关于TI8107 VPSS-M3固件加载不成功的求解
Other Parts Discussed in Thread: TVP5158
您好:
我现在使用的是8107开发板,我的内核及文件系统都运行良好,但是加载VPSS-M3固件时出现了开发板死机的情况。我的内核及文件系统都是在DVR_RDK_v03.00.01.26下编译的。编译.xem3文件时发现代码中tvp5158相关的驱动,但是我的板子上并没有tvp5158,而是用其他芯片代替的。是不是因为这个原因导致加载失败的??是的话又该如何解决??
下面是文件系统启动后的log信息:
start application
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
Kernel bootargs validated
numid=101,iface=MIXER,name='Left DAC Mux'
  ; type=ENUMERATED,access=rw------,values=1,items=3
  ; Item #0 'DAC_L1'
  ; Item #1 'DAC_L3'
  ; Item #2 'DAC_L2'
  : values=2
numid=99,iface=MIXER,name='Right DAC Mux'
  ; Item #0 'DAC_R1'
  ; Item #1 'DAC_R3'
  ; Item #2 'DAC_R2'
  : values=2
 [c6xdsp ] Remote Debug Shared Memory @ 0xbfff0000
 [m3video] Remote Debug Shared Memory @ 0xbfff5020
 [m3vpss ] Remote Debug Shared Memory @ 0xbfffa040
SysLink version : 2.20.02.20
SysLink module created on Date:Apr 29 2013 Time:18:57:31
Trace enabled
Trace SetFailureReason enabled
 Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[3,3] BW=2000, WM Cycles=4000]
 Setting DMM priority for [DUCATI  ] to [0] ( 0x4e000624 = 0x08000000 )
 Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3vpss_512M_128M.xem3 on slave procId 1.
Started slave procId 1.
After Ipc_loadcallback status [0x00000000]
 [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 280000000
 [m3vpss ] notify_attach  rtnVal  0
 [m3vpss ] initProxyServer  rtnVal  0
 [m3vpss ]
 [m3vpss ]  *** UTILS: CPU KHz = 560000 Khz ***
 [m3vpss ]
 [m3vpss ]  44: SYSTEM  : System Common Init in progress !!!
 [m3vpss ]  44: SYSTEM: IPC init in progress !!!
 [m3vpss ]  44: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  1043: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  1046: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3vpss ]  1046: SYSTEM: Attaching to [VIDEO-M3] ...
After Ipc_startcallback status [0x00000000]
Attached to slave procId 0.
 [m3vpss ]  2045: SYSTEM: Attaching to [VIDEO-M3] ...
Loaded file ../firmware/dvr_rdk_fw_m3video_512M_128M.xem3 on slave procId 0.
Started slave procId 0.
 [m3video] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 280000000
 [m3video]
 [m3video]  *** UTILS: CPU KHz = 560000 Khz ***
 [m3video]
 [m3video]  2637: SYSTEM  : System Common Init in progress !!!
 [m3video]  2637: SYSTEM: IPC init in progress !!!
 [m3video]  2637: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  3045: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  3636: SYSTEM: Attaching to [HOST] ...
 [m3video]  3639: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3video]  3639: SYSTEM: Attaching to [VPSS-M3] ...
DMA: Module install successful, device major num = 251
DRV: Module install successful
DRV: Module built on Apr 29 2013 18:57:54
 [m3vpss ]  4045: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  4638: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  5046: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  5045: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  5046: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3vpss ]  5046: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3vpss ]  5046: SYSTEM: Crea     ---->到这里就不再运行了,但是每次最后的打印信息位置都不一样。。
希望能够得到各位的帮助,问题困扰很久了。
