dm3730 ISP问题
Other Parts Discussed in Thread: TVP5158, DM3730, TVP5146M2
现在在调试dm3730+tvp5158,dm3730ISP连接到tvp5158portA发现一个问题:
当将tvp5158设置为单通道D1时,omap34xx_isp_isr()函数中fld_std的值是0和1变换,表示奇偶帧在交替,而将tvp5158设置成2通道D1模式时,该函数中的fld_std的值却一直为0,只有奇场数据,这是怎么回事?
  • 在你的应用里面,是否是接了FLD的?能不能直接在硬件上面测量FLD有没有?
  • hello Eason Wang :
     谢谢您的回答。
     我的dm3730的camera 没有接cam_fld,只接了cam_pclk和8根数据线,我的应用里面采用的是CCDC_YUV_BT,fldmode=0(逐行)
    在ispccdc_s_pipeline()函数中,关于奇偶设置如下:
    ispccdc_config_outlineoffset(isp_ccdc,pipe->ccdc_out_w*2,EVENEVEN,0);
    ispccdc_config_outlineoffset(isp_ccdc,pipe->ccdc_out_w*2,ODDEVEN,0);
    ispccdc_config_outlineoffset(isp_ccdc,pipe->ccdc_out_w*2,EVENODD,1);
    ispccdc_config_outlineoffset(isp_ccdc,pipe->ccdc_out_w*2,ODDODD,1);
    设置的capture_buf的大小是720*1050,可以收到奇偶场的数据,但是发现里面接收到数据里从sc[0],sc[1],sc[2],sc[3]中分析出来的linenum不是从o开始的,而且2个capture_buf中的开始linenum不连续的,打印如下:
    [root@ZOOMLION /web]# rm saMmapLoopback9
    [root@ZOOMLION /web]# rz
    rz ready. Type "sz file ..." to your modem program
    Starting zmodem transfer.  Press Ctrl+C to cancel.
    Transferring saMmapLoopback9...
      100%      12 KB    6 KB/s 00:00:02       0 Errors
    妑z 3.48 01-27-98 finished.
    [root@ZOOMLION /web]# chmod 777 saMmapLoopback9
    [root@ZOOMLION /web]# ./saMmapLoopback9
    tvp514x 2-0058: tvp5146m2 found at 0xb0 (OMAP I2C adapter)
    Patch is already running.
    tvp514x 2-0058: Reg(0x00): 0x6E
    tvp514x 2-0058: Reg(0x01): 0x80
    tvp514x 2-0058: Reg(0x02): 0x95
    tvp514x 2-0058: Reg(0x04): 0x02
    tvp514x 2-0058: Reg(0x05): 0x01
    tvp514x 2-0058: Reg(0x06): 0x17
    tvp514x 2-0058: Reg(0x08): 0x51
    tvp514x 2-0058: Reg(0x09): 0x58
    tvp514x 2-0058: Reg(0x0C): 0x82
    tvp514x 2-0058: Reg(0x0D): 0x00
    tvp514x 2-0058: Reg(0x0E): 0x03
    tvp514x 2-0058: Reg(0x0F): 0x00
    tvp514x 2-0058: Reg(0x10): 0x80
    tvp514x 2-0058: Reg(0x11): 0x80
    tvp514x 2-0058: Reg(0x12): 0x00
    tvp514x 2-0058: Reg(0x13): 0x80
    tvp514x 2-0058: Reg(0x14): 0x00
    tvp514x 2-0058: Reg(0x16): 0x10
    tvp514x 2-0058: Reg(0x18): 0x40
    tvp514x 2-0058: Reg(0x19): 0x00
    tvp514x 2-0058: Reg(0x1A): 0x00
    tvp514x 2-0058: Reg(0x1B): 0x00
    tvp514x 2-0058: Reg(0x1C): 0x0C
    tvp514x 2-0058: Reg(0x20): 0x00
    tvp514x 2-0058: Reg(0x21): 0x00
    tvp514x 2-0058: Reg(0x23): 0x80
    tvp514x 2-0058: Reg(0x24): 0x00
    tvp514x 2-0058: Reg(0x25): 0xF5
    tvp514x 2-0058: Reg(0x26): 0x00
    tvp514x 2-0058: Reg(0x27): 0x00
    tvp514x 2-0058: Reg(0x29): 0x06
    tvp514x 2-0058: Reg(0x2A): 0x1E
    tvp514x 2-0058: Reg(0x2B): 0x04
    tvp514x 2-0058: Reg(0x2C): 0x00
    tvp514x 2-0058: Reg(0x2D): 0xF2
    tvp514x 2-0058: Reg(0x2E): 0x08
    tvp514x 2-0058: Reg(0x34): 0x6A
    tvp514x 2-0058: Reg(0x35): 0x08
