hi,
when I use IPNC3.5 on evm848,but there is some errors about aic3106 configuration,,let's look the following
U-Boot 2010.06 (May 18 2014 - 17:05:13)
TI8148-GP rev 3.0
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
DRAM: 2 GiB
NAND: HW ECC BCH8 Selected
256 MiB
Using default environment
The 2nd stage U-Boot will now be auto-loaded
Please do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashed
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x20000, size 0x40000
262144 bytes read: OK
## Starting application at 0x81000000 ...
U-Boot 2010.06 (May 18 2014 - 17:05:55)
TI8148-GP rev 3.0
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
I2C: ready
DRAM: 2 GiB
256 MiB
MMC: OMAP SD/MMC: 0
.:;rrr;;.
,5#@@@@#####@@@@@@#2,
,A@@@hi;;;r5;;;;r;rrSG@@@A,
r@@#i;:;s222hG;rrsrrrrrr;ri#@@r
:@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:
B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B
@@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@
@@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@
@@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@
G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G
@9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@
X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X
@#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@
@A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@
@&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@
@#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@
M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@#
:@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@,
@@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@
@A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@
;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@;
r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r
,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@,
B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H
.@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@.
.A@@#5r;;;r;;;rrr;r:r#AsM@@H.
;&@@@@MhXS5i5SX9B@@@@G;
:ihM#@@@@@##hs,
Net: Detected MACID:12:34:56:78:9a:bc
cpsw
Loading from nand0, offset 0x280000
Image Name: Linux-2.6.37_DM8127_IPNC_3.50.00
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2493104 Bytes = 2.4 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 81000000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37_DM8127_IPNC_3.50.00 (root@afa-desktop) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Sat May 31 19:10:20 CST 2014
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148ipnc
vram size = 4194304 at 0x0
bootconsole [earlycon0] enabled
ti81xx_reserve: ### Reserved DDR region @84f00000
reserved size = 4194304 at 0x0
FB: Reserving 4194304 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 3.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19040
Kernel command line: console=ttyO0,115200n8 root=/dev/nfs rw mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 nfsroot=192.168.1.182:/home/afa/work/DM8127/Source/ipnc_rdk/target/filesys,nolock cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 rootdelay=5 earlyprintk ip=192.168.1.181:192.168.1.182:192.168.1.1:255.255.255.0:DM8127_IPNC:eth0:off
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 74MB 1MB = 75MB total
Memory: 70652k/70652k available, 11268k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5800000 - 0xf8000000 ( 808 MB)
lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc003e000 ( 216 kB)
.text : 0xc003e000 - 0xc04bf000 (4612 kB)
.data : 0xc04c0000 - 0xc05004c0 ( 258 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 599.65 BogoMIPS (lpj=2998272)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0x84f00000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
_omap_mux_init_gpio: Could not set gpio79
_omap_mux_init_gpio: Could not set gpio80
Cannot clk_get ck_32
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
PWM0 init success.
PWM1 init success.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
regulator: VRTC: 1800 mV
regulator: VIO: 1500 mV
regulator: VDD1: 600 <--> 1500 mV at 1200 mV
regulator: VDD2: 600 <--> 1500 mV at 1200 mV
regulator: VDDCTRL: 600 <--> 1400 mV at 1200 mV
regulator: LDO1: 1100 <--> 3300 mV at 1800 mV
regulator: LDO2: 1100 <--> 3300 mV at 1800 mV
regulator: LDO3: 1100 <--> 3300 mV at 3300 mV
regulator: LDO4: 1100 <--> 3300 mV at 1800 mV
regulator: LDO5: 1100 <--> 3300 mV at 3300 mV
regulator: LDO6: 1100 <--> 3300 mV at 3300 mV
regulator: LDO7: 1100 <--> 3300 mV at 3300 mV
regulator: LDO8: 1100 <--> 3300 mV at 1800 mV
tps65911-rtc tps65911-rtc: rtc core: registered tps65911-rtc as rtc0
tps65910 1-002d: No interrupt support, no core IRQ
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, peripheral, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(32 18 16)
usb2phy: override computed values rxcalib(15)DACs(32 18 16)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f706586
musb-hdrc musb-hdrc.0: USB Peripheral mode controller at c581e000 using DMA, IRQ 18
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 137
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
CMEMK module: built on May 31 2014 at 19:03:32
Reference Linux version 2.6.37
File /home/afa/work/DM8127/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc7000000 of size 0x4000000
cmemk initialized
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled, bootconsole disabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron )
Creating 8 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x000006fc0000 : "File System"
0x000006fc0000-0x000007bc0000 : "Data"
0x000007bc0000-0x00000b0c0000 : "File System2"
0x00000b0c0000-0x000010000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
Linux video capture interface: v2.00
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000
cm: Module associated with clock hdmi_i2s_fck didn't enable in 100000 tries
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
#0: TI8148 IPNC
nf_conntrack version 0.5.0 (1103 buckets, 4412 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 17
Bridge firewalling registered
lib80211: common routines for IEEE802.11 drivers
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=84:7e:40:3d:bc:5c
tps65911-rtc tps65911-rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
mmc1: new high speed SDHC card at address e624
mmcblk0: mmc1:e624 SU04G 3.69 GiB
mmcblk0: p1
CPSW phy found : id is : 0x4dd074
PHY 0:01 not found
IP-Config: Complete:
device=eth0, addr=192.168.1.181, mask=255.255.255.0, gw=192.168.1.1,
host=DM8127_IPNC, domain=, nis-domain=(none),
bootserver=192.168.1.182, rootserver=192.168.1.182, rootpath=
Waiting 5sec before mounting root device...
PHY: 0:00 - Link is Up - 100/Full
VFS: Mounted root (nfs filesystem) on device 0:14.
devtmpfs: mounted
Freeing init memory: 216K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
Root filesystem already rw, not remounting
Caching udev devnodes
root: mount: mounting /dev/root on / failed: No such file or directory
NOT configuring network interfaces: / is an NFS mount
rm: cannot remove '/tmp': Device or resource busy
Sat Nov 10 04:11:00 GMT-8 2012
inside finish.sh
UBI: attaching mtd5 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: sub-page size: 512
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 917
UBI: attached mtd5 to ubi0
UBI: MTD device name: "Data"
UBI: MTD device size: 12 MiB
UBI: number of good PEBs: 96
UBI: number of bad PEBs: 0
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 96
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 13/11
UBI: image sequence number: 844251070
UBI: background thread "ubi_bgt0d" started, PID 275
UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
UBIFS: file system size: 10285056 bytes (10044 KiB, 9 MiB, 81 LEBs)
UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 485787 bytes (474 KiB)
UBI: attaching mtd7 to ubi1
UBI: max. sequence number: 60
UBI: attached mtd7 to ubi1
UBI: MTD device name: "Reserved"
UBI: MTD device size: 79 MiB
UBI: number of good PEBs: 634
UBI: total number of reserved PEBs: 634
UBI: number of PEBs reserved for bad PEB handling: 6
UBI: max/mean erase counter: 24/14
UBI: image sequence number: 131240250
UBI: background thread "ubi_bgt1d" started, PID 287
UBI device number 1, total 634 LEBs (80502784 bytes, 76.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
UBIFS: file system size: 78090240 bytes (76260 KiB, 74 MiB, 615 LEBs)
UBIFS: journal size: 3936256 bytes (3844 KiB, 3 MiB, 31 LEBs)
UBIFS: reserved for root: 3688395 bytes (3601 KiB)
./init.sh: line 5: -f: not found
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=127,127
| dBscale-min=-63.50dB,step=0.50dB,mute=0
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.20.02.20
SysLink module created on Date:May 31 2014 Time:19:11:54
Trace enabled
Trace SetFailureReason enabled
/dev/mem opened.
Phy Addr : 0x48181560 Data : 0x00000102
secss put in low power state
Phy Addr : 0x48180f10 Data : 0x00000000
Phy Addr : 0x48180508 Data : 0x00000302
Phy Addr : 0x48180520 Data : 0x00000002
Phy Addr : 0x48180524 Data : 0x00000002
Phy Addr : 0x48180528 Data : 0x00000002
Phy Addr : 0x4c0000e4 Data : 0x00170208
Phy Addr : 0x4d0000e4 Data : 0x00170208
DDR IOs RX is shutdown
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00800000 )
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
AlramThread created
Share memory init success
Creat queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
queue id:32769
Ready
Go to sleep
[host] Attached to slave procId 0.
[host] Loaded file ./firmware/ipnc_rdk_fw_c6xdsp.xe674 on slave procId 0.
[host] Started slave procId 0.
[host] After Ipc_loadcallback status [0x00000000]
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 500000000, <NEW> - 500000000
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 500000 Khz ***
[c6xdsp ]
[c6xdsp ] 1: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 1: SYSTEM: IPC init in progress !!!
[c6xdsp ] 1: SYSTEM: Attaching to [HOST] ...
[host] Attached to slave procId 2.
[host] Attached to slave procId 1.
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 2.
[host] Started slave procId 2.
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 1.
[host] Started slave procId 1.
[c6xdsp ] 1001: SYSTEM: Attaching to [HOST] ...
[m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3video]
[m3vpss ] notify_attach rtnVal 0
[m3video] *** UTILS: CPU KHz = 400000 Khz ***
[m3video]
[m3video] 54: SYSTEM : System Common Init in progress !!!
[m3video] 54: SYSTEM: IPC init in progress !!!
[m3video] 54: SYSTEM: Attaching to [HOST] ...
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[m3vpss ]
[m3vpss ] 95: SYSTEM : System Common Init in progress !!!
[m3vpss ] 95: SYSTEM: IPC init in progress !!!
[m3vpss ] 95: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1345: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 1345: SYSTEM: Attaching to [VIDEO-M3] ...
[host] After Ipc_startcallback status [0x00000000]
[m3video] 1054: SYSTEM: Attaching to [HOST] ...
[m3video] 1062: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 1062: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 1095: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1098: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1098: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2345: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 3025: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 2062: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3025: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 2062: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 2063: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 2098: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 4024: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 3062: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4061: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 3098: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 4061: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 3098: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 3099: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 4062: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 5061: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 4099: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 4098: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 4099: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 4099: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 4099: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 4099: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 4100: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 4099: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3video] 4102: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 4099: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3video] 4102: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3vpss ] 4102: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3video] 4102: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3vpss ] 4102: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3video] 4102: SYSTEM: IPC init DONE !!!
[m3vpss ] 4102: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3vpss ] 4102: SYSTEM: IPC init DONE !!!
[m3vpss ] Received character 's'
[m3video] 4112: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3vpss ] 4112: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 4112: MEM: ERROR: SharedRegion_setEntry (2, 0x8d9c8340) FAILED !!! (status=-1)
[m3vpss ] 4113: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3vpss ] 4115: SYSTEM : System Common Init Done !!!
[m3video] 4122: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3video] 4124: SYSTEM : System Common Init Done !!!
[m3video] Received character 's'
[c6xdsp ] 6061: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[c6xdsp ] 6061: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[c6xdsp ] 6062: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[c6xdsp ] 6062: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[c6xdsp ] 6062: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[c6xdsp ] 6062: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[c6xdsp ] 6063: SYSTEM: IPC init DONE !!!
[c6xdsp ] 6066: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[c6xdsp ] 6066: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[c6xdsp ] 6067: SYSTEM : System Common Init Done !!!
[c6xdsp ] Received character 's'
queue id:65538
CPU is TI812x
Error: SemWait: Invalid Semaphore handler
Error: SemRelease: Invalid Semaphore handler
IPNC BUILD VERSION: DM8127 IPNC RDK VERSION 03.50.00.08
./bin/ipnc_rdk_mcfw.out VNF_QUALITY TRISTREAM TRIPLE_H264 AUDIO 8000 TI2A AEWB 1080P_D1 H264 HIGH_SPEED1 H264 HIGH_SPEED2 MJPEG 80 &
[c6xdsp ] 6265: SYSTEM : System DSP Init in progress !!!
[c6xdsp ] 6270: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ...
[c6xdsp ] 6271: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ...
[c6xdsp ] 6271: SYSTEM: ListElem Shared Addr = 0xbe98b680
[c6xdsp ] 6272: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 6272: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] 6272: SYSTEM: ListElem Shared Addr = 0xbe9ab080
[c6xdsp ] 6273: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 6274: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 6274: SYSTEM: ListElem Shared Addr = 0xbe9caa80
[c6xdsp ] 6275: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ...
[m3vpss ] 5315: SYSTEM : System VPSS Init in progress !!!
[c6xdsp ] 6275: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ...
[c6xdsp ] 6275: SYSTEM: ListElem Shared Addr = 0xbe9ea480
[c6xdsp ] 6276: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
[c6xdsp ] 6276: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
[c6xdsp ] 6276: SYSTEM: ListElem Shared Addr = 0xbea04100
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 6276: SYSTEM : Initializing Links !!!
[c6xdsp ] 6277: SYSTEM : FREE SPACE : System Heap = 6282544 B, Mbx = 10240 msgs)
[m3video] 5324: SYSTEM : System Video Init in progress !!!
[m3video] 5324: SYSTEM : System Video Init Done !!!
[c6xdsp ] 6291: SYSTEM : Initializing Links ... DONE !!!
[m3video] 5324: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 5325: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[c6xdsp ] 6291: SYSTEM : System DSP Init Done !!!
[m3video] 5325: SYSTEM: ListElem Shared Addr = 0xbea1dd80
[m3video] 5327: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 5328: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 5328: SYSTEM: ListElem Shared Addr = 0xbea21280
[m3video] 5339: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] === I2C0/2 Clk is active ===
[m3video] 5340: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
[m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_2_1
[m3video] 5340: SYSTEM: ListElem Shared Addr = 0xbea2b180
[m3vpss ] 5334: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3vpss ] 5334: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3vpss ] 5334: SYSTEM: ListElem Shared Addr = 0xbea24780
[m3vpss ] 5337: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3vpss ] 5337: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3video] 5343: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 5337: SYSTEM: ListElem Shared Addr = 0xbea27c80
[m3video] 5343: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3video] 5343: SYSTEM: ListElem Shared Addr = 0xbea44e00
[m3video] 5345: HDVICP: Doing PRCM for IVAHD[0] ...
