Part Number: SK-TDA4VM
我在板端用官方提供的命令:./docker_build.sh配置docker镜像,但报错显示:
Error response from daemon: Get "">registry-1.docker.io/.../": dial tcp: lookup registry-1.docker.io on 1.0.0.1:53: dial udp 1.0.0.1:53: connect: network is
| errors | |
| 0 | |
| code | "UNAUTHORIZED" |
| message | "authentication required" |
| detail |
null |
