TMS320C6748: win11下ccs5.5安装问题
Part Number: TMS320C6748
02/15/2023 16:34:47PM - Checking to see if <%EclipseDir%>/ccs_config.xml.bk exists
02/15/2023 16:34:47PM - ** Checking to see if D:\ti/ccsv5/eclipse/ccs_config.xml.bk exists
02/15/2023 16:34:47PM - Condition failed
02/15/2023 16:34:47PM - Skipping action 8DC9C68D-0C93-432C-9F50-9ECCB01EE7D2 - Rename Config File - conditions failed
02/15/2023 16:34:47PM - Checking conditions for 399F1ECF-EE97-4986-B49B-AFBAAA32EEB7 - Rename Update Installer - Before Action is Executed
02/15/2023 16:34:47PM - Checking condition 6C4DE03E-6713-48F2-82B8-822120A43BE6 - String Is Condition
02/15/2023 16:34:47PM - Checking to see if <%UpdateMode%> is true
02/15/2023 16:34:47PM - ** Checking to see if 0 is true
02/15/2023 16:34:47PM - Skipping action 399F1ECF-EE97-4986-B49B-AFBAAA32EEB7 - Rename Update Installer - conditions failed
02/15/2023 16:34:47PM - Checking conditions for BFD51AB7-3ADC-495B-8102-3465FBB334B3 - Message Box - Before Action is Executed
02/15/2023 16:34:47PM - Checking condition D4BB77EC-B3CA-4A9A-8817-3D84D19B7811 - String Is Condition
02/15/2023 16:34:47PM - Checking to see if <%GuiMode%> is true
02/15/2023 16:34:47PM - ** Checking to see if 1 is true
02/15/2023 16:34:47PM - Condition passed
02/15/2023 16:34:47PM - Checking condition EBE9B8A8-38F1-4848-BCAD-5D7C7C548025 - String Is Condition
02/15/2023 16:34:47PM - Skipping action BFD51AB7-3ADC-495B-8102-3465FBB334B3 - Message Box - conditions failed
02/15/2023 16:34:47PM - Checking conditions for 05EE68FE-6C93-4340-82C2-21CF20CE1591 - Create Update.txt - Before Action is Executed
02/15/2023 16:34:47PM - Checking condition C8AE338B-8D17-4EDB-99A9-313C01CA352A - String Is Condition
02/15/2023 16:34:47PM - Checking to see if <%updates_found%> is true
02/15/2023 16:34:47PM - ** Checking to see if false is true
02/15/2023 16:34:47PM - Skipping action 05EE68FE-6C93-4340-82C2-21CF20CE1591 - Create Update.txt - conditions failed
02/15/2023 16:34:47PM - Checking conditions for 1160585F-F26F-4111-911E-B0D10C849C31 - Remove .ij_running.txt - Before Action is Executed
02/15/2023 16:34:47PM - Checking condition 588D69A8-22C4-4BE8-A09F-5123D47D7FEF - File Exists Condition
02/15/2023 16:34:47PM - Checking to see if <%EclipseDir%>/downloads/.ijrunning.txt exists
02/15/2023 16:34:47PM - ** Checking to see if D:\ti/ccsv5/eclipse/downloads/.ijrunning.txt exists
02/15/2023 16:34:47PM - Skipping action 1160585F-F26F-4111-911E-B0D10C849C31 - Remove .ij_running.txt - conditions failed
  • win10好像也不支持但是看别人也装起来了?