[m3video] 5346: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3video] 5346: SYSTEM : Initializing Links !!!
[m3video] 5347: SYSTEM : FREE SPACE : System Heap = 6282128 B, Mbx = 10240 msgs)
[m3vpss ] 5353: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ...
[m3vpss ] 5353: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ...
[m3video] 5347: SYSTEM : FREE SPACE : SR0 Heap = 15342464 B (14 MB)
[m3vpss ] 5354: SYSTEM: ListElem Shared Addr = 0xbea5ea80
[m3vpss ] 5357: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3video] 5347: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[m3vpss ] 5357: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 5357: SYSTEM: ListElem Shared Addr = 0xbea7e480
[m3video] 5347: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 5360: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 5361: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3video] 5347: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 5361: SYSTEM: ListElem Shared Addr = 0xbea9de80
[m3video] 5348: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (S-M3_IPC_OUT_29] in region 0 ...
[m3video] 5405: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 5372: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 5372: SYSTEM: ListElem Shared Addr = 0xbead7500
[m3vpss ] 5375: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3vpss ] 5375: SYSTEM : FVID2 Init in progress !!!
[m3vpss ] 5441: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 5441: SYSTEM : Device Init in progress !!!
[m3vpss ] Iss_init called !!!!!!
[m3vpss ] Iss_init: issCommonInit called start @ line 358 ================
[m3vpss ] Iss_init: issCommonInit called end @ line 360 ================
[m3vpss ] Iss_init: issDriverInit called start @ line 364 ================
[m3vpss ] issDriverInit:Iss_captInit called start @ line 317 ================
[m3vpss ] Iss_captInit:FVID2_registerDrive called start @ line 1504 ============= sbulla: unknown partition table
[m3vpss ] Iss_captInit: FVID2_registerDrive called end status @ line 0 ================
[m3vpss ] Iss_captInit: FVID2_registerDrive called end @ line 1507 ================
[m3vpss ] issDriverInit: Iss_captInit called end @ line 319 ================
[m3vpss ] Iss_init: issDriverInit called end @ line 366 ================
[m3vpss ] Iss_init: RM_SIMCOP_Init called end @ line 372 ================
[m3vpss ] CPIS_init DONE !!!!!!
[m3vpss ] Received character 't'
[m3vpss ] initPrms.isI2cInitReq = 1
INIT: Entering runlevel: 5
[m3vpss ] Vps_platformGetBoardId: ----------------- @ line 678 --------------------------
[m3vpss ] 5: gPlatformCommonObj.platBoardId
inside autorun
[m3vpss ] 5549: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 5577: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 5577: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 5578: SYSTEM : Initializing Links !!!
[m3vpss ] 5578: SYSTEM : FREE SPACE : System Heap = 1719376 B, Mbx = 10240 msgs)
[m3video] Received character 't'
[m3vpss ] 5578: SYSTEM : FREE SPACE : SR0 Heap = 14742656 B (14 MB)
[m3vpss ] 5578: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[m3vpss ] 5578: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[c6xdsp ] Received character 't'
[m3vpss ] 5579: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] 5703: SYSTEM : Initializing Links ... DONE !!!
Starting telnet daemonDMA: Module install successful, device major num = 248
DRV: Module install successful
DRV: Module built on Jun 4 2014 14:28:48
Starting syslogd/klogd: [m3vpss ] 0 cnt========================
[m3vpss ]
[m3vpss ] 0 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ] 1536 drvId========================
[m3vpss ]
[m3vpss ] 1 cnt========================
[m3vpss ]
[m3vpss ] 1 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 2 cnt========================
[m3vpss ]
[m3vpss ] 513 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 3 cntHDMI W1 rev 4.0
================HDMI CEC Spec version 1.2
[m3vpss ]
[m3vpss ] 514 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 4 cnt========================
[m3vpss ]
[m3vpss ] 256 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 5 cnt========================
[m3vpss ]
[m3vpss ] 512 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 6 cnt========================
[m3vpss ]
[m3vpss ] 2 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 7 cnt========================
[m3vpss ]
[m3vpss ] 268435712 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 8 cnt========================
[m3vpss ]
[m3vpss ] 268435970 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 9 cnt========================
[m3vpss ]
[m3vpss ] 1536 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668904 channel ========================
[m3vpss ]
[m3vpss ] 9 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] -1893555224 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 drvId========================
[m3vpss ]
[m3vpss ] -1893668872 channel ========================
[m3vpss ]
[m3vpss ] 0 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] -1893720320 drvHandle ========================
[m3vpss ]
[m3vpss ]
done
I2C No Ack
[host]
[host] ORG 0x46c00524: 0
[host] NEW 0x46c00524: 2
[host]
[host] Application Start Completed
mkdosfs 3.0.12 (29 Oct 2011)
unable to get drive geometry, using default 255/63
/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
There is 1 reserved sector.
Root directory contains 512 slots and uses 32 sectors.
Volume ID is 362a608d, no volume label.
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 0: SYSTEM: IPC init in progress !!!
[host] 13: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
[host] 13: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
[host] 13: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
[host] 13: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
[host] 14: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 15: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 17: SYSTEM:
[host] 61: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 63: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 65: SYSTEM: ListElem Shared Addr = 0x405bb480
DMA: ChannelID allocated:4
[host] 66: SYDMA: ChannelID allocated:10
STEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dm814x-evm ttyO0
Arago 2011.09 dm814x-evm ttyO0
dm814x-evm login: root (automatic login)
[host] 70: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 72: SYSTEM: ListElem Shared Addr = 0x405dae80
[host] 72: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0x4beaa000,size = 65011712
[host] MCFW_IPCBITS:App_streamSysInit:virt addr of 85000000 cir buffer is 4beaa000
##########pInfo->totalsize 63897600
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[host] CacheMng_Mg_file_storage gadget: No serial-number string provided!
emCpy_open:OSA_dmaOpen passed with ch id = 10
Creat queue id:131076
queue id:1g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
31076
queue id:g_file_storage gadget: Number of LUNs=1
65538
[hostg_file_storage gadget-lun0: ro=0, nofua=0, file: /dev/sbulla
] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:Entered...
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 3 cnt========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668840 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] VPS_DCTRL_INST_0
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_DVO2
[host]
********** FULL FEATURE USECASE ********
[host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[host] 177: MCFW : CPU Revision [ES2.1] !!!
[host] 177: MCFW : Detected [UNKNOWN] Board !!!
[host] 177: MCFW : Base Board Revision [REV A] !!!
[m3vpss ] 7390: CAPTURE: Create in progress !!!
[m3vpss ] CAPTURELINK:!!WARNING.FORCIBLY DISABLING TILER since tiler is disabled at build time
[m3vpss ]
[m3vpss ]
[m3vpss ] 1026 drvId========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
amixer: Unable to find simple control '鈥楻ight',0
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 20 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] 0 channel ========================
[m3vpss ]
[m3vpss ] 7393: Assertion @ Line: 2204 in links_m3vpss/capture/captureLink_drv.c: videoDecoderHandle != NULL : failed !!!
root@dm814x-evm:~# amixer: Unable to find simple control '鈥楻ight',0
queue id:0
ApproDrvInit: 3
queue id:131076
queue id:0
queue id:32769
queue id:0
ApproDrvInit: 7
queue id:131076
ApproDrvExit: 7
Error: WaitStreamReady Fail.
[host]
Force IDR on Channel: 0
TI8148-GP rev 3.0
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
DRAM: 2 GiB
256 MiB
TI8148-GP rev 3.0
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
I2C: ready
DRAM: 2 GiB
256 MiB
MMC: OMAP SD/MMC: 0
.:;rrr;;.
:ihM#@@@@@##hs,
cpsw
OK
Starting kernel ...
Machine: ti8148ipnc
NR_IRQS:375
GPMC revision 6.0
regulator: dummy:
PWM0 init success.
PWM1 init success.
Cppi41 Init Done
usb2phy: computed values rxcalib(15)DACs(33 18 15)
usb2phy: override computed values rxcalib(15)DACs(33 18 15)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f70e57e
TCP reno registered
cmemk initialized
brd: module loaded
loop: module loaded
ALSA device list:
#0: TI8148 IPNC
mmcblk0: p1
PHY 0:01 not found
devtmpfs: mounted
Starting udev
inside finish.sh
UBI: max. sequence number: 923
UBI: background thread "ubi_bgt0d" started, PID 263
UBI: max. sequence number: 61
UBI: background thread "ubi_bgt1d" started, PID 275
: values=127,127
Trace enabled
/dev/mem opened.
Creat queue id:0
queue id:0
queue id:32769
AlramThread created
queue id:65538
queue id:98307
queue id:32769
Ready
Go to sleep
[m3video]
[m3video]
[m3video] 52: SYSTEM : System Common Init in progress !!!
[m3video] 52: SYSTEM: IPC init in progress !!!
[m3video] 52: SYSTEM: Attaching to [HOST] ...
[m3vpss ]
[m3vpss ]
[m3vpss ] 92: SYSTEM : System Common Init in progress !!!
[m3vpss ] 93: SYSTEM: IPC init in progress !!!
[m3vpss ] 93: SYSTEM: Attaching to [HOST] ...
[c6xdsp ]
[c6xdsp ]
[m3video] 1052: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1092: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1095: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1096: SYSTEM: Attaching to [DSP] ...
[m3video] 1159: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 1159: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 1004: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 1004: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 2095: SYSTEM: Attaching to [DSP] ...
[m3video] 2159: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2004: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 3095: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2243: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 3159: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2243: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 3159: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 3159: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 4095: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3242: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 4159: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4179: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 5095: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 4180: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 5096: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 5096: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 5159: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 5179: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 6096: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 6095: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 6096: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 6096: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 6097: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
INIT: Entering runlevel: 5Cr
inside autorun
Starting telnet daemon sbulla: unknown partition table
Starting syslogd/klogd: done
_____ _____ _ _
|___| |___|
root@dm814x-evm:~# [c6xdsp ] 6179: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[c6xdsp ] 6179: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[c6xdsp ] 6180: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[c6xdsp ] 6180: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[c6xdsp ] 6180: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[c6xdsp ] 6180: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[c6xdsp ] 6181: SYSTEM: IPC init DONE !!!
[c6xdsp ] 6184: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[c6xdsp ] 6184: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[c6xdsp ] 6185: SYSTEM : System Common Init Done !!!
queue id:65538
CPU is TI812x
[m3video] 7312: SYSTEM : System Video Init in progress !!!
[m3vpss ] 7312: SYSTEM : System VPSS Init in progress !!!
[m3video] 7312: SYSTEM : System Video Init Done !!!
[m3video] 7312: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 7313: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 7313: SYSTEM: ListElem Shared Addr = 0xbe98b680
[m3video] 7315: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 7316: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 7316: SYSTEM: ListElem Shared Addr = 0xbe98eb80
[m3video] 7327: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
[m3video] 7327: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
[m3video] 7328: SYSTEM: ListElem Shared Addr = 0xbe992080
[m3vpss ] 7331: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3video] 7330: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 7331: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3video] 7331: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 7332: SYSTEM: ListElem Shared Addr = 0xbe9c5980
[m3video] 7331: SYSTEM: ListElem Shared Addr = 0xbe9abd00
[m3vpss ] 7334: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3video] 7333: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 7335: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3video] 7333: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 7335: SYSTEM: ListElem Shared Addr = 0xbe9c8e80
[m3video] 7334: SYSTEM : Initializing Links !!!
[m3video] 7334: SYSTEM : FREE SPACE : System Heap = 6282128 B, Mbx = 10240 msgs)
[m3video] 7334: SYSTEM : FREE SPACE : SR0 Heap = 15955200 B (15 MB)
[m3vpss ] 7350: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ...
[m3vpss ] 7351: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ...
[m3video] 7335: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[m3vpss ] 7351: SYSTEM: ListElem Shared Addr = 0xbe9cc380
[m3vpss ] 7354: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3video] 7335: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 7354: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 7355: SYSTEM: ListElem Shared Addr = 0xbe9ebd80
[m3video] 7335: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3video] 7336: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] 7358: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 7358: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 7358: SYSTEM: ListElem Shared Addr = 0xbea0b780
[m3vpss ] 7365: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] 7366: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 7366: SYSTEM: ListElem Shared Addr = 0xbea2b180
[m3vpss ] 7369: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 7369: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 7369: SYSTEM: ListElem Shared Addr = 0xbea44e00
[m3vpss ] 7372: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3vpss ] 7372: SYSTEM : FVID2 Init in progress !!!
[m3video] 7393: SYSTEM : Initializing Links ... DONE !!!
[c6xdsp ] 6483: SYSTEM : System DSP Init in progress !!!
[c6xdsp ] 6489: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ...
[c6xdsp ] 6489: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ...
[c6xdsp ] 6489: SYSTEM: ListElem Shared Addr = 0xbea5ea80
[c6xdsp ] 6490: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 6490: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] 6490: SYSTEM: ListElem Shared Addr = 0xbea7e480
[c6xdsp ] 6492: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 6492: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 6492: SYSTEM: ListElem Shared Addr = 0xbea9de80
[c6xdsp ] 6493: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ...
[c6xdsp ] 6493: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ...
[c6xdsp ] 6493: SYSTEM: ListElem Shared Addr = 0xbeabd880
[c6xdsp ] 6494: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
[c6xdsp ] 6494: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
[c6xdsp ] 6494: SYSTEM: ListElem Shared Addr = 0xbead7500
[c6xdsp ] 6494: SYSTEM : Initializing Links !!!
[c6xdsp ] 6495: SYSTEM : FREE SPACE : System Heap = 6282544 B, Mbx = 10240 msgs)
[c6xdsp ] 6509: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 7437: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 7437: SYSTEM : Device Init in progress !!!
[c6xdsp ] 6509: SYSTEM : System DSP Init Done !!!
[m3vpss ] Iss_captInit:FVID2_registerDrive called start @ line 1504 ================
Volume ID is 3627c40e, no volume label.
