C6678开发板连接器的问题FEMALE HEADER 2x40P 1.27mm 180D(F) SMD 22L8742
FEMALE HEADER 2x40P 1.27mm 180D(F) SMD 22L8742这个连接器的芯片资料没有找到呀,我要画电路板,和 H1的80针连接器相连接,我去百度和GOOGLE都没找到SMD 22L8742的资料,让我怎么画电路板呀
在TI E2E 论坛也有人问 FEMALE HEADER 2x40P 1.27mm 180D(F) SMD 22L8742的资料:
Thank you,  I'll look there and dig in, in more detail.
Meanwhile, I need to hook up the External 80pin Expansion bus to get diagnostic data output.
The BOM for the C6678 EVM lists it as TEST_PH1 FEMALE HEADER 2x40P 1.27mm 180D(F) SMD 22L8742
I can't find a matching male connector on eg digikey.
Any idea where I can find a male header --ribbon-cable--male header  that will plug into this connector?
