关于深圳SEED培训的问题: CMEMK Error
Other Parts Discussed in Thread: TVP5146
沈老师:
       你好,如下是我上次深圳培训上问你的问题,这个问题现在我这边还没有解决,我这个产品等着出货,想请你帮忙解决!
        我用IPNC RDK4.1 做一款视频报警产品,硬件采集芯片及主芯片是TVP5146+DM368,单码流没有问题,当打开双码流(H264 D1+JPG D1)的时候 ,就会出现如下错误信息:
Starting kernel ...
INIT: version 2.86 booting
Starting mounting local filesystems: mount Creat queue id:0
queue id:0
Creat queue id:32769
queue id:32769
FileMngThread created
Creat queue id:65538
queue id:65538
queue id:65538
AlramThread created
Share memory init success
Creat queue id:98307
queue id:98307
--- Coson Thread
IPNC_DM365_4.1.0 (root@ubuntu) (gcc version 4.3.3 (GCC) ) #1 PREEMPT Mon Jul 2
queue id:98307
mount: mounting /dev/root on / failed: No such file or directory
 failed (1: ).
net_search_gateway:eth0, 2EA8C0, 0, 1
CPU is DM368
Check_device_version : DEVICE VER = 1 !!
Starting internet superserver: inetdDEMOCFG Value       : 0
Videocodecmode  : 3
Videocodecres   : 1
  IPNC BUILD VERSION: DM368 IPNC RDK V4.10.00.02
./av_server.out DM368 NTSC AUDIO 8000 G711 64000 TI2A AEWB D1_D1 INTERLACE 720 480 H264 80000 VBR AUTO MJPEG 80 MENUOFF &
CPU CurrentStatus is = 1
ApproDrvInit: 7
Creat queue id:131076
queue id:131076
 DM365MM Init Successful
AVSERVER UI: Initializing.
ApproDrvInit: 9
queue id:131076
ApproDrvInit: 2
ApproDrvInit: 8
queue id:131076
queue id:131076
ApproDrvInit: 6
queue id:131076
ApproDrvInit: 10
queue id:131076
 CLK Hz,
 ARM   Hz =  432000000
 DDR   Hz =  340000000
 VPSS  Hz =  340000000
 IMCOP Hz =  340000000
 [OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR
IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter
 DM365MM Init SuccessfulSYSTEM.MSTPRI0 value changed to 00440011
CONFIGURING AVSERVER FOR DM368 .....
queue id:98307
SENSOR FPS VALUE = 30
-----DRV_captureOpen() success
 0 - DEI create successful = 0x456198, wxh = 736x480
queue id:131076
 FR : 0 users registered from exsiting face album
IPNC AUTO_IRIS = 1
Initializing...
Initializing...
Initializing...
Initializing...
Initializing...
WaitStreamReady begin.
...done initializing
Play this stream using the URL:
        rtsp://192.168.46.168:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8304 for optional RTSP-over-HTTP tunneling.)
        rtsp://192.168.46.168:8554/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8301 for optional RTSP-over-HTTP tunneling.)
        rtsp://192.168.46.168:8556/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8303 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.46.168:8555/PSIA/Streaming/channels/0?videoCodecType=MJPEG
(We use port 8302 for optional RTSP-over-HTTP tunneling.)
        rtsp://192.168.46.168:8553/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8300 for optional RTSP-over-HTTP tunneling.)
DRV_i2cWrite8()22
VIDEO_encodeTskMain
[    4.505273] CMEMK Error: get_phys: Unable to find phys addr for 0x5226c504
[    4.512276] CMEMK Error: get_phys: get_user_pages() failed: -14
[    4.518276] CMEMK Error: GETPHYS: Failed to convert virtual 0x5226c504 to physical.