    tvp514x 2-0058: Reg(0x48): 0x84
    tvp514x 2-0058: Reg(0x49): 0x00
    tvp514x 2-0058: Reg(0x4A): 0xD0
    tvp514x 2-0058: Reg(0x4B): 0x02
    tvp514x 2-0058: Reg(0x5C): 0x1E
    tvp514x 2-0058: Reg(0x5D): 0x09
    tvp514x 2-0058: Reg(0x5E): 0x34
    tvp514x 2-0058: Reg(0x5F): 0x03
    tvp514x 2-0058: Reg(0x60): 0x00
    tvp514x 2-0058: Reg(0x61): 0x09
    tvp514x 2-0058: Reg(0x7C): 0x02
    tvp514x 2-0058: Reg(0x7D): 0x08
    tvp514x 2-0058: Reg(0x81): 0x01
    tvp514x 2-0058: Reg(0x85): 0x03
    tvp514x 2-0058: Reg(0x87): 0x00
    tvp514x 2-0058: Reg(0x88): 0x03
    tvp514x 2-0058: Reg(0x89): 0x16
    tvp514x 2-0058: Reg(0x8C): 0x00
    tvp514x 2-0058: Reg(0x8F): 0x04
    tvp514x 2-0058: Reg(0x90): 0x10
    tvp514x 2-0058: Reg(0x91): 0x80
    tvp514x 2-0058: Reg(0x92): 0x80
    tvp514x 2-0058: Reg(0x93): 0x00
    tvp514x 2-0058: Reg(0x94): 0x00
    tvp514x 2-0058: Reg(0x95): 0x00
    tvp514x 2-0058: Reg(0x96): 0x60
    tvp514x 2-0058: Reg(0x97): 0x50
    tvp514x 2-0058: Reg(0x9E): 0x03
    tvp514x 2-0058: Reg(0x9F): 0xBC
    tvp514x 2-0058: Reg(0xA0): 0xBC
    tvp514x 2-0058: Reg(0xA2): 0x0D
    tvp514x 2-0058: Reg(0xA3): 0x02
    tvp514x 2-0058: Reg(0xA8): 0x44
    tvp514x 2-0058: Reg(0xA9): 0x40
    tvp514x 2-0058: Reg(0xAD): 0x00
    tvp514x 2-0058: Reg(0xAE): 0x01
    tvp514x 2-0058: Reg(0xAF): 0x00
    tvp514x 2-0058: Reg(0xB0): 0x90
    tvp514x 2-0058: Reg(0xB1): 0x18
    tvp514x 2-0058: Reg(0xB2): 0x05
    tvp514x 2-0058: Reg(0xB3): 0xE4
    tvp514x 2-0058: Reg(0xB4): 0xE4
    tvp514x 2-0058: Reg(0xB5): 0x00
    tvp514x 2-0058: Reg(0xB6): 0x1B
    tvp514x 2-0058: Reg(0xB7): 0x04
    tvp514x 2-0058: Reg(0xB8): 0xF8
    tvp514x 2-0058: Reg(0xB9): 0x10
    tvp514x 2-0058: Reg(0xBA): 0x00
    tvp514x 2-0058: Reg(0xC0): 0x00
    tvp514x 2-0058: Reg(0xC1): 0x88
    tvp514x 2-0058: Reg(0xC2): 0x88
    tvp514x 2-0058: Reg(0xC3): 0xE0
    tvp514x 2-0058: Reg(0xC4): 0x01
    tvp514x 2-0058: Reg(0xC5): 0x00
    tvp514x 2-0058: Reg(0xC7): 0x00
    tvp514x 2-0058: Reg(0xC8): 0x00
    tvp514x 2-0058: Reg(0xD0): 0xF8
    tvp514x 2-0058: Reg(0xD1): 0x00
    tvp514x 2-0058: Reg(0xD2): 0xA8
    tvp514x 2-0058: Reg(0xD3): 0x05
    tvp514x 2-0058: Reg(0xE0): 0x02
    tvp514x 2-0058: Reg(0xE1): 0x02
    tvp514x 2-0058: Reg(0xE8): 0x61
    tvp514x 2-0058: Reg(0xE9): 0x00
    tvp514x 2-0058: Reg(0xEA): 0xB0
    tvp514x 2-0058: Reg(0xF2): 0x00
    tvp514x 2-0058: Reg(0xF4): 0x00
    tvp514x 2-0058: Reg(0xF6): 0x00
    Capture: Opened Channel
    Capturetvp514x 2-0058: CH1:std_status:0x82
    : Current Input: COMPOSITE
    tvp514x 2-0058: CH2:std_status:0x82
    tvp514x 2-0058: CH1:sync_lock_status:0x6e
    tvp514x 2-0058: CH2:sync_lock_status:0x6e
    Capture: Capable of streamingtvp514x 2-0058: CH1:std_status:0x82
