x41a68, retVal=0x0)
@1,269,456us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_control> Enter (handle=0x41af0, id=0, params=0xbefffda8, status=0xbefffc48
@1,269,590us: [+5 T:0x00004000] CV - VISA_allocMsg> Allocating message for messageId=0x00030013
@1,269,697us: [+0 T:0x00004000] CV - VISA_call(visa=0x41af0, msg=0x40190880): messageId=0x00030013, command=0x1
[DSP] @3,294,121tk: [+5 T:0x8fa4916c] CN - NODE> 0x8fa49020(viddec_copy#1) call(algHandle=0x8fa49090, msg=0x8fe05880); messageId=0x00030013
[DSP] @3,294,738tk: [+0 T:0x8fa4916c] ti.sdo.ce.video.VIDDEC - VIDDEC_control> Enter (handle=0x8fa49090, id=0, params=0x8fe058b4, status=0x8fe058c4
[DSP] @3,295,367tk: [+5 T:0x8fa4916c] CV - VISA_enter(visa=0x8fa49090): algHandle = 0x8fa490c0
[DSP] @3,295,786tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(handle=0x8fa490c0)
[DSP] @3,296,272tk: [+0 T:0x8fa4916c] ti.codecs.videnc_copy - VIDENCCOPY_TI_deactivate(0x88000250)
[DSP] @3,296,685tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_activate> return
[DSP] @3,297,069tk: [+0 T:0x8fa4916c] ti.codecs.viddec_copy - VIDDECCOPY_TI_control(0x88000258, 0x8fe058b4, 0xffffffff, 0x1)
[DSP] @3,297,610tk: [+5 T:0x8fa4916c] CV - VISA_exit(visa=0x8fa49090): algHandle = 0x8fa490c0
[DSP] @3,298,021tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(handle=0x8fa490c0)
[DSP] @3,298,505tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> return
[DSP] @3,298,895tk: [+0 T:0x8fa4916c] ti.sdo.ce.video.VIDDEC - VIDDEC_control> Exit (handle=0x8fa49090, retVal=0x0)
[DSP] @3,299,382tk: [+5 T:0x8fa4916c] CN - NODE> returned from call(algHandle=0x8fa49090, msg=0x8fe05880); messageId=0x00030013
@1,274,874us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [1349]
@1,274,983us: [+0 T:0x00004000] CV - VISA_call Completed: messageId=0x00030013, command=0x1, return(status=0)
@1,275,102us: [+5 T:0x00004000] CV - VISA_freeMsg(0x41af0, 0x40190880): Freeing message with messageId=0x00030013
@1,275,218us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_control> Exit (handle=0x41af0, retVal=0x0)
@1,275,330us: [+5 T:0x00004000] OM - Memory_dumpKnownContigBufsList> following buffers were translated/registered:
@1,275,436us: [+5 T:0x00004000] OM - [ virt: 0x401fe000, size: 00001024, phys: 0x87ffd000 ]
@1,473,690us: [+5 T:0x00004000] OM - [ virt: 0x4001d000, size: 00001024, phys: 0x87ffe000 ]
@1,473,815us: [+5 T:0x00004000] OM - [ virt: 0x4001c000, size: 00001024, phys: 0x87fff000 ]
@1,474,147us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_process> Enter (handle=0x41a68, inBufs=0xbefffdb0, outBufs=0xbefffda0, inArgs=0xbefffbfc, outArgs=0xbefffd00)
@1,474,313us: [+5 T:0x00004000] CV - VISA_allocMsg> Allocating message for messageId=0x00020009
@1,474,431us: [+0 T:0x00004000] CV - VISA_call(visa=0x41a68, msg=0x4018f880): messageId=0x00020009, command=0x0
[DSP] @4,093,871tk: [+5 T:0x8fa46ba4] CN - NODE> 0x8fa466a0(videnc_copy#0) call(algHandle=0x8fa46758, msg=0x8fe04880); messageId=0x00020009
[DSP] @4,094,504tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> Enter(addr=0x87fff000, sizeInBytes=1024)
[DSP] @4,094,933tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> return
[DSP] @4,095,221tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> Enter(addr=0x87ffe000, sizeInBytes=1024)
[DSP] @4,095,648tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> return
[DSP] @4,095,940tk: [+0 T:0x8fa46ba4] ti.sdo.ce.video.VIDENC - VIDENC_process> Enter (handle=0x8fa46758, inBufs=0x8fa48f74, outBufs=0x8fa48f80, inArgs=0x8fe049b8, outArgs=0x8fe049bc)
[DSP] @4,096,739tk: [+5 T:0x8fa46ba4] CV - VISA_enter(visa=0x8fa46758): algHandle = 0x8fa46788
[DSP] @4,097,158tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(handle=0x8fa46788)
[DSP] @4,097,615tk: [+0 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_activate(0x88000250)
[DSP] @4,098,024tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> return
[DSP] @4,098,410tk: [+0 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_process(0x88000250, 0x8fa48f74, 0x8fa48f80, 0x8fe049b8, 0x8fe049bc)
[DSP] @4,099,087tk: [+2 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_process> memcpy (0x87ffe000, 0x87fff000, 1024)