[m3vpss ] 7455: Vps_deviceI2cInit >>>
[m3vpss ] Vps_deviceInit @ line 38 ===============
[m3vpss ] 5 boardId===============
[m3vpss ] Vps_deviceInit @ line 41 ===============
[m3vpss ] 7455: Vps_deviceI2cInit <<<
[m3vpss ] 7455: Vps_thsFiltersInit >>>
[m3vpss ] 7455: Vps_thsFiltersInit <<<
[m3vpss ] 7456: Vps_tvp5158Init >>>
[m3vpss ] Vps_deviceInit @ line 157 ===============
[m3vpss ] 7456: Vps_sii9135Init >>>
[m3vpss ] FVID2_registerDriver ( &gVps_sii9135CommonObj.fvidDrvOps ) start sg_file_storage gadget: No serial-number string provided!
ii9135/src/vpsdrv_sii9135Api.c:Vps_sii9135Init:248 !!!
[m3vpss ] FVID2_registerDriver ( &gVps_g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
sii9135CommonObjg_file_storage gadget: Number of LUNs=1
.fvidDrvOps ) dog_file_storage gadget-lun0: ro=0, nofua=0, file: /dev/sbulla
ne sii9135/src/vpsdrv_sii9135Api.c:Vps_sii9135Init:250 !!!
[m3vpss ] sii9135/src/vpsdrv_sii9135Api.c:Vps_sii9135Init: status=0 !!!
[m3vpss ] 7456: Vps_sii9135Init <<<
[m3vpss ] I2C0: Passed for address 0x18 !!!
amixer: Unable to find simple control 'Right PGA Mixer Mic3L Switch',0
amixer: Unable to find simple control 'Right PGA Mixer Mic3R Switch',0
[m3vpss ] I2C0: Passed for address 0x2d !!!
[m3vpss ] I2C0: Passed for address 0x30 !!!
[m3vpss ] I2C0: Passed for address 0x34 !!!
[m3vpss ] I2C0: Passed for address 0x4b !!!
queue id:0
[m3vpss ] 10056: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 10085: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 10085: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 10085: SYSTEM : Initializing Links !!!
[m3vpss ] 10085: SYSTEM : FREE SPACE : System Heap = 1718872 B, Mbx = 10240 msgs)
[m3vpss ] 10085: SYSTEM : FREE SPACE : SR0 Heap = 14742656 B (14 MB)
[m3vpss ] 10085: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[m3vpss ] 10086: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 10086: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] 10211: SYSTEM : Initializing Links ... DONE !!!
DRV: Module built on Jun 4 2014 15:16:15
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[mHDMI W1 rev 4.0
3vpss ] 513 gFdmHDMI CEC Spec version 1.2
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668648 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893554968 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668616 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893720064 drvHandle ========================
[m3vpss ]
[m3vpss ]
I2C No Ack
[host]
[host]
[host] 1: SYSTEM: IPC init in progress !!!
[host] 43: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
[host] 43: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
[host] 43: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
[host] 44: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
[host] 44: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 45: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 47: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[host] 49: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
[host] 49: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 50: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 51: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[host] 52: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 52: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 53: SYSTEM: IPC init DONE !!!
[host] 55: SYSTEM: Creating ListMP [HOST_IPC_OUT_28] in region 0 ...
[host] 64: SYSTEM: Creating ListMP [HOST_IPC_IN_28] in region 0 ...
[host] 68: SYSTEM: ListElem Shared Addr = 0x40558180
[host] 73: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 78: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 82: SYSTEM: ListElem Shared Addr = 0x4DMA: ChannelID allocated:10
0571e00
[host] 89: SYSTEM: Creating ListMP [HOST_IPC_OUT_23] in region 0 ...
[host] 97: SYSTEM: Creating ListMP [HOST_IPC_IN_23] in region 0 ...
[host] 102: SYSTEM: ListElem Shared Addr = 0x4058ba80
[host] 107: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 115: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 117: SYSTEM: ListElem Shared Addr = 0x405ab480
[host] 120: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 127: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 133: SYSTEM: ListElem Shared Addr = 0x405cae80
[host] 135: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0x4c117000,size = 65011712
[host] MCFW_IPCBITS:App_streamSysInit:virt addr of 85000000 cir buffer is 4c117000
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 10
queue id:131076
queue id:65538
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:Entered...
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668584 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[host]
[host] 247: MCFW : CPU Revision [ES2.1] !!!
[host] 247: MCFW : Detected [UNKNOWN] Board !!!
[host] 248: MCFW : Base Board Revision [REV A] !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 11654: CAPTURE: Create in progress !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
ApproDrvInit: 3
queue id:131076
queue id:0
queue id:32769
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 10 cnt========================
[m3vpss ]
[m3vpss ] 1026 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668552 channel ========================
[m3vpss ]
[m3vpss ] 10 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] Vps_sii9135Create: ----------------- @ line 126 --------------------------
[m3vpss ] Vps_sii9135Create: ----------------- @ line -1896260528 --------------------------
[m3vpss ] Vps_sii9135Create: ----------------- @ line 141 --------------------------
[m3vpss ] Vps_sii9135Create: ----------------- @ line 0 --------------------------
[m3vpss ] Vps_sii9135Create: ----------------- @ line 155 --------------------------
[m3vpss ] Vps_sii9135Create: ----------------- @ line -1895643648 --------------------------
[m3vpss ] Vps_sii9135Create: ----------------- @ line 170 --------------------------
[m3vpss ] Vps_sii9135Create exit
[m3vpss ] -1895643648 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] 11659: CAPTURE: VIP 2: VID DEC 1026 (0x30): Video Standard Detect in Progress !!!
[m3vpss ] Vps_sii9135Control: ----------------- @ line 33 cmd = 268828675-------------------------
[m3vpss ] 11764: CAPTURE: Detecting video .....!!!
[m3vpss ] 11869: CAPTURE: Detecting video .....!!!
[m3vpss ] 11974: CAPTURE: Detecting video .....!!!
[m3vpss ] 12079: CAPTURE: Detecting video .....!!!
[m3vpss ] 12184: CAPTURE: Detecting video .....!!!
[m3vpss ] 12289: CAPTURE: Detecting video .....!!!
[m3vpss ]
[m3vpss ]
[m3vpss ] 256 drvId========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 4 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] Vps_captCreate: ----------------- @ line 178 --------------------------
[m3vpss ] 255 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] 12327: CAPTURE: VIP1 PortA capture mode is [16-bit, Non-mux Embedded Sync] !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668520 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] Vps_captCreate: ----------------- @ line 186 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 252 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 290 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 316 --------------------------
[m3vpss ] Vps_captAllocPath: ----------------- @ pObj->resAllocParams.inSrc = -1 --------------------------
[m3vpss ] Vps_captAllocPath: ----------------- @ line 1032 --------------------------
[m3vpss ] Vps_captAllocPath: ----------------- @ pObj->resAllocParams.inSrc= 1 --------------------------
[m3vpss ] Vps_captAllocPath: ----------------- @ line 1129 --------------------------
[m3vpss ] Vps_captAllocPath: ----------------- @ line 1176 --------------------------
[m3vpss ] Vps_captAllocPath: ----------------- @ line 1179 --------------------------
[m3vpss ] Vcore_vipResAllocPath: ----------------- @ line 206 --------------------------
[m3vpss ] VIP 1 RES: DRV [fvid2_vps_capt_vip_ti, 0x0dca0002] path alloc in progress ...
[m3vpss ] Vcore_vipResAllocPath: ----------------- @ line 213 --------------------------
[m3vpss ] Vcore_vipResAllocPath: ----------------- @ line 218 --------------------------
[m3vpss ] Vcore_vipResAllocPath: ----------------- @ line 232 --------------------------
[m3vpss ] Vcore_vipResAllocPath: ----------------- @ line 235 --------------------------
[m3vpss ] VIP 1 RES: [PORT_A ] is allocated in EXCLUSIVE mode
[m3vpss ] VIP 1 RES: [PORT_B ] is allocated in EXCLUSIVE mode
[m3vpss ] VIP 1 RES: [Y_LOW ] is allocated in EXCLUSIVE mode
[m3vpss ] VIP 1 RES: [CHR_DS_1 ] is allocated in EXCLUSIVE mode
[m3vpss ] VIP 1 RES: [Y_LOW ] is ALREADY allocated (ALLOC COUNT = 1, DRV ID = 0x0dca0002)
[m3vpss ] VIP 1 RES: [CHR_DS_1 ] is FREE
[m3vpss ] VIP 1 RES: [CHR_DS_0 ] is allocated in EXCLUSIVE mode
[m3vpss ] VIP 1 RES: [Y_UP ] is allocated in EXCLUSIVE mode
[m3vpss ] VIP 1 RES: [UV_UP ] is allocated in EXCLUSIVE mode
[m3vpss ] Vcore_vipResAllocPath: ----------------- @ line 276 --------------------------
[m3vpss ] VIP 1 RES: DRV [fvid2_vps_capt_vip_ti, 0x0dca0002] path alloc is DONE !!!
[m3vpss ] Vps_captAllocPath: ----------------- @ line 1182 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 321 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 324 --------------------------
[m3vpss ] VIP 1 MUX: CHR DS 0 SRC = PORTA_422 (3)
[m3vpss ] VIP 1 MUX: CHR DS 0 BYPASS = 0
[m3vpss ] VIP 1 MUX: CHR DS 1 BYPASS = 0
[m3vpss ] VIP 1 MUX: MULTI CH = 1
[m3vpss ] VIP 1 MUX: RGB HI = 0
[m3vpss ] VIP 1 MUX: RGB LO = 0
[m3vpss ] Vps_captCreate: ----------------- @ line 329 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 332 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 376 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 384 --------------------------
[m3vpss ] -1906421284 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] 0: pInst->vidDecCreateArgs.deviceI2cAddr[0]=========
[m3vpss ] 48: pInst->vidDecCreateArgs.deviceI2cAddr[0]=========
[m3vpss ] Invalid board ID!!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668488 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] Vps_sii9135Create: ----------------- @ line -1904203956 --------------------------
[m3vpss ]
[m3vpss ]
[m3vpss ] Vps_sii9135Control: ----------------- @ line 33 cmd = 268828672-------------------------
[m3vpss ] 12907: CAPTURE: VIP 2: VID DEC 1026 (0x30): 9135:0004:0001, AUD_STATUS 0
[m3vpss ] CAPTURE::HEAPID:0 USED:352
[m3vpss ] 12907: CAPTURE: Create Done !!!
[m3vpss ] Vps_sii9135Control: ----------------- @ line 33 cmd = 268828674-------------------------
[m3vpss ] Vps_sii9135OutputEnable: ----------------- @ line 719 --------------------------
[m3vpss ] Vps_sii9135OutputEnable: ----------------- @ line 742 --------------------------
[m3vpss ] +++++++++++++++++++++++++++++++++++++++++++++++++++
[m3vpss ] 13075: NSF: Create in progress !!!
[m3vpss ] NSFLINK:!!WARNING.FORCIBLY DISABLING TILER since tiler is disabled at build time
[m3vpss ]
[m3vpss ]
[m3vpss ] 512 drvId========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668456 channel ========================
[m3vpss ]
[m3vpss ] 5 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] -1895899476 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] NSF::HEAPID:0 USED:128
[m3vpss ] NSF::HEAPID:1 USED:4928
[m3vpss ] 13201: NSF: Create Done !!!
[m3vpss ] 13207: DUP : Create Done !!!
[m3vpss ] 13214: DUP : Create Done !!!
[m3vpss ] 13215: MERGE : Create Done !!!
[m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[m3vpss ] {SWOSD} edma3Handle->chId = 36
[m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[m3vpss ] {SWOSD} edma3Handle->chId = 37
[m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[m3vpss ] {SWOSD} edma3Handle->chId = 38
[m3vpss ] 13191: SWOSD : Create Done !!!
[m3vpss ] 13288: DUP : Create Done !!!
[m3vpss ] 13288: SCLR: Create in progress !!!
[m3vpss ]
[m3vpss ]
[m3vpss ] 513 drvId========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668424 channel ========================
[m3vpss ]
[m3vpss ] 2 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] VIP 0 RES: DRV [fvid2_vps_vip_core_ti, 0x00000000] path alloc in progress ...
[m3vpss ] VIP 0 RES: [SECONDARY ] is allocated in SHARED mode (ALLOC COUNT = 1, DRV ID = 0x00000000)
[m3vpss ] VIP 0 RES: [CHR_DS_0 ] is allocated in SHARED mode (ALLOC COUNT = 1, DRV ID = 0x00000000)
[m3vpss ] VIP 0 RES: [Y_UP ] is allocated in SHARED mode (ALLOC COUNT = 1, DRV ID = 0x00000000)
[m3vpss ] VIP 0 RES: [UV_UP ] is allocated in SHARED mode (ALLOC COUNT = 1, DRV ID = 0x00000000)
[m3vpss ] VIP 0 RES: [SC ] is allocated in SHARED mode (ALLOC COUNT = 1, DRV ID = 0x00000000)
[m3vpss ] VIP 0 RES: DRV [fvid2_vps_vip_core_ti, 0x00000000] path alloc is DONE !!!
[m3vpss ] VIP 0 MUX: SC SRC = SECONDARY (4)
[m3vpss ] VIP 0 MUX: CHR DS 0 SRC = SC (1)
[m3vpss ] VIP 0 MUX: CHR DS 0 BYPASS = 0
[m3vpss ] VIP 0 MUX: CHR DS 1 BYPASS = 0
[m3vpss ] VIP 0 MUX: RGB HI = 0
[m3video] 13306: IPC_IN_M3 : Create in progress !!!
[m3video] 13307: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3video] 13307: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3video] 13310: IPC_IN_M3 : Create Done !!!
[m3video] 13311: ENCODE: Create in progress ... !!!
[m3video] 13397: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[m3video] ENCLINK_H264:HEAPID:0 USED:13808
[m3video] 13505: ENCODE: Creating CH1 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[m3video] ENCLINK_H264:HEAPID:0 USED:11912
[m3video] 13615: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[m3vpss ] -1913649780 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] 13299: SCLR : Loading Up-scaling Co-effs ...
[m3vpss ] 13299: SCLR : Co-effs Loading ... DONE !!!
[m3video] ENCLINK_JPEG:HEAPID:0 USED:4432
[m3video] 13616: ENCODE: All CH Create ... DONE !!!