  • 这是前面的部分
    02/16/2023 17:05:52PM - InstallID : F830CCB7-1C8E-4D57-A76C-121BDEBF90D1
    02/16/2023 17:05:52PM - Installer : E:\electric_board\tms320c6748\Tools\CCS5.5.0.00077_win32\ccs_setup_5.5.0.00077.exe
    02/16/2023 17:05:52PM - BuildName : ccs_setup_5.5.0.00077.exe
    02/16/2023 17:05:52PM - Install version: 5.5.0.00077
    02/16/2023 17:05:52PM - Install source : E:\electric_board\tms320c6748\Tools\CCS5.5.0.00077_win32
    02/16/2023 17:05:52PM - OS : Windows
    02/16/2023 17:05:52PM - UserName : SenHao
    02/16/2023 17:05:52PM - Update? : 0
    02/16/2023 17:05:52PM - testmode : false
    02/16/2023 17:05:52PM - testurl : <%testurl%>
    02/16/2023 17:05:52PM - http info : -accept */* -proxyfilter http::ProxyRequired -proxyhost {} -proxyport {} -urlencoding utf-8 -useragent {Tcl http client package 2.5.3}
    02/16/2023 17:05:52PM - tmp dir : C:/Users/Éòê»/AppData/Local/Temp/ijtmp_D449BE43-DA3B-4C4D-B588-F1FC701D029C
    02/16/2023 17:05:52PM - InstallURL : <%InstallURL%>
    02/16/2023 17:05:52PM - Command line : /installkitvfs/main.tcl 0
    02/16/2023 17:05:52PM - Executing action DAE6D44E-3DC2-4543-A1EB-001C5F515422 - Find NVidia
    02/16/2023 17:05:52PM - Executing action B8763022-D5E2-4AA8-844A-EC7CFCAD7157 - Set answer (OK)
    02/16/2023 17:05:52PM - Checking conditions for 27036D2D-68D1-4483-BE67-0FF19E850B0E - Message Box - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition AD8FFE88-09C6-4C1A-B557-188632C09B2D - String Is Condition
    02/16/2023 17:05:52PM - Checking to see if <%foundNVidia%> is true
    02/16/2023 17:05:52PM - ** Checking to see if false is true
    02/16/2023 17:05:52PM - Condition failed
    02/16/2023 17:05:52PM - Skipping action 27036D2D-68D1-4483-BE67-0FF19E850B0E - Message Box - conditions failed
    02/16/2023 17:05:52PM - Checking conditions for 73D33A11-6A32-4488-A6B1-9BB8ACD7372B - Exit (NVidia) - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition 32FD86A1-3EC3-4270-9E8D-7476DE237A5E - String Equal Condition
    02/16/2023 17:05:52PM - Checking to see if <%answer%> equals Cancel
    02/16/2023 17:05:52PM - ** Checking to see if OK equals Cancel
    02/16/2023 17:05:52PM - Skipping action 73D33A11-6A32-4488-A6B1-9BB8ACD7372B - Exit (NVidia) - conditions failed
    02/16/2023 17:05:52PM - Checking conditions for B64D3D93-67B0-4BD9-9B1B-4264B8023A45 - Set Temp value - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition 5401F86C-FE5E-4FF7-A77A-C4CBD8D576EB - Execute Script Condition
    02/16/2023 17:05:52PM - Condition passed
    02/16/2023 17:05:52PM - Executing action B64D3D93-67B0-4BD9-9B1B-4264B8023A45 - Set Temp value
    02/16/2023 17:05:52PM - Executing action A2728FBB-5A26-4329-BFBE-DE6C9E246501 - Check Temp/Installsource value
    02/16/2023 17:05:52PM - Checking conditions for 3A18DFFF-E127-407E-987E-23B777277223 - Check for McAfee - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition 60C48044-51FA-4487-BFBF-5E5276E11AA6 - Platform Condition
    02/16/2023 17:05:52PM - Checking to see if <%Platform%> is Windows
    02/16/2023 17:05:52PM - ** Checking to see if Windows is Windows
    02/16/2023 17:05:52PM - Executing action 3A18DFFF-E127-407E-987E-23B777277223 - Check for McAfee
    02/16/2023 17:05:52PM - Registry key HKEY_LOCAL_MACHINE\SOFTWARE\McAfee does not exist unable to open key: 系统找不到指定的文件。
    02/16/2023 17:05:52PM - Checking conditions for 123EF823-0459-4F01-ABF1-BE12CCBD883C - Check for junctions (Windows) - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition 9DA2DCAC-C1A2-4FA9-A505-21437A8B0431 - Platform Condition
