感谢您的解答!
我们在开发过程中使用了H264的编解码算法,开始时我们将编解码算法配置在了相同的groupID内,长时间运行后会导致dsp端崩溃,通过编解码加锁,情况会明显改善,故我们考虑是资源共享出了问题,于是尝试配置编解码算法在不同的group内,但是按照示例配置,不同group后,编码算法总是创建失败,由于对这方面的配置不是很熟悉,所以也不知道哪里没有配置正确,下面是配置文件内容
/* set up OSAL */
var osalGlobal = xdc.useModule('ti.sdo.ce.osal.Global');
osalGlobal.runtimeEnv = osalGlobal.DSPLINK_BIOS;
osalGlobal.traceBufferSize = 0x40000;
/* configure default memory seg id to BIOS-defined "DDR" */
osalGlobal.defaultMemSegId = "DDR2";
osalGlobal.embedBuildInfo = false;
/* Enable DSP-side BIOS logging */
var LogServer = xdc.useModule('ti.sdo.ce.bioslog.LogServer');
* ======== Server Configuration ========
var Server = xdc.useModule('ti.sdo.ce.Server');
Server.threadAttrs.stackSize = 16384;
/* The servers execution priority */
Server.threadAttrs.priority = Server.MINPRI;
* The optional stack pad to add to non-configured stacks. This is well
* beyond most codec needs, but follows the approach of "start big and
* safe, then optimize when things are working."
Server.stackSizePad = 9000;
/* get various codec modules; i.e., implementation of codecs */
var H264HDENC = xdc.useModule('ti.sdo.codecs.h264hdenc.ce.H264HDENC');
// H264HDENC.manageInBufsCache = [ false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false ];
H264HDENC.manageOutBufsCache = [ false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false ];
H264HDENC.alg.codeSection = "DDR2";
// H264HDENC.alg.udataSection = "DDR2";
// H264HDENC.alg.dataSection = "DDR2";
var H264DEC = xdc.useModule('ti.sdo.codecs.h264dec.ce.H264DEC');
H264DEC.alg.watermark = false; /*if it is production version.*/
// H264DEC.manageInBufsCache = [ true, true, true,true, true,true, true, true, true, true, true, true, true, true, true,true];
// H264DEC.manageOutBufsCache = [ true, true, true,true, true,true, true, true, true, true, true, true, true, true, true, true ];
H264DEC.alg.codeSection = "DDR2";
// H264DEC.alg.udataSection = "DDRALGHEAP";//"DDR2";
// H264DEC.alg.dataSection = "DDRALGHEAP";//"DDR2";
var HDVICP = xdc.useModule('ti.sdo.codecs.hdvicp.HDVICP');
var AACHEENC = xdc.useModule('ti.sdo.codecs.aacheenc.ce.AACHEENC');
AACHEENC.alg.watermark = false;
AACHEENC.alg.codeSection = "DDR2";
AACHEENC.alg.udataSection = "DDR2";
AACHEENC.alg.dataSection = "DDR2";
var MP3DEC = xdc.useModule('ti.sdo.codecs.mp3dec.ce.MP3DEC');
MP3DEC.alg.watermark = false;
MP3DEC.alg.codeSection = "DDR2";
MP3DEC.alg.udataSection = "DDR2";
MP3DEC.alg.dataSection = "DDR2";
var IMGENC1_DEINTERLACE = xdc.useModule('ti.sdo.codecs.imgenc1_deinterlace.IMGENC1_DEINTERLACE');
var IMGENC1_OSD = xdc.useModule('ti.sdo.codecs.imgenc1_osd.IMGENC1_OSD');
var IMGENC1_CHECK = xdc.useModule('ti.sdo.codecs.imgenc1_check.IMGENC1_CHECK');
var IMGENC1_COPY = xdc.useModule('ti.sdo.codecs.imgenc1_copy.IMGENC1_COPY');
var COLORBARCHECK = xdc.useModule('ti.sdo.codecs.colorbarcheck.COLORBARCHECK');
Server.algs = [
{name: "h264hdenc", mod: H264HDENC,groupId:0,threadAttrs: {
stackMemId: 0, priority: Server.MINPRI + 1}
{name: "h264dec", mod: H264DEC,groupId:1,threadAttrs: {
stackMemId: 0, priority: Server.MINPRI + 3}
{name: "aacheenc", mod: AACHEENC,groupId:2,threadAttrs: {
stackMemId: 0, priority: Server.MINPRI + 2}
{name: "imgenc1_deinterlace", mod: IMGENC1_DEINTERLACE,groupId:2,threadAttrs: {
{name: "imgenc1_osd", mod: IMGENC1_OSD,groupId:2,threadAttrs: {