[m3vpss ] SCLR:HEAPID:0 USED:64
[m3vpss ] SCLR:HEAPID:1 USED:5952
[m3video] ENCLINK:HEAPID:0 USED:30392
[m3vpss ] 13299: SCLR: Create Done !!!
[m3video] 13618: ENCODE: Create ... DONE !!!
[m3vpss ] 13213: FD : Alg Create Done !!!
[m3video] 13619: IPC_BITS_OUT : Create in progress !!!
[m3vpss ] 13214: FD : Create Done !!!
[m3vpss ] 13305: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 13306: IPC_OUT_M3 : Create Done !!!
[m3video] 13621: IPC_BITS_OUT : Create Done !!!
queue id:0
[host] IpcBitsInLink_tskMain:Entered
[host] 2234: IPC_BITS_IN : Create in progress !!!
[host] 2234: IPC_BITS_IN : ListMPOpen start !!!
[host] 2234: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
[host] 2236: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
[host] 2238: IPC_BITS_IN : ListMPOpen done !!!
[host] 2239: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 2239: IPC_BITS_IN : Create Done !!!
[m3vpss ] 13642: DISPLAY: Create in progress !!!
[m3vpss ] DisplayId = 1,DataFormat = 7
[m3vpss ] SC2 displayInstId = 6
[m3vpss ]
[m3vpss ]
[m3vpss ] 1 drvId========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668392 channel ========================
[m3vpss ]
[m3vpss ] 1 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] -1898081704 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] 13644: DISPLAY: Create Done !!!
[m3vpss ] 13644: DISPLAY: Create in progress !!!
[m3vpss ] DisplayId = 4,DataFormat = 7
[m3vpss ] SD displayInstId = 2
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668360 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] -1898137752 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] 13646: DISPLAY: Create Done !!!
[host] USECASE SETUP DONE
[m3vpss ] 13984: DISPLAY: Start in progress !!!
[m3vpss ] 14048: DISPLAY: Start Done !!!
[m3vpss ] 14048: DISPLAY: AUX PATH: 31 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 14048: DISPLAY: Start in progress !!!
[m3vpss ] 14116: DISPLAY: Start Done !!!
[m3vpss ] 14116: DISPLAY: SDDAC(SEC1): 14 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 14118: CAPTURE: Start in progress !!!
[m3vpss ] Vps_sii9135Control: ----------------- @ line 33 cmd = 5-------------------------
[m3vpss ] -1893668488: CAPTURE: pInstObj->videoDecoderHandle !!!
[m3vpss ] 14119: CAPTURE: Start Done !!!
[host]
Audio capture task created [m3vpss ] 14244: CAPTURE: Fields = 0 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)
[m3video] Channel:1 inputframerate:30 targetfps:60
[host] MCFW_IPCBITS: Callback function:App_ipcBitsInCbFxn
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print.. [m3video] Channel:0 inputframerate:30 targetfps:60
[m3video] Channel:2 inputframerate:60 targetfps:5
omap_i2c omap_i2c.1: controller timed out
ApproDrvInit: 7
queue id:131076
[m3vpss ] 17256: DISPLAY: Stop in progress !!!
Venc not supporomap_i2c omap_i2c.1: controller timed out
ted!!
[m3vpss ] 17319: DISPLAY: Stop Done !!!
[m3vpss ] 17328: DISPLAY: Start in progress !!!
[host] VNF MESSAGE RECIEVED: (Enable:0) (Mode:5) (Strength:0) (EnableTNF:0) (EnableSNF:0)
[host]
Channel Selected: 0
[host]
Channel Selected: 0,rate control = 0 [m3vpss ] 17378: DISPLAY: Start Done !!!
[m3vpss ] 17378: DISPLAY: SDDAC(SEC1): 1920 fps, Latency (Min / Max) = ( 1 / 33 ), Callback Interval (Min / Max) = ( 33 / 34 ) !!!
[host]
Channel Selected: 0
[host]
Channel Selected: 0
[host]
Channel Selected: 0
[host]
Channel Selected: 0,packet size = 100
[host]
Channel Selected: 0,encPreset = 0
[host]
Channel Selected: 0,enable = 0
[host]
Channel Selected: 1 [m3video] ENCLINK: new targetbitrate to set:10000000
[host]
Channel Selected: 1,rate control = 0
[host]
Channel Selected: 1
[host]
Channel Selected: 1
[host]
Channel Selected: 1
[host]
Channel Selected: 1,packet size = 100
[host]
Channel Selected: 1,encPreset = 0
[host]
Channel Selected: 1,enable = 0
[host]
Channel Selected: 2 [m3video] ENCLINK: new targetframerate to set:30000
[host]
Channel Selected: 2,rate control = 2
[host] MJPEG in Rate Control OFF Mode
Check_device_version : DEVICE VER = 0 !!
[m3video] ENCLINK: new rate control algorithm to set:0
[m3video] ENCLINK: new targetbitrate to set:2000000
[m3video] Channel:0 inputframerate:30 targetfps:30
[m3video] Channel:2 inputframerate:30 targetfps:5
[m3video] ENCLINK: new intraFrameInterval to set:60
[m3video] ENCLINK: new QP I Param to set:10 36 -1
[m3video] ENCLINK: new QP P Param to set:10 40 28
[m3video] ENCLINK: new PacketSize Param to set:100
[m3video] ENCLINK: new Encode Preset Param to set:0
[m3video] Channel:1 inputframerate:30 targetfps:30
[m3video] JPGLINK: new targetframerate to set:5000 for bitrate 100000
[m3video] JPGLINK: new QP Param to set:1 51 80
[m3video] JPGLINK: new qualityFactor Param to set:80
[m3video] JPGLINK: new rate control algorithm to set:2 for bitrate: 100000
[m3video] JPGLINK: Run time parameters changed 0
[m3video] ENCLINK: new intraFrameInterval to set:30
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print..omap_i2c omap_i2c.1: controller timed out
[m3video] ==================== EncLink_PrintDetails ====================
[m3video] =================================================================
[host] AUDIO : period size = 500 frames, dir = 0
[host] AUDIO : period time = 62500 us, dir = 0
numid=15,iface=MIXER,name='Left HPCOM Mixer PGAR Bypass Volume'
; type=INTEGER,access=rw---R--,values=1,min=0,max=118,step=0
: values=76
| dBscale-min=-59.00dB,step=0.50dB,mute=1
[host]
Application Run Completed
: values=76,76
[host]
[host]
Force IDR on Channel: 1SystemInit success
Schedule manager init success
Dmva Schedule manager init success
SystemServer:============================ SYS_MSG_DO_BOOT_PROC
SystemServer:doning at SYS_MSG_DO_BOOT_PROC
umount: can't umount /mnt/mmc: Invalid argument
mount: mounting /dev/mmcblk0 on /mnt/mmc failed: Invalid argument
net_search_gateway:eth0, 1A8C0, 0, 1
net_search_gateway:eth0, 0, 101A8C0, 3
net_get_dns: file "/etc/resolv.conf" opened for reading error!
Debug SysDoBootProc control success.
Debug
boot_src:============================ boot_src
Debug
boot_src:doning at boot_src
Debug
Debug
boot_src end:============================ boot_src
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print..[09/Nov/2012:20:11:18 +0000] boa: server version Boa/0.94.13
[09/Nov/2012:20:11:18 +0000] boa: server built Jun 4 2014 at 15:11:58.
[09/Nov/2012:20:11:18 +0000] boa: starting server pid=531, port 80
Debug
Debug
Debug
Debug
queue id:0
<UDN>uuid:Upnp-TVEmulator-1_0-00_0065294056</UDN>
Upnp port is 0
UPnP Initialized OK ip=192.168.1.181, port=0
desc_doc_url = 192.168.1.181/tvdevicedesc.xml
error code = 0
ApproDrvInit: 8
ApproDrvInit: 9
queue id:131076
queue id:131076
Initializing...
Initializing...
...done initializing
Play this stream using the URL:
rtsp://192.168.1.181:8555/PSIA/Streaming/channels/0?videoCodecType=MJPEG
(We use port 8302 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.1.181:8556/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8303 for optional RTSP-over-HTTP tunneling.)
device advertisement succeed.
ApproDrvInit: 10
queue id:131076
Initializing...
ApproDrvInit: 6
queue id:131076
Initializing...
rtsp://192.168.1.181:8554/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8301 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.1.181:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8304 for optional RTSP-over-HTTP tunneling.)
ApproDrvInit: 2
queue id:131076
Initializing...
rtsp://192.168.1.181:8553/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8300 for optional RTSP-over-HTTP tunneling.)
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print.. [m3video] ==================== EncLink_PrintDetails ====================
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print..[09/Nov/2012:20:12:50 +0000] request from 192.168.1.183 "GET /favicon.ico HTTP/1.1" ("/var/www/favicon.ico"): document open: No such file or directory
[host]
Usecase is Active !!!
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print..[09/Nov/2012:20:13:09 +0000] request from 192.168.1.183 "GET /favicon.ico HTTP/1.1" ("/var/www/favicon.ico"): document open: No such file or directory
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print..queue id:32769
[host]
: values=76
: values=76,76
==================== STREAMING DETAILS ====================
Start Time : 1352492011sec 136038usec
End Time : 1352492059sec 104989usec
Total Time to stream 1000 frames: 47968.951 msec
Time per frame: 47.9690 msec
Streaming Performance in FPS: 20.8468
[host]
Start Time : 1352492064sec 496236usec
End Time : 1352492100sec 110793usec
Total Time to stream 1000 frames: 35614.557 msec
Time per frame: 35.6146 msec
Streaming Performance in FPS: 28.0784
Start Time : 1352492105sec 451515usec
End Time : 1352492141sec 002294usec
Total Time to stream 1000 frames: 35550.779 msec
Time per frame: 35.5508 msec
Streaming Performance in FPS: 28.1288
[host]
Start Time : 1352492146sec 361421usec
End Time : 1352492182sec 024224usec
Total Time to stream 1000 frames: 35662.803 msec
Time per frame: 35.6628 msec
Streaming Performance in FPS: 28.0404
[host]
Start Time : 1352492187sec 418891usec
End Time : 1352492223sec 142832usec
Total Time to stream 1000 frames: 35723.941 msec
Time per frame: 35.7239 msec
Streaming Performance in FPS: 27.9924
Start Time : 1352492228sec 562841usec
End Time : 1352492264sec 146688usec
Total Time to stream 1000 frames: 35583.847 msec
Time per frame: 35.5838 msec
Streaming Performance in FPS: 28.1026
[host]
Start Time : 1352492269sec 521282usec
End Time : 1352492305sec 185582usec
Total Time to stream 1000 frames: 35664.300 msec
Time per frame: 35.6643 msec
Streaming Performance in FPS: 28.0392
U-Boot 2010.06 (May 18 2014 - 17:05:13)
TI8148-GP rev 3.0
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
DRAM: 2 GiB
NAND: HW ECC BCH8 Selected
256 MiB
Using default environment
The 2nd stage U-Boot will now be auto-loaded
Please do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashed
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x20000, size 0x40000
262144 bytes read: OK
## Starting application at 0x81000000 ...
U-Boot 2010.06 (May 18 2014 - 17:05:55)
TI8148-GP rev 3.0
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
I2C: ready
DRAM: 2 GiB
256 MiB
MMC: OMAP SD/MMC: 0
.:;rrr;;.
,5#@@@@#####@@@@@@#2,
,A@@@hi;;;r5;;;;r;rrSG@@@A,
r@@#i;:;s222hG;rrsrrrrrr;ri#@@r
:@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:
B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B
@@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@
@@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@
@@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@
G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G
@9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@
X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X
@#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@
@A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@
@&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@
@#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@
M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@#
:@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@,
@@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@
@A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@
;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@;
r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r
,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@,
B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H
.@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@.
.A@@#5r;;;r;;;rrr;r:r#AsM@@H.
;&@@@@MhXS5i5SX9B@@@@G;
:ihM#@@@@@##hs,
Net: Detected MACID:12:34:56:78:9a:bc
cpsw
TI8148_EVM#boot
Loading from nand0, offset 0x280000
Image Name: Linux-2.6.37_DM8127_IPNC_3.50.00
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2493104 Bytes = 2.4 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 81000000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37_DM8127_IPNC_3.50.00 (root@afa-desktop) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Sat May 31 19:10:20 CST 2014
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148ipnc
vram size = 4194304 at 0x0
bootconsole [earlycon0] enabled
ti81xx_reserve: ### Reserved DDR region @84f00000
reserved size = 4194304 at 0x0
FB: Reserving 4194304 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 3.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19040
Kernel command line: console=ttyO0,115200n8 root=/dev/nfs rw mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 nfsroot=192.168.1.182:/home/afa/work/DM8127/Source/ipnc_rdk/target/filesys,nolock cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 rootdelay=5 earlyprintk ip=192.168.1.181:192.168.1.182:192.168.1.1:255.255.255.0:DM8127_IPNC:eth0:off
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 74MB 1MB = 75MB total
Memory: 70652k/70652k available, 11268k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5800000 - 0xf8000000 ( 808 MB)
lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc003e000 ( 216 kB)
.text : 0xc003e000 - 0xc04bf000 (4612 kB)
.data : 0xc04c0000 - 0xc05004c0 ( 258 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 599.65 BogoMIPS (lpj=2998272)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0x84f00000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
_omap_mux_init_gpio: Could not set gpio79
_omap_mux_init_gpio: Could not set gpio80
Cannot clk_get ck_32
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
PWM0 init success.