    tvp514x 2-0058:
    Try FMT: pixelformat - 8-bit UYVY 4:2:2 Format, bytesperline - 1440Width - 720, Height - 1050,field:4
    Capture: Number of requested buffers = 1
    Capture: Init done successfully
    Display: Opened Channel
    Display: Capable of streaming
    Display: Number of requested buffers = 3
    Display: Init done successfully
    Display: Stream on...
    tvp514x 2-0058: Reg(0x01): 0x90
    tvp514x 2-0058: Reg(0x02): 0x8D
    Capture: Stream on...
    display_fmt.fmt.pix.width=720
    display_fmt.fmt.pix.height=576
    capture_fmt.fmt.pix.width=720
    capture_fmt.fmt.pix.height=1050
    capture_buf.index=0
    field:0,ch1:linenum:160
    field:0,ch1:linenum:161
    field:0,ch1:linenum:162
    field:0,ch1:linenum:163
    field:0,ch1:linenum:164
    field:0,ch1:linenum:165
    field:0,ch1:linenum:166
    field:0,ch1:linenum:167
    field:0,ch1:linenum:168
    field:0,ch1:linenum:169
    field:0,ch1:linenum:170
    field:0,ch1:linenum:171
    field:0,ch1:linenum:172
    field:0,ch1:linenum:173
    field:0,ch1:linenum:174
    field:0,ch1:linenum:175
    field:0,ch1:linenum:176
    field:0,ch1:linenum:177
    field:0,ch1:linenum:178
    field:0,ch1:linenum:179
    field:0,ch1:linenum:180
    field:0,ch1:linenum:181
    field:0,ch1:linenum:182
    field:0,ch1:linenum:183
    field:0,ch1:linenum:184
    field:0,ch1:linenum:185
    field:0,ch1:linenum:186
    field:0,ch1:linenum:187
    field:0,ch1:linenum:188
    field:0,ch1:linenum:189
    field:0,ch1:linenum:190
    field:0,ch1:linenum:191
    field:0,ch1:linenum:192
    field:0,ch1:linenum:193
    field:0,ch1:linenum:194
    field:0,ch1:linenum:195
    field:0,ch1:linenum:196
    field:0,ch1:linenum:197
    field:0,ch1:linenum:198
    field:0,ch1:linenum:199
    field:0,ch1:linenum:200
    field:0,ch1:linenum:201
    field:0,ch1:linenum:202
    field:0,ch1:linenum:203
    field:0,ch1:linenum:204
    field:0,ch1:linenum:205
    field:0,ch1:linenum:206
    field:0,ch1:linenum:207
    field:0,ch1:linenum:208
    field:0,ch1:linenum:209
    field:0,ch1:linenum:210
    field:0,ch1:linenum:211
    field:0,ch1:linenum:212
    field:0,ch1:linenum:213
    field:0,ch1:linenum:214
    field:0,ch1:linenum:215
    field:0,ch1:linenum:216
    field:0,ch1:linenum:217
    field:0,ch1:linenum:218
    field:0,ch1:linenum:219
    field:0,ch1:linenum:220
    field:0,ch1:linenum:221
    field:0,ch1:linenum:222
    field:0,ch1:linenum:223
    field:0,ch1:linenum:224
    field:0,ch1:linenum:225
    field:0,ch1:linenum:226
    field:0,ch1:linenum:227
    field:0,ch1:linenum:228
    field:0,ch1:linenum:229
    field:0,ch1:linenum:230
    field:0,ch1:linenum:231
    field:0,ch1:linenum:232
    field:0,ch1:linenum:233
    field:0,ch1:linenum:234