[DSP] @4,099,666tk: [+5 T:0x8fa46ba4] CV - VISA_exit(visa=0x8fa46758): algHandle = 0x8fa46788
[DSP] @4,100,079tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(handle=0x8fa46788)
[DSP] @4,100,543tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> return
[DSP] @4,100,934tk: [+0 T:0x8fa46ba4] ti.sdo.ce.video.VIDENC - VIDENC_process> Exit (handle=0x8fa46758, retVal=0x0)
[DSP] @4,101,450tk: [+0 T:0x8fa46ba4] OM - Memory_cacheWb> Enter(addr=0x87ffe000, sizeInBytes=1024)
[DSP] @4,101,875tk: [+0 T:0x8fa46ba4] OM - Memory_cacheWb> return
[DSP] @4,102,163tk: [+5 T:0x8fa46ba4] CN - NODE> returned from call(algHandle=0x8fa46758, msg=0x8fe04880); messageId=0x00020009
@1,482,111us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [2026]
@1,482,222us: [+0 T:0x00004000] CV - VISA_call Completed: messageId=0x00020009, command=0x0, return(status=0)
@1,482,348us: [+5 T:0x00004000] CV - VISA_freeMsg(0x41a68, 0x4018f880): Freeing message with messageId=0x00020009
@1,482,467us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_process> Exit (handle=0x41a68, retVal=0x0)
@1,482,580us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Enter (handle=0x41af0, inBufs=0xbefffdb0, outBufs=0xbefffda0, inArgs=0xbefffd90, outArgs=0xbefffcf0)
@1,482,733us: [+5 T:0x00004000] CV - VISA_allocMsg> Allocating message for messageId=0x00030014
@1,482,843us: [+0 T:0x00004000] CV - VISA_call(visa=0x41af0, msg=0x40190880): messageId=0x00030014, command=0x0
[DSP] @4,126,720tk: [+5 T:0x8fa4916c] CN - NODE> 0x8fa49020(viddec_copy#1) call(algHandle=0x8fa49090, msg=0x8fe05880); messageId=0x00030014
[DSP] @4,127,336tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> Enter(addr=0x87ffe000, sizeInBytes=1024)
[DSP] @4,127,768tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> return
[DSP] @4,128,058tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> Enter(addr=0x87ffd000, sizeInBytes=1024)
[DSP] @4,128,486tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> return
[DSP] @4,128,779tk: [+0 T:0x8fa4916c] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Enter (handle=0x8fa49090, inBufs=0x8fa4b53c, outBufs=0x8fa4b548, inArgs=0x8fe059b8, outArgs=0x8fe059c4)
[DSP] @4,129,571tk: [+5 T:0x8fa4916c] CV - VISA_enter(visa=0x8fa49090): algHandle = 0x8fa490c0
[DSP] @4,129,990tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(handle=0x8fa490c0)
[DSP] @4,130,446tk: [+0 T:0x8fa4916c] ti.codecs.videnc_copy - VIDENCCOPY_TI_deactivate(0x88000250)
[DSP] @4,130,859tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_activate> return
[DSP] @4,131,270tk: [+0 T:0x8fa4916c] ti.codecs.viddec_copy - VIDDECCOPY_TI_process(0x88000258, 0x8fa4b548, 0x8fe059c4, 0x1, 0x1)
[DSP] @4,131,861tk: [+2 T:0x8fa4916c] ti.codecs.viddec_copy - VIDDECCOPY_TI_process> Processed 1024 bytes.
[DSP] @4,132,304tk: [+5 T:0x8fa4916c] CV - VISA_exit(visa=0x8fa49090): algHandle = 0x8fa490c0
[DSP] @4,132,716tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(handle=0x8fa490c0)
[DSP] @4,133,178tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> return
[DSP] @4,133,587tk: [+0 T:0x8fa4916c] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Exit (handle=0x8fa49090, retVal=0x0)
[DSP] @4,134,078tk: [+0 T:0x8fa4916c] OM - Memory_cacheWb> Enter(addr=0x87ffd000, sizeInBytes=1024)
[DSP] @4,134,505tk: [+0 T:0x8fa4916c] OM - Memory_cacheWb> return
[DSP] @4,134,792tk: [+5 T:0x8fa4916c] CN - NODE> returned from call(algHandle=0x8fa49090, msg=0x8fe05880); messageId=0x00030014
@1,689,686us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [1998]
@1,689,799us: [+0 T:0x00004000] CV - VISA_call Completed: messageId=0x00030014, command=0x0, return(status=0)
@1,689,924us: [+5 T:0x00004000] CV - VISA_freeMsg(0x41af0, 0x40190880): Freeing message with messageId=0x00030014
@1,690,088us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Exit (handle=0x41af0, retVal=0x0)
@1,690,449us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_process> Enter (handle=0x41a68, inBufs=0xbefffdb0, outBufs=0xbefffda0, inArgs=0xbefffbfc, outArgs=0xbefffd00)
@1,690,617us: [+5 T:0x00004000] CV - VISA_allocMsg> Allocating message for messageId=0x0002000a
