DM37x EVM开发板长时间运行会死机
Other Parts Discussed in Thread: OMAP3530, ADS7846
经过这几天的测试发现,DM37x EVM开发板提供的WINCE、LINUX及Android三个操作系统均存在死机的情况。
测试都是利用开发板提供的SD卡将系统启动,之后运行TI的官方测试程序,长时间运行,情况比较糟糕,经过一夜的运行,早晨到单位看,都死机了。
不知道是买的开发板硬件有问题,还是各个系统软件有问题。
在PB中增加KITL调试后,出现以下的调试信息后就死机了
PB Debugger The Kernel Debugger is waiting to connect with target.
PB Debugger The Kernel Debugger has been disconnected successfully.
   3740 PID:400002 TID:410002 Compensating OPP1 for 63mV Orig nvalue:0x8988de New nvalue:0x99cba8
   3740 PID:400002 TID:410002 Compensating OPP2 for 63mV Orig nvalue:0x9a8ff0 New nvalue:0xaaf2cc
   3740 PID:400002 TID:410002 Compensating OPP3 for 75mV Orig nvalue:0xaad5b6 New nvalue:0xaab79d
   3740 PID:400002 TID:410002 Compensating OPP4 for 100mV Orig nvalue:0xaaa291 New nvalue:0xab8bf8
   3740 PID:400002 TID:410002 SetOpp to 3
   3948 PID:400002 TID:c20002 ECC TYPE is Hamming 1 bit
   6739 PID:400002 TID:c20002 SDHC: CPU revision 0x12
   6739 PID:400002 TID:c20002 SDHC host controller initialize: m_fastPathSDIO:1 m_fastPathSDMEM:0
   7699 PID:400002 TID:c20002 RELFSD: Opening file lpmdrv.dll from desktop
   9122 PID:400002 TID:73c0006 RELFSD: Opening file iectl.dll from desktop
  68082 PID:400002 TID:1060002 kernel IOCTL_POWER_SET setting state 1
 368084 PID:400002 TID:1060002 kernel IOCTL_POWER_SET setting state 2
 427664 PID:400002 TID:2980002 Exception 'Data Abort'(4) Thread-Id=02980002(pth=8e8e057c) PC=8006af3c BVA=b6318034, dwInfo = 00001008
 427664 PID:400002 TID:2980002  R0=00000000  R1=0000fffc  R2=6000001f  R3=ffffc800
 427664 PID:400002 TID:2980002  R4=debefc1c  R5=8e8e057c  R6=00000000  R7=00000000
 427664 PID:400002 TID:2980002  R8=00000002  R9=00000000 R10=00000000 R11=debefe04
 427664 PID:400002 TID:2980002 R12=8006af3c  SP=debefc04  Lr=8006af3c Psr=6000001f
 427664 PID:400002 TID:2980002 Exception 'Data Abort'(4) Thread-Id=02980002(pth=ffffc424) PC=8001cda4 BVA=b6318034, dwInfo = 00001008
 427664 PID:400002 TID:2980002  R0=b6318000  R1=841f7100  R2=00000002  R3=0000000a
 427664 PID:400002 TID:2980002  R4=b6318028  R5=00000000  R6=841fdea4  R7=841ffa40
 427664 PID:400002 TID:2980002  R8=000000c0  R9=00000000 R10=00000000 R11=00000000
 427664 PID:400002 TID:2980002 R12=800580d8  SP=ffffc574  Lr=00000000 Psr=20000193
 427664 PID:400002 TID:2980002 Exception 'Data Abort' (4): Thread-Id=02980002(pth=8e8e057c), Proc-Id=00400002(pprc=8424d448) 'NK.EXE', VM-active=01e30002(pprc=87ca67f8) 'shell.exe'
 427664 PID:400002 TID:2980002 PC=8001cda4(NK.EXE+0x0001ada4) RA=00000000(???+0x00000000) SP=ffffc574, BVA=00000000
 427664 PID:400002 TID:2980002 Exception 'Data Abort'(4) Thread-Id=02980002(pth=8e8e057c) PC=8001cda4 BVA=b6318034, dwInfo = 00001008
 427664 PID:400002 TID:2980002  R4=b6318028  R5=841fdb24  R6=00000000  R7=00d5d511
 427664 PID:400002 TID:2980002  R8=841f6a48  R9=00000000 R10=8424fe90 R11=8424d010
 427664 PID:400002 TID:2980002 R12=00000000  SP=ffffc4a4  Lr=00000000 Psr=2000011f
 427664 PID:400002 TID:2980002 Exception 'Data Abort' (4): Thread-Id=02980002(pth=8e8e057c), Proc-Id=00400002(pprc=8424d448) 'NK.EXE', VM-active=00400002(pprc=8424d448) 'NK.EXE'
LINUX平台下的死机情况:
root@dm37x-evm:/usr/share/ti/ti-dsplink-examples# /etc/init.d/matrix-gui-e start
Removing stale PID file /var/run/matrix-gui-e.pid.