    field:0,ch1:linenum:235
    field:0,ch1:linenum:236
    field:0,ch1:linenum:237
    field:0,ch1:linenum:238
    field:0,ch1:linenum:239
    field:0,ch1:linenum:240
    field:0,ch1:linenum:241
    field:0,ch1:linenum:242
    field:0,ch1:linenum:243
    field:0,ch1:linenum:244
    field:0,ch1:linenum:245
    field:0,ch1:linenum:246
    field:0,ch1:linenum:247
    field:0,ch1:linenum:248
    field:0,ch1:linenum:249
    field:0,ch1:linenum:250
    field:0,ch1:linenum:251
    field:0,ch1:linenum:252
    field:0,ch1:linenum:253
    field:0,ch1:linenum:254
    field:0,ch1:linenum:255
    field:0,ch1:linenum:256
    field:0,ch1:linenum:257
    field:0,ch1:linenum:258
    field:0,ch1:linenum:259
    field:0,ch1:linenum:260
    field:0,ch1:linenum:261
    field:0,ch1:linenum:262
    field:0,ch1:linenum:263
    field:0,ch1:linenum:264
    field:0,ch1:linenum:265
    field:0,ch1:linenum:266
    field:0,ch1:linenum:267
    field:0,ch1:linenum:268
    field:0,ch1:linenum:269
    field:0,ch1:linenum:270
    field:0,ch1:linenum:271
    field:0,ch1:linenum:272
    field:0,ch1:linenum:273
    field:0,ch1:linenum:274
    field:0,ch1:linenum:275
    field:0,ch1:linenum:276
    field:0,ch1:linenum:277
    field:0,ch1:linenum:278
    field:0,ch1:linenum:279
    field:0,ch1:linenum:280
    field:0,ch1:linenum:281
    field:0,ch1:linenum:282
    field:0,ch1:linenum:283
    field:0,ch1:linenum:284
    field:0,ch1:linenum:285
    field:0,ch1:linenum:286
    field:0,ch1:linenum:287
    field:1,ch1:linenum:287
    field:1,ch1:linenum:0
    field:1,ch1:linenum:1
    field:1,ch1:linenum:3
    field:1,ch1:linenum:4
    field:1,ch1:linenum:5
    field:1,ch1:linenum:6
    field:1,ch1:linenum:7
    field:1,ch1:linenum:8
    field:1,ch1:linenum:9
    field:1,ch1:linenum:10
    field:1,ch1:linenum:11
    field:1,ch1:linenum:12
    field:1,ch1:linenum:13
    field:1,ch1:linenum:14
    field:1,ch1:linenum:15
    field:1,ch1:linenum:16
    field:1,ch1:linenum:17
    field:1,ch1:linenum:18
    field:1,ch1:linenum:19
    field:1,ch1:linenum:20
    field:1,ch1:linenum:21
    field:1,ch1:linenum:22
    field:1,ch1:linenum:23
    field:1,ch1:linenum:24
    field:1,ch1:linenum:25
    field:1,ch1:linenum:26
    field:1,ch1:linenum:27
    field:1,ch1:linenum:29
    field:1,ch1:linenum:30
    field:1,ch1:linenum:31
    field:1,ch1:linenum:32
    field:1,ch1:linenum:33
    field:1,ch1:linenum:34
    field:1,ch1:linenum:35
    field:1,ch1:linenum:36
    field:1,ch1:linenum:37
    field:1,ch1:linenum:38
    field:1,ch1:linenum:39
    field:1,ch1:linenum:40
    field:1,ch1:linenum:41
    field:1,ch1:linenum:42
    field:1,ch1:linenum:43
    field:1,ch1:linenum:44
    field:1,ch1:linenum:45
    field:1,ch1:linenum:46