PWM1 init success.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
regulator: VRTC: 1800 mV
regulator: VIO: 1500 mV
regulator: VDD1: 600 <--> 1500 mV at 1200 mV
regulator: VDD2: 600 <--> 1500 mV at 1200 mV
regulator: VDDCTRL: 600 <--> 1400 mV at 1200 mV
regulator: LDO1: 1100 <--> 3300 mV at 1800 mV
regulator: LDO2: 1100 <--> 3300 mV at 1800 mV
regulator: LDO3: 1100 <--> 3300 mV at 3300 mV
regulator: LDO4: 1100 <--> 3300 mV at 1800 mV
regulator: LDO5: 1100 <--> 3300 mV at 3300 mV
regulator: LDO6: 1100 <--> 3300 mV at 3300 mV
regulator: LDO7: 1100 <--> 3300 mV at 3300 mV
regulator: LDO8: 1100 <--> 3300 mV at 1800 mV
tps65911-rtc tps65911-rtc: rtc core: registered tps65911-rtc as rtc0
tps65910 1-002d: No interrupt support, no core IRQ
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, peripheral, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
musb-hdrc musb-hdrc.0: USB Peripheral mode controller at c581e000 using DMA, IRQ 18
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 137
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
CMEMK module: built on May 31 2014 at 19:03:32
Reference Linux version 2.6.37
File /home/afa/work/DM8127/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc7000000 of size 0x4000000
cmemk initialized
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled, bootconsole disabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron )
Creating 8 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x000006fc0000 : "File System"
0x000006fc0000-0x000007bc0000 : "Data"
0x000007bc0000-0x00000b0c0000 : "File System2"
0x00000b0c0000-0x000010000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
Linux video capture interface: v2.00
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000
cm: Module associated with clock hdmi_i2s_fck didn't enable in 100000 tries
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
#0: TI8148 IPNC
nf_conntrack version 0.5.0 (1103 buckets, 4412 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 17
Bridge firewalling registered
lib80211: common routines for IEEE802.11 drivers
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=84:7e:40:3d:bc:5c
tps65911-rtc tps65911-rtc: setting system clock to 2012-11-10 04:11:00 UTC (1352520660)
mmc1: new high speed SDHC card at address e624
mmcblk0: mmc1:e624 SU04G 3.69 GiB
mmcblk0: p1
CPSW phy found : id is : 0x4dd074
PHY 0:01 not found
IP-Config: Complete:
device=eth0, addr=192.168.1.181, mask=255.255.255.0, gw=192.168.1.1,
host=DM8127_IPNC, domain=, nis-domain=(none),
bootserver=192.168.1.182, rootserver=192.168.1.182, rootpath=
Waiting 5sec before mounting root device...
PHY: 0:00 - Link is Up - 100/Full
VFS: Mounted root (nfs filesystem) on device 0:14.
devtmpfs: mounted
Freeing init memory: 216K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
Root filesystem already rw, not remounting
Caching udev devnodes
root: mount: mounting /dev/root on / failed: No such file or directory
NOT configuring network interfaces: / is an NFS mount
rm: cannot remove '/tmp': Device or resource busy
inside finish.sh
UBI: attaching mtd5 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: sub-page size: 512
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 935
UBI: attached mtd5 to ubi0
UBI: MTD device name: "Data"
UBI: MTD device size: 12 MiB
UBI: number of good PEBs: 96
UBI: number of bad PEBs: 0
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 96
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 13/11
UBI: image sequence number: 844251070
UBI: background thread "ubi_bgt0d" started, PID 269
UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
UBIFS: file system size: 10285056 bytes (10044 KiB, 9 MiB, 81 LEBs)
UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 485787 bytes (474 KiB)
UBI: attaching mtd7 to ubi1
UBI: max. sequence number: 62
UBI: attached mtd7 to ubi1
UBI: MTD device name: "Reserved"
UBI: MTD device size: 79 MiB
UBI: number of good PEBs: 634
UBI: total number of reserved PEBs: 634
UBI: number of PEBs reserved for bad PEB handling: 6
UBI: max/mean erase counter: 24/14
UBI: image sequence number: 131240250
UBI: background thread "ubi_bgt1d" started, PID 281
UBI device number 1, total 634 LEBs (80502784 bytes, 76.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
UBIFS: file system size: 78090240 bytes (76260 KiB, 74 MiB, 615 LEBs)
UBIFS: journal size: 3936256 bytes (3844 KiB, 3 MiB, 31 LEBs)
UBIFS: reserved for root: 3688395 bytes (3601 KiB)
./init.sh: line 5: -f: not found
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.20.02.20
SysLink module created on Date:May 31 2014 Time:19:11:54
Trace enabled
Trace SetFailureReason enabled
/dev/mem opened.
Phy Addr : 0x48181560 Data : 0x00000102
secss put in low power state
Phy Addr : 0x48180f10 Data : 0x00000000
Phy Addr : 0x48180508 Data : 0x00000302
Phy Addr : 0x48180520 Data : 0x00000002
Phy Addr : 0x48180524 Data : 0x00000002
Phy Addr : 0x48180528 Data : 0x00000002
Phy Addr : 0x4c0000e4 Data : 0x00170208
Phy Addr : 0x4d0000e4 Data : 0x00170208
DDR IOs RX is shutdown
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00800000 )
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
AlramThread created
Share memory init success
Creat queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
queue id:32769
Ready
Go to sleep
[host] Attached to slave procId 2.
[host] Attached to slave procId 0.
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 2.
[host] Started slave procId 2.
[host] Attached to slave procId 1.
[host] Loaded file ./firmware/ipnc_rdk_fw_c6xdsp.xe674 on slave procId 0.
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[host] Started slave procId 0.
[host] After Ipc_loadcallback status [0x00000000]
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 500000000, <NEW> - 500000000
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[m3vpss ]
[m3vpss ] 186: SYSTEM : System Common Init in progress !!!
[c6xdsp ]
[m3vpss ] 187: SYSTEM: IPC init in progress !!!
[c6xdsp ] *** UTILS: CPU KHz = 500000 Khz ***
[m3vpss ] 187: SYSTEM: Attaching to [HOST] ...
[c6xdsp ]
[c6xdsp ] 24: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 24: SYSTEM: IPC init in progress !!!
[c6xdsp ] 24: SYSTEM: Attaching to [HOST] ...
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 1.
[host] Started slave procId 1.
[m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3video]
[m3video] *** UTILS: CPU KHz = 400000 Khz ***
[m3video]
[m3video] 744: SYSTEM : System Common Init in progress !!!
[m3video] 744: SYSTEM: IPC init in progress !!!
[m3video] 744: SYSTEM: Attaching to [HOST] ...
[host] After Ipc_startcallback status [0x00000000]
[c6xdsp ] 1024: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1186: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1074: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1267: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 1074: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 1267: SYSTEM: Attaching to [DSP] ...
[m3video] 1743: SYSTEM: Attaching to [HOST] ...
[m3video] 1762: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 1762: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 2266: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2074: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2558: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 2761: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2558: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 2762: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 2762: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 3266: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3558: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 3761: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4063: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 4266: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 4063: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 4267: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 4267: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 4761: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 5063: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 5267: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 5266: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 5267: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 5267: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 5268: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 5267: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 5268: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 5268: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3video] 5270: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 5268: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3video] 5271: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3vpss ] 5270: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3video] 5271: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3vpss ] 5270: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3video] 5271: SYSTEM: IPC init DONE !!!
[m3vpss ] 5271: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3vpss ] 5271: SYSTEM: IPC init DONE !!!
[m3video] 5281: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3vpss ] 5281: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 5281: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3vpss ] 5281: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3vpss ] 5283: SYSTEM : System Common Init Done !!!
[m3vpss ] Received character 's'
[m3video] 5283: SYSTEM : System Common Init Done !!!
[m3video] Received character 's'
[c6xdsp ] 6063: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[c6xdsp ] 6063: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[c6xdsp ] 6063: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[c6xdsp ] 6064: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[c6xdsp ] 6064: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[c6xdsp ] 6064: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[c6xdsp ] 6064: SYSTEM: IPC init DONE !!!
[c6xdsp ] 6067: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[c6xdsp ] 6067: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[c6xdsp ] 6068: SYSTEM : System Common Init Done !!!
[c6xdsp ] Received character 's'
queue id:65538
CPU is TI812x
Error: SemWait: Invalid Semaphore handler
Error: SemRelease: Invalid Semaphore handler
IPNC BUILD VERSION: DM8127 IPNC RDK VERSION 03.50.00.08
./bin/ipnc_rdk_mcfw.out VNF_QUALITY TRISTREAM TRIPLE_H264 AUDIO 8000 TI2A AEWB 1080P_D1 H264 HIGH_SPEED1 H264 HIGH_SPEED2 MJPEG 80 &
inside autorun
[c6xdsp ] Remote Debug Shared Memory @ 0xbff000 sbulla: unknown partition table
00
[m3vpss ] 6583: SYSTEM : System VPSS Init in progress !!!
[m3vpss ] === I2C0/2 Clk is active ===
[m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_2_1
[m3vpss ] 6602: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3vpss ] 6602: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3vpss ] 6603: SYSTEM: ListElem Shared Addr = 0xbe98b680
[m3vpss ] 6605: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3vpss ] 6606: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3vpss ] 6606: SYSTEM: ListElem Shared Addr = 0xbe98eb80
[m3vpss ] 6621: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ...
[m3vpss ] 6621: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ...
[m3vpss ] 6621: SYSTEM: ListElem Shared Addr = 0xbe992080
[m3vpss ] 6624: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
Starting telnet daemon [m3vpss ] 6624: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 6625: SYSTEM: ListElem Shared Addr = 0xbe9b1a80
[m3vpss ] 6627: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 6628: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 6628: SYSTEM: ListElem Shared Addr = 0xbe9d1480
[m3vpss ] 6635: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] 6636: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 6636: SYSTEM: ListElem Shared Addr = 0xbe9f0e80
[m3vpss ] 6638: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] sbulla: unknown partition table
6639: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 6639: SYSTEM: ListElem Shared Addr = 0xbea0ab00
[m3vpss ] 6641: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3vpss ] 6642: SYSTEM : FVID2 Init in progress !!!
[m3vpss ] 6707: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 6708: SYSTEM : Device Init in progress !!!
[m3vpss ] Iss_init called !!!!!!
[m3vpss ] Iss_init: issCommonInit called start @ line 358 ================
[m3vpss ] Iss_init: issCommonInit called end @ line 360 ================
[m3vpss ] Iss_init: issDriverInit called start @ line 364 ================
[m3vpss ] issDriverInit:Iss_captInit called start @ line 317 ================
[m3vpss ] Iss_captInit: FVID2_registerDrive called end status @ line 0 ================
[m3vpss ] Iss_captInit: FVID2_registerDrive called end @ line 1507 ================
[m3vpss ] issDriverInit: Iss_captInit called end @ line 319 ================
[m3vpss ] Iss_init: issDriverInit called end @ line 366 ================
[m3vpss ] Iss_init: RM_SIMCOP_Init called end @ line 372 ================
[m3vpss ] CPIS_init DONE !!!!!!
[m3video] 6783: SYSTEM : System Video Init in progress !!!
[m3vpss ] initPrms.isI2cInitReq = 1
[m3video] 6784: SYSTEM : System Video Init Done !!!
[m3video] 6784: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 6784: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 6785: SYSTEM: ListElem Shared Addr = 0xbea24780
[m3video] 6787: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 6787: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 6788: SYSTEM: ListElem Shared Addr = 0xbea27c80
[m3video] 6799: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
[m3video] 6799: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
[m3video] 6799: SYSTEM: ListElem Shared Addr = 0xbea2b180
[m3video] 6802: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3video] 6802: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3video] 6803: SYSTEM: ListElem Shared Addr = 0xbea44e00
[m3video] 6805: HDVICP: Doing PRCM for IVAHD[0] ...
[m3video] 6805: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3video] 6806: SYSTEM : Initializing Links !!!
[m3video] 6806: SYSTEM : FREE SPACE : System Heap = 6282128 B, Mbx = 10240 msgs)
[m3vpss ] 6632: Vps_deviceI2cInit >>>
[m3video] 6806: SYSTEM : FREE SPACE : SR0 Heap = 15342464 B (14 MB)
[m3video] 6806: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[m3vpss ] Vps_platformGetBoardId: ----------------- @ line 678 --------------------------
[m3vpss ] 5: gPlatformCommonObj.platBoardId
[m3video] 6806: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3video] 6807: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3video] 6808: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] 6632: Vps_deviceI2cInit <<<
[m3vpss ] 6632: Vps_thsFiltersInit >>>
[c6xdsp ] 6645: SYSTEM : System DSP Init in progress !!!
[m3video] 6864: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 6633: Vps_thsFiltersInit <<<
Starting syslogd/klogd: [c6xdsp ] 6672: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ...
[m3vpss ] 6633: Vps_tvp5158Init >>>
[c6xdsp ] 6672: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ...
[c6xdsp ] 6672: SYSTEM: ListElem Shared Addr = 0xbea5ea80
[c6xdsp ] 6673: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[m3vpss ] 6633: Vps_sii9135Init >>>
[c6xdsp ] 6674: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] 6674: SYSTEM: ListElem Shared Addr = 0xbea7e480
[m3vpss ] FVID2_registerDriver ( &gVps_sii9135CommonObj.fvidDrvOps ) start sii9135/src/vpsdrv_sii9135Api.c:Vps_sii9135Init:248 !!!
[c6xdsp ] 6675: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[m3vpss ] FVID2_registerDriver ( &gVps_sii9135CommonObj.fvidDrvOps ) done sii9135/src/vpsdrv_sii9135Api.c:Vps_sii9135Init:250 !!!
[c6xdsp ] 6675: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 6675: SYSTEM: ListElem Shared Addr = 0xbea9de80
[m3vpss ] 6633: Vps_sii9135Init <<<
[c6xdsp ] 6676: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ...
[c6xdsp ] 6676: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ...
[c6xdsp ] 6677: SYSTEM: ListElem Shared Addr = 0xbeabd880
[c6xdsp ] 6677: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
[c6xdsp ] 6678: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
[c6xdsp ] 6678: SYSTEM: ListElem Shared Add
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dm814x-evm ttyO0
Arago 2011.09 dm814x-evm ttyO0
dm814x-evm login: root (automatic login)
root@dm814x-evm:~# [m3vpss ] I2C0: Passed for address 0x2d !!!
mkdosfs 3.0.12 (29 Oct 2011)
unable to get drive geometry, using default 255/63
/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
There is 1 reserved sector.
Root directory contains 512 slots and uses 32 sectors.
Volume ID is 362463b3, no volume label.
amixer: Unable to find simple control 'Left PGA Mixer Mic3L Switch',0
amixer: Unable to find simple control 'Left PGA Mixer Mic3R Switch',0
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=77,77
| dBscale-min=-63.50dB,step=0.50dB,mute=0
numid=37,iface=MIXER,name='PGA Capture Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
: values=72,72
| dBscale-min=0.00dB,step=0.50dB,mute=0
queue id:0
[m3vpss ] 9329: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 9357: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 9357: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 9357: SYSTEM : Initializing Links !!!
