Part Number: PROCESSOR-SDK-AM62X
Other Parts Discussed in Thread: AM625, SK-AM62
tar: ./usr/bin/cmake: time stamp 2022-12-14 13:42:04 is 2641.456978585 s in the future tar: ./usr/bin/containerd: time stamp 2022-12-14 14:58:23 is 7218.651506035 s in the future [ 2860.981392] mmc0: running CQE recovery [ 2860.996979] mmc0: running CQE recovery [ 2860.998313] mmc0: running CQE recovery [ 2860.999370] mmc0: running CQE recovery [ 2861.000970] mmc0: running CQE recovery [ 2861.006289] mmc0: running CQE recovery [ 2861.007324] mmc0: running CQE recovery [ 2861.008954] mmc0: running CQE recovery [ 2861.015265] mmc0: running CQE recovery [ 2861.031938] mmc0: running CQE recovery [ 2861.032945] print_req_error: 25 callbacks suppressed [ 2861.032963] blk_update_request: I/O error, dev mmcblk0, sector 17069024 op 0x1:(WRITE) flags 0x4000 phys_seg 17 prio class 0 [ 2861.033244] mmc0: running CQE recovery [ 2861.034284] blk_update_request: I/O error, dev mmcblk0, sector 17070048 op 0x1:(WRITE) flags 0x4000 phys_seg 17 prio class 0 [ 2861.045853] mmc0: running CQE recovery [ 2861.053873] mmc0: running CQE recovery [ 2861.058818] blk_update_request: I/O error, dev mmcblk0, sector 17068000 op 0x1:(WRITE) flags 0x4000 phys_seg 17 prio class 0 [ 2861.068269] mmc0: running CQE recovery [ 2861.076576] mmc0: running CQE recovery [ 2861.081737] mmc0: running CQE recovery [ 2861.082929] mmc0: running CQE recovery [ 2861.099754] EXT4-fs warning: 13 callbacks suppressed [ 2861.099777] EXT4-fs warning (device mmcblk0p1): ext4_end_bio:347: I/O error 10 writing to inode 523442 starting block 2133925) [ 2861.099922] buffer_io_error: 11640 callbacks suppressed [ 2861.099930] Buffer I/O error on device mmcblk0p1, logical block 2132860 [ 2861.099958] Buffer I/O error on device mmcblk0p1, logical block 2132861 [ 2861.099964] Buffer I/O error on device mmcblk0p1, logical block 2132862 [ 2861.099971] Buffer I/O error on device mmcblk0p1, logical block 2132863 [ 2861.099978] Buffer I/O error on device mmcblk0p1, logical block 2132864 [ 2861.099985] Buffer I/O error on device mmcblk0p1, logical block 2132865 [ 2861.099992] Buffer I/O error on device mmcblk0p1, logical block 2132866 [ 2861.099998] Buffer I/O error on device mmcblk0p1, logical block 2132867 tar: [ 2861.100004] Buffer I/O error on device mmcblk0p1, logical block 2132868 ./usr/bin/containerd-ctr: time stamp 2022-12-14 14:58:23 is 7217[ 2861.100011] Buffer I/O error on device mmcblk0p1, logical block 2132869 .69618382 s in the future [ 2861.101556] mmc0: running CQE recovery [ 2861.106140] blk_update_request: I/O error, dev mmcblk0, sector 17056824 op 0x1:(WRITE) flags 0x4000 phys_seg 82 prio class 0 [ 2861.106728] mmc0: running CQE recovery [ 2861.110588] mmc0: running CQE recovery [ 2861.117495] blk_update_request: I/O error, dev mmcblk0, sector 17061192 op 0x1:(WRITE) flags 0x4000 phys_seg 15 prio class 0 [ 2861.118818] mmc0: running CQE recovery [ 2861.125939] mmc0: running CQE recovery [ 2861.127420] mmc0: running CQE recovery [ 2861.128237] blk_update_request: I/O error, dev mmcblk0, sector 17064264 op 