    field:1,ch1:linenum:47
    field:1,ch1:linenum:48
    field:1,ch1:linenum:49
    field:1,ch1:linenum:50
    field:1,ch1:linenum:51
    field:1,ch1:linenum:52
    field:1,ch1:linenum:53
    field:1,ch1:linenum:54
    field:1,ch1:linenum:55
    field:1,ch1:linenum:56
    field:1,ch1:linenum:57
    field:1,ch1:linenum:58
    field:1,ch1:linenum:59
    field:1,ch1:linenum:60
    field:1,ch1:linenum:61
    field:1,ch1:linenum:62
    field:1,ch1:linenum:63
    field:1,ch1:linenum:64
    field:1,ch1:linenum:65
    field:1,ch1:linenum:66
    field:1,ch1:linenum:67
    field:1,ch1:linenum:68
    field:1,ch1:linenum:69
    field:1,ch1:linenum:70
    field:1,ch1:linenum:71
    field:1,ch1:linenum:72
    field:1,ch1:linenum:73
    field:1,ch1:linenum:74
    field:1,ch1:linenum:75
    field:1,ch1:linenum:76
    field:1,ch1:linenum:77
    field:1,ch1:linenum:78
    field:1,ch1:linenum:79
    field:1,ch1:linenum:80
    field:1,ch1:linenum:81
    field:1,ch1:linenum:82
    field:1,ch1:linenum:83
    field:1,ch1:linenum:84
    field:1,ch1:linenum:85
    field:1,ch1:linenum:86
    field:1,ch1:linenum:87
    field:1,ch1:linenum:88
    field:1,ch1:linenum:89
    field:1,ch1:linenum:90
    field:1,ch1:linenum:91
    field:1,ch1:linenum:92
    field:1,ch1:linenum:93
    field:1,ch1:linenum:94
    field:1,ch1:linenum:95
    field:1,ch1:linenum:96
    field:1,ch1:linenum:97
    field:1,ch1:linenum:98
    field:1,ch1:linenum:99
    field:1,ch1:linenum:100
    field:1,ch1:linenum:101
    field:1,ch1:linenum:102
    field:1,ch1:linenum:103
    field:1,ch1:linenum:104
    field:1,ch1:linenum:105
    field:1,ch1:linenum:106
    field:1,ch1:linenum:107
    field:1,ch1:linenum:108
    field:1,ch1:linenum:109
    field:1,ch1:linenum:110
    field:1,ch1:linenum:111
    field:1,ch1:linenum:112
    field:1,ch1:linenum:113
    field:1,ch1:linenum:114
    field:1,ch1:linenum:115
    field:1,ch1:linenum:116
    field:1,ch1:linenum:117
    field:1,ch1:linenum:118
    field:1,ch1:linenum:119
    field:1,ch1:linenum:120
    field:1,ch1:linenum:121
    field:1,ch1:linenum:122
    field:1,ch1:linenum:123
    field:1,ch1:linenum:124
    field:1,ch1:linenum:125
    field:1,ch1:linenum:126
    field:1,ch1:linenum:127
    field:1,ch1:linenum:128
    field:1,ch1:linenum:129
    field:1,ch1:linenum:130
    field:1,ch1:linenum:131
    field:1,ch1:linenum:132
    field:1,ch1:linenum:133
    field:1,ch1:linenum:134
    field:1,ch1:linenum:135
    field:1,ch1:linenum:136
    field:1,ch1:linenum:137
    field:1,ch1:linenum:138
    field:1,ch1:linenum:139
    field:1,ch1:linenum:140
    field:1,ch1:linenum:141
    field:1,ch1:linenum:142
    field:1,ch1:linenum:143
    field:1,ch1:linenum:144
    field:1,ch1:linenum:145
    field:1,ch1:linenum:146