Starting Matrix GUI application.
root@dm37x-evm:/usr/share/ti/ti-dsplink-examples# Unhandled fault: external abort on non-linefetch (0x1028) at 0xfa318034
Internal error: : 1028 [#1]
last sysfs file: /sys/devices/platform/omapdss/manager0/display
Modules linked in: sdmak lpm_omap3530 dsplinkk cmemk bufferclass_ti omaplfb pvrsrvkm [last unloaded: sdmak]
CPU: 0    Not tainted  (2.6.32 #1)
PC is at omap_dm_timer_set_load_start+0x20/0x84
LR is at omap2_gp_timer_set_next_event+0x18/0x24
pc : [<c005037c>]    lr : [<c003edec>]    psr: 20000093
sp : c046ded0  ip : 00000000  fp : 00000000
r10: 00000000  r9 : 00001c49  r8 : 00001c49
r7 : 385852f4  r6 : ffffff0c  r5 : 00000000  r4 : c047b674
r3 : fa318000  r2 : ffffff0c  r1 : 00000000  r0 : c047b674
Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c5387d  Table: 8fad4019  DAC: 00000017
Process swapper (pid: 0, stack limit = 0xc046c2e8)
Stack: (0xc046ded0 to 0xc046e000)
dec0:                                     0071995d 00000000 c0471d30 c003edec
dee0: 0071995d c007c158 385852f4 00001c49 c047db00 c0471d30 37e6b997 c007c908
df00: 37e6b997 00001c49 37e6b997 00001c49 00000001 385852f4 00001c49 c047db00
df20: c047dff0 00001c49 00000000 60000093 00001c49 c007ca04 00000000 00001c49
df40: 00000000 c0076018 00000000 00000000 385852f4 00001c49 00000000 00000000
df60: 385852f4 00001c49 385852f4 00001c49 c047dff0 c00760c0 00000000 00000002
df80: 00000001 00001c49 00000000 c007d57c 00000000 00000002 c002a014 37e5cb2c
dfa0: 37e5cb2c 00001c49 0000001f c046c000 c04af45c c002a014 c046fc18 80027f24
dfc0: 413fc082 0000001f 00000000 c003541c c04b8478 c0008a68 c00085f4 00000000
dfe0: 00000000 c002a018 00000000 10c53c7d c04af558 80008034 00000000 00000000
[<c005037c>] (omap_dm_timer_set_load_start+0x20/0x84) from [<c003edec>] (omap2_gp_timer_set_next_event+0x18/0x24)
[<c003edec>] (omap2_gp_timer_set_next_event+0x18/0x24) from [<c007c158>] (clockevents_program_event+0x120/0x138)
[<c007c158>] (clockevents_program_event+0x120/0x138) from [<c007c908>] (tick_dev_program_event+0x3c/0xe4)
[<c007c908>] (tick_dev_program_event+0x3c/0xe4) from [<c007ca04>] (tick_program_event+0x1c/0x24)
[<c007ca04>] (tick_program_event+0x1c/0x24) from [<c0076018>] (__hrtimer_start_range_ns+0x1b4/0x214)
[<c0076018>] (__hrtimer_start_range_ns+0x1b4/0x214) from [<c00760c0>] (hrtimer_start_range_ns+0x20/0x28)
[<c00760c0>] (hrtimer_start_range_ns+0x20/0x28) from [<c007d57c>] (tick_nohz_restart_sched_tick+0x1ac/0x218)
[<c007d57c>] (tick_nohz_restart_sched_tick+0x1ac/0x218) from [<c003541c>] (cpu_idle+0x74/0x88)
[<c003541c>] (cpu_idle+0x74/0x88) from [<c0008a68>] (start_kernel+0x234/0x28c)
[<c0008a68>] (start_kernel+0x234/0x28c) from [<80008034>] (0x80008034)
Code: e3130004 1a000000 ea000003 e5943010 (e5933034)
---[ end trace bd38be2c3330280d ]---
Kernel panic - not syncing: Attempted to kill the idle task!
