在使用TDS560仿真DM6446时,加载了工程以后,发现程序跳不到main(),一点击go main就成了运行,点halt就出现错误:
Trouble Removing Breakpoint with the Action "Terminate GEL_Go()" at 0x80005934: Error 0x80000008/-1066 Fatal Error during: Break Point, Cannot set/verify breakpoint at 0x80005934 Sequence ID: 8 Error Code: -1066 Error Class: 0x80000008
Failed to remove the debug state from the target before disconnecting. There may still be breakpoint opcodes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging.
哪位大神能帮忙解答下是什么问题!!