CMEM Error: getP[    4.526350] CMEMK Error: get_phys: Unable to find phys addr for 0x50bc2ec4
hys: Failed to g[    4.534601] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    4.541857] CMEMK Error: GETPHYS: Failed to convert virtual 0x50bc2ec4 to physical.
ess of 0x5226c504
CMEM Error: getPhys: Failed to get physical address of 0x50bc2ec4
stream ok
[    4.580428] CMEMK Error: get_phys: Unable to find phys addr for 0x5235e504
[    4.587366] CMEMK Error: get_phys: get_user_pages() failed: -14
[    4.593418] CMEMK Error: GETPHYS: Failed to convert virtual 0x5235e504 to physical.
CMEM Error: getP[    4.601406] CMEMK Error: get_phys: Unable to find phys addr for 0x50cb4ec4
hys: Failed to g[    4.609551] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    4.616950] CMEMK Error: GETPHYS: Failed to convert virtual 0x50cb4ec4 to physical.
ess of 0x5235e504
CMEM Error: getPhys: Failed to get physical address of 0x50cb4ec4
[    4.654352] CMEMK Error: get_phys: Unable to find phys addr for 0x5241e504
[    4.661381] CMEMK Error: get_phys: get_user_pages() failed: -14
[    4.667365] CMEMK Error: GETPHYS: Failed to convert virtual 0x5241e504 to physical.
CMEM Error: getP[    4.675364] CMEMK Error: get_phys: Unable to find phys addr for 0x50d74ec4
hys: Failed to g[    4.683627] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    4.690919] CMEMK Error: GETPHYS: Failed to convert virtual 0x50d74ec4 to physical.
ess of 0x5241e504
CMEM Error: getPhys: Failed to get physical address of 0x50d74ec4
[    4.728289] CMEMK Error: get_phys: Unable to find phys addr for 0x5226c504
[    4.735352] CMEMK Error: get_phys: get_user_pages() failed: -14
[    4.741392] CMEMK Error: GETPHYS: Failed to convert virtual 0x5226c504 to physical.
CMEM Error: getP[    4.749320] CMEMK Error: get_phys: Unable to find phys addr for 0x50bc2ec4
hys: Failed to g[    4.757615] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    4.764857] CMEMK Error: GETPHYS: Failed to convert virtual 0x50bc2ec4 to physical.
ess of 0x5226c504
[    4.802430] CMEMK Error: get_phys: Unable to find phys addr for 0x5235e504
[    4.809337] CMEMK Error: get_phys: get_user_pages() failed: -14
[    4.815422] CMEMK Error: GETPHYS: Failed to convert virtual 0x5235e504 to physical.
CMEM Error: getP[    4.823420] CMEMK Error: get_phys: Unable to find phys addr for 0x50cb4ec4
hys: Failed to g[    4.831681] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    4.838920] CMEMK Error: GETPHYS: Failed to convert virtual 0x50cb4ec4 to physical.
ess of 0x5235e504
[    4.876517] CMEMK Error: get_phys: Unable to find phys addr for 0x5241e504
[    4.883645] CMEMK Error: get_phys: get_user_pages() failed: -14
[    4.889628] CMEMK Error: GETPHYS: Failed to convert virtual 0x5241e504 to physical.
CMEM Error: getP[    4.897666] CMEMK Error: get_phys: Unable to find phys addr for 0x50d74ec4
hys: Failed to g[    4.905899] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    4.913165] CMEMK Error: GETPHYS: Failed to convert virtual 0x50d74ec4 to physical.
ess of 0x5241e504
[    4.950771] CMEMK Error: get_phys: Unable to find phys addr for 0x5226c504
[    4.957719] CMEMK Error: get_phys: get_user_pages() failed: -14
[    4.963820] CMEMK Error: GETPHYS: Failed to convert virtual 0x5226c504 to physical.