0x1:(WRITE) flags 0x0 phys_seg 24 prio class 0 [ 2861.129562] mmc0: running CQE recovery tar: ./usr/bin/containerd-shim: time stamp 2022-12-14 14:58:23 is 7217.36616946 s in the future tar: ./usr/bin/cpack: time stamp 2022-12-14 13:42:04 is 2637.968259065 s in the future tar: ./usr/bin/cpp: time stamp 2022-12-14 13:52:00 is 3233.967577875 s in the future tar: ./usr/bin/crossscripts: time stamp 2022-12-14 13:13:06 is 899.94117555 s in the future tar: ./usr/bin/cryptdir: time stamp 2022-12-14 13:16:31 is 1104.94076695 s in the future tar: ./usr/bin/ctest: time stamp 2022-12-14 13:42:04 is 2637.70119498 s in the future tar: ./usr/bin/cvtsudoers: time stamp 2022-12-14 12:59:08 is 61.66823581 s in the future tar: ./usr/bin/decryptdir: time stamp 2022-12-14 13:16:31 is 1104.63633819 s in the future tar: ./usr/bin/dislocate: time stamp 2022-12-14 13:16:31 is 1104.612384365 s in the future tar: ./usr/bin/docker: time stamp 2022-12-14 15:00:39 is 7350.278375805 s in the future [ 2921.498239] mmc0: cqhci: timeout for tag 25 [ 2921.498266] mmc0: cqhci: ============ CQHCI REGISTER DUMP =========== [ 2921.498270] mmc0: cqhci: Caps: 0x000030c8 | Version: 0x00000510 [ 2921.498276] mmc0: cqhci: Config: 0x00000101 | Control: 0x00000000 [ 2921.498281] mmc0: cqhci: Int stat: 0x00000000 | Int enab: 0x00000006 [ 2921.498285] mmc0: cqhci: Int sig: 0x00000006 | Int Coal: 0x00000000 [ 2921.498289] mmc0: cqhci: TDL base: 0x80ef9000 | TDL up32: 0x00000000 [ 2921.498293] mmc0: cqhci: Doorbell: 0xffffffff | TCN: 0x00000000 [ 2921.498298] mmc0: cqhci: Dev queue: 0x00000000 | Dev Pend: 0x00000000 [ 2921.498302] mmc0: cqhci: Task clr: 0x00000000 | SSC1: 0x00011000 [ 2921.498307] mmc0: cqhci: SSC2: 0x00000001 | DCMD rsp: 0x00000000 [ 2921.498311] mmc0: cqhci: RED mask: 0xfdf9a080 | TERRI: 0x872f052c [ 2921.498316] mmc0: cqhci: Resp idx: 0x0000002d | Resp arg: 0x00000d00 [ 2921.498320] mmc0: sdhci: ============ SDHCI REGISTER DUMP =========== [ 2921.498325] mmc0: sdhci: Sys addr: 0x00000400 | Version: 0x00001004 [ 2921.498329] mmc0: sdhci: Blk size: 0x00007080 | Blk cnt: 0x00000000 [ 2921.498334] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013 [ 2921.498338] mmc0: sdhci: Present: 0x01ff00f0 | Host ctl: 0x0000003c [ 2921.498343] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 2921.498347] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000007 [ 2921.498351] mmc0: sdhci: Timeout: 0x0000000e | Int stat: 0x00000000 [ 2921.498355] mmc0: sdhci: Int enab: 0x02ff4000 | Sig enab: 0x02ff4000 [ 2921.498359] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 2921.498363] mmc0: sdhci: Caps: 0x3decc801 | Caps_1: 0x18002407 [ 2921.498367] mmc0: sdhci: Cmd: 0x0000153a | Max curr: 0x00000000 [ 2921.498372] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffc003ff [ 2921.498377] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d07f01 [ 2921.498380] mmc0: sdhci: Host ctl2: 0x0000000b [ 2921.498384] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000081e5720c [ 2921.498389] mmc0: sdhci: ============================================ [ 2921.498424] mmc0: running CQE recovery [ 2921.504462] mmc0: running CQE recovery [ 2921.515617] mmc0: running CQE recovery [ 2921.520871] mmc0: running CQE recovery [ 2921.550551] mmc0: running CQE recovery [ 2921.559104] mmc0: running CQE recovery [ 2921.569970] mmc0: running CQE recovery [ 2921.577616] mmc0: running CQE recovery [ 2921.582919] mmc0: running CQE recovery [ 2921.584175] mmc0: running CQE recovery [ 2921.585363] mmc0: running CQE recovery [ 2921.586225] blk_update_request: I/O error, dev mmcblk0, sector 17057848 op 0x1:(WRITE) flags 0x4000 phys_seg 91 prio class 0 [ 2921.586249] EXT4-fs warning (device mmcblk0p1): ext4_end_bio:347: I/O error 10 writing to inode 523440 starting block 2132377) [ 2921.586303] blk_update_request: I/O error, dev mmcblk0, sector 17062216 op 0x1:(WRITE) flags 0x4000 phys_seg 24 prio class 0 [ 2982.938220] mmc0: cqhci: timeout for tag 0 [ 2982.938251] mmc0: cqhci: ============ CQHCI REGISTER DUMP =========== [ 2982.938256] mmc0: cqhci: Caps: 0x000030c8 | Version: 0x00000510 [ 2982.938261] mmc0: cqhci: Config: 0x00000101 | Control: 0x00000000 [ 2982.938266] mmc0: cqhci: Int stat: 0x00000000 | Int enab: 0x00000006 [ 2982.938270] mmc0: cqhci: Int sig: 0x00000006 | Int Coal: 0x00000000 [ 2982.938274] mmc0: cqhci: TDL base: 0x80ef9000 | TDL up32: 0x00000000 [ 2982.938279] mmc0: cqhci: Doorbell: 0xffffffff | TCN: 0x00000000 [ 2982.938283] mmc0: cqhci: Dev queue: 0x00000000 | Dev Pend: 0x00000000 [ 2982.938287] mmc0: cqhci: Task clr: 0x00000000 | SSC1: 0x00011000 [ 2982.938292] mmc0: cqhci: SSC2: 0x00000001 | DCMD rsp: 0x00000000 [ 2982.938296] mmc0: cqhci: RED mask: 0xfdf9a080 | TERRI: 0x992f1a2c [ 2982.938301] mmc0: cqhci: Resp idx: 0x0000002f | Resp arg: 0x00000900 [ 2982.938306] mmc0: sdhci: ============ SDHCI REGISTER DUMP =========== [ 2982.938311] mmc0: sdhci: Sys addr: 0x00000400 | Version: 0x00001004 [ 2982.938315] mmc0: sdhci: Blk size: 0x00007080 | Blk cnt: 0x00000000 [ 2982.938320] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013 [ 2982.938324] mmc0: sdhci: Present: 0x01ff00f0 | Host ctl: 0x0000003c [ 2982.938329] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 2982.938334] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000007 [ 2982.938339] mmc0: sdhci: Timeout: 0x0000000e | Int stat: 0x00000000 [ 2982.938343] mmc0: sdhci: Int enab: 0x02ff4000 | Sig enab: 0x02ff4000 [ 2982.938348] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 2982.938352] mmc0: sdhci: Caps: 0x3decc801 | Caps_1: 0x18002407 [ 2982.938357] mmc0: sdhci: Cmd: 0x0000153a | Max curr: 0x00000000 [ 2982.938361] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffc003ff [ 2982.938365] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d07f01 [ 2982.938369] mmc0: sdhci: Host ctl2: 0x0000000b [ 2982.938373] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000081e5720c [ 2982.938378] mmc0: sdhci: ============================================ [ 2982.938447] mmc0: running CQE recovery [ 2982.955917] mmc0: running CQE recovery [ 2982.980064] mmc0: running CQE recovery [ 2982.986814] mmc0: running CQE recovery [ 3044.378219] mmc0: cqhci: timeout for tag 