Internal error: : 1028 [#2]
CPU: 0    Tainted: G      D     (2.6.32 #1)
PC is at omap_dm_timer_write_reg+0x1c/0x38
LR is at omap2_gp_timer_interrupt+0x10/0x2c
pc : [<c0050258>]    lr : [<c003ee08>]    psr: 00000193
sp : c046dca0  ip : 00000002  fp : 00000000
r10: 00000000  r9 : 00000008  r8 : 00000000
r7 : 00000025  r6 : 00000000  r5 : 00000000  r4 : c0471d08
r3 : fa318000  r2 : 00000000  r1 : 00000018  r0 : c047b674
Flags: nzcv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Stack: (0xc046dca0 to 0xc046e000)
dca0: c0471d08 c0087438 c047edb0 00000025 c046dda7 c0050380 00000000 c0088dc4
dcc0: 00000025 00000000 c046dda7 c0033070 ffffffff fa200000 c046dda7 c0033a70
dce0: 0006859d 00000000 00000ee0 c04b0cf8 00000307 00000307 c046dda7 c0050380
dd00: 00000000 00000008 00000000 00000000 00000000 c046dd28 c0334c08 c0184040
dd20: 20000113 ffffffff c03e4c9c c046dd44 c046c000 0000000b c046ef50 c0063a94
dd40: c03e4c9c c046dd50 c046c000 00000000 0000000b c03e4a41 00000001 c005037e
dd60: c046dda7 c0050380 00000000 00000008 00000000 c0037a44 c046c2e8 c007c158
dd80: 65a282a8 30333133 20343030 30306131 30303030 30616520 30303030 35652033
dda0: 30333439 28203031 33393565 34333033 c0002029 fa318034 00001028 c046ddf0
ddc0: 00000000 c046de88 fa318034 20000193 00000000 c0037b18 00000007 c046fe68
dde0: 00001028 c00332c8 00000000 00000000 00000007 00000000 00000000 fa318034
de00: 00000000 00000000 00000000 fd010018 cfa3fec0 c02d0e44 cfa3fec0 cf8ba680
de20: 6b280000 00000000 cc8a5c10 cc88c822 00000000 c02c2c20 cc8a1180 c046dea4
de40: 00000000 c046dea4 cc88c810 c02f4f64 37e5cb2c 00000000 37d7d2e5 00000000
de60: ffffffff 00000000 c04b6be0 c0079ac4 ffffffff c046debc ffffff0c 385852f4
de80: 00001c49 c0033a2c c047b674 00000000 ffffff0c fa318000 c047b674 00000000
dea0: ffffff0c 385852f4 00001c49 00001c49 00000000 00000000 00000000 c046ded0
dec0: c003edec c005037c 20000093 ffffffff 0071995d 00000000 c0471d30 c003edec
[<c0050258>] (omap_dm_timer_write_reg+0x1c/0x38) from [<c003ee08>] (omap2_gp_timer_interrupt+0x10/0x2c)
[<c003ee08>] (omap2_gp_timer_interrupt+0x10/0x2c) from [<c0087438>] (handle_IRQ_event+0x34/0xf4)
[<c0087438>] (handle_IRQ_event+0x34/0xf4) from [<c0088dc4>] (handle_level_irq+0x88/0xec)
[<c0088dc4>] (handle_level_irq+0x88/0xec) from [<c0033070>] (asm_do_IRQ+0x70/0x90)
[<c0033070>] (asm_do_IRQ+0x70/0x90) from [<c0033a70>] (__irq_svc+0x30/0x80)
Exception stack(0xc046dce0 to 0xc046dd28)
[<c0033a70>] (__irq_svc+0x30/0x80) from [<c0184040>] (__delay+0x0/0xc)
Code: 11a02821 1a000000 ea000003 e5903010 (e5933034)
---[ end trace bd38be2c3330280e ]---
Kernel panic - not syncing: Fatal exception in interrupt
Unhandled fault: external abort on non-linefetch (0x1028) at 0xfa320010
Internal error: : 1028 [#3]
PC is at omap_readl+0x4/0xc
LR is at omap34xx_32k_read+0xc/0x18
pc : [<c004c754>]    lr : [<c0049480>]    psr: 60000193
sp : c046d9d0  ip : c0484ad0  fp : 0015ca8e
r10: c04b6be0  r9 : 00000000  r8 : c047ad88
