8168 16路编码只有一路数据有效
Other Parts Discussed in Thread: TVP5158
大家好,我现在用自制的8168板运行rdk中demo,硬件为4片tvp5158,接入16路d1视频,直接显示这16路视频,是正常的,但编码后发现只有第一路有有效编码数据,通过打印得到的buf的信息,只有正常的那一路的mvDataFilledSize是大于0的,其余都为0,看了代码目前也没发现哪里有问题,希望各位给点调试建议,拓宽一下思路,谢谢
BitBufInfo:virt:0x44487c80,bufSize:622080,chnId:0,codecType:9,filledBufSize:7362,mvDataFilledSize:17396,timeStamp:103708,isKeyFrame:0,phy:0x91da9c80,width:704height:480
BitBufInfo:virt:0x4477f280,bufSize:622080,chnId:11,codecType:9,filledBufSize:25,mvDataFilledSize:0,timeStamp:103710,isKeyFrame:0,phy:0x920a1280,width:704height:480
BitBufInfo:virt:0x44d6de80,bufSize:622080,chnId:1,codecType:9,filledBufSize:5556,mvDataFilledSize:0,timeStamp:103711,isKeyFrame:0,phy:0x9268fe80,width:704height:480
BitBufInfo:virt:0x445b7880,bufSize:622080,chnId:2,codecType:9,filledBufSize:25,mvDataFilledSize:0,timeStamp:103713,isKeyFrame:0,phy:0x91ed9880,width:704height:480
BitBufInfo:virt:0x44ba6480,bufSize:622080,chnId:3,codecType:9,filledBufSize:7827,mvDataFilledSize:0,timeStamp:103717,isKeyFrame:0,phy:0x924c8480,width:704height:480
BitBufInfo:virt:0x44946c80,bufSize:622080,chnId:5,codecType:9,filledBufSize:7194,mvDataFilledSize:0,timeStamp:103719,isKeyFrame:0,phy:0x92268c80,width:704height:480
BitBufInfo:virt:0x450fd280,bufSize:622080,chnId:12,codecType:9,filledBufSize:6611,mvDataFilledSize:0,timeStamp:103720,isKeyFrame:0,phy:0x92a1f280,width:704height:480
BitBufInfo:virt:0x45065480,bufSize:622080,chnId:6,codecType:9,filledBufSize:6951,mvDataFilledSize:0,timeStamp:103722,isKeyFrame:0,phy:0x92987480,width:704height:480
BitBufInfo:virt:0x44e05c80,bufSize:622080,chnId:13,codecType:9,filledBufSize:7832,mvDataFilledSize:0,timeStamp:103723,isKeyFrame:0,phy:0x92727c80,width:704height:480
BitBufInfo:virt:0x449dea80,bufSize:622080,chnId:7,codecType:9,filledBufSize:6568,mvDataFilledSize:0,timeStamp:103724,isKeyFrame:0,phy:0x92300a80,width:704height:480
BitBufInfo:virt:0x44a76880,bufSize:622080,chnId:15,codecType:9,filledBufSize:7957,mvDataFilledSize:0,timeStamp:103726,isKeyFrame:0,phy:0x92398880,width:704height:480