    field:1,ch1:linenum:147
    field:1,ch1:linenum:148
    field:1,ch1:linenum:149
    field:1,ch1:linenum:150
    field:1,ch1:linenum:151
    field:1,ch1:linenum:152
    field:1,ch1:linenum:153
    field:1,ch1:linenum:154
    field:1,ch1:linenum:155
    field:1,ch1:linenum:156
    field:1,ch1:linenum:157
    field:1,ch1:linenum:158
    field:1,ch1:linenum:159
    field:1,ch1:linenum:160
    field:1,ch1:linenum:161
    field:1,ch1:linenum:162
    field:1,ch1:linenum:163
    field:1,ch1:linenum:164
    field:1,ch1:linenum:165
    field:1,ch1:linenum:166
    field:1,ch1:linenum:167
    field:1,ch1:linenum:168
    field:1,ch1:linenum:169
    field:1,ch1:linenum:170
    field:1,ch1:linenum:171
    field:1,ch1:linenum:172
    field:1,ch1:linenum:173
    field:1,ch1:linenum:174
    field:1,ch1:linenum:175
    field:1,ch1:linenum:176
    field:1,ch1:linenum:177
    field:1,ch1:linenum:178
    field:1,ch1:linenum:179
    field:1,ch1:linenum:180
    field:1,ch1:linenum:181
    field:1,ch1:linenum:182
    field:1,ch1:linenum:183
    field:1,ch1:linenum:184
    field:1,ch1:linenum:185
    field:1,ch1:linenum:186
    field:1,ch1:linenum:187
    field:1,ch1:linenum:188
    field:1,ch1:linenum:189
    field:1,ch1:linenum:190
    field:1,ch1:linenum:191
    field:1,ch1:linenum:192
    field:1,ch1:linenum:193
    field:1,ch1:linenum:194
    field:1,ch1:linenum:195
    field:1,ch1:linenum:196
    field:1,ch1:linenum:197
    field:1,ch1:linenum:198
    field:1,ch1:linenum:199
    field:1,ch1:linenum:200
    field:1,ch1:linenum:201
    field:1,ch1:linenum:202
    field:1,ch1:linenum:203
    field:1,ch1:linenum:204
    field:1,ch1:linenum:205
    field:1,ch1:linenum:206
    field:1,ch1:linenum:207
    field:1,ch1:linenum:208
    field:1,ch1:linenum:209
    field:1,ch1:linenum:210
    field:1,ch1:linenum:211
    field:1,ch1:linenum:212
    field:1,ch1:linenum:213
    field:1,ch1:linenum:214
    field:1,ch1:linenum:215
    field:1,ch1:linenum:216
    field:1,ch1:linenum:217
    field:1,ch1:linenum:218
    field:1,ch1:linenum:219
    field:1,ch1:linenum:220
    field:1,ch1:linenum:221
    field:1,ch1:linenum:222
    field:1,ch1:linenum:223
    field:1,ch1:linenum:224
    field:1,ch1:linenum:225
    field:1,ch1:linenum:226
    field:1,ch1:linenum:227
    field:1,ch1:linenum:228
    field:1,ch1:linenum:229
    field:1,ch1:linenum:230
    field:1,ch1:linenum:231
    field:1,ch1:linenum:232
    field:1,ch1:linenum:233
    field:1,ch1:linenum:234
    field:1,ch1:linenum:235
    field:1,ch1:linenum:236
    field:1,ch1:linenum:237
    field:1,ch1:linenum:238
    field:1,ch1:linenum:239
    field:1,ch1:linenum:240
    field:1,ch1:linenum:241
    field:1,ch1:linenum:242
    field:1,ch1:linenum:243
    field:1,ch1:linenum:244