    02/16/2023 17:05:52PM - Executing action 123EF823-0459-4F01-ABF1-BE12CCBD883C - Check for junctions (Windows)
    02/16/2023 17:05:52PM - checking C:/Users/Éòê»/AppData/Local/Temp/ijtmp_D449BE43-DA3B-4C4D-B588-F1FC701D029C for links
    02/16/2023 17:05:52PM - Checking conditions for 6D910536-6D94-48FC-9FB6-DEC5FBC0E6B9 - Set Update variables if needed - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition A2DF4B22-7FD5-40DD-A8C7-744CDD290075 - String Equal Condition
    02/16/2023 17:05:52PM - Checking to see if <%InstallPrefix%> equals ccs_update
    02/16/2023 17:05:52PM - ** Checking to see if ccs_setup equals ccs_update
    02/16/2023 17:05:52PM - Skipping action 6D910536-6D94-48FC-9FB6-DEC5FBC0E6B9 - Set Update variables if needed - conditions failed
    02/16/2023 17:05:52PM - Checking conditions for FD9BA738-0681-4F8C-A99E-D9630FE9317A - Get InstallDir - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition 96501BA3-2DAB-4133-BEAD-86FCA44BFE84 - String Is Condition
    02/16/2023 17:05:52PM - Checking to see if <%UpdateMode%> is true
    02/16/2023 17:05:52PM - ** Checking to see if 0 is true
    02/16/2023 17:05:52PM - Skipping action FD9BA738-0681-4F8C-A99E-D9630FE9317A - Get InstallDir - conditions failed
    02/16/2023 17:05:52PM - Checking conditions for 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition A2036039-9CCB-492A-8247-6D07128AEE2F - Command Line Test Condition
    02/16/2023 17:05:52PM - Checking to see if eclipseprefix was passed on the command line
    02/16/2023 17:05:52PM - Skipping action 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - conditions failed
    02/16/2023 17:05:52PM - Checking conditions for 99A470ED-DD5C-4D41-BA90-A04A061322EB - Set Native Eclipse Variable - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition DF6C1A44-866A-4053-A6D4-D810A1260FFA - String Is Condition
    02/16/2023 17:05:52PM - Skipping action 99A470ED-DD5C-4D41-BA90-A04A061322EB - Set Native Eclipse Variable - conditions failed
    02/16/2023 17:05:52PM - Checking conditions for 0E76BDFA-AE33-4D11-80D4-021EEE28FADA - Set Valid Eclipse Variable - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition A0F1E771-08C1-4655-89F3-A760BAE68E12 - String Is Condition
    02/16/2023 17:05:52PM - Skipping action 0E76BDFA-AE33-4D11-80D4-021EEE28FADA - Set Valid Eclipse Variable - conditions failed
    02/16/2023 17:05:52PM - Checking conditions for F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition C434E3F3-C405-466D-9713-A8F99B3BCC12 - Command Line Test Condition
    02/16/2023 17:05:52PM - Checking to see if response-file was passed on the command line
    02/16/2023 17:05:52PM - Skipping action F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - conditions failed
    02/16/2023 17:05:52PM - Checking conditions for 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition DDEDDBE3-895A-4F08-B242-B5CEB39360F2 - Platform Condition
    02/16/2023 17:05:52PM - Executing action 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information
    02/16/2023 17:05:52PM - Checking System Info...
    02/16/2023 17:05:52PM - Registry key WindowsCSDVersionString does not exist
    02/16/2023 17:05:52PM - Windows 7 Ultimate matched .*\s*Windows 7.*
    02/16/2023 17:05:52PM - WindowsProductName= Windows 7 Ultimate
    WindowsCurrentVersion= 6.1
    WindowsCSDVersionString= -
    WindowsCSDVersionDWord= 0
    WindowsPlatform= Windows7
    02/16/2023 17:05:52PM - Executing action 1409F691-5623-49F1-99EB-D4ED15870571 - Set BuildName (default)
    02/16/2023 17:05:52PM - Setting active setup type to New Setup Type (B6E0CE8C-4E6F-4885-953A-32946A051105).
