load用汇编写的程序,可是无法运行
你好,
我初学汇编,想用汇编编写一段改变XF位从而改变LED灯暗灭的简单程序。(5416DSP, CCS3.3)
以下是我的程序:
1.main.asm
	                .def	main
			.def	timer0
			.mmregs
			.data
ms			.word	00h
			.text
main:		STM		#0000h,CLKMD
loop1:		LD		CLKMD,A
			AND		#01h,A
			BC		loop1,AEQ
			STM		#40C7h,CLKMD
			STM		#4240h,SWWSR
			STM		#0FFA0h,PMST
			STM		#0802h,BSCR
;INITIALIZE THE TIMER
			STM		#0000h,IMR
			STM		#0010h,TCR
			STM		#186Ah,PRD
			STM		#0C2Fh,TCR
			STM		#0008h,IFR
			ORM		#0008h,*(IMR)
			RSBX	INTM
			LD 		#40,DP;因为data段起始地址为0x8000,是第40页,其中有变量ms
loop2:
			LD		@ms,A
			SUB		#500,A
			BC		loop2,ANEQ
			ST		#0,@ms
			RSBX	XF
loop3:
			LD 		@ms,A
			SUB		#500,A
			BC		loop3,ANEQ
			BD		loop2
			ST		#0,@ms
			SSBX	XF
;interrupt
timer0:
			PSHM	AL
			PSHM	AH
			LD		@ms,A
			ADD		#01h,A
			STL		A,@ms
			POPM	AH
			POPM 	AL
			RETE
2.
		.ref	main
		.ref	timer0
		.sect   ".vectors"
rs: BD 		main
	nop
	nop
nmi: rete 		;NMI, SINT16
    nop
	NOP
	NOP
sint17: rete 	;SINT17
	NOP
	NOP
sint18: rete 	;SINT18
	NOP
	NOP
sint19: rete 	;SINT19
	NOP
	NOP
sint20: rete 	;SINT20
	NOP
	NOP
sint21: rete 	;SINT21
	NOP
	NOP
sint22: rete 	;SINT22
	NOP
	NOP
sint23: rete 	;SINT23
	NOP
	NOP
sint24: rete 	;SINT24
	NOP
	NOP
sint25: rete 	;SINT25
	NOP
	NOP
sint26: rete 	;SINT26
	NOP
	NOP
sint27: rete 	;SINT27
	NOP
	NOP
sint28: rete 	;SINT28
	NOP
	NOP
sint29: rete 	;SINT29
	NOP
	NOP
sint30: rete       	;SINT30
	NOP
	NOP
int0: rete 		;INT0, SINT0
	NOP
	NOP
int1: rete		;INT1, SINT1
	NOP
	NOP
int2: rete 		;INT2, SINT2
	NOP
	NOP
tint0: B  timer0 	;TINT0, SINT3
	NOP
	NOP
brint0: rete 	;BRINT0, SINT4
	NOP
	NOP
bxint0: rete 				;BXINT0, SINT5
	NOP
	NOP
dmac0: rete 				;DMAC0, brint2, SINT6
	NOP
	NOP
dmac1: rete 				;DMAC1, bxint2, SINT7 ??
	NOP
	NOP
int3: rete 					;INT3, SINT8
	NOP
	NOP
hpint:rete 				;HPINT, SINT9
	NOP
	NOP
brint1:rete				;BRINT1 or DMAC2, SINT10
	NOP
	NOP
bxint1: rete 				;BXINT1 or DMAC3, SINT11
	NOP
	NOP
dmac4: rete 				;DMAC4, SINT12
	NOP
	NOP
dmac5: rete				;DMAC5, SINT13
	NOP
	NOP
rsvd1: rete 				;reserved
	NOP
	NOP
rsvd2: rete 				;reserved
	NOP
	NOP
3. my.cmd
MEMORY
	PAGE 0:
		VECT:	origin = 0xFF80	   length = 0x80
		DARAM1:	origin = 0x0080	   length = 0x200
	PAGE 1:
		DARAM2: origin = 0x8000	   length = 0x100
SECTIONS
	.text    :>  	DARAM1	PAGE 0
	.vectors :>		VECT	PAGE 0
	.data	 :> 	DARAM2	PAGE 1
	.bss	 :>		DARAM2	PAGE 1
遇到的问题是,当直接加载后,跳出的窗口是没有指令的,即”-----------------“
                             当加载后,并且用.geL文件重启,即PC指向中断向量表,则程序无法正常从中断向量表跳到main。
请高手解答一下,谢谢!
vect.asm
  • 你好,
    我自己是这么解决的:把中断向量表里的第一个中断跳向 _c_int00,然后再.text段中令_c_int00: 跳向main。在linker选项当中选择load-time autoinitiation。我的程序中也有一些地方修改了一下。
    我想问的是,为什么之前那样直接跳到main不可以(在linker选项当中选择no autoinitiation)?还有,CCS中debug->reset CPU, 与.gel文件 reset CPU有什么区别?