@1,690,734us: [+0 T:0x00004000] CV - VISA_call(visa=0x41a68, msg=0x4018f880): messageId=0x0002000a, command=0x0
[DSP] @4,938,823tk: [+5 T:0x8fa46ba4] CN - NODE> 0x8fa466a0(videnc_copy#0) call(algHandle=0x8fa46758, msg=0x8fe04880); messageId=0x0002000a
[DSP] @4,939,431tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> Enter(addr=0x87fff000, sizeInBytes=1024)
[DSP] @4,939,860tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> return
[DSP] @4,940,150tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> Enter(addr=0x87ffe000, sizeInBytes=1024)
[DSP] @4,940,581tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> return
[DSP] @4,940,873tk: [+0 T:0x8fa46ba4] ti.sdo.ce.video.VIDENC - VIDENC_process> Enter (handle=0x8fa46758, inBufs=0x8fa48f74, outBufs=0x8fa48f80, inArgs=0x8fe049b8, outArgs=0x8fe049bc)
[DSP] @4,941,667tk: [+5 T:0x8fa46ba4] CV - VISA_enter(visa=0x8fa46758): algHandle = 0x8fa46788
[DSP] @4,942,084tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(handle=0x8fa46788)
[DSP] @4,942,542tk: [+0 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_activate(0x88000250)
[DSP] @4,942,951tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> return
[DSP] @4,943,358tk: [+0 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_process(0x88000250, 0x8fa48f74, 0x8fa48f80, 0x8fe049b8, 0x8fe049bc)
[DSP] @4,944,017tk: [+2 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_process> memcpy (0x87ffe000, 0x87fff000, 1024)
[DSP] @4,944,593tk: [+5 T:0x8fa46ba4] CV - VISA_exit(visa=0x8fa46758): algHandle = 0x8fa46788
[DSP] @4,945,008tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(handle=0x8fa46788)
[DSP] @4,945,470tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> return
[DSP] @4,945,883tk: [+0 T:0x8fa46ba4] ti.sdo.ce.video.VIDENC - VIDENC_process> Exit (handle=0x8fa46758, retVal=0x0)
[DSP] @4,946,373tk: [+0 T:0x8fa46ba4] OM - Memory_cacheWb> Enter(addr=0x87ffe000, sizeInBytes=1024)
[DSP] @4,946,799tk: [+0 T:0x8fa46ba4] OM - Memory_cacheWb> return
[DSP] @4,947,087tk: [+5 T:0x8fa46ba4] CN - NODE> returned from call(algHandle=0x8fa46758, msg=0x8fe04880); messageId=0x0002000a
@1,896,229us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [2026]
@1,896,344us: [+0 T:0x00004000] CV - VISA_call Completed: messageId=0x0002000a, command=0x0, return(status=0)
@1,896,470us: [+5 T:0x00004000] CV - VISA_freeMsg(0x41a68, 0x4018f880): Freeing message with messageId=0x0002000a
@1,896,589us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_process> Exit (handle=0x41a68, retVal=0x0)
@1,896,701us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Enter (handle=0x41af0, inBufs=0xbefffdb0, outBufs=0xbefffda0, inArgs=0xbefffd90, outArgs=0xbefffcf0)
@1,896,849us: [+5 T:0x00004000] CV - VISA_allocMsg> Allocating message for messageId=0x00030015
@1,896,961us: [+0 T:0x00004000] CV - VISA_call(visa=0x41af0, msg=0x40190880): messageId=0x00030015, command=0x0
[DSP] @5,744,377tk: [+5 T:0x8fa4916c] CN - NODE> 0x8fa49020(viddec_copy#1) call(algHandle=0x8fa49090, msg=0x8fe05880); messageId=0x00030015
[DSP] @5,744,992tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> Enter(addr=0x87ffe000, sizeInBytes=1024)
[DSP] @5,745,428tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> return
[DSP] @5,745,719tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> Enter(addr=0x87ffd000, sizeInBytes=1024)
[DSP] @5,746,147tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> return
[DSP] @5,746,465tk: [+0 T:0x8fa4916c] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Enter (handle=0x8fa49090, inBufs=0x8fa4b53c, outBufs=0x8fa4b548, inArgs=0x8fe059b8, outArgs=0x8fe059c4)
[DSP] @5,747,230tk: [+5 T:0x8fa4916c] CV - VISA_enter(visa=0x8fa49090): algHandle = 0x8fa490c0
[DSP] @5,747,648tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(handle=0x8fa490c0)
[DSP] @5,748,105tk: [+0 T:0x8fa4916c] ti.codecs.videnc_copy - VIDENCCOPY_TI_deactivate(0x88000250)
[DSP] @5,748,539tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_activate> return
[DSP] @5,748,923tk: [+0 T:0x8fa4916c] ti.codecs.viddec_copy - VIDDECCOPY_TI_process(0x88000258, 0x8fa4b548, 0x8fe059c4, 0x1, 0x1)
[DSP] @5,749,511tk: [+2 T:0x8fa4916c] ti.codecs.viddec_copy - VIDDECCOPY_TI_process> Processed 1024 bytes.