    field:1,ch1:linenum:245
    field:1,ch1:linenum:246
    field:1,ch1:linenum:247
    field:1,ch1:linenum:248
    field:1,ch1:linenum:249
    field:1,ch1:linenum:250
    field:1,ch1:linenum:251
    field:1,ch1:linenum:252
    field:1,ch1:linenum:253
    field:1,ch1:linenum:254
    field:1,ch1:linenum:255
    field:1,ch1:linenum:256
    field:1,ch1:linenum:257
    field:1,ch1:linenum:258
    field:1,ch1:linenum:259
    field:1,ch1:linenum:260
    field:1,ch1:linenum:261
    field:1,ch1:linenum:262
    field:1,ch1:linenum:263
    field:1,ch1:linenum:264
    field:1,ch1:linenum:265
    field:1,ch1:linenum:266
    field:1,ch1:linenum:267
    field:1,ch1:linenum:268
    field:1,ch1:linenum:269
    field:1,ch1:linenum:270
    field:1,ch1:linenum:271
    field:1,ch1:linenum:272
    field:1,ch1:linenum:273
    field:1,ch1:linenum:274
    field:1,ch1:linenum:275
    field:1,ch1:linenum:276
    field:1,ch1:linenum:277
    field:1,ch1:linenum:278
    field:1,ch1:linenum:279
    field:1,ch1:linenum:280
    field:1,ch1:linenum:281
    field:1,ch1:linenum:282
    field:1,ch1:linenum:283
    field:1,ch1:linenum:284
    field:1,ch1:linenum:285
    field:1,ch1:linenum:286
    field:0,ch1:linenum:0
    field:0,ch1:linenum:3
    field:0,ch1:linenum:4
    field:0,ch1:linenum:5
    field:0,ch1:linenum:6
    field:0,ch1:linenum:7
    field:0,ch1:linenum:8
    field:0,ch1:linenum:9
    field:0,ch1:linenum:10
    field:0,ch1:linenum:11
    field:0,ch1:linenum:12
    field:0,ch1:linenum:13
    field:0,ch1:linenum:14
    field:0,ch1:linenum:15
    field:0,ch1:linenum:29
    field:0,ch1:linenum:30
    field:0,ch1:linenum:31
    field:0,ch1:linenum:32
    field:0,ch1:linenum:33
    field:0,ch1:linenum:34
    field:0,ch1:linenum:35
    field:0,ch1:linenum:36
    field:0,ch1:linenum:37
    field:0,ch1:linenum:38
    field:0,ch1:linenum:39
    field:0,ch1:linenum:40
    field:0,ch1:linenum:41
    field:0,ch1:linenum:42
    field:0,ch1:linenum:43
    field:0,ch1:linenum:44
    field:0,ch1:linenum:45
    field:0,ch1:linenum:46
    field:0,ch1:linenum:47
    field:0,ch1:linenum:48
    field:0,ch1:linenum:49
    field:0,ch1:linenum:50
    field:0,ch1:linenum:51
    field:0,ch1:linenum:52
    3
    k=:520,j=517,m=0
    capture_buf.index=0
    field:0,ch1:linenum:53
    field:0,ch1:linenum:54
    field:0,ch1:linenum:55
    field:0,ch1:linenum:56
    field:0,ch1:linenum:57
    field:0,ch1:linenum:58
    field:0,ch1:linenum:59
    field:0,ch1:linenum:60
    field:0,ch1:linenum:61
    field:0,ch1:linenum:62
    field:0,ch1:linenum:63
    field:0,ch1:linenum:64
    field:0,ch1:linenum:65
    field:0,ch1:linenum:66
    field:0,ch1:linenum:67
    field:0,ch1:linenum:68
    field:0,ch1:linenum:69
    field:0,ch1:linenum:70