CMEM Error: getP[    4.971809] CMEMK Error: get_phys: Unable to find phys addr for 0x50bc2ec4
hys: Failed to g[    4.979965] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    4.987336] CMEMK Error: GETPHYS: Failed to convert virtual 0x50bc2ec4 to physical.
ess of 0x5226c504
[    5.024787] CMEMK Error: get_phys: Unable to find phys addr for 0x5235e504
[    5.031869] CMEMK Error: get_phys: get_user_pages() failed: -14
[    5.037839] CMEMK Error: GETPHYS: Failed to convert virtual 0x5235e504 to physical.
CMEM Error: getP[    5.045838] CMEMK Error: get_phys: Unable to find phys addr for 0x50cb4ec4
hys: Failed to g[    5.054106] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    5.061371] CMEMK Error: GETPHYS: Failed to convert virtual 0x50cb4ec4 to physical.
ess of 0x5235e504
[    5.098905] CMEMK Error: get_phys: Unable to find phys addr for 0x5241e504
[    5.105960] CMEMK Error: get_phys: get_user_pages() failed: -14
[    5.111999] CMEMK Error: GETPHYS: Failed to convert virtual 0x5241e504 to physical.
CMEM Error: getP[    5.119970] CMEMK Error: get_phys: Unable to find phys addr for 0x50d74ec4
hys: Failed to g[    5.128193] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    5.135490] CMEMK Error: GETPHYS: Failed to convert virtual 0x50d74ec4 to physical.
ess of 0x5241e504
[    5.173044] CMEMK Error: get_phys: Unable to find phys addr for 0x5226c504
[    5.179980] CMEMK Error: get_phys: get_user_pages() failed: -14
[    5.186054] CMEMK Error: GETPHYS: Failed to convert virtual 0x5226c504 to physical.
CMEM Error: getP[    5.194048] CMEMK Error: get_phys: Unable to find phys addr for 0x50bc2ec4
hys: Failed to g[    5.202298] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    5.209502] CMEMK Error: GETPHYS: Failed to convert virtual 0x50bc2ec4 to physical.
ess of 0x5226c504
[    5.247475] CMEMK Error: get_phys: Unable to find phys addr for 0x5235e504
[    5.254555] CMEMK Error: get_phys: get_user_pages() failed: -14
[    5.260639] CMEMK Error: GETPHYS: Failed to convert virtual 0x5235e504 to physical.
CMEM Error: getP[    5.268643] CMEMK Error: get_phys: Unable to find phys addr for 0x50cb4ec4
hys: Failed to g[    5.276905] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    5.284228] CMEMK Error: GETPHYS: Failed to convert virtual 0x50cb4ec4 to physical.
ess of 0x5235e504
mkdosfs 2.11 (12 Mar 2005)
[    5.321957] CMEMK Error: get_phys: Unable to find phys addr for 0x5241e504
[    5.328867] CMEMK Error: get_phys: get_user_pages() failed: -14
[    5.334949] CMEMK Error: GETPHYS: Failed to convert virtual 0x5241e504 to physical.
CMEM Error: getP[    5.342961] CMEMK Error: get_phys: Unable to find phys addr for 0x50d74ec4
hys: Failed to g[    5.351223] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    5.358463] CMEMK Error: GETPHYS: Failed to convert virtual 0x50d74ec4 to physical.
ess of 0x5241e504
unable to get drive geometry, using default 255/63/dev/ram0 has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 8192 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT[    5.396282] CMEMK Error: get_phys: Unable to find phys addr for 0x5226c504
 size is 6 secto[    5.403520] CMEMK Error: get_phys: get_user_pages() failed: -14
rs, and provides[    5.410760] CMEMK Error: GETPHYS: Failed to convert virtual 0x5226c504 to physical.
[    5.419912] CMEMK Error: get_phys: Unable to find phys addr for 0x50bc2ec4
Root directory [    5.428078] CMEMK Error: get_phys: get_user_pages() failed: -14
contains 512 slo[    5.435364] CMEMK Error: GETPHYS: Failed to convert virtual 0x50bc2ec4 to physical.
ts.
Volume ID is 522d4658, no volume label.