{name: "imgenc1_copy", mod: IMGENC1_COPY,groupId:2,threadAttrs: {
{name: "imgenc1_check", mod: IMGENC1_CHECK,groupId:2,threadAttrs: {
{name: "colorbarcheck", mod: COLORBARCHECK,groupId:2,threadAttrs: {
* ======== DSKT2 and RMAN Configuration ========
* XDAIS Algorithm Memory and DMA allocation
var DSKT2 = xdc.useModule('ti.sdo.fc.dskt2.DSKT2');
DSKT2.DARAM0 = "IRAM";
DSKT2.DARAM1 = "IRAM";
DSKT2.DARAM2 = "IRAM";
DSKT2.SARAM0 = "L1DHEAP";
DSKT2.SARAM1 = "L1DHEAP";
DSKT2.SARAM2 = "L1DHEAP";
DSKT2.ESDATA = "DDRALGHEAP";
DSKT2.IPROG = "DDRALGHEAP";//"IRAM";
DSKT2.EPROG = "DDRALGHEAP";//"DDR2";
DSKT2.DSKT2_HEAP = "DDRALGHEAP";//"DDR2"; /* to allocate internal DSKT2 object */
// DSKT2.trace = true;
// DSKT2.debug = false;
/* Scratch group 0 */
// DSKT2.DARAM_SCRATCH_SIZES = [64*1024,64*1024,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0];
// DSKT2.SARAM_SCRATCH_SIZES = [64*1024,64*1024,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0];
DSKT2.DARAM_SCRATCH_SIZES[0] = 64*1024;
DSKT2.SARAM_SCRATCH_SIZES[0] = 64*1024;
// /* Scratch group 1 */
DSKT2.DARAM_SCRATCH_SIZES[1] = 64*1024;
DSKT2.SARAM_SCRATCH_SIZES[1] = 64*1024;
var RMAN = xdc.useModule('ti.sdo.fc.rman.RMAN');
RMAN.useDSKT2 = true;
RMAN.tableSize = 10;
RMAN.semCreateFxn = "Sem_create";
RMAN.semDeleteFxn = "Sem_delete";
RMAN.semPendFxn = "Sem_pend";
RMAN.semPostFxn = "Sem_post";
RMAN.debug = false;
RMAN.trace = true;
var DMAN3 = xdc.useModule('ti.sdo.fc.dman3.DMAN3');
DMAN3.heapInternal = "L1DHEAP"; //"IRAM"; /* L1DHEAP is an internal segment */
DMAN3.heapExternal = "DDRALGHEAP"; /* DDRALGHEAP is an external segment */
DMAN3.idma3Internal = false;
DMAN3.scratchAllocFxn = "DSKT2_allocScratch";
DMAN3.scratchFreeFxn = "DSKT2_freeScratch";
var EDMA3 = xdc.useModule('ti.sdo.fc.edma3.Settings');
EDMA3.trace = true;
EDMA3.debug = false;
//EDMA3.regionConfig = "DM6467_EDMA3_RM_INITCONFIG";
* Group:0, H264ENC gets 192 PaRAMs, 13 TCCs, 19 EDMA, and 2 QDMA channels
// DMAN3.numTccGroup = [22, 22, 0, 0, 0, 0];
// DMAN3.numPaRamGroup = [93, 192, 0, 0, 0, 0];
// DMAN3.qdmaChannels = [0, 2, 0, 0, 0, 0, 0,0];
// DMAN3.maxQdmaChannels = 8;
// DMAN3.numQdmaChannels = 8;
// EDMA3.maxPaRams[0] = 384;
// EDMA3.maxTccs[0] = 49;//21;
// EDMA3.maxEdmaChannels[0] = 49;//21;
// EDMA3.maxQdmaChannels[0] = 4;
EDMA3.maxPaRams[0] = 93;
EDMA3.maxTccs[0] = 22;//21;
EDMA3.maxEdmaChannels[0] = 22;//21;
EDMA3.maxQdmaChannels[0] = 0;
* Group:1, H264DEC gets 192 PaRAMs, 13 TCCs, 19 EDMA, and 2 QDMA channels
// EDMA3.maxPaRams[1] = 93;
// EDMA3.maxTccs[1] = 22;
// EDMA3.maxEdmaChannels[1] = 22;
// EDMA3.maxQdmaChannels[1] = 0;
EDMA3.maxPaRams[1] = 192;
EDMA3.maxQdmaChannels[1] = 2;
var EDMA3CHAN = xdc.useModule('ti.sdo.fc.ires.edma3chan.EDMA3CHAN');
EDMA3CHAN.debug = false;
EDMA3CHAN.trace = true;
var HDVICP = xdc.useModule('ti.sdo.fc.ires.hdvicp.HDVICP');
HDVICP.debug = false;
HDVICP.trace = true;
var HDINTC = xdc.useModule('ti.sdo.fc.hdintc.HDINTC');
HDINTC.interruptVectorId_0 = 10;
HDINTC.interruptVectorId_1 = 11;
HDINTC.hdvicpInterruptEventNo_0 = 29;
HDINTC.hdvicpInterruptEventNo_1 = 39;
// HDINTC.biosInterruptVectorId_0 = 7;
// HDINTC.biosInterruptVectorId_1 = 8;
// HDINTC.biosInterruptEventNo_0 = 30;
// HDINTC.biosInterruptEventNo_1 = 31;
请指正!EDMA3的资源量是从编码器的datasheet文件找出来的