[m3vpss ] 9357: SYSTEM : FREE SPACE : System Heap = 1718872 B, Mbx = 10240 msgs)
[m3vpss ] 9357: SYSTEM : FREE SPACE : SR0 Heap = 14742656 B (14 MB)
[m3vpss ] 9358: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[m3vpss ] 9358: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 9358: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] Received character 't'
[m3vpss ] 9484: SYSTEM : Initializing Links ... DONE !!!
[m3video] Received character 't'
[c6xdsp ] Received character 't'
DMA: Module install successful, device major num = 248
DRV: Module install successful
[m3vpss ] 0 cnt========================
[m3vpss ]
[m3vpss ] 0 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ] 1536 drvId========================
[m3vpss ]
[m3vpss ] 1 cnt========================
[m3vpss ]
[m3vpss ] 1 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 2 cnt========================
HDMI W1 rev 4.0
[m3vpss ]
[mHDMI CEC Spec version 1.2
3vpss ] 513 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 3 cnt========================
[m3vpss ]
[m3vpss ] 514 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 4 cnt========================
[m3vpss ]
[m3vpss ] 256 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 5 cnt========================
[m3vpss ]
[m3vpss ] 512 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 6 cnt========================
[m3vpss ]
[m3vpss ] 2 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 7 cnt========================
[m3vpss ]
[m3vpss ] 268435712 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 8 cnt========================
[m3vpss ]
[m3vpss ] 268435970 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] 9 cnt========================
[m3vpss ]
[m3vpss ] 1536 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 9 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 drvId========================
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
I2C No Ack
[host]
[host] ORG 0x46c00524: 0
[host] NEW 0x46c00524: 2
[host]
[host] Application Start Completed
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 0: SYSTEM: IPC init in progress !!!
[host] 12: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
[host] 12: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
[host] 12: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
[host] 12: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
[host] 12: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 14: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 16: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[host] DMA: ChannelID allocated:4
17: SYSTEM: OpeDMA: ChannelID allocated:10
[host] 18: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 18: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 19: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[host] 20: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 21: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 21: SYSTEM: IPC init DONE !!!
[host] 22: SYSTEM: Creating ListMP [HOST_IPC_OUT_28] in region 0 ...
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_28] in region 0 ...
[host] 26: SYSTEM: ListElem Shared Addr = 0x40597180
[host] 27: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 29: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 31: SYSTEM: ListElem Shared Addr = 0x405b0e00
[host] 32: SYSTEM: Creating ListMP [HOST_IPC_OUT_23] in region 0 ...
[host] 34: SYSTEM: Creating ListMP [HOST_IPC_IN_23] in region 0 ...
[host] 36: SYSTEM: ListElem Shared Addr = 0x405caa80
[host] 37: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 39: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 40: SYSTEM: ListElem Shared Addr = 0x405ea480
[host] 41: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 43: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 45: SYSTEM: ListElem Shared Addr = 0x40609e80
[host] 45: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0x4c064000,size = 65011712
[host] MCFW_IPCBITS:App_streamSysInit:virt addr of 85000000 cir buffer is 4c064000
##########pInfo->totalsize 63897600
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
Creat queue id:131076
queue id:131076
queue id:65538
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 513 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] VPS_DCTRL_INST_0
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_DVO2
[host]
********** FULL FEATURE USECASE ********
[host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[host] 410: MCFW : CPU Revision [ES2.1] !!!
[host] 410: MCFW : Detected [UNKNOWN] Board !!!
[host] 410: MCFW : Base Board Revision [REV A] !!!
[m3vpss ] 11032: CAPTURE: Create in progress !!!
[m3vpss ] CAPTURELINK:!!WARNING.FORCIBLY DISABLING TILER since tiler is disabled at build time
[m3vpss ]
[m3vpss ]
[m3vpss ] 1026 drvId========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 11037: CAPTURE: VIP 2: VID DEC 1026 (0x30): Video Standard Detect in Progress !!!
[m3vpss ] 11142: CAPTURE: Detected video (1920x1080@28Hz, 0)!!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 11180: CAPTURE: VIP1 PortA capture mode is [16-bit, Non-mux Embedded Sync] !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
ApproDrvInit: 3
queue id:131076
queue id:0
queue id:32769
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 11760: CAPTURE: VIP 2: VID DEC 1026 (0x30): 9135:0004:0001, AUD_STATUS 0
[m3vpss ] 11761: CAPTURE: Create Done !!!
[m3vpss ] 11928: NSF: Create in progress !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 12054: NSF: Create Done !!!
[m3vpss ] 12060: DUP : Create Done !!!
[m3vpss ] 12067: DUP : Create Done !!!
[m3video] 12159: IPC_IN_M3 : Create in progress !!!
[m3vpss ] 12068: MERGE : Create Done !!!
[m3video] 12160: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3video] 12160: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3video] 12163: IPC_IN_M3 : Create Done !!!
[m3video] 12164: ENCODE: Create in progress ... !!!
[m3video] 12250: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[m3vpss ] 11950: SWOSD : Create Done !!!
[m3vpss ] 12141: DUP : Create Done !!!
[m3video] 12359: ENCODE: Creating CH1 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[m3vpss ] 12142: SCLR: Create in progress !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3video] 12468: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[m3video] 12469: ENCODE: All CH Create ... DONE !!!
[m3video] 12471: ENCODE: Create ... DONE !!!
[host] 2188: IPC_BITS_IN : Create in progress !!!
[host] 2188: IPC_BITS_IN : ListMPOpen start !!!
[host] 2188: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
[m3video] 12473: IPC_BITS_OUT : Create in progress !!!
[m3video] 12475: IPC_BITS_OUT : Create Done !!!
[m3vpss ]
[m3vpss ]
[m3vpss ] 12152: SCLR : Loading Up-scaling Co-effs ...
[m3vpss ] 12152: SCLR : Co-effs Loading ... DONE !!!
[host] 2191: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
[host] 2192: IPC_BITS_IN : ListMPOpen done !!!
[host] 2193: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 2194: IPC_BITS_IN : Create Done !!!
[m3vpss ] 12153: SCLR: Create Done !!!
[m3vpss ] 11972: FD : Alg Create Done !!!
[m3vpss ] 11972: FD : Create Done !!!
[m3vpss ] 12158: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 12159: IPC_OUT_M3 : Create Done !!!
[m3vpss ] 12815: DISPLAY: Create in progress !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 12817: DISPLAY: Create Done !!!
[m3vpss ] 12818: DISPLAY: Create in progress !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 12820: DISPLAY: Create Done !!!
[m3vpss ] 12821: DISPLAY: Start in progress !!!
[m3vpss ] 12886: DISPLAY: Start Done !!!
[m3vpss ] 12887: DISPLAY: AUX PATH: 30 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 12887: DISPLAY: Start in progress !!!
[m3vpss ] 12942: DISPLAY: Start Done !!!
[m3vpss ] 12942: DISPLAY: SDDAC(SEC1): 18 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 12944: CAPTURE: Start in progress !!!
[m3vpss ] 12945: CAPTURE: Start Done !!!
[host]
Audio capture task created [m3vpss ] 13070: CAPTURE: Fields = 0 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print.. [m3video] Channel:1 inputframerate:30 targetfps:60
queue id:0
ApproDrvInit: 7
queue id:131076
[m3vpss ] 16396: DISPLAY: Stop in progress !!!
Venc not supported!!
[m3vpss ] 16446: DISPLAY: Stop Done !!!
[m3vpss ] 16449: DISPLAY: Start in progress !!!
[m3vpss ] 16499: DISPLAY: Start Done !!!
[m3vpss ] 16499: DISPLAY: SDDAC(SEC1): 2120 fps, Latency (Min / Max) = ( 0 / 34 ), Callback Interval (Min / Max) = ( 33 / 34 ) !!!
[host]
Channel Selected: 0
[host]
[host]
Channel Selected: 0
[host]
Channel Selected: 0
[host]
Channel Selected: 0
[host]
[host]
[host]
[host]
Channel Selected: 1
[host]
Channel Selected: 1,rate control = 0 [m3video] ENCLINK: new targetbitrate to set:10000000
[host]
Channel Selected: 1
[host]
Channel Selected: 1
[host]
Channel Selected: 1
[host]
[host]
[host]
[host]
Channel Selected: 2
[host]
root@DM8127_IPNC:~# omap_i2c omap_i2c.1: controller timed out
[host]
: values=76
: values=76,76
[host]
Force IDR on Channel: 0
[host]
g_file_storage gadget: No serial-number string provided!
g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
g_file_storage gadget: Number of LUNs=1
g_file_storage gadget-lun0: ro=0, nofua=0, file: /dev/sbulla
Debug
Debug
Debug
Debug
[09/Nov/2012:20:11:18 +0000] boa: starting server pid=563, port 80
Debug
Debug
Debug
Debug
queue id:0
<UDN>uuid:Upnp-TVEmulator-1_0-00_0018104708</UDN>
Upnp port is 0
error code = 0
ApproDrvInit: 9
queue id:131076
ApproDrvInit: 8
queue id:131076
Initializing...
ApproDrvInit: 10
queue id:131076
Initializing...
ApproDrvInit: 2
queue id:131076
Initializing...
Initializing...
ApproDrvInit: 6
queue id:131076
Initializing...
[09/Nov/2012:20:12:21 +0000] request from 192.168.1.183 "GET /favicon.ico HTTP/1.1" ("/var/www/favicon.ico"): document open: No such file or directory
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print..[09/Nov/2012:20:12:32 +0000] request from 192.168.1.183 "GET /favicon.ico HTTP/1.1" ("/var/www/favicon.ico"): document open: No such file or directory
Start Time : 1352491935sec 762172usec
End Time : 1352491970sec 821427usec
Total Time to stream 1000 frames: 35059.255 msec
Time per frame: 35.0593 msec
Streaming Performance in FPS: 28.5231
[host]
caught SIGINT: shutting down
ApproDrvExit: 9
ApproDrvExit: 2
ApproDrvExit: 10
ApproDrvExit: 8
ApproDrvExit: 6
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print..killall: wis-streamer: no process killed
ApproDrvInit: 10
queue id:131076
Initializing...
ApproDrvInit: 6
queue id:131076
ApproDrvInit: 2
queue id:131076
Initializing...
ApproDrvInit: 8
queue id:131076
Initializing...
Initializing...
ApproDrvInit: 9
queue id:131076
Initializing...
: values=76
: values=76,76
[host]
Start Time : 1352492009sec 385094usec
End Time : 1352492067sec 550133usec
Total Time to stream 1000 frames: 58165.039 msec
Time per frame: 58.1650 msec
Streaming Performance in FPS: 17.1925
Start Time : 1352492072sec 829202usec
End Time : 1352492107sec 835161usec
Total Time to stream 1000 frames: 35005.959 msec
Time per frame: 35.0060 msec
Streaming Performance in FPS: 28.5666
[host]
root@DM8127_IPNC:~#
root@DM8127_IPNC:~#
Start Time : 1352492113sec 127901usec
End Time : 1352492148sec 437645usec
Total Time to stream 1000 frames: 35309.744 msec
Time per frame: 35.3097 msec
Streaming Performance in FPS: 28.3208
root@DM8127_IPNC:~# reboot
Broadcast message from root (ttyO0) (Sat Nov 10 04:15:53 2012):
The system is going down for reboot NOW!
INIT: Switching to runlevel: 6
INIT: Sending processes the TERM signal
INIT: Stopping telnet daemon.
NOT deconfiguring network interfaces: / is an NFS mount
Stopping syslogd/klogd: stopped syslogd (pid 386)
stopped klogd (pid 389)
done
Sending all processes the TERM signal...
caught SIGTERM: shutting down
ApproDrvExit: 8
ApproDrvExit: 10
ApproDrvExit: 2
ApproDrvExit: 9
ApproDrvExit: 6
Sending all processes the KILL signal...
hwclock: RTC_SET_TIME: Connection timed out
Unmounting remote filesystems...
Deactivating swap...
Unmounting local filesystems...
mount: can't find /mnt/ram in /proc/mounts
mount: invalid number 'sys'
UBIFS: un-mount UBI device 1, volume 0
UBIFS: un-mount UBI device 0, volume 0
Rebooting... Restarting system.
TI8148-GP rev 3.0
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
DRAM: 2 GiB
256 MiB
TI8148-GP rev 3.0
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
I2C: ready
DRAM: 2 GiB
256 MiB
MMC: OMAP SD/MMC: 0
.:;rrr;;.
:ihM#@@@@@##hs,
cpsw
OK
Starting kernel ...
Machine: ti8148ipnc
NR_IRQS:375
GPMC revision 6.0
regulator: dummy:
PWM0 init success.
PWM1 init success.
Cppi41 Init Done
usb2phy: computed values rxcalib(15)DACs(33 17 15)
usb2phy: override computed values rxcalib(15)DACs(33 17 15)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f70e37e
TCP reno registered
cmemk initialized
brd: module loaded
loop: module loaded
ALSA device list:
#0: TI8148 IPNC
tps65911-rtc tps65911-rtc: setting system clock to 2012-11-10 04:16:04 UTC (1352520964)
mmcblk0: p1
PHY 0:01 not found
devtmpfs: mounted
Starting udev
inside finish.sh
UBI: max. sequence number: 952
UBI: background thread "ubi_bgt0d" started, PID 259
UBI: max. sequence number: 63
UBI: background thread "ubi_bgt1d" started, PID 271
Trace enabled
/dev/mem opened.
Creat queue id:0
queue id:0
queue id:32769
AlramThread created
queue id:65538
queue id:98307
queue id:32769
Ready
Go to sleep
[m3video]
[m3vpss ]
[m3video]
[m3video] 73: SYSTEM : System Common Init in progress !!!
[m3vpss ]
[m3video] 73: SYSTEM: IPC init in progress !!!
[m3vpss ] 94: SYSTEM : System Common Init in progress !!!
[m3video] 73: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 94: SYSTEM: IPC init in progress !!!
[m3vpss ] 94: SYSTEM: Attaching to [HOST] ...