[DSP] @5,749,954tk: [+5 T:0x8fa4916c] CV - VISA_exit(visa=0x8fa49090): algHandle = 0x8fa490c0
[DSP] @5,750,367tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(handle=0x8fa490c0)
[DSP] @5,750,852tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> return
[DSP] @5,751,242tk: [+0 T:0x8fa4916c] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Exit (handle=0x8fa49090, retVal=0x0)
[DSP] @5,751,732tk: [+0 T:0x8fa4916c] OM - Memory_cacheWb> Enter(addr=0x87ffd000, sizeInBytes=1024)
[DSP] @5,752,157tk: [+0 T:0x8fa4916c] OM - Memory_cacheWb> return
[DSP] @5,752,444tk: [+5 T:0x8fa4916c] CN - NODE> returned from call(algHandle=0x8fa49090, msg=0x8fe05880); messageId=0x00030015
@1,904,493us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [1998]
@1,904,604us: [+0 T:0x00004000] CV - VISA_call Completed: messageId=0x00030015, command=0x0, return(status=0)
@1,904,729us: [+5 T:0x00004000] CV - VISA_freeMsg(0x41af0, 0x40190880): Freeing message with messageId=0x00030015
@1,904,846us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Exit (handle=0x41af0, retVal=0x0)
@1,905,067us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_process> Enter (handle=0x41a68, inBufs=0xbefffdb0, outBufs=0xbefffda0, inArgs=0xbefffbfc, outArgs=0xbefffd00)
@1,905,222us: [+5 T:0x00004000] CV - VISA_allocMsg> Allocating message for messageId=0x0002000b
@1,905,333us: [+0 T:0x00004000] CV - VISA_call(visa=0x41a68, msg=0x4018f880): messageId=0x0002000b, command=0x0
[DSP] @5,777,082tk: [+5 T:0x8fa46ba4] CN - NODE> 0x8fa466a0(videnc_copy#0) call(algHandle=0x8fa46758, msg=0x8fe04880); messageId=0x0002000b
[DSP] @5,777,704tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> Enter(addr=0x87fff000, sizeInBytes=1024)
[DSP] @5,778,132tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> return
[DSP] @5,778,421tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> Enter(addr=0x87ffe000, sizeInBytes=1024)
[DSP] @5,778,883tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> return
[DSP] @5,779,178tk: [+0 T:0x8fa46ba4] ti.sdo.ce.video.VIDENC - VIDENC_process> Enter (handle=0x8fa46758, inBufs=0x8fa48f74, outBufs=0x8fa48f80, inArgs=0x8fe049b8, outArgs=0x8fe049bc)
[DSP] @5,779,940tk: [+5 T:0x8fa46ba4] CV - VISA_enter(visa=0x8fa46758): algHandle = 0x8fa46788
[DSP] @5,780,356tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(handle=0x8fa46788)
[DSP] @5,780,816tk: [+0 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_activate(0x88000250)
[DSP] @5,781,247tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> return
[DSP] @5,781,633tk: [+0 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_process(0x88000250, 0x8fa48f74, 0x8fa48f80, 0x8fe049b8, 0x8fe049bc)
[DSP] @5,782,287tk: [+2 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_process> memcpy (0x87ffe000, 0x87fff000, 1024)
[DSP] @5,782,864tk: [+5 T:0x8fa46ba4] CV - VISA_exit(visa=0x8fa46758): algHandle = 0x8fa46788
[DSP] @5,783,278tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(handle=0x8fa46788)
[DSP] @5,783,765tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> return
[DSP] @5,784,156tk: [+0 T:0x8fa46ba4] ti.sdo.ce.video.VIDENC - VIDENC_process> Exit (handle=0x8fa46758, retVal=0x0)
[DSP] @5,784,646tk: [+0 T:0x8fa46ba4] OM - Memory_cacheWb> Enter(addr=0x87ffe000, sizeInBytes=1024)
[DSP] @5,785,071tk: [+0 T:0x8fa46ba4] OM - Memory_cacheWb> return
[DSP] @5,785,359tk: [+5 T:0x8fa46ba4] CN - NODE> returned from call(algHandle=0x8fa46758, msg=0x8fe04880); messageId=0x0002000b
@2,111,421us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [2026]
@2,111,534us: [+0 T:0x00004000] CV - VISA_call Completed: messageId=0x0002000b, command=0x0, return(status=0)
@2,111,657us: [+5 T:0x00004000] CV - VISA_freeMsg(0x41a68, 0x4018f880): Freeing message with messageId=0x0002000b
@2,111,797us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_process> Exit (handle=0x41a68, retVal=0x0)
@2,111,912us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Enter (handle=0x41af0, inBufs=0xbefffdb0, outBufs=0xbefffda0, inArgs=0xbefffd90, outArgs=0xbefffcf0)
@2,112,064us: [+5 T:0x00004000] CV - VISA_allocMsg> Allocating message for messageId=0x00030016
@2,112,177us: [+0 T:0x00004000] CV - VISA_call(visa=0x41af0, msg=0x40190880): messageId=0x00030016, command=0x0
[DSP] @6,585,074tk: [+5 T:0x8fa4916c] CN - NODE> 0x8fa49020(viddec_copy#1) call(algHandle=0x8fa49090, msg=0x8fe05880); messageId=0x00030016
[DSP] @6,585,690tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> Enter(addr=0x87ffe000, sizeInBytes=1024)
[DSP] @6,586,122tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> return
[DSP] @6,586,435tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> Enter(addr=0x87ffd000, sizeInBytes=1024)
[DSP] @6,586,866tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> return
[DSP] @6,587,159tk: [+0 T:0x8fa4916c] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Enter (handle=0x8fa49090, inBufs=0x8fa4b53c, outBufs=0x8fa4b548, inArgs=0x8fe059b8, outArgs=0x8fe059c4)
[DSP] @6,587,925tk: [+5 T:0x8fa4916c] CV - VISA_enter(visa=0x8fa49090): algHandle = 0x8fa490c0
[DSP] @6,588,343tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(handle=0x8fa490c0)
[DSP] @6,588,825tk: [+0 T:0x8fa4916c] ti.codecs.videnc_copy - VIDENCCOPY_TI_deactivate(0x88000250)
[DSP] @6,589,251tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_activate> return
[DSP] @6,589,633tk: [+0 T:0x8fa4916c] ti.codecs.viddec_copy - VIDDECCOPY_TI_process(0x88000258, 0x8fa4b548, 0x8fe059c4, 0x1, 0x1)
[DSP] @6,590,220tk: [+2 T:0x8fa4916c] ti.codecs.viddec_copy - VIDDECCOPY_TI_process> Processed 1024 bytes.
