1.我們的板子想用使用ramdisk 來當rootfs ( TI Linux SDK 6.0 )
ramdisk 放置於SD卡 boot分區
2.我該如何修改uboot 讓kernel 開機可以自動載入ramdisk??
(不使用setenv 方式)
可以参考以下命令,
fatload mmc 0 $loadaddr uImage
fatload mmc 0 $rdaddr ramdisk.gz
setenv bootargs console=ttyO0,115200n8 root=/dev/ram0 rw initrd=$rdaddr,64M
bootm
Dear Blaider
1.請問這些命令是要加再uboot 哪邊??
2.或是有uenv.txt 可以參考??
3.我看am335x_evm.h 的CONFIG_EXTRA_ENV_SETTINGS
已經有你列出的命令,請問要如何修改呢??
(我現在都會固定從mmc 抓取rootfs 然後抓不到)
#define CONFIG_EXTRA_ENV_SETTINGS \
"loadaddr=0x80200000\0" \
"kloadaddr=0x80007fc0\0" \
"fdtaddr=0x80F80000\0" \
"fdt_high=0xffffffff\0" \
"rdaddr=0x81000000\0" \
"bootfile=uImage\0" \
"fdtfile=\0" \
"console=ttyO0,115200n8\0" \
"optargs=\0" \
"mtdids=" MTDIDS_DEFAULT "\0" \
"mtdparts=" MTDPARTS_DEFAULT "\0" \
"dfu_alt_info_mmc=" DFU_ALT_INFO_MMC "\0" \
"dfu_alt_info_emmc=rawemmc mmc 0 3751936\0" \
"dfu_alt_info_nand=" DFU_ALT_INFO_NAND "\0" \
"mmcdev=0\0" \
"mmcroot=/dev/mmcblk0p2 ro\0" \
"mmcrootfstype=ext3 rootwait\0" \
"nandroot=ubi0:rootfs rw ubi.mtd=7,2048\0" \
"nandrootfstype=ubifs rootwait=1\0" \
"nandsrcaddr=0x280000\0" \
"nandimgsize=0x500000\0" \
"rootpath=/export/rootfs\0" \
"nfsopts=nolock\0" \
"static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}" \
"::off\0" \
"ramroot=/dev/ram0 rw ramdisk_size=65536 initrd=${rdaddr},64M\0" \
"ramrootfstype=ext2\0" \
"ip_method=none\0" \
"bootargs_defaults=setenv bootargs " \
"console=${console} " \
"${optargs}\0" \
"mmcargs=run bootargs_defaults;" \
"setenv bootargs ${bootargs} " \
"root=${mmcroot} " \
"rootfstype=${mmcrootfstype} ip=${ip_method}\0" \
"nandargs=setenv bootargs console=${console} " \
"${optargs} " \
"root=${nandroot} " \
"rootfstype=${nandrootfstype}\0" \
"spiroot=/dev/mtdblock4 rw\0" \
"spirootfstype=jffs2\0" \
"spisrcaddr=0xe0000\0" \
"spiimgsize=0x362000\0" \
"spibusno=0\0" \
"spiargs=setenv bootargs console=${console} " \
"${optargs} " \
"root=${spiroot} " \
"rootfstype=${spirootfstype}\0" \
"netargs=setenv bootargs console=${console} " \
"${optargs} " \
"root=/dev/nfs " \
"nfsroot=${serverip}:${rootpath},${nfsopts} rw " \
"ip=dhcp\0" \
"bootenv=uEnv.txt\0" \
"loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \
"importbootenv=echo Importing environment from mmc ...; " \
"env import -t $loadaddr $filesize\0" \
"ramargs=setenv bootargs console=${console} " \
"${optargs} " \
"root=${ramroot} " \
"rootfstype=${ramrootfstype}\0" \
"loadramdisk=fatload mmc ${mmcdev} ${rdaddr} ramdisk.gz\0" \
"loaduimagefat=fatload mmc ${mmcdev} ${kloadaddr} ${bootfile}\0" \
"loaduimage=ext2load mmc ${mmcdev}:2 ${kloadaddr} /boot/${bootfile}\0" \
"mmcboot=echo Booting from mmc ...; " \
"run mmcargs; " \
"bootm ${kloadaddr}\0" \
"nandboot=echo Booting from nand ...; " \
"run nandargs; " \
"nand read ${loadaddr} ${nandsrcaddr} ${nandimgsize}; " \
"bootm ${loadaddr}\0" \
"spiboot=echo Booting from spi ...; " \
"run spiargs; " \
"sf probe ${spibusno}:0; " \
"sf read ${loadaddr} ${spisrcaddr} ${spiimgsize}; " \
"netboot=echo Booting from network ...; " \
"setenv autoload no; " \
"dhcp; " \
"tftp ${loadaddr} ${bootfile}; " \
"run netargs; " \
"ramboot=echo Booting from ramdisk ...; " \
"run ramargs; " \
"findfdt="\
"if test $board_name = A335BONE; then " \
"setenv fdtfile am335x-bone.dtb; fi; " \
"if test $board_name = A33515BB; then " \
"setenv fdtfile am335x-evm.dtb; fi; " \
"if test $board_name = A335X_SK; then " \
"setenv fdtfile am335x-evmsk.dtb; fi\0" \
jiew 说:Dear Blaider
"fdtfile=\0" \
"optargs=\0" \
"mmcdev=0\0" \
"::off\0" \
"${optargs}\0" \
"${optargs} " \
"spibusno=0\0" \
"${optargs} " \
"${optargs} " \
"root=/dev/nfs " \
"ip=dhcp\0" \
"${optargs} " \
"run mmcargs; " \
"run nandargs; " \
"run spiargs; " \
"dhcp; " \
"run netargs; " \
"run ramargs; " \
"findfdt="\
简单点就是修改一下bootcmd变量,让它自动运行
bootcmd= run loaduimagefat;run loadramdisk;run ramargs;bootm;
bootcmd= run loaduimagefat;run loadramdisk;run ramargs;bootm ${kloadaddr};
参考过下面这个guide列出来的步骤和参数吗,可以从NAND或者SD卡启动ramdisk:
