求助,C6455在FPGA触发时,老是会掉的问题
大家好,求助各位大神一个问题:
系统的硬件是用S6(FPGA)与C6455搭建的,在JTAG链路中,烧写FPGA正常,烧写DSP也正常,我在FPGA中做了一个chipscope观测核,每次在点触发的时候DSP总是挂掉,显示的是这样子:
C64XP_0:Power Failure on Target CPU
C64XP_0:Failed to remove the debug state from the target before disconnecting. There may still be breakpoint opcodes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
请各位帮帮忙,看看如何解决
