我程序里面需要用到edma,但在看dm365 dvsdk4里面的edma例子时有个地方不明白,请专家指点:
例子是psp里面linuxutil里面的edma例子,edma_test.c里面函数
int edma3_memtomemcpytest_dma(int acnt, int bcnt, int ccnt, int sync_mode,
int event_queue)
int result = 0;
unsigned int dma_ch = 0;
int i;
int count = 0;
unsigned int Istestpassed = 0u;
unsigned int numenabled = 0;
unsigned int BRCnt = 0;
int srcbidx = 0;
int desbidx = 0;
int srccidx = 0;
int descidx = 0;
struct edmacc_param param_set;
/* Initalize source and destination buffers */
for (count = 0u; count < (acnt * bcnt * ccnt); count++) {
dmabufsrc1[count] = 'A' + (count % 26);
dmabufdest1[count] = 0;
/* Set B count reload as B count. */
BRCnt = bcnt;
/* Setting up the SRC/DES Index */
srcbidx = acnt;
desbidx = acnt;
/* A Sync Transfer Mode */
srccidx = acnt;
descidx = acnt;
dma_ch = edma_alloc_channel(EDMA_CHANNEL_ANY, callback1, NULL,
event_queue);
printk("edma3_memtomemcpytest_dma::dma_ch is %d\n", dma_ch);
if (dma_ch < 0) {
DMA_PRINTK
("\nedma3_memtomemcpytest_dma::edma_alloc_channel failed for dma_ch, error:%d\n",
dma_ch);
return dma_ch;
edma_set_src(dma_ch, (unsigned long)(dmaphyssrc1), INCR, W8BIT);
edma_set_dest(dma_ch, (unsigned long)(dmaphysdest1), INCR, W8BIT);
edma_set_src_index(dma_ch, srcbidx, srccidx);
edma_set_dest_index(dma_ch, desbidx, descidx);
/*上面输入参数acnt=512,bcnt=8,ccnt=8,我的问题是:
不明白为什么这里srccidx等于acnt,我查edma_set_src_index的函数解释是
edma_set_src_index - configure DMA source address indexing
@slot: parameter RAM slot being configured
@src_bidx: byte offset between source arrays in a frame
@src_cidx: byte offset between source frames in a block
src_cidx即块中frame间的字节偏移,我觉得应该是acnt*bcnt才对,怎么会是acnt呢?
是不是因为下面红字处的edma_start在for循环中要运行bcnt * ccnt次,所以这里每次就传512字节,所以src_cidx和src_cidx都设置成了acnt*/
edma_set_transfer_params(dma_ch, acnt, bcnt, ccnt, BRCnt, ASYNC);
/* Enable the Interrupts on Channel 1 */
edma_read_slot(dma_ch, ¶m_set);
param_set.opt |= (1 << ITCINTEN_SHIFT);
param_set.opt |= (1 << TCINTEN_SHIFT);
param_set.opt |= EDMA_TCC(EDMA_CHAN_SLOT(dma_ch));
edma_write_slot(dma_ch, ¶m_set);
numenabled = bcnt * ccnt;
for (i = 0; i < numenabled; i++) {
irqraised1 = 0;
/* Now enable the transfer as many times as calculated above. */
result = edma_start(dma_ch);
if (result != 0) {
DMA_PRINTK
("edma3_memtomemcpytest_dma: edma_start failed \n");
break;
/* Wait for the Completion ISR. */
while (irqraised1 == 0u) ;
/* Check the status of the completed transfer */
if (irqraised1 < 0) {
/* Some error occured, break from the FOR loop. */
DMA_PRINTK("edma3_memtomemcpytest_dma: "
"Event Miss Occured!!!\n");
break;
if (0 == result) {
for (i = 0; i < (acnt * bcnt * ccnt); i++) {
if (dmabufsrc1[i] != dmabufdest1[i]) {
DMA_PRINTK
("\n edma3_memtomemcpytest_dma: Data write-read matching failed at = %u\n",
i);
Istestpassed = 0u;
result = -1;
break;
if (i == (acnt * bcnt * ccnt)) {
Istestpassed = 1u;
edma_stop(dma_ch);
edma_clean_channel(dma_ch);
edma_free_slot(dma_ch);
edma_free_channel(dma_ch);
if (Istestpassed == 1u) {
DMA_PRINTK
("\nedma3_memtomemcpytest_dma: EDMA Data Transfer Successfull \n");
} else {
DMA_PRINTK
("\nedma3_memtomemcpytest_dma: EDMA Data Transfer Failed \n");
return result;
谢谢专家!期待您的指导!