    02/16/2023 17:05:52PM - Activating component D253A697-7480-46F3-AF71-AB63991129FD
    02/16/2023 17:05:52PM - Executing actions A0AAD47D-43D9-43F8-9439-47A03F6F4E2B - Startup Actions
    02/16/2023 17:05:52PM - Executing action 13EDEC6E-8DA0-4447-BDEA-CA07B2E6C024 - Run Common Startup Actions
    02/16/2023 17:05:52PM - Executing actions 0C7AA01C-904A-49D5-A05B-E0AE9CC22448 - Common Startup Actions
    02/16/2023 17:05:52PM - Checking conditions for 22F60A3C-BD94-46EA-A08B-8DE1A6DE012D - - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition 4759E3D6-FA8F-4285-8B95-F54DBEA3EEC5 - Platform Condition
    02/16/2023 17:05:52PM - Executing action 22F60A3C-BD94-46EA-A08B-8DE1A6DE012D - Check For Reboots (Windows)
    02/16/2023 17:05:52PM - Executing actions C5310624-D7B0-49EA-8FC1-2DF23B182604 - Check For Reboots
    02/16/2023 17:05:52PM - Executing action E5553D24-EE8E-4F1E-9135-8F2D646360AC - Run reg.exe 1
    02/16/2023 17:05:52PM - Executing Command Line: reg.exe query {HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager} /v PendingFileRenameOperations
    02/16/2023 17:05:52PM - Executing action 3BEBA945-EC03-49BA-923B-4462C8B0014B - Write reg text 1
    02/16/2023 17:05:52PM - Executing action 1CE32F44-11E6-4A2A-8A3B-2C2FED1167A3 - Disable Wow64 Redirection
    02/16/2023 17:05:52PM - Executing action 0F3250A5-CF27-4500-8C41-59F5DCE44D15 - Run reg.exe 1
    02/16/2023 17:05:52PM - Executing Command Line: reg.exe query {HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\RebootRequired}
    02/16/2023 17:05:52PM - Error while executing: ´íÎó: ϵͳÕҲ»µ½ָ¶¨µÄע²á±íÏî»òֵ¡£
    02/16/2023 17:05:52PM - Executing action 65EA5366-7EB8-49AD-9A3E-4F89BF27182B - Write reg text 1
    02/16/2023 17:05:52PM - Executing action 40ECEE20-4593-482C-A807-3446FE6334DE - Check registry keys
    02/16/2023 17:05:52PM - Checking for reboots ...
    02/16/2023 17:05:52PM - Registry key UpdateExeVolatile does not exist unable to open key: 系统找不到指定的文件。
    02/16/2023 17:05:52PM - Registry key rebootrequired does not exist unable to open key: 系统找不到指定的文件。
    02/16/2023 17:05:52PM - ´íÎó: ϵͳÕҲ»µ½ָ¶¨µÄע²á±íÏî»òֵ¡£ reboot required
    02/16/2023 17:05:52PM - Executing action 8CF4D98E-2365-4D45-93AB-A75D9F9A45B6 - Revert Wow64 Redirection
    02/16/2023 17:05:52PM - Checking conditions for 177AA845-805E-424B-A48A-6E2BFD6C9CD6 - - Before Action is Executed
    02/16/2023 17:05:52PM - Checking condition 05370712-1717-4B2A-A7F9-359FCCA2E57B - String Is Condition
    02/16/2023 17:05:52PM - Checking to see if <%GuiMode%> is true
    02/16/2023 17:05:52PM - ** Checking to see if 1 is true
    02/16/2023 17:05:52PM - Checking condition 0459569F-EDC5-4A4D-93EE-0FB7BE84B4C9 - String Is Condition
    02/16/2023 17:05:52PM - Checking to see if <%UpdateMode%> is false
    02/16/2023 17:05:52PM - ** Checking to see if 0 is false
    02/16/2023 17:05:52PM - Checking condition 50A21EBD-54A7-45F4-8988-7791D76EC6A3 - String Is Condition
    02/16/2023 17:05:52PM - Checking to see if <%FoundReboot%> is true
    02/16/2023 17:05:52PM - ** Checking to see if true is true
    02/16/2023 17:05:52PM - Executing action 177AA845-805E-424B-A48A-6E2BFD6C9CD6 - Reboot Message
