C66xx_4: Trouble Reading Register ControlRegisters_CSR: (Error -1202 @ 0x41) Device core is hung. The debugger will attempt to force the device to a ready state to recover debug control. Your application's state will be corrupt. You should have limited access to memory and registers, but you may need to reset the device to debug further. (Emulation package 5.0.872.0)
用4个核没有问题,但是使用5个核的时候报错,问题如上,这个如何解决。
