How to scale video image and graphic simultaneously
Hi Sir :
I work on DM8148 platform and use DVRRDK_03.00.00.00 to develop our system.
I want to scale the video image and graphic simultaneously.
I try to trace source code and I find out a example saFbdevScalingDisplay.c.
However, it can only scale graphic.
Could you give me some hint or suggestion about how to scale the video image and graphic simultaneously?
Best regards,
Marcus
  • Marcus,
    GRPX内部带了缩放模块。但video图像需要用SC来缩放。
  • Hi Chris:
    I appreciate your reply!
    If I do not misunderstand what you mean, I can not scale the video image and graphic simultaneously,right?
    I must use gprx and SC to scale graphic and video image one by one,right?
    I see there is SC parameter in multich_progressive_8d1_vcap_venc_vdec_vdis.c.
    So, this SC link only work for video,right?
    Because, we use multich_progressive_4d1_vcap_venc_vdec_vdis.c to develop our system, so there is no SC parameter.
    I do not know why SC parameter is used by 8CH and 16CH.
    Could you tell me the reason?
    Best regards,
    Marcus
  • Hi Chris:
    I follow your suggestion and add scalar link to down scalar, but it only affect video.
    What I mean is that the graphic remains same size.
    Is there another way that can scale the video image and graphic simultaneously?
    Could you help me, I have tried to solve this issue for couple weeks?
    Best regards,
    Marcus
  • Hi there
    For me ,i usually scale the image using an image processing  control.It can scale,crop image well.But i've never tried to scale video image.
    I think there must be some third party program which can scale video image directly.You can have a try.
