我在对C6678执行Power Sleep Control的关核操作,按照Corepac User Guide中说明要执行如下操作:
1. Enable power-down by setting the MEGPD field to 1 in the PDCCMD register.
2. Enable the DSP interrupt(s) that you want to wake-up the C66x CorePac. Disable all other interrupts.
3. Execute the IDLE instruction.
请问第2步中的DSP interrupt是哪个中断 最好能够提供相应的代码,谢谢!!!
中断号118 PDC_INT (Power down sleep interrupt)是用来唤醒核的么?还是其他的中断,例如GPIO中断也可以唤醒核?谢谢!