[DSP] @6,590,662tk: [+5 T:0x8fa4916c] CV - VISA_exit(visa=0x8fa49090): algHandle = 0x8fa490c0
[DSP] @6,591,102tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(handle=0x8fa490c0)
[DSP] @6,591,563tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> return
[DSP] @6,591,952tk: [+0 T:0x8fa4916c] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Exit (handle=0x8fa49090, retVal=0x0)
[DSP] @6,592,442tk: [+0 T:0x8fa4916c] OM - Memory_cacheWb> Enter(addr=0x87ffd000, sizeInBytes=1024)
[DSP] @6,592,868tk: [+0 T:0x8fa4916c] OM - Memory_cacheWb> return
[DSP] @6,593,179tk: [+5 T:0x8fa4916c] CN - NODE> returned from call(algHandle=0x8fa49090, msg=0x8fe05880); messageId=0x00030016
@2,317,678us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [1998]
@2,317,811us: [+0 T:0x00004000] CV - VISA_call Completed: messageId=0x00030016, command=0x0, return(status=0)
@2,317,941us: [+5 T:0x00004000] CV - VISA_freeMsg(0x41af0, 0x40190880): Freeing message with messageId=0x00030016
@2,318,059us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Exit (handle=0x41af0, retVal=0x0)
@2,318,283us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_process> Enter (handle=0x41a68, inBufs=0xbefffdb0, outBufs=0xbefffda0, inArgs=0xbefffbfc, outArgs=0xbefffd00)
@2,318,440us: [+5 T:0x00004000] CV - VISA_allocMsg> Allocating message for messageId=0x0002000c
@2,318,553us: [+0 T:0x00004000] CV - VISA_call(visa=0x41a68, msg=0x4018f880): messageId=0x0002000c, command=0x0
[DSP] @7,391,226tk: [+5 T:0x8fa46ba4] CN - NODE> 0x8fa466a0(videnc_copy#0) call(algHandle=0x8fa46758, msg=0x8fe04880); messageId=0x0002000c
[DSP] @7,391,858tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> Enter(addr=0x87fff000, sizeInBytes=1024)
[DSP] @7,392,287tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> return
[DSP] @7,392,576tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> Enter(addr=0x87ffe000, sizeInBytes=1024)
[DSP] @7,393,002tk: [+0 T:0x8fa46ba4] OM - Memory_cacheInv> return
[DSP] @7,393,294tk: [+0 T:0x8fa46ba4] ti.sdo.ce.video.VIDENC - VIDENC_process> Enter (handle=0x8fa46758, inBufs=0x8fa48f74, outBufs=0x8fa48f80, inArgs=0x8fe049b8, outArgs=0x8fe049bc)
[DSP] @7,394,091tk: [+5 T:0x8fa46ba4] CV - VISA_enter(visa=0x8fa46758): algHandle = 0x8fa46788
[DSP] @7,394,509tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(handle=0x8fa46788)
[DSP] @7,394,967tk: [+0 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_activate(0x88000250)
[DSP] @7,395,376tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> return
[DSP] @7,395,760tk: [+0 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_process(0x88000250, 0x8fa48f74, 0x8fa48f80, 0x8fe049b8, 0x8fe049bc)
[DSP] @7,396,434tk: [+2 T:0x8fa46ba4] ti.codecs.videnc_copy - VIDENCCOPY_TI_process> memcpy (0x87ffe000, 0x87fff000, 1024)
[DSP] @7,397,011tk: [+5 T:0x8fa46ba4] CV - VISA_exit(visa=0x8fa46758): algHandle = 0x8fa46788
[DSP] @7,397,424tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(handle=0x8fa46788)
[DSP] @7,397,886tk: [+0 T:0x8fa46ba4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> return
[DSP] @7,398,303tk: [+0 T:0x8fa46ba4] ti.sdo.ce.video.VIDENC - VIDENC_process> Exit (handle=0x8fa46758, retVal=0x0)
[DSP] @7,398,794tk: [+0 T:0x8fa46ba4] OM - Memory_cacheWb> Enter(addr=0x87ffe000, sizeInBytes=1024)
[DSP] @7,399,220tk: [+0 T:0x8fa46ba4] OM - Memory_cacheWb> return
[DSP] @7,399,508tk: [+5 T:0x8fa46ba4] CN - NODE> returned from call(algHandle=0x8fa46758, msg=0x8fe04880); messageId=0x0002000c
@2,326,191us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [2026]
@2,326,303us: [+0 T:0x00004000] CV - VISA_call Completed: messageId=0x0002000c, command=0x0, return(status=0)
@2,326,429us: [+5 T:0x00004000] CV - VISA_freeMsg(0x41a68, 0x4018f880): Freeing message with messageId=0x0002000c
@2,326,549us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_process> Exit (handle=0x41a68, retVal=0x0)
@2,326,659us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Enter (handle=0x41af0, inBufs=0xbefffdb0, outBufs=0xbefffda0, inArgs=0xbefffd90, outArgs=0xbefffcf0)
