OMAPL138 boot.asm编译出错
;* BOOT  v4.6.4                                                               *
;* Copyright (c) 1996-2010 Texas Instruments Incorporated                     *
;* BOOT.ASM
;* THIS IS THE INITAL BOOT ROUTINE FOR TMS470 C++ PROGRAMS.
;* IT MUST BE LINKED AND LOADED WITH ALL C++ PROGRAMS.
;* THIS MODULE PERFORMS THE FOLLOWING ACTIONS:
;*   1) ALLOCATES THE STACK AND INITIALIZES THE STACK POINTER
;*   2) CALLS AUTO-INITIALIZATION ROUTINE
;*   3) CALLS THE FUNCTION MAIN TO START THE C++ PROGRAM
;*   4) CALLS THE STANDARD EXIT ROUTINE
;* THIS MODULE DEFINES THE FOLLOWING GLOBAL SYMBOLS:
;*   1) __stack     STACK MEMORY AREA
;*   2) _c_int00    BOOT ROUTINE
   .if  __TI_TMS470_V7M3__
 .thumbfunc _c_int00
   .else
 .armfunc _c_int00
   .endif
; Accomodate different lowerd names in different ABIs
   .if   __TI_EABI_ASSEMBLER
        .asg _args_main,   ARGS_MAIN_RTN
        .asg exit,         EXIT_RTN
        .asg    main_func_sp, MAIN_FUNC_SP
   .elseif __TI_ARM9ABI_ASSEMBLER | .TMS470_32BIS
        .asg __args_main,   ARGS_MAIN_RTN
        .asg _exit,         EXIT_RTN
        .asg    _main_func_sp, MAIN_FUNC_SP
   .else
        .asg $_args_main,   ARGS_MAIN_RTN
        .asg $exit,         EXIT_RTN
   .endif
   .if .TMS470_16BIS
;*  16 BIT STATE BOOT ROUTINE                                               *
 .state16
   .else
 .state32
   .endif
 .global __stack
;* DEFINE THE USER MODE STACK (DEFAULT SIZE IS 512)
__stack:.usect ".stack", 0, 4
 .global _c_int00
;* FUNCTION DEF: _c_int00
_c_int00: .asmfunc
 .if !__TI_TMS470_V7M3__
 .if __TI_NEON_SUPPORT__ | __TI_VFP_SUPPORT__
 ;* SETUP PRIVILEGED AND USER MODE ACCESS TO COPROCESSORS
 ;* 10 AND 11, REQUIRED TO ENABLE NEON/VFP
 ;* COPROCESSOR ACCESS CONTROL REG
 ;* BITS [23:22] - CP11, [21:20] - CP10
 ;* SET TO 0b11 TO ENABLE USER AND PRIV MODE ACCESS
 MRC      p15,#0x0,r0,c1,c0,#2
        MOV      r3,#0xf00000
 ORR      r0,r0,r3
        MCR      p15,#0x0,r0,c1,c0,#2
 ; SET THE EN BIT, FPEXC[30] TO ENABLE NEON AND VFP
       MOV      r0,#0x40000000
        FMXR     FPEXC,r0
 .endif
 ;* SET TO USER MODE
        MRS     r0, cpsr
        BIC     r0, r0, #0x1F  ; CLEAR MODES
        ORR     r0, r0, #0x10  ; SET USER MODE
        MSR     cpsr_cf, r0
 ;* CHANGE TO 16 BIT STATE
 ADD r0, pc, #1
 BX r0
 .state16
 .endif
        ;* INITIALIZE THE USER MODE STACK
 LDR     r0, c_stack
 MOV sp, r0
        LDR     r0, c_STACK_SIZE
 ADD sp, r0
 ;* ALIGN THE STACK TO 64-BITS IF EABI.
 MOV r7, sp
 MOV r0, #0x07
 BIC     r7, r0         ; Clear upper 3 bits for 64-bit alignment.
 MOV sp, r7
 .endif
 ;* SAVE CURRENT STACK POINTER FOR SDP ANALYSIS
 LDR r0, c_mf_sp
 MOV r7, sp
 STR r7, [r0]
        ;* Perform all the required initilizations:
        ;*   - Process BINIT Table
        ;*   - Perform C auto initialization
        ;*   - Call global constructors
        BL      __TI_auto_init
 ;* CALL APPLICATION
        BL      ARGS_MAIN_RTN
 ;* IF APPLICATION DIDN'T CALL EXIT, CALL EXIT(1)
        MOV     r0, #1
        BL      EXIT_RTN
 ;* DONE, LOOP FOREVER
L1:     B L1
 .endasmfunc
   .else           ; !.TMS470_16BIS
;*  32 BIT STATE BOOT ROUTINE                                               *
 .global __stack
 .global _c_int00
_c_int00: .asmfunc
        MOV      r3,#0xf00000
 ORR      r0,r0,r3
       MOV      r0,#0x40000000
        FMXR     FPEXC,r0
 .endif
 ;* SET TO USER MODE
        MRS     r0, cpsr
        ORR     r0, r0, #0x13  ; SET USER MODE
        MSR     cpsr_cf, r0
 LDR     sp, c_stack
 ADD sp, sp, r0
 BIC     sp, sp, #0x07  ; Clear upper 3 bits for 64-bit alignment.
 .endif
 LDR r0, c_mf_sp
 STR sp, [r0]
        BL      __TI_auto_init
 ;* CALL APPLICATION
        BL      ARGS_MAIN_RTN
        MOV     R0, #1
        BL      EXIT_RTN
L1:     B L1
 .endasmfunc
   .endif    ; !.TMS470_16BIS
;* CONSTANTS USED BY THIS MODULE
c_stack  .long    __stack
c_STACK_SIZE   .long    __STACK_SIZE
c_mf_sp         .long    MAIN_FUNC_SP
        .data
        .align 4
_stkchk_called:
        .field          0,32
        .else
        .sect   ".cinit"
        .align  4
        .field          4,32
        .field          _stkchk_called+0,32
        .field          0,32
        .bss    _stkchk_called,4,4
        .symdepend ".cinit", ".bss"
        .symdepend ".cinit", ".text"
        .symdepend ".bss", ".text"
 .endif
;* UNDEFINED REFERENCES                               *
 .global _stkchk_called
 .global __STACK_SIZE
 .global ARGS_MAIN_RTN
 .global MAIN_FUNC_SP
 .global EXIT_RTN
        .global __TI_auto_init
 .end
编译出错,请问__TI_TMS470_V7M3__这些定义在那里有?
"boot.asm", ERROR!   at line 23: [E0004] Absolute, well-defined integer value
                                         expected
"boot.asm", ERROR!   at line 177: [E0004] Absolute, well-defined integer value
                                          expected
"boot.asm", ERROR!   at line 272: [E0002] Illegal mnemonic specified
"boot.asm", ERROR!   at line 273: [E0002] Illegal mnemonic specified
"boot.asm", ERROR!   at line 274: [E0002] Illegal mnemonic specified
"boot.asm", ERROR!   at EOF: [E0300] The following symbols are undefined:
6 Assembly Errors, No Assembly Warnings
  __TI_TMS470_V7M3__
  __TI_NEON_SUPPORT__
  __TI_VFP_SUPPORT__
Errors in Source - Assembler Aborted