CMEM Error: getPhys: Failed to get physical address of 0x5226c504
[    5.473091] CMEMK Error: get_phys: Unable to find phys addr for 0x5235e504
[    5.479998] CMEMK Error: get_phys: get_user_pages() failed: -14
[    5.486156] CMEMK Error: GETPHYS: Failed to convert virtual 0x5235e504 to physical.
CMEM Error: getP[    5.494186] CMEMK Error: get_phys: Unable to find phys addr for 0x50cb4ec4
hys: Failed to g[    5.502433] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    5.509631] CMEMK Error: GETPHYS: Failed to convert virtual 0x50cb4ec4 to physical.
ess of 0x5235e504
queue id:32769
[    5.547658] CMEMK Error: get_phys: Unable to find phys addr for 0x5241e504
[    5.554749] CMEMK Error: get_phys: get_user_pages() failed: -14
[    5.560804] CMEMK Error: GETPHYS: Failed to convert virtual 0x5241e504 to physical.
CMEM Error: getP[    5.568743] CMEMK Error: get_phys: Unable to find phys addr for 0x50d74ec4
hys: Failed to g[    5.576976] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    5.584299] CMEMK Error: GETPHYS: Failed to convert virtual 0x50d74ec4 to physical.
ess of 0x5241e504
[    5.621910] CMEMK Error: get_phys: Unable to find phys addr for 0x5226c504
[    5.628818] CMEMK Error: get_phys: get_user_pages() failed: -14
[    5.634902] CMEMK Error: GETPHYS: Failed to convert virtual 0x5226c504 to physical.
CMEM Error: getP[    5.642926] CMEMK Error: get_phys: Unable to find phys addr for 0x50bc2ec4
hys: Failed to g[    5.651239] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    5.658427] CMEMK Error: GETPHYS: Failed to convert virtual 0x50bc2ec4 to physical.
ess of 0x5226c504
[    5.695657] CMEMK Error: get_phys: Unable to find phys addr for 0x5235e504
[    5.702715] CMEMK Error: get_phys: get_user_pages() failed: -14
[    5.708660] CMEMK Error: GETPHYS: Failed to convert virtual 0x5235e504 to physical.
CMEM Error: getP[    5.716686] CMEMK Error: get_phys: Unable to find phys addr for 0x50cb4ec4
hys: Failed to g[    5.724922] CMEMK Error: get_phys: get_user_pages() failed: -14
et physical addr[    5.732251] CMEMK Error: GETPHYS: Failed to convert virtual 0x50cb4ec4 to physical.
ess of 0x5235e504
另外我的rules.make 内容如下:
# Copyright (c) Texas Instruments Inc 2012
# Use of this software is controlled by the terms and conditions found in the
# license agreement under which this software has been supplied or provided.
IPNC_INSTALL_DIR    := $(shell pwd)/..
