你好,在CaptureLink_drvCreateInst这个函数里面pVipCreateArgs->inDataFormat = pInstPrm->inDataFormat;这个值我不知道怎么从上面传过来,当我的分辨率大于1080p,它就默认是1080p
Int32 CaptureLink_drvCreateInst(CaptureLink_Obj * pObj, UInt16 instId)
CaptureLink_VipInstParams *pInstPrm;
CaptureLink_InstObj *pInst;
Vps_CaptCreateParams *pVipCreateArgs;
Vps_CaptOutInfo *pVipOutPrm;
CaptureLink_OutParams *pOutPrm;
System_LinkChInfo *pQueChInfo;
UInt16 queId, queChId, outId, chId, inWidth, inHeight;
FVID2_ScanFormat inScanFormat;
pInstPrm = &pObj->createArgs.vipInst[instId];
pInst = &pObj->instObj[instId];
pVipCreateArgs = &pInst->createArgs;
pInst->instId = pInstPrm->vipInstId;
pInst->numChPerOutput = pInstPrm->numChPerOutput;
pInst->enableTs = pInstPrm->enableTimestampInInterrupt;
CaptureLink_drvInitCreateArgs(pVipCreateArgs);
pVipCreateArgs->inDataFormat = pInstPrm->inDataFormat;/////////////////////////////////////////////////////////////
#if 1
int i = 100;
while(i--){
Vps_printf("pInstPrm->standard = %d\n",pInstPrm->standard);
#endif
memset(&pInst->vidDecCurStatus, 0, sizeof(pInst->vidDecCurStatus));
for(chId=0; chId<VPS_CAPT_CH_PER_PORT_MAX; chId++)
pInst->vidDecCurStatus[chId].chId = chId;
pInst->vidDecCurStatus[chId].vipInstId = pInst->instId;
if (pInstPrm->videoDecoderId == FVID2_VPS_VID_DEC_TVP5158_DRV)
inScanFormat = FVID2_SF_INTERLACED;
if(pObj->createArgs.enableSdCrop)
pInst->maxWidth = 704;
else
pInst->maxWidth = 720;
if (pObj->isPalMode)
pInst->maxHeight = 288;
else
pInst->maxHeight = 240;
inWidth = pInst->maxWidth;
inHeight = pInst->maxHeight;
pVipCreateArgs->videoCaptureMode =
VPS_CAPT_VIDEO_CAPTURE_MODE_MULTI_CH_PIXEL_MUX_EMBEDDED_SYNC;
pVipCreateArgs->videoIfMode = VPS_CAPT_VIDEO_IF_MODE_8BIT;
switch (pInstPrm->standard)
case FVID2_STD_CIF:
pInst->maxHeight = pInst->maxHeight/2 ;
inHeight = inHeight/2;
case FVID2_STD_HALF_D1:
pVipCreateArgs->numCh = 1;
VPS_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_EMBEDDED_SYNC;
pInst->maxWidth = pInst->maxWidth/2;
inWidth = inWidth/2;
break;
case FVID2_STD_D1:
// psuedo HD mode
if(pObj->createArgs.fakeHdMode)
pInst->maxWidth = 1920;
pInst->maxHeight = 1080;
break;
case FVID2_STD_MUX_2CH_D1:
pVipCreateArgs->numCh = 2;
break;
case FVID2_STD_MUX_4CH_CIF:
pInst->maxHeight /= 2 ;
case FVID2_STD_MUX_4CH_HALF_D1:
pVipCreateArgs->numCh = 4;
break;
case FVID2_STD_MUX_4CH_960H:
pInst->maxWidth = 944;
else
pInst->maxWidth = 960;
case FVID2_STD_MUX_4CH_D1:
default:
break;
else
case FVID2_STD_1080I_60:
if (pVipCreateArgs->inDataFormat == FVID2_DF_RGB24_888)
inScanFormat = FVID2_SF_PROGRESSIVE; // since in 24-bit
// discrete sync
// mode FID signal
// is not
// connected in
// board
pInst->maxHeight = 540;
inWidth = 1920;
inHeight = 540;
break;
case FVID2_STD_720P_60:
pInst->maxWidth = 1280;
pInst->maxHeight = 720;
inWidth = 1280;
inHeight = 720;
break;
case FVID2_STD_576P:
pInst->maxHeight = 576;
inWidth = 720;
inHeight = 576;
break;
case FVID2_STD_480I:
