Part Number: TMS320C6678
当程序在小端模式编译成功时,理解SEED XDS560V2 仿真器,加载程序时连接报错:Does not match the target endianness, not loaded. Check project build options and target configuration file(ccxml).
请问是否可通过软件设置,使得开发板运行小端程序?
只能通过硬件,把LENDIAN管脚拉高配成小端模式,请看数据手册说明Table 3-1 TMS320C6678 Device Configuration Pins。
https://www.ti.com/lit/ds/symlink/tms320c6678.pdf