@2,525,570us: [+5 T:0x00004000] CV - VISA_allocMsg> Allocating message for messageId=0x00030017
@2,525,708us: [+0 T:0x00004000] CV - VISA_call(visa=0x41af0, msg=0x40190880): messageId=0x00030017, command=0x0
[DSP] @8,200,438tk: [+5 T:0x8fa4916c] CN - NODE> 0x8fa49020(viddec_copy#1) call(algHandle=0x8fa49090, msg=0x8fe05880); messageId=0x00030017
[DSP] @8,201,054tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> Enter(addr=0x87ffe000, sizeInBytes=1024)
[DSP] @8,201,505tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> return
[DSP] @8,201,796tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> Enter(addr=0x87ffd000, sizeInBytes=1024)
[DSP] @8,202,224tk: [+0 T:0x8fa4916c] OM - Memory_cacheInv> return
[DSP] @8,202,518tk: [+0 T:0x8fa4916c] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Enter (handle=0x8fa49090, inBufs=0x8fa4b53c, outBufs=0x8fa4b548, inArgs=0x8fe059b8, outArgs=0x8fe059c4)
[DSP] @8,203,304tk: [+5 T:0x8fa4916c] CV - VISA_enter(visa=0x8fa49090): algHandle = 0x8fa490c0
[DSP] @8,203,763tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(handle=0x8fa490c0)
[DSP] @8,204,247tk: [+0 T:0x8fa4916c] ti.codecs.videnc_copy - VIDENCCOPY_TI_deactivate(0x88000250)
[DSP] @8,204,687tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_activate> return
[DSP] @8,205,092tk: [+0 T:0x8fa4916c] ti.codecs.viddec_copy - VIDDECCOPY_TI_process(0x88000258, 0x8fa4b548, 0x8fe059c4, 0x1, 0x1)
[DSP] @8,205,735tk: [+2 T:0x8fa4916c] ti.codecs.viddec_copy - VIDDECCOPY_TI_process> Processed 1024 bytes.
[DSP] @8,206,207tk: [+5 T:0x8fa4916c] CV - VISA_exit(visa=0x8fa49090): algHandle = 0x8fa490c0
[DSP] @8,206,644tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(handle=0x8fa490c0)
[DSP] @8,207,133tk: [+0 T:0x8fa4916c] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> return
[DSP] @8,207,544tk: [+0 T:0x8fa4916c] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Exit (handle=0x8fa49090, retVal=0x0)
[DSP] @8,208,084tk: [+0 T:0x8fa4916c] OM - Memory_cacheWb> Enter(addr=0x87ffd000, sizeInBytes=1024)
[DSP] @8,208,535tk: [+0 T:0x8fa4916c] OM - Memory_cacheWb> return
[DSP] @8,208,839tk: [+5 T:0x8fa4916c] CN - NODE> returned from call(algHandle=0x8fa49090, msg=0x8fe05880); messageId=0x00030017
@2,533,348us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [1998]
@2,533,458us: [+0 T:0x00004000] CV - VISA_call Completed: messageId=0x00030017, command=0x0, return(status=0)
@2,533,581us: [+5 T:0x00004000] CV - VISA_freeMsg(0x41af0, 0x40190880): Freeing message with messageId=0x00030017
@2,533,699us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_process> Exit (handle=0x41af0, retVal=0x0)
@2,534,218us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_delete> Enter (handle=0x41a68)
@2,534,351us: [+0 T:0x00004000] CV - VISA_delete(0x41a68)
@2,534,441us: [+5 T:0x00004000] CV - VISA_delete> deleting codec (localQueue=0x10001, remoteQueue=0x2)
@2,534,660us: [+0 T:0x00004000] CE - Engine_deleteNode(0x419e0)
@2,536,871us: [+5 T:0x00004000] CE - Engine_deleteNode(0x419e0): algName = videnc_copy, algHandle = 0x8fa46758, stack size = 9216, stack used = 795(9%)
@2,537,268us: [+0 T:0x00004000] ti.sdo.ce.video.VIDENC - VIDENC_delete> return
@2,537,397us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_delete> Enter (handle=0x41af0)
@2,537,506us: [+0 T:0x00004000] CV - VISA_delete(0x41af0)
@2,537,592us: [+5 T:0x00004000] CV - VISA_delete> deleting codec (localQueue=0x10002, remoteQueue=0x3)
@2,537,807us: [+0 T:0x00004000] CE - Engine_deleteNode(0x41b28)
@2,539,983us: [+5 T:0x00004000] CE - Engine_deleteNode(0x41b28): algName = viddec_copy, algHandle = 0x8fa49090, stack size = 9216, stack used = 787(9%)
@2,540,409us: [+0 T:0x00004000] ti.sdo.ce.video.VIDDEC - VIDDEC_delete> return
@2,540,558us: [+0 T:0x00004000] CE - Engine_close(0x41790)
[DSP] @8,234,542tk: [+0 T:0x8fa46ba4] CN - NODE_EXECFXN(0x8fa466a0): videnc_copy#0 exiting per request ...
