使用CCS5.4编译时出现下面的警告,怎么才能去掉呢?
Description Resource Path Location Type #16002-D build attribute vendor section TI missing in "../csl6713.lib<csl_irq.obj>": compatibility cannot be determined Timer C/C++ Problem
这个warning是因为csl6713.lib是老版本的CGT生成的, 用CCS v5新版本的cgt编译, 就会出现这个warning, 可以忽略这个warning, 或者到build option中选择--diag_suppress=16002 , 详细见下面的wiki.
http://processors.wiki.ti.com/index.php/C28x_Compiler_Error_and_Warning_Messages#Warning:_build_attribute_vendor_section_TI_missing_in_.22.3Clibrary_or_object.3E_:_compatibility_cannot_be_determined