r7 : 00000000  r6 : 37d7d2e5  r5 : 000f4240  r4 : c046da20
r3 : 00001c49  r2 : b274340e  r1 : 00000001  r0 : fa320010
Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Stack: (0xc046d9d0 to 0xc046e000)
d9c0:                                     c046da20 c0079a70 c04b4312 c01c88a8
d9e0: c04bedb8 00000000 c046da20 00001c49 c04b4312 c046da20 000f4240 c047db30
da00: cf9d03d8 00000000 00000000 60000193 fb058018 c0075ed0 cf9d03d8 00000001
da20: 000f4240 00000000 cf9d0000 40000113 00000000 0000014f 00000000 c047ecc0
da40: 00000022 c0076098 00000000 00000001 00000001 00000000 cf9d0000 c023871c
da60: 00000001 cf9d0000 cfa14d80 00000000 00000000 c0087438 c0484ad0 0000014f
da80: cfa14d80 00000001 00000000 c0088c38 0000014f 00010000 c047b240 c004c4fc
daa0: c047ecc0 00000022 c046dce0 c046db77 c005025c 00000000 00000008 00000000
dac0: 00000000 c0033070 ffffffff fa200000 c046db77 c0033a70 0001c5b7 00000000
dae0: 00000ee0 c04b0cf8 0009a1b5 0009a1b5 c046db77 c005025c 00000000 00000008
db00: 00000000 00000000 00000000 c046db20 c0334c08 c0184040 20000113 ffffffff
db20: c03ddad7 c046db3c c046db3c 00000001 c005025a c0037a3c c03ddad7 c03e4a41
db40: c046db3c 00010000 c046c2e8 00000000 31000000 32306131 20313238 30306131
db60: 30303030 30616520 30303030 35652033 30333039 28203031 33393565 34333033
db80: c0002029 fa318034 00001028 c046dbc0 00000000 c046dc58 fa318034 00000193
dba0: 00000000 c0037b18 00000007 c046fe68 00001028 c00332c8 00000000 00000000
dbc0: 00000007 00000000 00000000 fa318034 c046dc11 cf8ba680 c035e9a8 00000000
dbe0: 00000008 cc8a5c10 cc8a1180 cf9d0800 cc8a1180 cc8a1180 cc8a5c10 cf8ba680
dc00: 010110ac 010110ac cf9d0800 cc8a1180 c04c2f8c cf9d0800 00000608 00000000
dc20: 00000040 00000000 00000001 c02ba880 cf9d0800 cf9d0ba8 00000011 c02bae8c
dc40: ffffffff c046dc8c 00000000 00000025 00000000 c0033a2c c047b674 00000018
dc60: 00000000 fa318000 c0471d08 00000000 00000000 00000025 00000000 00000008
dc80: 00000000 00000000 00000002 c046dca0 c003ee08 c0050258 00000193 ffffffff
[<c004c754>] (omap_readl+0x4/0xc) from [<c0049480>] (omap34xx_32k_read+0xc/0x18)
[<c0049480>] (omap34xx_32k_read+0xc/0x18) from [<c0079a70>] (ktime_get+0x6c/0xd4)
[<c0079a70>] (ktime_get+0x6c/0xd4) from [<c0075ed0>] (__hrtimer_start_range_ns+0x6c/0x214)
[<c0075ed0>] (__hrtimer_start_range_ns+0x6c/0x214) from [<c0076098>] (hrtimer_start+0x20/0x28)
[<c0076098>] (hrtimer_start+0x20/0x28) from [<c023871c>] (ads7846_irq+0x6c/0x7c)
[<c023871c>] (ads7846_irq+0x6c/0x7c) from [<c0087438>] (handle_IRQ_event+0x34/0xf4)
[<c0087438>] (handle_IRQ_event+0x34/0xf4) from [<c0088c38>] (handle_edge_irq+0x10c/0x14c)
[<c0088c38>] (handle_edge_irq+0x10c/0x14c) from [<c004c4fc>] (gpio_irq_handler+0xfc/0x12c)
[<c004c4fc>] (gpio_irq_handler+0xfc/0x12c) from [<c0033070>] (asm_do_IRQ+0x70/0x90)
Exception stack(0xc046dad8 to 0xc046db20)
dac0:                                                       0001c5b7 00000000
Code: e28004b2 e1d000b0 e12fff1e e28004b2 (e5900000)
---[ end trace bd38be2c3330280f ]---