    02/16/2023 17:05:55PM - Checking conditions for E52C2017-2ED3-4B74-BBE2-86BB2E723383 - - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition 0FAA39B6-E52E-4D19-B9EC-7071A6697A0C - String Is Condition
    02/16/2023 17:05:55PM - Checking to see if <%GuiMode%> is false
    02/16/2023 17:05:55PM - ** Checking to see if 1 is false
    02/16/2023 17:05:55PM - Condition failed
    02/16/2023 17:05:55PM - Skipping action E52C2017-2ED3-4B74-BBE2-86BB2E723383 - Reboot Message - conditions failed
    02/16/2023 17:05:55PM - Checking conditions for CC5D72E4-5258-41C5-9C78-AB886C2F8673 - - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition 9D5BB820-1691-42D3-8ADE-0DC2304F9BCD - String Equal Condition
    02/16/2023 17:05:55PM - Checking to see if <%Answer%> equals No
    02/16/2023 17:05:55PM - ** Checking to see if yes equals No
    02/16/2023 17:05:55PM - Skipping action CC5D72E4-5258-41C5-9C78-AB886C2F8673 - Exit - conditions failed
    02/16/2023 17:05:55PM - Executing action 1C82CB44-08EC-4BAE-BCF7-719902E9C236 - Execute Windows Startup
    02/16/2023 17:05:55PM - Checking conditions for AED7E1E0-3E40-41B5-A471-FAAFD73529F8 - Windows Startup Action - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition BDCBFA61-EF65-4DF4-A4C3-1CD5758BDD79 - Platform Condition
    02/16/2023 17:05:55PM - Checking to see if <%Platform%> is Windows
    02/16/2023 17:05:55PM - ** Checking to see if Windows is Windows
    02/16/2023 17:05:55PM - Condition passed
    02/16/2023 17:05:55PM - Executing actions AED7E1E0-3E40-41B5-A471-FAAFD73529F8 - Windows Startup Action
    02/16/2023 17:05:55PM - Executing action C4D1AB2C-8D0E-4AF0-BA43-2DF6CA3D3A1C - Check Memory
    02/16/2023 17:05:55PM - Checking Memory...
    02/16/2023 17:05:55PM - Checking conditions for 98FB6613-1F73-4BCB-8DDB-B431EBD71496 - - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition 17D28D55-F95F-4DD0-AC94-EF4CDE6400D2 - Execute Script Condition
    02/16/2023 17:05:55PM - C:/Users/Éòê»/AppData/Local/Temp is writable ? 1 or 1
    02/16/2023 17:05:55PM - C:/Users/Éòê»/AppData/Local/Temp/ijtmp_D449BE43-DA3B-4C4D-B588-F1FC701D029C exists? 1
    02/16/2023 17:05:55PM - C:/Users/Éòê»/AppData/Local/Temp/ijtmp_D449BE43-DA3B-4C4D-B588-F1FC701D029C is writable ? 1
    02/16/2023 17:05:55PM - making C:/Users/Éòê»/AppData/Local/Temp/ijtmp_D449BE43-DA3B-4C4D-B588-F1FC701D029C/baserepo
    02/16/2023 17:05:55PM - Skipping action 98FB6613-1F73-4BCB-8DDB-B431EBD71496 - Exit if no access to Temp dir - conditions failed
    02/16/2023 17:05:55PM - Checking conditions for B6872AE1-0E02-431F-B454-399EF4DB3A9F - - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition 0747C492-B4C3-420E-B891-6A9F93C6AA21 - Command Line Test Condition
    02/16/2023 17:05:55PM - Checking to see if prefix was passed on the command line
    02/16/2023 17:05:55PM - Skipping action B6872AE1-0E02-431F-B454-399EF4DB3A9F - Check InstallDir parameter - conditions failed
    02/16/2023 17:05:55PM - Checking conditions for 1514399D-CAAF-4087-9E82-A65109B675F8 - - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition 245ABF90-7270-43B9-A0A7-17F7DAAB3466 - Command Line Test Condition