[DSP] @8,235,677tk: [+0 T:0x8fa4578c] CN - NODE_delete(0x8fa466a0): videnc_copy#0
[DSP] @8,236,111tk: [+0 T:0x8fa4578c] ti.sdo.ce.video.VIDENC - VIDENC_delete> Enter (handle=0x8fa46758)
[DSP] @8,236,570tk: [+0 T:0x8fa4578c] CV - VISA_delete(0x8fa46758)
[DSP] @8,236,910tk: [+5 T:0x8fa4578c] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
[DSP] @8,237,410tk: [+0 T:0x8fa4578c] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(handle=0x8fa46788)
[DSP] @8,237,926tk: [+0 T:0x8fa4578c] OM - Memory_free> Enter(addr=0x8fa46788, size=16)
[DSP] @8,238,359tk: [+0 T:0x8fa4578c] OM - Memory_free> return (0x1)
[DSP] @8,238,684tk: [+0 T:0x8fa4578c] ti.sdo.ce.alg.Algorithm - Algorithm_delete> return
[DSP] @8,239,085tk: [+0 T:0x8fa4578c] OM - Memory_free> Enter(addr=0x8fa46758, size=48)
[DSP] @8,239,490tk: [+0 T:0x8fa4578c] OM - Memory_free> return (0x1)
[DSP] @8,239,812tk: [+0 T:0x8fa4578c] ti.sdo.ce.video.VIDENC - VIDENC_delete> return
[DSP] @8,240,193tk: [+0 T:0x8fa4578c] OM - Memory_free> Enter(addr=0x8fa466c0, size=36)
[DSP] @8,240,619tk: [+0 T:0x8fa4578c] OM - Memory_free> return (0x1)
[DSP] @8,240,941tk: [+0 T:0x8fa4578c] OM - Memory_free> Enter(addr=0x8fa466a0, size=32)
[DSP] @8,241,342tk: [+0 T:0x8fa4578c] OM - Memory_free> return (0x1)
[DSP] @8,241,664tk: [+0 T:0x8fa4578c] OM - Memory_free> Enter(addr=0x8fa46690, size=14)
[DSP] @8,242,068tk: [+0 T:0x8fa4578c] OM - Memory_free> return (0x1)
[DSP] @8,242,385tk: [+0 T:0x8fa4578c] OM - Memory_free> Enter(addr=0x8fa46678, size=24)
[DSP] @8,242,788tk: [+0 T:0x8fa4578c] OM - Memory_free> return (0x1)
[DSP] @8,246,844tk: [+0 T:0x8fa4916c] CN - NODE_EXECFXN(0x8fa49020): viddec_copy#1 exiting per request ...
[DSP] @8,247,959tk: [+0 T:0x8fa4578c] CN - NODE_delete(0x8fa49020): viddec_copy#1
[DSP] @8,248,373tk: [+0 T:0x8fa4578c] ti.sdo.ce.video.VIDDEC - VIDDEC_delete> Enter (handle=0x8fa49090)
[DSP] @8,248,835tk: [+0 T:0x8fa4578c] CV - VISA_delete(0x8fa49090)
[DSP] @8,249,174tk: [+5 T:0x8fa4578c] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
[DSP] @8,249,676tk: [+0 T:0x8fa4578c] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(handle=0x8fa490c0)
[DSP] @8,250,201tk: [+0 T:0x8fa4578c] OM - Memory_free> Enter(addr=0x8fa490c0, size=16)
[DSP] @8,250,612tk: [+0 T:0x8fa4578c] OM - Memory_free> return (0x1)
[DSP] @8,250,937tk: [+0 T:0x8fa4578c] ti.sdo.ce.alg.Algorithm - Algorithm_delete> return
[DSP] @8,251,338tk: [+0 T:0x8fa4578c] OM - Memory_free> Enter(addr=0x8fa49090, size=48)
[DSP] @8,251,746tk: [+0 T:0x8fa4578c] OM - Memory_free> return (0x1)
[DSP] @8,252,069tk: [+0 T:0x8fa4578c] ti.sdo.ce.video.VIDDEC - VIDDEC_delete> return
[DSP] @8,252,477tk: [+0 T:0x8fa4578c] OM - Memory_free> Enter(addr=0x8fa49040, size=36)
[DSP] @8,252,885tk: [+0 T:0x8fa4578c] OM - Memory_free> return (0x1)
[DSP] @8,253,204tk: [+0 T:0x8fa4578c] OM - Memory_free> Enter(addr=0x8fa49020, size=32)
[DSP] @8,253,597tk: [+0 T:0x8fa4578c] OM - Memory_free> return (0x1)
[DSP] @8,253,901tk: [+0 T:0x8fa4578c] OM - Memory_free> Enter(addr=0x8fa49010, size=14)
[DSP] @8,254,283tk: [+0 T:0x8fa4578c] OM - Memory_free> return (0x1)
[DSP] @8,254,603tk: [+0 T:0x8fa4578c] OM - Memory_free> Enter(addr=0x8fa48ff8, size=24)
[DSP] @8,254,988tk: [+0 T:0x8fa4578c] OM - Memory_free> return (0x1)
@2,747,752us: [+0 T:0x00004000] CE - Engine_fwriteTrace> returning count [3388]
@2,748,088us: [+0 T:0x00004000] CE - rserverClose(0x3e60c), count = 1
@2,748,233us: [+0 T:0x00004000] OP - Processor_delete> Enter(proc=0x417c0)
@2,748,339us: [+0 T:0x00004000] OP - doCmd> Enter (cmdId=2, proc=0x417c0)
@2,748,434us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f508]
@2,748,554us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f508]
@2,748,658us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f520] timeout[0xffffffff]
@2,748,811us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f508] status[0]
@2,748,933us: [+0 T:0x00004002] OP - getCmd_d> Exit (result=2)
@2,947,599us: [+0 T:0x00004002] OP - Processor_delete_d> Enter (proc=0x417c0)
@2,947,715us: [+2 T:0x00004002] OP - Processor_delete_d> Closing remote transport...
