Part Number: SK-TDA4VM
请问edgeai-benchmark是只能编译推理ModelZoo里的模型吗?可以编译推理自定义的目标检测模型吗,和modelzoo里的模型不一样
请看下面工程师的回复。
2. Custom models can also be used with edgeai-benchmark by following the instructions documented here: https://github.com/TexasInstruments/edgeai-benchmark#compiling-custom-models. I would recommend customers to also read the following documentation in our SDK that talks about the different tools for models available: https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-sk-tda4vm/08_05_00/exports/docs/inference_models.html