    02/16/2023 17:05:55PM - Checking to see if eclipseprefix was passed on the command line
    02/16/2023 17:05:55PM - Skipping action 1514399D-CAAF-4087-9E82-A65109B675F8 - Execute Look for EclipseDir - conditions failed
    02/16/2023 17:05:55PM - Executing action 7A1CB0AB-04A3-41C0-8655-22F6AE6A972A - Full CCS or Component install test
    02/16/2023 17:05:55PM - .*_setup_5.5.*
    02/16/2023 17:05:55PM - full installer
    02/16/2023 17:05:55PM - Checking conditions for 390AFA53-7D35-4C26-A453-27B7CEBB834E - - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition AB402A5E-1927-4722-B563-CAF54B6E53AA - Platform Condition
    02/16/2023 17:05:55PM - Executing action 390AFA53-7D35-4C26-A453-27B7CEBB834E - Unpack Setup xml file
    02/16/2023 17:05:55PM - Unpacking C:/Users/Éòê»/AppData/Local/Temp/ijtmp_D449BE43-DA3B-4C4D-B588-F1FC701D029C/ccs_installini.xml
    02/16/2023 17:05:55PM - Checking conditions for F4C790E5-5B05-43B4-ABC4-B4B9C1C01A59 - - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition D1A276F0-17F4-498A-B707-E9B7CDAF7109 - Platform Condition
    02/16/2023 17:05:55PM - Checking to see if <%Platform%> is Linux-x86
    02/16/2023 17:05:55PM - ** Checking to see if Windows is Linux-x86
    02/16/2023 17:05:55PM - Skipping action F4C790E5-5B05-43B4-ABC4-B4B9C1C01A59 - Unpack Setup xml file - conditions failed
    02/16/2023 17:05:55PM - Executing action 1FDA0E1A-FA6B-40B5-934E-553F9ABDC49B - Set InstallIni file name
    02/16/2023 17:05:55PM - InstallSource = E:/electric_board/tms320c6748/Tools/CCS5.5.0.00077_win32
    02/16/2023 17:05:55PM - InstallIni file = C:/Users/Éòê»/AppData/Local/Temp/ijtmp_D449BE43-DA3B-4C4D-B588-F1FC701D029C/ccs_installini.xml C:/Users/Éòê»/AppData/Local/Temp/ijtmp_D449BE43-DA3B-4C4D-B588-F1FC701D029C/ccs_installini.xml
    02/16/2023 17:05:55PM - Executing action C325767C-1961-4AB1-8037-7C19CB4BA543 - Get Setup Types
    02/16/2023 17:05:55PM - Executing action D6E650CF-E79A-4C23-86E7-FE0AF5BB288C - Set USERPROFILE variable
    02/16/2023 17:05:55PM - userprofile = C:\Users\Éò↑»
    02/16/2023 17:05:55PM - C:\Users\Éò↑»/ti doesn't exist, all's well
    02/16/2023 17:05:55PM - Checking conditions for DCC432F6-3409-4694-A45A-ADE2F727D197 - Run Main Startup Actions - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition 811E0FCC-5436-4EF1-B100-38D48AEDAEDB - String Is Condition
    02/16/2023 17:05:55PM - Checking to see if <%UpdateMode%> is false
    02/16/2023 17:05:55PM - ** Checking to see if 0 is false
    02/16/2023 17:05:55PM - Executing action DCC432F6-3409-4694-A45A-ADE2F727D197 - Run Main Startup Actions
    02/16/2023 17:05:55PM - Executing actions 4BA19292-8FFD-40DE-8CA5-B8FC9CDD9A15 - Main Startup Actions
    02/16/2023 17:05:55PM - Executing action 164527E4-7D70-4D17-BBF9-D2D79EA6EC93 - Run Manifest File Actions
    02/16/2023 17:05:55PM - Executing actions 2E15C1E1-4FB2-4D3F-8401-2D82FB9F0AF6 - Manifest File Actions
    02/16/2023 17:05:55PM - Checking conditions for 25BA989D-274D-4302-A91E-48B8454834E4 - - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition 45766827-6E1C-43A5-AE55-3EDC12383C2C - Platform Condition
