如题,本人现在在使用GPMC与FPGA通讯,现在问题是频率有些高,想降低到50M左右,现在FCLK的频率是200M。
参考e2e.ti.com/.../282404.aspx做修改,发现
clk_set_rate(clkp, rate)函数中的rate值并不是刻意随便更改的,目前只能更改为200000000,源程序中的值为400000000.
想请教一下论坛的前辈,是不是我修改的地方不对,还是其他原因,为什么频率没法改呢?
我修改的文档为:
linux/arch/arm/mach-omap2/Clock34xx.c
下面为该文档中我修改的函数,红色部分为我修改的地方。
int __init omap2_clk_set_freq(void)
struct clk *osc_sys_ck, *dpll1_ck, *arm_fck, *core_ck;
struct clk *dpll2_ck, *iva2_ck, *dpll3_m2_ck;
unsigned long osc_sys_rate;
unsigned long dsprate, l3rate;
short err = 0 ;
int l3div;
* Check if any processing is required.
if ((vdd1_opp == 0) && (vdd2_opp == 0))
return 0;
if (WARN((vdd1_opp == 0), "VDD1 OPP is not set.\n"))
err = 1;
if (WARN((vdd2_opp == 0), "VDD2 OPP is not set.\n"))
err = 1;
* Attempt to get the required clocks
dpll1_ck = clk_get(NULL, "dpll1_ck");
if (WARN(IS_ERR(dpll1_ck), "Failed to get dpll1_ck.\n"))
err = 1;
arm_fck = clk_get(NULL, "arm_fck");
if (WARN(IS_ERR(arm_fck), "Failed to get arm_fck.\n"))
err = 1;
core_ck = clk_get(NULL, "core_ck");
if (WARN(IS_ERR(core_ck), "Failed to get core_ck.\n"))
err = 1;
osc_sys_ck = clk_get(NULL, "osc_sys_ck");
if (WARN(IS_ERR(osc_sys_ck), "Failed to get osc_sys_ck.\n"))
err = 1;
dpll2_ck = clk_get(NULL, "dpll2_ck");
if (WARN(IS_ERR("dpll2_ck"), "Failed to get dpll2_ck.\n"))
err = 1;
iva2_ck = clk_get(NULL, "iva2_ck");
if (WARN(IS_ERR("iva2_ck"), "Failed to get iva2_ck.\n"))
err = 1;
dpll3_m2_ck = clk_get(NULL, "dpll3_m2_ck");
if (WARN(IS_ERR("dpll3_m2_ck"), "Failed to get dpll3_m2_ck.\n"))
err = 1;
if (err)
return -ENOENT;
* Set MPU frequency
mpurate = mpu_opps [vdd1_opp].rate;
if (clk_set_rate(dpll1_ck, mpurate))
pr_err("Unable to set MPU frequency (%u)\n", mpurate);
* Set DSP frequency
if (omap3_has_iva()) {
omap2_clk_iva_init_to_idle();
dsprate = dsp_opps [vdd1_opp].rate;
if (clk_set_rate(dpll2_ck, dsprate))
pr_err("Unable to set DSP frequency (%lu)\n", dsprate);
* Set L3 frequency
l3div = cm_read_mod_reg(CORE_MOD, CM_CLKSEL) &
OMAP3430_CLKSEL_L3_MASK;
l3rate = l3_opps[vdd2_opp].rate * l3div;
if (clk_set_rate(dpll3_m2_ck, l3rate))
pr_err("Unable to set L3 frequency (%lu)\n", l3rate);
* Re-calculate the clocks
recalculate_root_clocks();
osc_sys_rate = clk_get_rate(osc_sys_ck);
pr_info("Switched to new clocking rate (Crystal/Core/MPU): "
"%ld.%01ld/%ld/%ld MHz\n",
(osc_sys_rate / 1000000),
((osc_sys_rate / 100000) % 10),
(clk_get_rate(core_ck) / 1000000),
(clk_get_rate(arm_fck) / 1000000));
pr_info("IVA2 clocking rate: %ld MHz\n",
(clk_get_rate(iva2_ck) / 1000000)) ;
calibrate_delay();
return 0;
short err = 0 ;
int l3div;
return 0;
err = 1;
err = 1;
err = 1;
err = 1;
err = 1;
err = 1;
err = 1;
err = 1;
err = 1;
if (err)
return -ENOENT;
* Set MPU frequency
* Set DSP frequency
* Set L3 frequency
calibrate_delay();
return 0;
