关于AM1808的PLL0的问题
Other Parts Discussed in Thread: AM1808, SYSCONFIG
我是用openocd调试AM1808,在init文件里面初始化PLL0和PLL1,初始化PLL0时,发现设置PLLCMD的GO位时,仿真器死机了,
提示如下
Warn : Bad value '01C11104' captured during DR or IR scan:
Warn :  check_value: 0x00000009
Warn :  check_mask: 0x00000009 Error: JTAG error while reading cpsr
我设置PLLM=24,PLLPOSTDIV=1,PLL的频率为600M,输出为300M
我把这个配置数据加载到PLL1,可以正常输出300M
我开始做了第二个实验
我把PLLCMD的GO位不操作,因为我用的缺省的DIV数据,但是执行PLLCTL里面的PLLEN位时,仿真器同样死机,提示一样
附上我的ocd命令
大家帮我看看
PLL1可以设置成功,PLL0不行
帮我找找原因
#************************************************************************* # gdb port #*************************************************************************
telnet_port 8023
gdb_port 1000
# interface
interface ft2232
ft2232_device_desc "USB<=>JTAG&RS232 A"
ft2232_layout jtagkey
ft2232_vid_pid 0x1457 0x5118
adapter_khz 500
# chip name
if { [info exists CHIPNAME] } {
   set _CHIPNAME $CHIPNAME
} else {
   set _CHIPNAME omapl138
source [find target/icepick.cfg]
# Subsidiary TAP: ARM ETB11, with scan chain for 4K of ETM trace buffer
if { [info exists ETB_TAPID] } {
   set _ETB_TAPID $ETB_TAPID
} else {
   set _ETB_TAPID 0x2B900F0F
jtag newtap $_CHIPNAME etb -irlen 4 -irmask 0xF -expected-id $_ETB_TAPID -disable
jtag configure $_CHIPNAME.etb -event tap-enable "icepick_c_tapenable $_CHIPNAME.jrc 3"
# Subsidiary TAP: ARM926ejs with scan chains for ARM Debug, EmbeddedICE-RT, ETM.
if { [info exists CPU_TAPID] } {
   set _CPU_TAPID $CPU_TAPID
} else {
   set _CPU_TAPID 0x07926001
jtag newtap $_CHIPNAME arm -irlen 4 -irmask 0xF -expected-id $_CPU_TAPID -disable
jtag configure $_CHIPNAME.arm -event tap-enable "icepick_c_tapenable $_CHIPNAME.jrc 2"
# Primary TAP: ICEpick-C (JTAG route controller) and boundary scan
if { [info exists JRC_TAPID] } {
   set _JRC_TAPID $JRC_TAPID
} else {
   set _JRC_TAPID 0x0b7d102f
jtag newtap $_CHIPNAME jrc -irlen 6 -irmask 0x3F -expected-id $_JRC_TAPID -ignore-version
jtag configure $_CHIPNAME.jrc -event setup "jtag tapenable $_CHIPNAME.etb; jtag tapenable $_CHIPNAME.arm"
set _TARGETNAME $_CHIPNAME.arm
target create $_TARGETNAME arm926ejs -chain-position $_TARGETNAME
# $_TARGETNAME configure -work-area-phys 0x80000000 -work-area-size 0x2000
$_TARGETNAME configure -work-area-phys 0xFFFF0000 -work-area-size 0x2000
$_TARGETNAME configure -event "reset-start" { adapter_khz 500 }
arm7_9 fast_memory_access enable
arm7_9 dcc_downloads enable
etm config $_TARGETNAME 16 normal full etb
etb config $_TARGETNAME $_CHIPNAME.etb
gdb_breakpoint_override hard
arm7_9 dbgrq enable
reset_config trst_and_srst separate
proc mrw {reg} {
 set value ""
 mem2array value 32 $reg 1
 return $value(0)
# phyaddr define
global AM1808
set AM1808 [ dict create ]
dict set AM1808 pllc1      0x01C11000