@2,948,009us: [+2 T:0x00004002] OP - Processor_delete_d> Stopping DSP...
@2,948,287us: [+2 T:0x00004002] OP - Processor_delete_d> Closing pool...
@2,948,660us: [+2 T:0x00004002] OP - Processor_delete_d> Detaching from DSP...
@2,957,911us: [+2 T:0x00004002] OP - Processor_delete_d> Destroying DSP... (object, that is)
@2,958,692us: [+0 T:0x00004002] OP - Processor_delete_d> return
@2,958,819us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f520]
@2,958,950us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f520]
@2,959,127us: [+0 T:0x00004002] OP - getCmd_d> Enter (proc=0xbe7ffaec)
@2,959,306us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f508] timeout[0xffffffff]
@2,959,477us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f520] status[0]
@2,959,601us: [+0 T:0x00004000] OP - doCmd> Exit (result=1)
@2,959,688us: [+1 T:0x00004000] OP - Processor_delete(0x417c0) freeing object ...
@2,959,791us: [+0 T:0x00004000] OP - Processor_delete> return.
@2,959,876us: [+0 T:0x00004000] CE - rserverClose(0x3e60c) done.
@2,960,198us: [+0 T:0x00004000] OP - doCmd> Enter (cmdId=3, proc=0x0)
@2,960,316us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f508]
@2,960,443us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f508]
@2,960,549us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x3f520] timeout[0xffffffff]
@2,960,702us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f508] status[0]
@2,960,824us: [+0 T:0x00004002] OP - getCmd_d> Exit (result=3)
@2,960,942us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x3f520]
@2,961,060us: [+0 T:0x00004002] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x3f520]
@2,965,313us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x3f520] status[0]
@2,965,456us: [+0 T:0x00004000] OP - doCmd> Exit (result=1)
@2,965,548us: [+0 T:0x00004000] OT - Thread_delete> Enter (task=0x3f558)
@2,965,669us: [+4 T:0x00004000] OT - Thread_delete> pthread_cancel (0x3)
@2,965,794us: [+4 T:0x00004000] OT - Thread_delete> pthread_join (0x0)
@2,965,919us: [+0 T:0x00004000] OT - Thread_delete> Exit (task=0x3f558)
@2,966,019us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x3f508]
@2,966,144us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
@2,966,240us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x3f520]
@2,966,343us: [+0 T:0x00004000] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
Problem: PROC_start failed with configuration mismatch/failure
Symptom: PROC_start timed out and/or printed configuration mismatch failure information of the type:
DSP-side configuration mismatch/failure
0 -> success
Positive value -> DSP-side failure code.
(Uint32) -1 -> DSP-side component was not initialized.
DRV configuration status [0xffffffff]
IPS configuration status [0xffffffff]
POOL configuration status [0xffffffff]
MPCS configuration status [0xffffffff]
MPLIST configuration status [0xffffffff]
MQT configuration status [0xffffffff]
DATA configuration status [0xffffffff]
RingIO configuration status [0xffffffff]
Explanation: This failure indicates that DSPLink failed while attempting to start the DSP running. DSPLink internally performs handshake within the drivers on the GPP and DSP. It verifies that each component on the DSP has been correctly initialized, as required by the GPP.
The above print indicates the status of initialization of each DSPLink component on the DSP-side.
For example, the above prints indicate that none of the DSPLink components were initialized. 0xffffffff means that the value is -1. This indicates that the specific DSP-side component with this value was not initialized. When this appears for all components, it indicates that none of the components were initialized. This implies that there was some generic issue in running the DSP.
Possible cause 1: DSP has not been loaded correctly, and hence is not executing correctly to reach the point where the driver completes the handshake. In case of a custom board, check if the board setup/configuration has been done correctly.
Possible cause 2: There is a configuration mismatch in memory regions between the GPP and DSP, resulting in the GPP looking for handshake at one location, and the DSP looking at another location. Check the DSP-side and GPP-side configuration files.
Possible cause 3: User has not reserved the required amount of memory from Linux kernel space. On Linux, check the bootcmd for mem parameter as specified at Changing DSPLink memory map wiki page
Possible cause 4: There is some other issue on the DSP-side resulting in the execution not reaching the driver handshake. This could also be an application integration issue, and can only be identified by debugging the DSP-side by connecting Code Composer Studio (CCS).
这里已经说了如果以上三个不是的话,请提供CCS连接是DSP的详细信息,所有寄存器的值
另外也要查电源部分,特别是core供电,
