1,Does DM3730 need vs and hs signal(ITU601 format),or Support ITU656?
2,Is the register I setted correct?
3,If anyone use the TVP5158 in the DM3730 platform?
I set the ISP register, as follow:
ISP_CTRL 0x29c140
CCDC_FMTCFG 0x4000
CCDC_SYN_MODE 0x32f84
ISPCCDC_REC656IF 0x3
CCDC_DCSUB 0
CCDC_VP_OUT 0
CCDC_HORZ_INFO 0
CCDC_HORZ_INFO 0x59f (1440-1)
CCDC_VERT_START 0x20002
CCDC_VERT_LINES 0x11f (576/2-1)
CCDC_HSIZE_OFF 0x5a0 (1440)
CCDC_VDINT 0x11f0032
CCDC_CFG 0x8800
CCDC_SDOFST 0x249