    02/16/2023 17:05:55PM - Skipping action 25BA989D-274D-4302-A91E-48B8454834E4 - Unpack Manifest xml file - conditions failed
    02/16/2023 17:05:55PM - Checking conditions for 1C65743D-E0A5-4787-B152-3A21723C2002 - - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition 9B003E01-3775-4A7C-ABAD-252F786C62F6 - Platform Condition
    02/16/2023 17:05:55PM - Executing action 1C65743D-E0A5-4787-B152-3A21723C2002 - Unpack Manifest xml file
    02/16/2023 17:05:55PM - Unpacking C:/Users/Éòê»/AppData/Local/Temp/ijtmp_D449BE43-DA3B-4C4D-B588-F1FC701D029C/ccs_manifest.xml
    02/16/2023 17:05:55PM - Checking conditions for 64C32BE4-E5A9-49DE-B300-99E89DCD537B - - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition 6CB61E0B-777D-4323-B690-2D6B7EC21739 - String Is Condition
    02/16/2023 17:05:55PM - Checking to see if <%ComponentInstaller%> is false
    02/16/2023 17:05:55PM - ** Checking to see if false is false
    02/16/2023 17:05:55PM - Executing action 64C32BE4-E5A9-49DE-B300-99E89DCD537B - Set Manifest file name (Main)
    02/16/2023 17:05:55PM - InstallIni file = C:/Users/Éòê»/AppData/Local/Temp/ijtmp_D449BE43-DA3B-4C4D-B588-F1FC701D029C/ccs_manifest.xml C:/Users/Éòê»/AppData/Local/Temp/ijtmp_D449BE43-DA3B-4C4D-B588-F1FC701D029C/ccs_manifest.xml
    02/16/2023 17:05:55PM - Checking conditions for 2237DB6B-9676-4FDA-8BBB-9CD0741C175B - - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition 15FF209F-7BBD-4D5E-BDC0-36EE302F2496 - String Is Condition
    02/16/2023 17:05:55PM - Checking to see if <%ComponentInstaller%> is true
    02/16/2023 17:05:55PM - ** Checking to see if false is true
    02/16/2023 17:05:55PM - Skipping action 2237DB6B-9676-4FDA-8BBB-9CD0741C175B - Set Manifest file name (Component) - conditions failed
    02/16/2023 17:05:55PM - Checking conditions for CB39A277-9A24-430C-8680-A15529B595BE - - Before Action is Executed
    02/16/2023 17:05:55PM - Checking condition 016B1F93-7184-4FC3-8688-0A1889957CA9 - String Is Condition
    02/16/2023 17:05:55PM - Skipping action CB39A277-9A24-430C-8680-A15529B595BE - Exit - conditions failed
    02/16/2023 17:05:55PM - Executing action 02082184-215D-4D0A-9DA8-3288BFC36931 - Run Get URL Name
    02/16/2023 17:05:55PM - Executing actions C6771919-CB79-4C4F-A842-7560C1B039E5 - Get URL Name
    02/16/2023 17:05:55PM - Executing action C6771919-CB79-4C4F-A842-7560C1B039E5 - Get URL Name
    02/16/2023 17:05:55PM - P2version =
    02/16/2023 17:05:55PM - Reading manifest file C:/Users/Éòê»/AppData/Local/Temp/ijtmp_D449BE43-DA3B-4C4D-B588-F1FC701D029C/ccs_manifest.xml
    02/16/2023 17:05:55PM - tsvar = domNode03CDE090
    02/16/2023 17:05:55PM - idvar = domNode03CDE5A0
    02/16/2023 17:05:55PM - ID = 5.5.0.00077
    02/16/2023 17:05:55PM - found at least one product update, setting product install eq true
    02/16/2023 17:05:55PM - updateversion is blank
    02/16/2023 17:05:55PM - urlname = |Code Composer Studio v5 Updates|
    02/16/2023 17:05:55PM - repotype = multiple
    02/16/2023 17:05:55PM - ts = 20130906145948
  • 官方是不支持win10,请按照官方要求操作。如果没有win7,建议使用高版本的CCS。
  • 好吧,换了台win10的PC装起来了
  • 感谢告知!