0 [ 3044.378248] mmc0: cqhci: ============ CQHCI REGISTER DUMP =========== [ 3044.378251] mmc0: cqhci: Caps: 0x000030c8 | Version: 0x00000510 [ 3044.378256] mmc0: cqhci: Config: 0x00000101 | Control: 0x00000000 [ 3044.378261] mmc0: cqhci: Int stat: 0x00000000 | Int enab: 0x00000006 [ 3044.378265] mmc0: cqhci: Int sig: 0x00000006 | Int Coal: 0x00000000 [ 3044.378269] mmc0: cqhci: TDL base: 0x80ef9000 | TDL up32: 0x00000000 [ 3044.378274] mmc0: cqhci: Doorbell: 0xffffffff | TCN: 0x00000000 [ 3044.378278] mmc0: cqhci: Dev queue: 0x00000000 | Dev Pend: 0x00000000 [ 3044.378282] mmc0: cqhci: Task clr: 0x00000000 | SSC1: 0x00011000 [ 3044.378286] mmc0: cqhci: SSC2: 0x00000001 | DCMD rsp: 0x00000000 [ 3044.378290] mmc0: cqhci: RED mask: 0xfdf9a080 | TERRI: 0x9e2f182c [ 3044.378295] mmc0: cqhci: Resp idx: 0x0000002f | Resp arg: 0x00000900 [ 3044.378300] mmc0: sdhci: ============ SDHCI REGISTER DUMP =========== [ 3044.378305] mmc0: sdhci: Sys addr: 0x00000400 | Version: 0x00001004 [ 3044.378309] mmc0: sdhci: Blk size: 0x00007080 | Blk cnt: 0x00000000 [ 3044.378313] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013 [ 3044.378318] mmc0: sdhci: Present: 0x01ff00f0 | Host ctl: 0x0000003c [ 3044.378322] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 3044.378326] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000007 [ 3044.378331] mmc0: sdhci: Timeout: 0x0000000e | Int stat: 0x00000000 [ 3044.378335] mmc0: sdhci: Int enab: 0x02ff4000 | Sig enab: 0x02ff4000 [ 3044.378339] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 3044.378343] mmc0: sdhci: Caps: 0x3decc801 | Caps_1: 0x18002407 [ 3044.378347] mmc0: sdhci: Cmd: 0x0000153a | Max curr: 0x00000000 [ 3044.378352] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffc003ff [ 3044.378356] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d07f01 [ 3044.378360] mmc0: sdhci: Host ctl2: 0x0000000b [ 3044.378365] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000081e5720c [ 3044.378369] mmc0: sdhci: ============================================ [ 3044.378434] mmc0: running CQE recovery [ 3044.381981] mmc0: running CQE recovery [ 3044.400848] mmc0: running CQE recovery [ 3044.411171] mmc0: running CQE recovery [ 3044.413504] mmc0: running CQE recovery [ 3044.417729] mmc0: running CQE recovery [ 3044.425287] blk_update_request: I/O error, dev mmcblk0, sector 17089480 op 0x1:(WRITE) flags 0x4000 phys_seg 27 prio class 0 [ 3044.434580] mmc0: running CQE recovery [ 3044.440631] mmc0: running CQE recovery [ 3044.442099] mmc0: running CQE recovery [ 3044.465522] mmc0: running CQE recovery [ 3044.467840] mmc0: running CQE recovery [ 3044.469968] mmc0: running CQE recovery [ 3044.476961] blk_update_request: I/O error, dev mmcblk0, sector 17063240 op 0x1:(WRITE) flags 0x4000 phys_seg 49 prio class 0 [ 3044.476991] EXT4-fs warning (device mmcblk0p1): ext4_end_bio:347: I/O error 10 writing to inode 523441 starting block 2133116) [ 3044.478489] mmc0: running CQE recovery
使用AM62x的官方开发板,从SD卡使用tar解压根文件系统到EMMC时,在解压了4-5分钟后会报错中断,报错内容如上。尝试用cp命令拷贝SD卡根目录下的文件同样也会出现。尝试过重新分区格式化过EMMC还是无效。使用的内核镜像与根文件系统都是TI默认提供的。
