jpeg2k encoder 的例子 build错误
我现在要在6678上实现jpeg2000的编码和解码,然后,想试试“C66x_j2e_01_00_01_01_ELF_32bit.exe”是否可行
可是在编译其自带的例子时出现如下错误:
**** Build of configuration Debug for project testappencoder ****
"C:\\ti\\ccsv5\\utils\\bin\\gmake" -k all
'Building file: ../testappencoder.cfg'
'Invoking: XDCtools'
"C:/ti/xdctools_3_25_05_94/xs" --xdcpath="C:/Program Files (x86)/Texas Instruments/Codecs/C66x_j2e_01_00_01_01_ELF/packages/ti/sdo/codecs/j2e/App/Client/Build/Repository/Packages;C:/ti/bios_6_33_06_50/packages;C:/ti/framework_components_3_30_00_06/framework_components_3_30_00_06/packages;C:/ti/ccsv5/ccs_base;C:/ti/edma3_lld_02_11_05_02/packages;C:/ti/xdais_7_24_00_04/xdais_7_24_00_04/packages;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C66 -p ti.platforms.custom66x -r release -c "C:/ti/ccsv5/tools/compiler/c6000_7.4.4" "../testappencoder.cfg"
当前目录无效。
gmake: *** [configPkg/linker.cmd] Error 1
gmake: Target `all' not remade because of errors.
**** Build Finished ****
这是什么情况?是win8的问题吗?我再win7上也是错误的
在win8上的ccs是5.5
其他的软件都是完全和"jpeg2k_encoder_c6678_userguide.pdf"推荐的一致
"2.3 Before Building the Sample Test Application
This codec is accompanied by a sample test application. To run the sample
test application, you need SYS/BIOS, Bios IPC, XDC Tools and TI
Framework Components (FC).
This version of the codec has been validated with
SYS/BIOS version 6.33.06.50,
XDC Tools version 3.23.04.60,
XDAIS Tools version 7.23.00.06,
EDMA3 LLD version 02.11.05.02 &
Framework Component (FC) version 3.23.02.16."
求大神们帮忙
