Other Parts Discussed in Thread: SK-AM62, , TPS65219
原理图:
引脚基本相同,使用SK-AM62 E3的SD卡启动内容,请问设备树文件和uboot配置该如何修改?
sdk版本为ti-processor-sdk-linux-am62xx-evm-08.04.01.03
这是串口打印的最后部分信息:
clk_get_parent(clk=7000be40)
--->>> LPDDR4 Initialization is in progress ... <<<---
LPDDR4_Start: PASS
fdtdec_setup_mem_size_base: Initial DRAM size x
TLB table from ffffc000 to 00000000
SPL malloc() before relocation used 0x6d50 bytes (27 KB)
>>SPL: board_init_r()
using memory lx-lx for malloc()
spl_init
fdtdec_setup_memory_banksize: DRAM Bank #0: start = 0xx, size = 0xx
am625_init: spl_boot_device: devstat = 0xe43 bootmedia = 0x8 bootindex = 0
Trying to boot from MMC2
0 1
- 0 -1 'mmc@fa10000'
- 1 -1 'mmc@fa00000'
- not found
1 1
- found
size=x, ptr=80, limit=80: 81f00000
size=x, ptr=4, limit=84: 81f00080
OF: ** translation for device mmc@fa00000 **
OF: bus is default (na=2, ns=2) on bus@f0000
OF: translating address: 00000000 0000a00f
OF: parent bus is default (na=2, ns=2) on
OF: walking ranges...
OF: default map, cp=x, s=x, da=x
OF: parent translation for: 00000000 0000000e
OF: with offset: u
OF: one level translation: 00000000 0000a00f
OF: reached root node
ofnode_read_bool: non-removable: false
ofnode_read_u32_index: ti,strobe-sel: (not found)
ofnode_read_u32_index: ti,clkbuf-sel: x (7)
ofnode_read_u32_index: bus-width: x (4)
ofnode_read_u32_index: max-frequency: (not found)
ofnode_read_bool: cap-sd-highspeed: false
ofnode_read_bool: cap-mmc-highspeed: false
ofnode_read_bool: sd-uhs-sdr12: false
ofnode_read_bool: sd-uhs-sdr25: false
ofnode_read_bool: sd-uhs-sdr50: false
ofnode_read_bool: sd-uhs-sdr104: false
ofnode_read_bool: sd-uhs-ddr50: false
ofnode_read_bool: mmc-ddr-1_8v: false
ofnode_read_bool: mmc-ddr-1_2v: false
ofnode_read_bool: mmc-hs200-1_8v: false
ofnode_read_bool: mmc-hs200-1_2v: false
ofnode_read_bool: mmc-hs400-1_8v: false
ofnode_read_bool: mmc-hs400-1_2v: false
ofnode_read_bool: mmc-hs400-enhanced-strobe: false
ofnode_read_bool: cd-inverted: false
ofnode_read_bool: broken-cd: false
ofnode_read_bool: no-1-8-v: false
0 1
- not found
0 -1
0 0
- -1 0 'wkup-uart0-pins-default'
- found
0 1
- -1 2 'main-uart0-pins-default'
- -1 -1 'main-i2c0-pins-default'
- -1 -1 'main-mmc1-pins-default'
- -1 -1 'main-mdio1-pins-default'
- -1 -1 'main-rgmii1-pins-default'
- -1 -1 'main-rgmii2-pins-default'
- -1 -1 'main-usb1-pins-default'
- -1 -1 'ospi0-pins-default'
- -1 1 'main-uart1-pins-default'
- found
0 2
- found
0 3
- not found
0 0
- -1 0 'pinctrl@4084000'
- found
pinconfig main-mmc1-pins-default: set_state_simple op missing
clk_set_defaults(main-mmc1-pins-default)
clk_set_default_parents: could not read assigned-clock-parents for 700078a4
ofnode_read_prop: assigned-clock-rates: <not found>
single-pinctrl pinctrl@f4000: configuring pins for main-mmc1-pins-default
single-pinctrl pinctrl@f4000: reg/val 0xf423c/0x00050000
single-pinctrl pinctrl@f4000: reg/val 0xf4234/0x00050000
single-pinctrl pinctrl@f4000: reg/val 0xf4230/0x00050000
single-pinctrl pinctrl@f4000: reg/val 0xf422c/0x00050000
single-pinctrl pinctrl@f4000: reg/val 0xf4228/0x00050000
single-pinctrl pinctrl@f4000: reg/val 0xf4224/0x00050000
single-pinctrl pinctrl@f4000: reg/val 0xf4240/0x00050000
到这里就停止了
U-Boot SPL 2021.01-00001-g441d4eb-dirty (Dec 06 2022 - 11:17:36 +0800) 0 0 - 0 -1 'sysctrler' - 1 -1 'a53@0' - not found 1 0 - 0 -1 'sysctrler' - found size=x, ptr=30, limit=6724: 7000d6f4 0 0 - 0 -1 'sysctrler' - 1 -1 'a53@0' - not found 0 0 - -1 0 'pinctrl@4084000' - found k3_system_controller sysctrler: set_state_simple op missing rproc_pre_probe: 'sysctrler': using fdt fdtdec_get_bool: remoteproc-internal-memory-mapped clk_set_defaults(sysctrler) clk_set_default_parents: could not read assigned-clock-parents for 700084c8 ofnode_read_prop: assigned-clock-rates: <not found> k3_sysctrler_probe(dev=700084c8) mbox_get_by_name(dev=700084c8, name=tx, chan=7000d6f4) mbox_get_by_index(dev=700084c8, index=0, chan=7000d6f4) fdtdec_get_int: #mbox-cells: x (1) k3_sec_proxy_of_xlate(chan=7000d6f4) k3_sec_proxy_request(chan=7000d6f4) mbox_get_by_name(dev=700084c8, name=rx, chan=7000d700) mbox_get_by_index(dev=700084c8, index=1, chan=7000d700) fdtdec_get_int: #mbox-cells: x (1) fdtdec_get_int: #mbox-cells: x (1) k3_sec_proxy_of_xlate(chan=7000d700) k3_sec_proxy_request(chan=7000d700) mbox_get_by_name(dev=700084c8, name=boot_notify, chan=7000d70c) mbox_get_by_index(dev=700084c8, index=2, chan=7000d70c) fdtdec_get_int: #mbox-cells: x (1) fdtdec_get_int: #mbox-cells: x (1) fdtdec_get_int: #mbox-cells: x (1) size=x, ptr=20, limit=6744: 7000d724 0 -1 0 0 - -1 0 'mailbox@4d000000' - found 0 1 - -1 0 'mailbox@4d000000' - -1 -1 'secproxy@44880000' - not found 0 0 - -1 0 'pinctrl@4084000' - found k3-secure-proxy secproxy@44880000: set_state_simple op missing clk_set_defaults(secproxy@44880000) clk_set_default_parents: could not read assigned-clock-parents for 7000845c ofnode_read_prop: assigned-clock-rates: <not found> k3_sec_proxy_probe(dev=7000845c) OF: ** translation for device secproxy@44880000 ** OF: bus is default (na=2, ns=2) on bus@f0000 OF: translating address: 00000000 00006043 OF: parent bus is default (na=2, ns=2) on OF: walking ranges... OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: parent translation for: 00000000 00006043 OF: with offset: u OF: one level translation: 00000000 00006043 OF: reached root node OF: ** translation for device secproxy@44880000 ** OF: bus is default (na=2, ns=2) on bus@f0000 OF: translating address: 00000000 00008644 OF: parent bus is default (na=2, ns=2) on OF: walking ranges... OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: parent translation for: 00000000 00008644 OF: with offset: u OF: one level translation: 00000000 00008644 OF: reached root node OF: ** translation for device secproxy@44880000 ** OF: bus is default (na=2, ns=2) on bus@f0000 OF: translating address: 00000000 00008844 OF: parent bus is default (na=2, ns=2) on OF: walking ranges... OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: parent translation for: 00000000 00008644 OF: with offset: u OF: one level translation: 00000000 00008844 OF: reached root node size=x, ptr=12c, limit=6870: 7000d744 size=x, ptr=3c, limit=68ac: 7000d870 size=x, ptr=3c, limit=68e8: 7000d8ac size=x, ptr=3c, limit=6924: 7000d8e8 size=x, ptr=3c, limit=6960: 7000d924 size=x, ptr=3c, limit=699c: 7000d960 size=x, ptr=3c, limit=69d8: 7000d99c size=x, ptr=3c, limit=6a14: 7000d9d8 size=x, ptr=3c, limit=6a50: 7000da14 size=x, ptr=3c, limit=6a8c: 7000da50 size=x, ptr=3c, limit=6ac8: 7000da8c size=x, ptr=3c, limit=6b04: 7000dac8 size=x, ptr=3c, limit=6b40: 7000db04 size=x, ptr=3c, limit=6b7c: 7000db40 size=x, ptr=3c, limit=6bb8: 7000db7c size=x, ptr=3c, limit=6bf4: 7000dbb8 k3_sec_proxy_of_xlate(chan=7000d70c) k3_sec_proxy_request(chan=7000d70c) 0 0 - 0 0 'sysctrler' - found _rproc_ops_wrapper: Starting sysctrler... k3_sysctrler_start(dev=700084c8) mbox_recv(chan=7000d70c, data=70006e68, timeout_us=800000) k3_sec_proxy_recv(chan=7000d70c, data=70006e68) k3_sec_proxy_recv: Message successfully received from thread 0 k3_sysctrler_boot_notification_response: Boot notification received k3_sysctrler_start: Boot notification received successfully on dev sysctrler SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.7--v08.04.07 (Jolly Jellyfi') 0 -1 0 0 - -1 -1 'esm@4100000' - -1 -1 'esm@420000' - not found 0 0 - -1 0 'pinctrl@4084000' - found k3_esm esm@420000: set_state_simple op missing clk_set_defaults(esm@420000) clk_set_default_parents: could not read assigned-clock-parents for 70008528 ofnode_read_prop: assigned-clock-rates: <not found> OF: ** translation for device esm@420000 ** OF: bus is default (na=2, ns=2) on bus@f0000 OF: translating address: 00000000 00004200 OF: parent bus is default (na=2, ns=2) on OF: walking ranges... OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: parent translation for: 00000000 00004200 OF: with offset: u OF: one level translation: 00000000 00004200 OF: reached root node ofnode_read_prop: ti,esm-pins: size=x, ptr=40, limit=6c40: aligned to 7000dc00 ofnode_read_u32_array: ti,esm-pins: fdtdec_get_int_array: ti,esm-pins get_prop_check_min_len: ti,esm-pins 0 -1 0 0 - -1 -1 'esm@4100000' - -1 0 'esm@420000' - found 0 1 - -1 -1 'esm@4100000' - -1 0 'esm@420000' - not found 0 0 - -1 0 'pinctrl@4084000' - found k3_esm esm@4100000: set_state_simple op missing clk_set_defaults(esm@4100000) clk_set_default_parents: could not read assigned-clock-parents for 70007248 ofnode_read_prop: assigned-clock-rates: <not found> OF: ** translation for device esm@4100000 ** OF: bus is default (na=2, ns=2) on bus@4000000 OF: translating address: 00000000 00001004 OF: parent bus is default (na=2, ns=2) on bus@f0000 OF: walking ranges... OF: default map, cp=x, s=x, da=x OF: parent translation for: 00000000 00000004 OF: with offset: u OF: one level translation: 00000000 00001004 OF: parent bus is default (na=2, ns=2) on OF: walking ranges... OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: parent translation for: 00000000 00000004 OF: with offset: u OF: one level translation: 00000000 00001004 OF: reached root node ofnode_read_prop: ti,esm-pins: size=x, ptr=40, limit=6c80: aligned to 7000dc40 ofnode_read_u32_array: ti,esm-pins: fdtdec_get_int_array: ti,esm-pins get_prop_check_min_len: ti,esm-pins size=x, ptr=d0, limit=6d50: 7000dc80 0 -1 0 0 - -1 -1 'memorycontroller@f300000' - not found 0 0 - -1 0 'pinctrl@4084000' - found k3_ddrss memorycontroller@f300000: set_state_simple op missing fdtdec_get_int: #power-domain-cells: x (2) fdtdec_get_int: #power-domain-cells: x (2) power_domain_get_by_index(dev=70008594, power_domain=70006ebc) fdtdec_get_int: #power-domain-cells: x (2) ti_power_domain_of_xlate(power_domain=70006ebc, id=170) power_domain_on(power_domain=70006ebc) ti_power_domain_on(pd=70006ebc, id=9) ti_lpsc_transition: transitioning psc:1, lpsc:9 to 3 psc_read: 0x100 from 400a24 psc_read: 0x1 from 400300 psc_write: 0x103 to 400a24 psc_write: 0x1 to 400120 psc_read: 0x1 from 400128 psc_read: 0x0 from 400128 psc_read: 0x1f03 from 400824 power_domain_get_by_index(dev=70008594, power_domain=70006ebc) fdtdec_get_int: #power-domain-cells: x (2) fdtdec_get_int: #power-domain-cells: x (2) ti_power_domain_of_xlate(power_domain=70006ebc, id=55) power_domain_on(power_domain=70006ebc) ti_power_domain_on(pd=70006ebc, id=11) ti_lpsc_transition: transitioning psc:1, lpsc:11 to 3 ti_lpsc_transition: transitioning psc:1, lpsc:10 to 3 psc_read: 0x100 from 400a28 psc_write: 0x103 to 400a28 psc_write: 0x1 to 400120 psc_read: 0x0 from 400128 psc_read: 0x1f03 from 400828 psc_read: 0x100 from 400a2c psc_write: 0x103 to 400a2c psc_write: 0x1 to 400120 psc_read: 0x0 from 400128 psc_read: 0x1f03 from 40082c clk_set_defaults(memorycontroller@f300000) clk_set_default_parents: could not read assigned-clock-parents for 70008594 ofnode_read_prop: assigned-clock-rates: <not found> k3_ddrss_probe(dev=70008594) k3_ddrss_ofdata_to_priv(dev=70008594) OF: ** translation for device memorycontroller@f300000 ** OF: bus is default (na=2, ns=2) on OF: translating address: 00000000 0080300f OF: reached root node OF: ** translation for device memorycontroller@f300000 ** OF: bus is default (na=2, ns=2) on OF: translating address: 00000000 00400143 OF: reached root node OF: ** translation for device memorycontroller@f300000 ** OF: bus is default (na=2, ns=2) on OF: translating address: 00000000 0000300f OF: reached root node power_domain_get_by_index(dev=70008594, power_domain=7000dc90) fdtdec_get_int: #power-domain-cells: x (2) ti_power_domain_of_xlate(power_domain=7000dc90, id=170) power_domain_get_by_index(dev=70008594, power_domain=7000dc9c) fdtdec_get_int: #power-domain-cells: x (2) fdtdec_get_int: #power-domain-cells: x (2) ti_power_domain_of_xlate(power_domain=7000dc9c, id=55) fdtdec_get_int: #clock-cells: x (2) ti_clk_of_xlate(clk=7000dca8, args_count=2 [0]=170 [1]=0) clk_request(dev=700076d4, clk=7000dca8) fdtdec_get_int: #clock-cells: x (2) fdtdec_get_int: #clock-cells: x (2) ti_clk_of_xlate(clk=7000dcc8, args_count=2 [0]=16 [1]=4) clk_request(dev=700076d4, clk=7000dcc8) ofnode_read_u32_index: ti,ddr-freq0: (not found) clk_get_rate(clk=7000dcc8) clk_get_rate(clk=700095c0) clk_get_parent_rate(clk=700095c0) clk_get_parent(clk=700095c0) k3_ddrss memorycontroller@f300000: ddr freq0 not populated, using bypass frequency 25000000 ofnode_read_u32_index: ti,ddr-freq1: x (400000000) ofnode_read_u32_index: ti,ddr-freq2: x (400000000) ofnode_read_u32_index: ti,ddr-fhs-cnt: x (6) ofnode_read_bool: ti,ecc-enable: false k3_ddrss_power_on(ddrss=7000dc80) power_domain_on(power_domain=7000dc90) ti_power_domain_on(pd=7000dc90, id=9) power_domain_on(power_domain=7000dc9c) ti_power_domain_on(pd=7000dc9c, id=11) k3_ddrss memorycontroller@f300000: vtt-supply not found. LPDDR4_Probe: PASS LPDDR4_Init: PASS ofnode_read_u32_array: ti,ctl-data: fdtdec_get_int_array: ti,ctl-data get_prop_check_min_len: ti,ctl-data ofnode_read_u32_array: ti,pi-data: fdtdec_get_int_array: ti,pi-data get_prop_check_min_len: ti,pi-data ofnode_read_u32_array: ti,phy-data: fdtdec_get_int_array: ti,phy-data get_prop_check_min_len: ti,phy-data clk_set_rate(clk=7000dca8, rate=400000000) clk_get_rate(clk=7000be40) clk_get_parent_rate(clk=7000be40) clk_get_parent(clk=7000be40) clk_get_rate(clk=7000b000) clk_get_parent_rate(clk=7000b000) clk_get_parent(clk=7000b000) clk_set_rate(clk=7000be40, rate=400000000) clk_get_parent_rate(clk=7000be40) clk_get_parent(clk=7000be40) clk_get_rate(clk=7000be40) clk_get_parent_rate(clk=7000be40) clk_get_parent(clk=7000be40) ti_clk_set_rate: clk=hsdiv0_16fft_main_12_hsdivout0_clk, div=1, rate=400000000, new_rate=25000000, diff=375000000 ti_clk_set_rate: propagating rate change to parent, rate=400000000. clk_get_parent(clk=7000be40) ti_clk_set_rate: pll_tgt=800000000, rate=400000000, div=2 clk_set_rate(clk=7000b000, rate=800000000) clk_get_parent_rate(clk=7000b000) clk_get_parent(clk=7000b000) ti_pll_clk_set_rate(clk=7000b000, rate=800000000) clk_get_parent_rate(clk=7000b000) clk_get_parent(clk=7000b000) ti_pll_clk_set_rate: pre-frac-calc: rate=800000000, parent_freq=25000000, plld=1, pllm=32 ti_pll_clk_set_rate: pllm=32, plld=1, pllfm=0, parent_freq=25000000 clk_set_rate(clk=7000be40, rate=400000000) clk_get_parent_rate(clk=7000be40) clk_get_parent(clk=7000be40) clk_get_rate(clk=7000b000) clk_get_parent_rate(clk=7000b000) clk_get_parent(clk=7000b000) clk_get_rate(clk=7000be40) clk_get_parent_rate(clk=7000be40) clk_get_parent(clk=7000be40) --->>> LPDDR4 Initialization is in progress ... <<<--- LPDDR4_Start: PASS fdtdec_setup_mem_size_base: Initial DRAM size x TLB table from ffffc000 to 00000000 SPL malloc() before relocation used 0x6d50 bytes (27 KB) >>SPL: board_init_r() using memory lx-lx for malloc() spl_init fdtdec_setup_memory_banksize: DRAM Bank #0: start = 0xx, size = 0xx am625_init: spl_boot_device: devstat = 0xe43 bootmedia = 0x8 bootindex = 0 Trying to boot from MMC2 0 1 - 0 -1 'mmc@fa10000' - 1 -1 'mmc@fa00000' - not found 1 1 - 0 -1 'mmc@fa10000' - 1 -1 'mmc@fa00000' - found size=x, ptr=80, limit=80: 81f00000 size=x, ptr=4, limit=84: 81f00080 OF: ** translation for device mmc@fa00000 ** OF: bus is default (na=2, ns=2) on bus@f0000 OF: translating address: 00000000 0000a00f OF: parent bus is default (na=2, ns=2) on OF: walking ranges... OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: default map, cp=x, s=x, da=x OF: parent translation for: 00000000 0000000e OF: with offset: u OF: one level translation: 00000000 0000a00f OF: reached root node ofnode_read_bool: non-removable: false ofnode_read_u32_index: ti,strobe-sel: (not found) ofnode_read_u32_index: ti,clkbuf-sel: x (7) ofnode_read_u32_index: bus-width: x (4) ofnode_read_u32_index: max-frequency: (not found) ofnode_read_bool: cap-sd-highspeed: false ofnode_read_bool: cap-mmc-highspeed: false ofnode_read_bool: sd-uhs-sdr12: false ofnode_read_bool: sd-uhs-sdr25: false ofnode_read_bool: sd-uhs-sdr50: false ofnode_read_bool: sd-uhs-sdr104: false ofnode_read_bool: sd-uhs-ddr50: false ofnode_read_bool: mmc-ddr-1_8v: false ofnode_read_bool: mmc-ddr-1_2v: false ofnode_read_bool: mmc-hs200-1_8v: false ofnode_read_bool: mmc-hs200-1_2v: false ofnode_read_bool: mmc-hs400-1_8v: false ofnode_read_bool: mmc-hs400-1_2v: false ofnode_read_bool: mmc-hs400-enhanced-strobe: false ofnode_read_bool: non-removable: false ofnode_read_bool: cd-inverted: false ofnode_read_bool: broken-cd: false ofnode_read_bool: no-1-8-v: false 0 1 - 0 -1 'mmc@fa10000' - 1 -1 'mmc@fa00000' - not found 0 -1 0 0 - -1 0 'wkup-uart0-pins-default' - found 0 1 - -1 0 'wkup-uart0-pins-default' - -1 2 'main-uart0-pins-default' - -1 -1 'main-i2c0-pins-default' - -1 -1 'main-mmc1-pins-default' - -1 -1 'main-mdio1-pins-default' - -1 -1 'main-rgmii1-pins-default' - -1 -1 'main-rgmii2-pins-default' - -1 -1 'main-usb1-pins-default' - -1 -1 'ospi0-pins-default' - -1 1 'main-uart1-pins-default' - found 0 2 - -1 0 'wkup-uart0-pins-default' - -1 2 'main-uart0-pins-default' - found 0 3 - -1 0 'wkup-uart0-pins-default' - -1 2 'main-uart0-pins-default' - -1 -1 'main-i2c0-pins-default' - -1 -1 'main-mmc1-pins-default' - -1 -1 'main-mdio1-pins-default' - -1 -1 'main-rgmii1-pins-default' - -1 -1 'main-rgmii2-pins-default' - -1 -1 'main-usb1-pins-default' - -1 -1 'ospi0-pins-default' - -1 1 'main-uart1-pins-default' - not found 0 0 - -1 0 'pinctrl@4084000' - found pinconfig main-mmc1-pins-default: set_state_simple op missing clk_set_defaults(main-mmc1-pins-default) clk_set_default_parents: could not read assigned-clock-parents for 700078a4 ofnode_read_prop: assigned-clock-rates: <not found> single-pinctrl pinctrl@f4000: configuring pins for main-mmc1-pins-default single-pinctrl pinctrl@f4000: reg/val 0xf423c/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0xf4234/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0xf4230/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0xf422c/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0xf4228/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0xf4224/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0xf4240/0x00050000
这是完整的串口信息
从日志来看,r5-spl 似乎无法从 SD 卡加载 tispl.bin。
既然是定制板,那定制板上跑什么类型的SW呢?
就是ti-processor-sdk-linux-am62xx-evm-08.04.01.03内sk-am62的sd卡启动程序
与sk-am62有所不同,我们使用的是tps65219进行供电,sd卡电路也有所不同,原理图已经在上面了,我们的接线是有问题的吗,以及根据原理图我需要怎么修改设备树文件及spl代码使其可以成功加载tispl.bin
您可以参考:
1/. Hardware Design Guide for AM62x Devices
www.ti.com/.../sprad05.pdf
2/. Powering the AM62x with the TPS65219 PMIC
www.ti.com/.../slvafd0a.pdf
关于原理图我还需要一些时间查看,请稍后。
根据内部检查,修改是首选方法,这是我们推荐的,因为在 ROM 启动后会切换电压。
您可以更改代码以不切换电压。这不是一个常见的用法,您必须进行必要的修改/测试以确认性能。
您能否确认您是否能够测试电路板上的其他功能或启动模式?
关于修改软件的问题,还在等待软件工程师的回复。
我想通知您还有其他error,例如Open drain i2C WKUP i2C 和 MCU I2C 未终止,请参阅数据表的引脚连接表。USB接口可能需要根据EVM和数据表建议重新审查。
建议您查看有关数据表和 EVM 的原理图。
发现 DP83867 以太网接口存在一些问题,包括 3.3V 时钟分频、MDIO 终端和使用的大容量电容。
请让以Ethernet PHY PL审查PHY部分。
我认为 SK-AM62-LP (www.ti.com/.../SK-AM62-LP) 板使用 TPS65219。但没有看到它的 U-Boot 设备树在 sdhci1 节点上与 SK-AM62 板有任何区别。请查看 SK-AM62-LP 电路板原理图和 U-Boot 设备树设置。