  • 你好,
    试试cmd文件指定程序入口地址为main。
    -e main
  • Debug->Reset CPU是指CCS将执行software reset, 停止CPU并将PC指针指到reset vector.
    gel->Reset CPU要看你的gel文件中reset cpu hotmenu具体是怎么定义的。
  • 你好,
    这是我修改后的程序,可是现在无法运行了,不知道错在哪里了?好像中断进不去,您能不能帮我看看?
    		    .def    main
                .def    timer0
                .def    _c_int00
                .mmregs
                .data
    ms            .word    00h
                .text
    _c_int00:    B        main
    loop1:      LDM        CLKMD,A
                AND        #01h,A
                BC        loop1,ANEQ
                STM        #40C7h,CLKMD
                STM        #4240h,SWWSR
                STM        #0FFA8h,PMST
                STM        #0802h,BSCR
                STM        #0000h,IMR
                STM        #0010h,TCR
                STM        #186Ah,PRD
                STM        #0C2Fh,TCR
                STM        #0008h,IFR
                LD        #0,DP
                ORM        #0008h,*(IMR)
                RSBX    INTM
                STM        #ms,AR0
    loop2:
                LD        *AR0,A
                SUB        #500,A
                BC        loop2,ANEQ
                ST        #0,*AR0
                RSBX    XF
    loop3:
                LD         *AR0,A
                SUB        #500,A
                BC        loop3,ANEQ
                ST        #0,*AR0
                SSBX    XF
                B        loop2
    ;interrupt
    timer0:
                PSHM    AL
                PSHM    AH
                LD        *AR0,A
                ADD        #01h,A
                STL        A,*AR0
                POPM    AH
                POPM     AL
                RETE
    	.ref	main
    		.ref	timer0
    		.ref	_c_int00
    		.sect   ".vectors"
    rs: BD 	_c_int00
    	NOP
    	NOP
        nop
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    -stack 0x400
    MEMORY
    	PAGE 0:
    	PAGE 1:
    		DARAM2: origin = 0x8000	   length = 0x1000
    SECTIONS
  • 你好,
    请问
    1、为什么先load程序,然后DEBUG->RESET CPU之后,再run程序无法正常运行。而先RESET CPU,再load,再RUN就可以了。
    2、我将linker选项中改为no autoinitiation ,并且按照您说的在cmd中加入-e main,然后load程序之后PC指向main没错,程序也可以正常运行。但是我把main.asm中的“.def _c_int00”与“_c_int00:    B        main”两句注释掉之后(因为用不着),程序却无法正常运行了,请问为什么。
    谢谢~
  • 看一下IFR TINT位有没有置1?
  • 1. Debug->Reset CPU不会重新初始化所有的变量,而load会重新初始化
    2. 如果你用汇编写的话, 不需要_c_int00这个函数, 这个函数在rts.lib库中, 是建立C语言环境用的。
  • 为什么我IFR一直是0x0008,就算reset CPU之后还是0x0008.向IFR写入0XFFFF之后还是不变。
  • 感觉在IFR为0008h的时候,TINT0中断还是没有响应。单步调试的时候就一直在loop2当中,我修改了一下程序。我觉得是程序哪里出问题了,您能不能看下。
     .def    main
                .def    timer0
                .mmregs
                .data
    ms            .word    00h
                .text
    main:       RSBX	  CPL
    			SSBX      SXM
    			STM        #0000h,CLKMD
    loop1:      LDM        CLKMD,A
                AND        #01h,A
                BC        loop1,ANEQ
    			STM		   #0000h,ST0
                STM        #40C7h,CLKMD
                STM        #4240h,SWWSR
                STM        #0FFA8h,PMST
                STM        #0802h,BSCR
    ;setup SP
    stack_size	.set		10
    stack		.usect 	    ".stack",stack_size
               	STM			#(stack+stack_size-1),SP
                STM        #0000h,IMR
                STM        #0010h,TCR
                STM        #186Ah,PRD
                STM        #0C2Fh,TCR
                STM        #0008h,IFR
                LD        #0,DP
                ORM        #0008h,*(IMR)
                RSBX    INTM
                STM        #ms,AR0
    loop2:
                LD        *AR0,A
                SUB        #500,A
                BC        loop2,ANEQ
                ST        #0,*AR0
                RSBX    XF
    loop3:
                LD         *AR0,A
                SUB        #500,A
                BC        loop3,ANEQ
                ST        #0,*AR0
                SSBX    XF
                B        loop2
    ;interrupt
    timer0:
                PSHM    AL
                PSHM    AH
                LD        *AR0,A
                ADD        #01h,A
                STL        A,*AR0
                POPM    AH
                POPM     AL
                RETE
