目前使用的是am3354(ZCZ)
目的是使E18這隻腳輸出PWM波形
做法是配置E18為timer7, 並設定DTTIMER7相關參數
但目前輸出都沒有變化, 不曉得是否少了哪些步驟?
參考20.1.3.5 Pulse-Width Modulation後的詳細做法如下:
// Initialize the ARM Interrupt Controller.
IntAINTCInit();
#define TIMER_INITIAL_COUNT (0xFFFF0000u)
#define TIMER_RLD_COUNT (0xFFFF0000u)
// -----Pinmux-----
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_UART_CTSN(0)) = ((0x00000020u) + CONTROL_CONF_MUXMODE(5));
// -----Timer CLK-----
DMTimer7ModuleClkConfig();
// -----IRQ-----
IntMasterIRQEnable();
IntRegister(SYS_INT_TINT7, DMTimer7Isr);
IntPrioritySet(SYS_INT_TINT7, 10, AINTC_HOSTINT_ROUTE_IRQ);
IntSystemEnable(SYS_INT_TINT7);
// -----Timer Counting Rate-----
DMTimerCounterSet(SOC_DMTIMER_7_REGS, TIMER_INITIAL_COUNT);
DMTimerReloadSet(SOC_DMTIMER_7_REGS, TIMER_RLD_COUNT);
DMTimerModeConfigure(SOC_DMTIMER_7_REGS, DMTIMER_AUTORLD_NOCMP_ENABLE);
// -----Trigger output mode-----
DMTimerWaitForWrite(DMTIMER_WRITE_POST_TCLR, SOC_DMTIMER_7_REGS);
HWREG(SOC_DMTIMER_7_REGS + DMTIMER_TCLR) &= ~DMTIMER_TCLR_TRG;
HWREG(SOC_DMTIMER_7_REGS + DMTIMER_TCLR) |= (DMTIMER_TCLR_TRG_OVERFLOWANDMATCH << DMTIMER_TCLR_TRG_SHIFT);
// -----plus or toggle-----
HWREG(SOC_DMTIMER_7_REGS + DMTIMER_TCLR) &= ~DMTIMER_TCLR_PT;
HWREG(SOC_DMTIMER_7_REGS + DMTIMER_TCLR) |= (DMTIMER_TCLR_PT_TOGGLE << DMTIMER_TCLR_PT_SHIFT);
// -----output----
DMTimerGPOConfigure(SOC_DMTIMER_7_REGS, DMTIMER_GPO_CFG_0); // 0 = output enabled, 1 = output disabled
// -----timer enable-----
DMTimerIntEnable(SOC_DMTIMER_7_REGS, DMTIMER_INT_OVF_EN_FLAG);
DMTimerEnable(SOC_DMTIMER_7_REGS);