dict set AM1808 pllc2      0x01E1A000
dict set AM1808 psc0      0x01C10000
dict set AM1808 psc1      0x01E27000
proc pll0_setup {pll_addr mult} {
    mdw 0x01C11000
    # init pll_ctrl_addr
    set pll_ctrl_addr [expr $pll_addr + 0x100]
 set pll_ctrl [mrw $pll_ctrl_addr]
    # 1 - clear CLKMODE (bit 8) iff using on-chip oscillator
 # NOTE: this assumes we should clear that bit
    set pll_ctrl [ expr $pll_ctrl  & ~0x100 ]
 mww $pll_ctrl_addr $pll_ctrl
    echo "clear CLKMODE BIT8"
    mdw $pll_ctrl_addr
    # 2 - clear EXTCLKSRC (bit 9) for Use OSCIN for the PLL bypass clock
 set pll_ctrl [expr $pll_ctrl & ~0x0200]
    echo "EXTCLKSRC BIT9"
    mdw $pll_ctrl_addr
    # 3 - clear PLLENSRC BIT5 for This bit must be cleared before the PLLEN bit will have any effect
 set pll_ctrl [expr $pll_ctrl & ~0x0020]
    echo "clear PLLENSRC (bit 5)"
    mdw $pll_ctrl_addr
    # 4 - clear PLLEN BIT0 enter bypass mode
 set pll_ctrl [expr $pll_ctrl & ~0x0001]
    echo "clear PLLEN (bit 0) for bypass"
    mdw $pll_ctrl_addr
    # 5 - wait at least 4 refclk cycles
 sleep 1
    # 6 - clear PLLRST BIT3 for PLL0 reset is asserted
 set pll_ctrl [expr $pll_ctrl & ~0x0008]
    echo "clear PLLRST BIT3 reset"
    mdw $pll_ctrl_addr
    # 8 - clear PLLPWRDN BIT1 for PLL0 is operating
 set pll_ctrl [expr $pll_ctrl & ~0x0002]
    echo "clear PLLPWRDN BIT1 run"
    mdw $pll_ctrl_addr
    # 10 write prediv, postdiv, and pllm
    set div [expr 0x8000 | 0]
    mww [expr $pll_addr + 0x0114] $div
    echo "set prediv"
    mdw [expr $pll_addr + 0x0114]
    # 10 write pllm
 mww [expr $pll_addr + 0x0110] [expr ($mult - 1) & 0xFF]
    echo "set pllm"
    mdw [expr $pll_addr + 0x0110]
    # 10 write postdiv
    set div [expr 0x8000 | 1]
    mww [expr $pll_addr + 0x0128] $div
    echo "set postdiv"
    mdw [expr $pll_addr + 0x0128]
    mdw [expr $pll_addr + 0x0118]
    mdw [expr $pll_addr + 0x011C]
    mdw [expr $pll_addr + 0x0120]
    mdw [expr $pll_addr + 0x0160]
    mdw [expr $pll_addr + 0x0164]
    mdw [expr $pll_addr + 0x0168]
    mdw [expr $pll_addr + 0x016C]
    # write go CMD
 # mww [expr $pll_addr + 0x0138] 0x01
    # sleep 800
    # echo "set CMD go"
    # mdw [expr $pll_addr + 0x0138]
    # 11 - wait at least 5 usec for reset to finish
    sleep 20
    # 12 set PLLRST BIT3
 set pll_ctrl [expr $pll_ctrl | 0x0008]
    echo "set PLLRST BIT3 out reset"
    mdw $pll_ctrl_addr
    # 13 - wait at least 8000 refclk cycles for PLL to lock
 sleep 800
    # 14 - set PLLEN BIT0 leave bypass mode
 set pll_ctrl [expr $pll_ctrl | 0x0001]
    echo "step set PLLEN BIT0 enable PLL"
    mdw $pll_ctrl_addr
proc pll1_setup {pll_addr mult} {
 mdw 0x01E1A000
    # PLLC1 init
    mdw $pll_ctrl_addr
    # 1 - clear PLLENSRC (bit 5) for This bit must be cleared before the PLLEN bit will have any effect