    field:0,ch1:linenum:71
    field:0,ch1:linenum:72
    field:0,ch1:linenum:73
    field:0,ch1:linenum:74
    field:0,ch1:linenum:75
    field:0,ch1:linenum:76
    field:0,ch1:linenum:77
    field:0,ch1:linenum:78
    field:0,ch1:linenum:79
    field:0,ch1:linenum:80
    field:0,ch1:linenum:81
    field:0,ch1:linenum:82
    field:0,ch1:linenum:83
    field:0,ch1:linenum:84
    field:0,ch1:linenum:85
    field:0,ch1:linenum:86
    field:0,ch1:linenum:87
    field:0,ch1:linenum:88
    field:0,ch1:linenum:89
    field:0,ch1:linenum:90
    field:0,ch1:linenum:91
    field:0,ch1:linenum:92
    field:0,ch1:linenum:93
    field:0,ch1:linenum:94
    field:0,ch1:linenum:95
    field:0,ch1:linenum:96
    field:0,ch1:linenum:97
    field:0,ch1:linenum:98
    field:0,ch1:linenum:99
    field:0,ch1:linenum:100
    field:0,ch1:linenum:101
    field:0,ch1:linenum:102
    field:0,ch1:linenum:103
    field:0,ch1:linenum:104
    field:0,ch1:linenum:105
    field:0,ch1:linenum:106
    field:0,ch1:linenum:107
    field:0,ch1:linenum:108
    field:0,ch1:linenum:109
    field:0,ch1:linenum:110
    field:0,ch1:linenum:111
    field:0,ch1:linenum:112
    field:0,ch1:linenum:113
    field:0,ch1:linenum:114
    field:0,ch1:linenum:115
    field:0,ch1:linenum:116
    field:0,ch1:linenum:117
    field:0,ch1:linenum:118
    field:0,ch1:linenum:119
    field:0,ch1:linenum:120
    field:0,ch1:linenum:121
    field:0,ch1:linenum:122
    field:0,ch1:linenum:123
    field:0,ch1:linenum:124
    field:0,ch1:linenum:125
    field:0,ch1:linenum:126
    field:0,ch1:linenum:127
    field:0,ch1:linenum:128
    field:0,ch1:linenum:129
    field:0,ch1:linenum:130
    field:0,ch1:linenum:131
    field:0,ch1:linenum:132
    field:0,ch1:linenum:133
    field:0,ch1:linenum:134
    field:0,ch1:linenum:135
    field:0,ch1:linenum:136
    field:0,ch1:linenum:137
    field:0,ch1:linenum:138
    field:0,ch1:linenum:139
    field:0,ch1:linenum:140
    field:0,ch1:linenum:141
    field:0,ch1:linenum:142
    field:0,ch1:linenum:143
    field:0,ch1:linenum:144
    field:0,ch1:linenum:145
    field:0,ch1:linenum:146
    field:0,ch1:linenum:147
    field:0,ch1:linenum:148
    field:0,ch1:linenum:149
    field:0,ch1:linenum:150
    field:0,ch1:linenum:151
    field:0,ch1:linenum:152
    field:0,ch1:linenum:153
    field:0,ch1:linenum:154
    field:0,ch1:linenum:155
    field:0,ch1:linenum:156
    field:0,ch1:linenum:157
    field:0,ch1:linenum:158
    field:0,ch1:linenum:159
    3
    k=:520,j=518,m=0
    omap3isp omap3isp: Ouch!
    capture_buf.index=0
    3
    k=:520,j=517,omap3isp omap3isp: Ouch!
    m=0
    capture_buf.index=0
    3
    k=:520,j=517,m=0
    capture_buf.index=0
    field:1,ch1:linen^C
    这样我无法提取出完整的一帧数据,请问应该如何解决这个问题。
    万分感谢
    suzhu