#SYSTEM := EVM
SYSTEM := IPNC
#IPNC_PLATFORM := DM365
IPNC_PLATFORM := DM368
#FILESYS_MODE := NFS
FILESYS_MODE := NAND
CONFIG :=
DVSDK_BASE_DIR    := $(IPNC_INSTALL_DIR)/dvsdk_ipnctools
IPNC_BASE_DIR    := $(IPNC_INSTALL_DIR)/ipnc_rdk
BUILD_TOOL_DIR    := $(DVSDK_BASE_DIR)/linux-devkit
include $(DVSDK_BASE_DIR)/Rules.make
BASE_DIR     := $(IPNC_BASE_DIR)/av_capture/build
FILESYS_BASE_DIR  := $(IPNC_BASE_DIR)/target
PSP_BASE_DIR    := $(DVSDK_BASE_DIR)/ipnc_psp_03_21_00_04
# The directory that points to the Linux Support Package
KERNELDIR  := $(PSP_BASE_DIR)/ti-davinci
KERNEL_CFGDIR  := $(KERNELDIR)/arch/arm/configs
# The directory that points to the u-boot Package
UBOOTDIR  := $(PSP_BASE_DIR)/u-boot
# The directory that points to where filesystem is mounted
TARGET_FS  := $(FILESYS_BASE_DIR)/filesys
UBIFS_PATH      := $(FILESYS_BASE_DIR)/mtd-utils
# Where to copy the resulting executables and data to (when executing 'make
# install') in a proper file structure. This EXEC_DIR should either be visible
# from the target, or you will have to copy this (whole) directory onto the
# target filesystem.
EXEC_DIR=$(TARGET_FS)/opt/ipnc
# The directory that points to the IPNC Application package
IPNC_DIR=$(IPNC_BASE_DIR)/ipnc_app
# The directory to application interface
IPNC_INTERFACE_DIR=$(IPNC_DIR)/interface
# The directory to application interface include files
PUBLIC_INCLUDE_DIR=$(IPNC_INTERFACE_DIR)/inc
# The directory to application interface library files
APP_LIB_DIR=$(IPNC_INTERFACE_DIR)/lib
# The directory to root file system
ROOT_FILE_SYS = $(TARGET_FS)
AEWB_LIBS :=
ifeq ($(SYSTEM), IPNC)
BOARD_ID := BOARD_AP_IPNC
#IMGS_ID := IMGS_MICRON_MT9P031_5MP
#IMGS_ID := IMGS_MICRON_MT9D131_2MP
IMGS_ID := IMGS_TVP514X
#IMGS_ID := IMGS_OV10630_1MP
#IMGS_ID := IMGS_MICRON_MT9M034_1.2MP
#IMGS_ID := IMGS_MICRON_MT9M031_1.2MP
#IMGS_ID := IMGS_OV2715_2MP
#IMGS_ID := IMGS_SONY_IMX035_1_3MP
#IMGS_ID := IMGS_SONY_IMX036_3MP
#IMGS_ID := IMGS_SONY_IMX104_1_3MP
#IMGS_ID := IMGS_SONY_IMX136_2_3MP
#IMGS_ID := IMGS_SONY_IMX122_2_3MP
#IMGS_ID := IMGS_AR0130_1.2MP
#IMGS_ID := IMGS_AR0330_3.1MP
#IMGS_ID := IMGS_AR0331_3.1MP
#IMGS_ID := IMGS_AR0331_3.1MP_WDR
#IMGS_ID := IMGS_PANASONIC_MN34041_2.1MP
AEWB_ID := AEWB_ENABLE
endif
ifeq ($(SYSTEM), EVM)
BOARD_ID := BOARD_TI_EVM
endif
ifeq ($(IPNC_PLATFORM), DM368)
HARDWARE := dm368
else
HARDWARE := dm365
endif
ifeq ($(FILESYS_MODE), NAND)
BUILD_CONFIG := nand
else
BUILD_CONFIG := nfs
endif
#Build warnings will be treated as errors for av_capture folder
TREAT_WARNINGS_AS_ERROR := no
TARGET_FS_DIR  := $(TARGET_FS)/opt/ipnc
TFTP_HOME  := $(IPNC_BASE_DIR)/tftp/$(HARDWARE)
export BUILD_TOOL_DIR
export IPNC_DIR
export PUBLIC_INCLUDE_DIR
export APP_LIB_DIR
export TARGET_FS
export SYSTEM
export LINUXKERNEL_INSTALL_DIR
export EXEC_DIR
export TARGET_FS_DIR
export SQUASHFS_PATH
export KERNELDIR
export UBOOTDIR
export BASE_DIR
export CONFIG
export DVSDK_BASE_DIR
export CMEM_INSTALL_DIR
export MVTOOL_PREFIX
export IMGS_ID
export BOARD_ID
export DVSDK_DEMOS_DIR
export AEWB_ID
export AEWB_LIBS
export FILESYS_MODE
export TFTP_HOME
export TREAT_WARNINGS_AS_ERROR
上述内容我打包在附件里!
ipnc_dual_err.zip