    echo "clear PLLENSRC BIT5"
    mdw $pll_ctrl_addr
    # 2 - clear PLLEN (bit 0) ... enter bypass mode
    echo "clear PLLEN BIT0"
    mdw $pll_ctrl_addr
    # 3 - wait at least 4 refclk cycles
 sleep 1
    # 4 - clear PLLRST (bit 3) for PLL0 reset is asserted
    echo "clear PLLRST BIT3 for reset"
    mdw $pll_ctrl_addr
    # 6 - clear PLLPWRDN (bit 1) for PLL0 is operating
    echo "clear PLLPWRDN BIT1 for powerup"
    mdw $pll_ctrl_addr
    # 8 - optional: write pllm
    echo "set PLLM"
    # 9 optional: write postdiv
    echo "set postdiv"
    mww [expr $pll_addr + 0x0118] 0x8000
    mww [expr $pll_addr + 0x011C] 0x8001
    mww [expr $pll_addr + 0x0120] 0x8002
    # set CMD go
    sleep 8
    echo "set CDM go end"
    #  10 - wait at least 5 usec for reset to finish
 sleep 1
    #  11 - set PLLRST BIT3
    echo "set PLLPWRDN BIT3 for exit reset"
    mdw $pll_ctrl_addr
 sleep 800
    # 14 - set PLLEN BIT0 ... leave bypass mode
    echo "set PLLEN bit0"
    mdw $pll_ctrl_addr
    # 14 OBSCLK enable
    mww [expr $pll_addr + 0x0148] 0x2
proc am1808_init {} {
 global AM1808
    echo "Initialize AM1808 board"
    set sysconfig_addr  0x01C14000
    # unlock sysconfig
    mww [expr $sysconfig_addr + 0x038] 0x83E70B13
    mww [expr $sysconfig_addr + 0x03C] 0x95A4F1E0
    # setup the CLKOUT pin
    set pinmux13  [mrw [expr $sysconfig_addr + 0x154]]
    set pinmux13 [expr $pinmux13 &~(0xF<<0x4)]
    set pinmux13 [expr $pinmux13 | (0x1<<0x4)]
    mww [expr $sysconfig_addr + 0x154] $pinmux13
    mdw [expr $sysconfig_addr + 0x154]
    # PLLC0 OBSCLK for PLL1C
    set pll0_base_addr 0x01C11000
    mww [expr $pll0_base_addr + 0x0104] 0x1E
    echo "set PLL0 OBSCLK for"
    mdw [expr $pll0_base_addr + 0x0104]
    # unclok PLLC1
    set sysconfig_cfg3 [mrw [expr $sysconfig_addr + 0x188]]
    set sysconfig_cfg3 [expr $sysconfig_cfg3 & ~0x20]
    mww [expr $sysconfig_addr + 0x188] $sysconfig_cfg3
    mdw [expr $sysconfig_addr + 0x188]
    # init PLLC1
    set addr [dict get $AM1808 pllc2]
 pll1_setup $addr 25
    # unclok PLLC0
    set sysconfig_cfg0 [mrw [expr $sysconfig_addr + 0x17C]]
    set sysconfig_cfg0 [expr $sysconfig_cfg0 & ~0x10]
    mww [expr $sysconfig_addr + 0x17C] $sysconfig_cfg0
    mdw [expr $sysconfig_addr + 0x17C]
    # init PLLC0
    set addr [dict get $AM1808 pllc1]
 pll0_setup $addr 25
    set pll1_base_addr 0x01E1A000
    mww [expr $pll1_base_addr + 0x0104] 0x19
    mdw [expr $pll1_base_addr + 0x0104]
proc gdb { } {
    jtag_reset 0 1
    sleep 2
    jtag_reset 0 0
 halt
 wait_halt
 am1808_init
    reg pc 0x80002000
  • 上面这些配置看不懂,处理过类似问题是由于CVDD供电不足导致配置PLL0后CVDD电流需求迅速增加,从而导致CVDD不稳,所以导致芯片工作不正常,所以建议修改一下CVDD的供电,或者用一个外部电源供电来验证我的推测。