[c6xdsp ]
[c6xdsp ]
[c6xdsp ] 1: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 1: SYSTEM: IPC init in progress !!!
[c6xdsp ] 1: SYSTEM: Attaching to [HOST] ...
[m3video] 1072: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1094: SYSTEM: Attaching to [HOST] ...
[m3video] 1075: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1122: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 1075: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 1122: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 1001: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1004: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 1004: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 2075: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 2122: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2004: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 2604: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 3075: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2604: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 3076: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 3076: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 3122: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3604: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 4075: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 3651: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 4122: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3651: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 4122: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 4123: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 5075: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 5122: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4651: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 5122: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 5122: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[c6xdsp ] 4651: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[m3video] 5123: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 5123: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[c6xdsp ] 4652: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[m3video] 5123: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 5123: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[c6xdsp ] 4652: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3video] 5123: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 5123: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[c6xdsp ] 4652: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3video] 5126: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 5125: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[c6xdsp ] 4652: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3video] 5126: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3vpss ] 5126: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[c6xdsp ] 4653: SYSTEM: IPC init DONE !!!
[m3video] 5126: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3vpss ] 5126: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[c6xdsp ] 4656: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 5126: SYSTEM: IPC init DONE !!!
[m3vpss ] 5126: SYSTEM: IPC init DONE !!!
[c6xdsp ] 4656: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[c6xdsp ] 4657: SYSTEM : System Common Init Done !!!
[m3video] 5136: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3vpss ] 5136: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 5136: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3vpss ] 5136: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03c00000 (60 MB)
[m3video] 5139: SYSTEM : System Common Init Done !!!
[m3vpss ] 5139: SYSTEM : System Common Init Done !!!
queue id:65538
CPU is TI812x
[c6xdsp ] 5055: SYSTEM : System DSP Init in progress !!!
[c6xdsp ] 5060: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ...
[m3video] 5538: SYSTEM : System Video Init in progress !!!
[m3vpss ] 5539: SYSTEM : System VPSS Init in progress !!!
[c6xdsp ] 5061: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ...
[m3video] 5538: SYSTEM : System Video Init Done !!!
[c6xdsp ] 5061: SYSTEM: ListElem Shared Addr = 0xbe98b680
[m3video] 5539: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[c6xdsp ] 5062: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[m3video] 5539: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[c6xdsp ] 5062: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[m3video] 5539: SYSTEM: ListElem Shared Addr = 0xbea1dd80
[c6xdsp ] 5062: SYSTEM: ListElem Shared Addr = 0xbe9ab080
[c6xdsp ] 5063: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 5064: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 5064: SYSTEM: ListElem Shared Addr = 0xbe9caa80
[c6xdsp ] 5065: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ...
[c6xdsp ] 5065: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ...
[c6xdsp ] 5065: SYSTEM: ListElem Shared Addr = 0xbe9ea480
[c6xdsp ] 5066: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
[c6xdsp ] 5066: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
[c6xdsp ] 5066: SYSTEM: ListElem Shared Addr = 0xbea04100
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 5065: SYSTEM : Initializing Links !!!
[c6xdsp ] 5067: SYSTEM : FREE SPACE : System Heap = 6282544 B, Mbx = 10240 msgs)
[m3video] 5542: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 5542: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 5542: SYSTEM: ListElem Shared Addr = 0xbea21280
[c6xdsp ] 5081: SYSTEM : Initializing Links ... DONE !!!
[m3video] 5554: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
[m3video] 5554: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
[c6xdsp ] 5081: SYSTEM : System DSP Init Done !!!
[m3video] 5554: SYSTEM: ListElem Shared Addr = 0xbea24780
[m3vpss ] 5558: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3video] 5557: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 5558: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3video] 5557: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 5558: SYSTEM: ListElem Shared Addr = 0xbea58080
[m3video] 5557: SYSTEM: ListElem Shared Addr = 0xbea3e400
[m3vpss ] 5561: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3video] 5560: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 5561: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3video] 5560: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 5561: SYSTEM: ListElem Shared Addr = 0xbea5b580
[m3video] 5561: SYSTEM : Initializing Links !!!
[m3video] 5561: SYSTEM : FREE SPACE : System Heap = 6282128 B, Mbx = 10240 msgs)
[m3video] 5561: SYSTEM : FREE SPACE : SR0 Heap = 15355392 B (14 MB)
[m3vpss ] 5577: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ...
[m3vpss ] 5577: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ...
[m3video] 5561: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[m3vpss ] 5578: SYSTEM: ListElem Shared Addr = 0xbea5ea80
[m3vpss ] 5580: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3video] 5561: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 5581: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 5581: SYSTEM: ListElem Shared Addr = 0xbea7e480
[m3video] 5562: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3video] 5563: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] 5584: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 5584: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 5585: SYSTEM: ListElem Shared Addr = 0xbea9de80
[m3vpss ] 5592: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] 5592: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 5592: SYSTEM: ListElem Shared Addr = 0xbeabd880
[m3vpss ] 5595: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 5596: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 5596: SYSTEM: ListElem Shared Addr = 0xbead7500
[m3vpss ] 5598: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3vpss ] 5598: SYSTEM : FVID2 Init in progress !!!
[m3video] 5620: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 5664: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 5664: SYSTEM : Device Init in progress !!!
[m3vpss ] Iss_captInit:FVID2_registerDrive called start @ line 1504 ================
[m3vpss ] 5680: Vps_deviceI2cInit >>>
[m3vpss ] Vps_deviceInit @ line 38 ===============
[m3vpss ] 5 boardId===============
[m3vpss ] Vps_deviceInit @ line 41 ===============
[m3vpss ] 5680: Vps_deviceI2cInit <<<
[m3vpss ] 5680: Vps_thsFiltersInit >>>
[m3vpss ] 5680: Vps_thsFiltersInit <<<
[m3vpss ] 5681: Vps_tvp5158Init >>>
[m3vpss ] Vps_deviceInit @ line 157 ===============
[m3vpss ] 5681: Vps_sii9135Init >>>
[m3vpss ] sii9135/src/vpsdrv_sii9135Api.c:Vps_sii9135Init: status=0 !!!
[m3vpss ] 5681: Vps_sii9135Init <<<
inside autorun
INIT: Entering runlevel: 5
[m3vpss ] I2C0: Passed for address 0x18 !!!
Starting telnet daemon.
Starting syslogd/klogd: done
_____ _____ _ _
|___| |___|
[m3vpss ] I2C0: Passed for address 0x30 !!!
[m3vpss ] I2C0: Passed for address 0x34 !!!
root@dm814x-evm:~# [m3vpss ] I2C0: Passed for address 0x4b !!!
Volume ID is 491ea918, no volume label.
amixer: Unable to find simple control 'Right PGA Mixer Mic3R Switch',0
./autorun_ipnc.sh: line 18: a: not found
[m3vpss ] 8283: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 8311: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 8311: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 8311: SYSTEM : Initializing Links !!!
[m3vpss ] 8312: SYSTEM : FREE SPACE : System Heap = 1718872 B, Mbx = 10240 msgs)
[m3vpss ] 8312: SYSTEM : FREE SPACE : SR0 Heap = 14742656 B (14 MB)
[m3vpss ] 8312: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[m3vpss ] 8312: SYSTEM : FREE SPACE : Bitstream Buffer = 62914432 B (59 MB)
[m3vpss ] 8312: SYSTEM : FREE SPACE : Tiler Buffer = 127 B (0 MB) - TILER OFF
[m3vpss ] 8438: SYSTEM : Initializing Links ... DONE !!!
DRV: Module built on Jun 4 2014 15:16:15
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 2HDMI W1 rev 4.0
cnt============HDMI CEC Spec version 1.2
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668648 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893554968 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668616 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893720064 drvHandle ========================
[m3vpss ]
[m3vpss ]
I2C No Ack
[host]
[host]
: values=77,77
: values=72,72
queue id:0
[host] 15: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] DMA: ChannelID allocated:4
[host] DMA: ChannelID allocated:10
17: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
[host] 20: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 26: SYSTEM: ListElem Shared Addr = 0x40553180
[host] 26: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 30: SYSTEM: ListElem Shared Addr = 0x4056ce00
[host] 35: SYSTEM: ListElem Shared Addr = 0x40586a80
[host] 36: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 38: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 40: SYSTEM: ListElem Shared Addr = 0x405a6480
[host] 44: SYSTEM: ListElem Shared Addr = 0x405c5e80
[host] Vsys_allocBuf - addr = 0x4c102000,size = 65011712
[host] MCFW_IPCBITS:App_streamSysInit:virt addr of 85000000 cir buffer is 4c102000
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 10
queue id:131076
queue id:65538
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:Entered...
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668584 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[host]
[host] 407: MCFW : CPU Revision [ES2.1] !!!
[host] 407: MCFW : Detected [UNKNOWN] Board !!!
[host] 407: MCFW : Base Board Revision [REV A] !!!
[m3vpss ] 9989: CAPTURE: Create in progress !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 10 cnt========================
[m3vpss ]
[m3vpss ] 1026 gFdmDriverObjects[cnt].drvOps========
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668552 channel ========================
[m3vpss ]
[m3vpss ] 10 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] Vps_sii9135Create: ----------------- @ line 126 --------------------------
[m3vpss ] Vps_sii9135Create: ----------------- @ line -1896260528 --------------------------
[m3vpss ] Vps_sii9135Create: ----------------- @ line 141 --------------------------
[m3vpss ] Vps_sii9135Create: ----------------- @ line 0 --------------------------
[m3vpss ] Vps_sii9135Create: ----------------- @ line 155 --------------------------
[m3vpss ] Vps_sii9135Create: ----------------- @ line -1895643648 --------------------------
[m3vpss ] Vps_sii9135Create: ----------------- @ line 170 --------------------------
[m3vpss ] Vps_sii9135Create exit
[m3vpss ] -1895643648 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] 9994: CAPTURE: VIP 2: VID DEC 1026 (0x30): Video Standard Detect in Progress !!!
[m3vpss ] Vps_sii9135Control: ----------------- @ line 33 cmd = 268828675-------------------------
[m3vpss ] 10099: CAPTURE: Detected video (1920x1080@28Hz, 0)!!!
[m3vpss ]
[m3vpss ]
[m3vpss ] 256 drvId========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 4 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] Vps_captCreate: ----------------- @ line 178 --------------------------
[m3vpss ] 255 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] 10138: CAPTURE: VIP1 PortA capture mode is [16-bit, Non-mux Embedded Sync] !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668520 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] Vps_captCreate: ----------------- @ line 186 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 252 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 290 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 316 --------------------------
[m3vpss ] Vps_captAllocPath: ----------------- @ pObj->resAllocParams.inSrc = -1 --------------------------
[m3vpss ] Vps_captAllocPath: ----------------- @ line 1032 --------------------------
[m3vpss ] Vps_captAllocPath: ----------------- @ pObj->resAllocParams.inSrc= 1 --------------------------
[m3vpss ] Vps_captAllocPath: ----------------- @ line 1129 --------------------------
[m3vpss ] Vps_captAllocPath: ----------------- @ line 1176 --------------------------
[m3vpss ] Vps_captAllocPath: ----------------- @ line 1179 --------------------------
[m3vpss ] Vcore_vipResAllocPath: ----------------- @ line 206 --------------------------
[m3vpss ] VIP 1 RES: DRV [fvid2_vps_capt_vip_ti, 0x0dca0002] path alloc in progress ...
[m3vpss ] Vcore_vipResAllocPath: ----------------- @ line 213 --------------------------
[m3vpss ] Vcore_vipResAllocPath: ----------------- @ line 218 --------------------------
[m3vpss ] Vcore_vipResAllocPath: ----------------- @ line 232 --------------------------
[m3vpss ] Vcore_vipResAllocPath: ----------------- @ line 235 --------------------------
[m3vpss ] VIP 1 RES: [PORT_A ] is allocated in EXCLUSIVE mode
[m3vpss ] VIP 1 RES: [PORT_B ] is allocated in EXCLUSIVE mode
[m3vpss ] VIP 1 RES: [Y_LOW ] is allocated in EXCLUSIVE mode
[m3vpss ] VIP 1 RES: [CHR_DS_1 ] is allocated in EXCLUSIVE mode
[m3vpss ] VIP 1 RES: [Y_LOW ] is ALREADY allocated (ALLOC COUNT = 1, DRV ID = 0x0dca0002)
[m3vpss ] VIP 1 RES: [CHR_DS_1 ] is FREE
[m3vpss ] VIP 1 RES: [CHR_DS_0 ] is allocated in EXCLUSIVE mode
[m3vpss ] VIP 1 RES: [Y_UP ] is allocated in EXCLUSIVE mode
[m3vpss ] VIP 1 RES: [UV_UP ] is allocated in EXCLUSIVE mode
[m3vpss ] Vcore_vipResAllocPath: ----------------- @ line 276 --------------------------
[m3vpss ] VIP 1 RES: DRV [fvid2_vps_capt_vip_ti, 0x0dca0002] path alloc is DONE !!!
[m3vpss ] Vps_captAllocPath: ----------------- @ line 1182 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 321 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 324 --------------------------
[m3vpss ] VIP 1 MUX: CHR DS 0 SRC = PORTA_422 (3)
[m3vpss ] VIP 1 MUX: CHR DS 0 BYPASS = 0
[m3vpss ] VIP 1 MUX: CHR DS 1 BYPASS = 0
[m3vpss ] VIP 1 MUX: MULTI CH = 1
[m3vpss ] VIP 1 MUX: RGB HI = 0
[m3vpss ] VIP 1 MUX: RGB LO = 0
[m3vpss ] Vps_captCreate: ----------------- @ line 329 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 332 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 376 --------------------------
[m3vpss ] Vps_captCreate: ----------------- @ line 384 --------------------------
[m3vpss ] -1906421284 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] 0: pInst->vidDecCreateArgs.deviceI2cAddr[0]=========
[m3vpss ] 48: pInst->vidDecCreateArgs.deviceI2cAddr[0]=========
[m3vpss ] Invalid board ID!!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668488 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] Vps_sii9135Create: ----------------- @ line -1904203956 --------------------------
[m3vpss ]
[m3vpss ]
[m3vpss ] Vps_sii9135Control: ----------------- @ line 33 cmd = 268828672-------------------------
[m3vpss ] 10718: CAPTURE: VIP 2: VID DEC 1026 (0x30): 9135:0004:0001, AUD_STATUS 0
[m3vpss ] CAPTURE::HEAPID:0 USED:352
[m3vpss ] 10718: CAPTURE: Create Done !!!
[m3vpss ] Vps_sii9135Control: ----------------- @ line 33 cmd = 268828674-------------------------
[m3vpss ] Vps_sii9135OutputEnable: ----------------- @ line 719 --------------------------
[m3vpss ] Vps_sii9135OutputEnable: ----------------- @ line 742 --------------------------
[m3vpss ] +++++++++++++++++++++++++++++++++++++++++++++++++++
[m3vpss ] 10886: NSF: Create in progress !!!
[m3vpss ] NSFLINK:!!WARNING.FORCIBLY DISABLING TILER since tiler is disabled at build time
[m3vpss ]
[m3vpss ]
[m3vpss ] 512 drvId========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668456 channel ========================
[m3vpss ]
[m3vpss ] 5 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] -1895899476 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] NSF::HEAPID:0 USED:128
[m3vpss ] NSF::HEAPID:1 USED:4928
[m3vpss ] 11012: NSF: Create Done !!!
[m3vpss ] 11018: DUP : Create Done !!!
[m3vpss ] 11024: DUP : Create Done !!!
[m3vpss ] 11026: MERGE : Create Done !!!
[m3video] 11116: IPC_IN_M3 : Create in progress !!!
[m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[m3video] 11117: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3vpss ] {SWOSD} edma3Handle->chId = 36
[m3video] 11117: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[m3video] 11120: IPC_IN_M3 : Create Done !!!
[m3vpss ] {SWOSD} edma3Handle->chId = 37
[m3video] 11121: ENCODE: Create in progress ... !!!
[m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[m3video] 11207: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[m3vpss ] {SWOSD} edma3Handle->chId = 38
[m3vpss ] 11000: SWOSD : Create Done !!!
[m3vpss ] 11098: DUP : Create Done !!!
[m3video] ENCLINK_H264:HEAPID:0 USED:13808
[m3vpss ] 11099: SCLR: Create in progress !!!
[m3video] 11316: ENCODE: Creating CH1 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[m3vpss ]
[m3vpss ]
[m3vpss ] 513 drvId========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668424 channel ========================
[m3vpss ]
[m3vpss ] 2 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] VIP 0 RES: DRV [fvid2_vps_vip_core_ti, 0x00000000] path alloc in progress ...
[m3video] ENCLINK_H264:HEAPID:0 USED:11912
[m3video] 11425: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[m3vpss ] VIP 0 RES: [SECONDARY ] is allocated in SHARED mode (ALLOC COUNT = 1, DRV ID = 0x00000000)
[m3video] ENCLINK_JPEG:HEAPID:0 USED:4432
[m3vpss ] VIP 0 RES: [CHR_DS_0 ] is allocated in SHARED mode (ALLOC COUNT = 1, DRV ID = 0x00000000)
[m3video] 11426: ENCODE: All CH Create ... DONE !!!
[m3vpss ] VIP 0 RES: [Y_UP ] is allocated in SHARED mode (ALLOC COUNT = 1, DRV ID = 0x00000000)
[m3vpss ] VIP 0 RES: [UV_UP ] is allocated in SHARED mode (ALLOC COUNT = 1, DRV ID = 0x00000000)
[m3vpss ] VIP 0 RES: [SC ] is allocated in SHARED mode (ALLOC COUNT = 1, DRV ID = 0x00000000)
[m3video] ENCLINK:HEAPID:0 USED:30392
[m3video] 11429: ENCODE: Create ... DONE !!!
[m3vpss ] VIP 0 RES: DRV [fvid2_vps_vip_core_ti, 0x00000000] path alloc is DONE !!!
[m3video] 11430: IPC_BITS_OUT : Create in progress !!!
[m3vpss ] VIP 0 MUX: SC SRC = SECONDARY (4)
[m3vpss ] VIP 0 MUX: CHR DS 0 SRC = SC (1)
[m3vpss ] VIP 0 MUX: CHR DS 0 BYPASS = 0
[m3vpss ] VIP 0 MUX: CHR DS 1 BYPASS = 0
[m3vpss ] VIP 0 MUX: RGB HI = 0
[host] IpcBitsInLink_tskMain:Entered
[host] 2186: IPC_BITS_IN : Create in progress !!!
[host] 2186: IPC_BITS_IN : ListMPOpen start !!!
[host] 2187: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
[m3video] 11432: IPC_BITS_OUT : Create Done !!!
[m3vpss ] -1913649780 drvHandle ========================
[host] 2195: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
[m3vpss ]
[m3vpss ]
[m3vpss ] 11109: SCLR : Loading Up-scaling Co-effs ...
[m3vpss ] 11109: SCLR : Co-effs Loading ... DONE !!!
[host] 2201: IPC_BITS_IN : ListMPOpen done !!!
[host] 2204: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 2205: IPC_BITS_IN : Create Done !!!
[host] USECASE SETUP DONE
[m3vpss ] SCLR:HEAPID:0 USED:64
[m3vpss ] SCLR:HEAPID:1 USED:5952
[m3vpss ] 11110: SCLR: Create Done !!!
[m3vpss ] 11022: FD : Alg Create Done !!!
[m3vpss ] 11022: FD : Create Done !!!
[m3vpss ] 11115: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 11116: IPC_OUT_M3 : Create Done !!!
[m3vpss ] 11788: DISPLAY: Create in progress !!!
[m3vpss ] DisplayId = 1,DataFormat = 7
[m3vpss ] SC2 displayInstId = 6
[m3vpss ]
[m3vpss ]
[m3vpss ] 1 drvId========================
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668392 channel ========================
[m3vpss ]
[m3vpss ] 1 Get the matching driver and channel object exit========================
[m3vpss ]
[m3vpss ] -1898081704 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] 11790: DISPLAY: Create Done !!!
[m3vpss ] 11791: DISPLAY: Create in progress !!!
[m3vpss ] DisplayId = 4,DataFormat = 7
[m3vpss ] SD displayInstId = 2
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] -1893668360 channel ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] -1898137752 drvHandle ========================
[m3vpss ]
[m3vpss ]
[m3vpss ] 11793: DISPLAY: Create Done !!!
[m3vpss ] 11795: DISPLAY: Start in progress !!!
[m3vpss ] 11845: DISPLAY: Start Done !!!
[m3vpss ] 11845: DISPLAY: AUX PATH: 40 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 11846: DISPLAY: Start in progress !!!
ApproDrvInit: 3
queue id:131076
queue id:0
queue id:32769
[m3vpss ] 11886: DISPLAY: Start Done !!!
[m3vpss ] 11887: DISPLAY: SDDAC(SEC1): 24 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 11894: CAPTURE: Start in progress !!!
[m3vpss ] Vps_sii9135Control: ----------------- @ line 33 cmd = 5-------------------------
[m3vpss ] -1893668488: CAPTURE: pInstObj->videoDecoderHandle !!!
[m3vpss ] 11895: CAPTURE: Start Done !!!
[host]
Audio capture task created [m3vpss ] 12020: CAPTURE: Fields = 0 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)
[host] MCFW_IPCBITS: Callback function:App_ipcBitsInCbFxn
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print.. [m3video] Channel:0 inputframerate:30 targetfps:60
[m3video] Channel:2 inputframerate:60 targetfps:5
queue id:0
ApproDrvInit: 7
queue id:131076
[m3vpss ] 15308: DISPLAY: Stop in progress !!!
[m3vpss ] 15357: DISPLAY: Stop Done !!!
[m3vpss ] 15361: DISPLAY: Start in progress !!!
[host] VNF MESSAGE RECIEVED: (Enable:0) (Mode:5) (Strength:0) (EnableTNF:0) (EnableSNF:0)
[m3vpss ] 15410: DISPLAY: Start Done !!!
[m3vpss ] 15411: DISPLAY: SDDAC(SEC1): 2100 fps, Latency (Min / Max) = ( 1 / 33 ), Callback Interval (Min / Max) = ( 33 / 34 ) !!!
[host]
Channel Selected: 0
[host]
Channel Selected: 0,rate control = 0
[host]
Channel Selected: 0
[host]
Channel Selected: 0
[host]
Channel Selected: 0
[host]
Channel Selected: 0,packet size = 100
[host]
Channel Selected: 0,encPreset = 0
[host]
Channel Selected: 0,enable = 0
[host]
Channel Selected: 1
[host]
[m3video] ENCLINK: new targetframerate to set:30000
[host]
Channel Selected: 1
[host]
Channel Selected: 1
[host]
Channel Selected: 1
[host]
Channel Selected: 1,packet size = 100
[host]
Channel Selected: 1,encPreset = 0 [m3video] ENCLINK: new rate control algorithm to set:0
[host]
Channel Selected: 1,enable = 0
[host]
Channel Selected: 2
[host]
Channel Selected: 2,rate control = 2
[host] MJPEG in Rate Control OFF Mode
[m3video] ENCLINK: new targetbitrate to set:2000000
Check_device_version : DEVICE VER = 0 !!
[m3video] Channel:0 inputframerate:30 targetfps:30
[m3video] Channel:2 inputframerate:30 targetfps:5
[m3video] ENCLINK: new intraFrameInterval to set:60
[m3video] ENCLINK: new QP I Param to set:10 36 -1
[m3video] ENCLINK: new QP P Param to set:10 40 28
[m3video] ENCLINK: new PacketSize Param to set:100
[m3video] ENCLINK: new Encode Preset Param to set:0
[m3video] Channel:1 inputframerate:30 targetfps:30
[m3video] JPGLINK: new targetframerate to set:5000 for bitrate 100000
[m3video] JPGLINK: new QP Param to set:1 51 80
[m3video] JPGLINK: new qualityFactor Param to set:80
[m3video] JPGLINK: new rate control algorithm to set:2 for bitrate: 100000
[m3video] JPGLINK: Run time parameters changed 0
[m3video] ENCLINK: new intraFrameInterval to set:30
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print..omap_i2c omap_i2c.1: controller timed out
[m3video] ==================== EncLink_PrintDetails ====================
[m3video] =================================================================
[host] AUDIO : period size = 500 frames, dir = 0
[host] AUDIO : period time = 62500 us, dir = 0
[host]
Application Run Completed
numid=15,iface=MIXER,name='Left HPCOM Mixer PGAR Bypass Volume'
; type=INTEGER,access=rw---R--,values=1,min=0,max=118,step=0
: values=76
| dBscale-min=-59.00dB,step=0.50dB,mute=1
: values=76,76
[host]
[host]
Force IDR on Channel: 1SystemInit success
Schedule manager init success
Dmva Schedule manager init success
SystemServer:============================ SYS_MSG_DO_BOOT_PROC
SystemServer:doning at SYS_MSG_DO_BOOT_PROC
umount: can't umount /mnt/mmc: Invalid argument
mount: mounting /dev/mmcblk0 on /mnt/mmc failed: Invalid argument
net_search_gateway:eth0, 1A8C0, 0, 1
net_search_gateway:eth0, 0, 101A8C0, 3
net_get_dns: file "/etc/resolv.conf" opened for reading error!
Debug SysDoBootProc control success.
Debug
boot_src:============================ boot_src
Debug
boot_src:doning at boot_src
Debug
Debug
boot_src end:============================ boot_src
[09/Nov/2012:20:16:22 +0000] boa: server version Boa/0.94.13
[09/Nov/2012:20:16:22 +0000] boa: server built Jun 4 2014 at 15:11:58.
[09/Nov/2012:20:16:22 +0000] boa: starting server pid=553, port 80
Debug
Debug
Debug
Debug
queue id:0
<UDN>uuid:Upnp-TVEmulator-1_0-00_0045244029</UDN>
Upnp port is 0
UPnP Initialized OK ip=192.168.1.181, port=0
desc_doc_url = 192.168.1.181/tvdevicedesc.xml
error code = 0
device advertisement succeed.
ApproDrvInit: 10
queue id:131076
Initializing...
...done initializing
Play this stream using the URL:
rtsp://192.168.1.181:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8304 for optional RTSP-over-HTTP tunneling.)
ApproDrvInit: 6
queue id:131076
Initializing...
ApproDrvInit: 2
queue id:131076
Initializing...
rtsp://192.168.1.181:8553/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8300 for optional RTSP-over-HTTP tunneling.)
ApproDrvInit: 8
queue id:131076
Initializing...
rtsp://192.168.1.181:8555/PSIA/Streaming/channels/0?videoCodecType=MJPEG
(We use port 8302 for optional RTSP-over-HTTP tunneling.)
ApproDrvInit: 9
queue id:131076
Initializing...
rtsp://192.168.1.181:8554/PSIA/Streaming/channels/1?videoCodecType=MPEG4
(We use port 8301 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.1.181:8556/PSIA/Streaming/channels/2?videoCodecType=H.264
(We use port 8303 for optional RTSP-over-HTTP tunneling.)
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print.. [m3video] ==================== EncLink_PrintDetails ====================
[host]
Usecase is Active !!!
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print..[09/Nov/2012:20:18:11 +0000] request from 192.168.1.183 "GET /favicon.ico HTTP/1.1" ("/var/www/favicon.ico"): document open: No such file or directory
==================== STREAMING DETAILS ====================
Start Time : 1352492303sec 656419usec
End Time : 1352492338sec 595391usec
Total Time to stream 1000 frames: 34938.972 msec
Time per frame: 34.9390 msec
Streaming Performance in FPS: 28.6213
[host]
we can see thar there is some error about configuretion of aic3106 by I2C ,I have try many times ,but I still can't
solve,
in autorun_ipnc.sh
amixer sset 'Right PGA Mixer Mic3L Switch' on
amixer sset 'Right PGA Mixer Mic3R Switch' on
amixer sset 'Left PGA Mixer Mic3L Switch' on
amixer sset 'Left PGA Mixer Mic3R Switch' on
sleep 1
amixer cset name='PCM Playback Volume' 60%,60%
amixer cset name='PGA Capture Volume' 60%,60%
can you give me some suggestions ,
thanks in advance,
Regards,
stone
