Hello Ti
AM335X 客製版使用 ubuntu filesystem,可以開進 filesystem,但在kernel期間出現
omap_i2c omap_i2c.1: controller timed out
我是新手能否給我些建議,'讓我一個一個步驟去檢查? log如下,謝謝。
U-Boot SPL 2014.01-rc1-00005-ga42d999 (Jun 27 2014 - 13:29:54) i2c_probe: pads on bus 0 probably not configured (status=0x10) reading args spl: error reading image args, err - -1 reading u-boot.img reading u-boot.img U-Boot 2014.01-rc1-00005-ga42d999 (Jun 27 2014 - 13:29:54) I2C: ready DRAM: 256 MiB WARNING: Caches not enabled NAND: 256 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 *** Warning - bad CRC, using default environment Net: <ethaddr> not set. Validating first E-fuse MAC cpsw, usb_ether Hit any key to stop autoboot: 0 syntax error mmc0 is current device SD/MMC found on device 0 reading uEnv.txt 153 bytes read in 4 ms (37.1 KiB/s) Loaded environment from uEnv.txt Importing environment from mmc ... Running uenvcmd ... reading uImage 4176424 bytes read in 924 ms (4.3 MiB/s) ## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.2.0-00274-g03a35a5-dirty Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4176360 Bytes = 4 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. [ 0.000000] Linux version 3.2.0-00274-g03a35a5-dirty (bernie@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #3 Fri Jun 27 14:23:13 CST 2014 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: am335xevm [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] AM335X ES2.1 (neon ) [ 0.000000] ------------[ cut here ]------------ [ 0.000000] WARNING: at arch/arm/mach-omap2/clkt_clksel.c:194 omap2_clksel_recalc+0xd8/0x108() [ 0.000000] clock: Could not find fieldval 0 for clock dpll_core_m6_ck parent dpll_core_x2_ck [ 0.000000] Modules linked in: [ 0.000000] Backtrace: [ 0.000000] [<c00176e8>] (dump_backtrace+0x0/0x114) from [<c05a6bd8>] (dump_stack+0x20/0x24) [ 0.000000] r6:000000c2 r5:c002fd6c r4:c07dfe80 r3:c0804fe0 [ 0.000000] [<c05a6bb8>] (dump_stack+0x0/0x24) from [<c00429c4>] (warn_slowpath_common+0x5c/0x74) [ 0.000000] [<c0042968>] (warn_slowpath_common+0x0/0x74) from [<c0042a98>] (warn_slowpath_fmt+0x40/0x48) [ 0.000000] r8:c07e82bc r7:00000001 r6:c05b5450 r5:00000100 r4:c07f65e8 [ 0.000000] r3:00000009 [ 0.000000] [<c0042a58>] (warn_slowpath_fmt+0x0/0x48) from [<c002fd6c>] (omap2_clksel_recalc+0xd8/0x108) [ 0.000000] r3:00000000 r2:c06db038 [ 0.000000] [<c002fc94>] (omap2_clksel_recalc+0x0/0x108) from [<c00342e8>] (propagate_rate+0x3c/0x5c) [ 0.000000] r7:c07e82bc r6:c0da1040 r5:c07f64e8 r4:c07f65e8 [ 0.000000] [<c00342ac>] (propagate_rate+0x0/0x5c) from [<c00342f4>] (propagate_rate+0x48/0x5c) [ 0.000000] r5:c07f648c r4:c07f64d4 [ 0.000000] [<c00342ac>] (propagate_rate+0x0/0x5c) from [<c00342f4>] (propagate_rate+0x48/0x5c) [ 0.000000] r5:c07f63d4 r4:c07f6478 [ 0.000000] [<c00342ac>] (propagate_rate+0x0/0x5c) from [<c00342f4>] (propagate_rate+0x48/0x5c) [ 0.000000] r5:c07f62c0 r4:c07f63c0 [ 0.000000] [<c00342ac>] (propagate_rate+0x0/0x5c) from [<c0034470>] (recalculate_root_clocks+0x48/0x60) [ 0.000000] r5:c080412c r4:c07f62ac [ 0.000000] [<c0034428>] (recalculate_root_clocks+0x0/0x60) from [<c0793a58>] (am33xx_clk_init+0x8c/0xa8) [ 0.000000] r5:c07f613c r4:c07f613c [ 0.000000] [<c07939cc>] (am33xx_clk_init+0x0/0xa8) from [<c0793788>] (omap3xxx_clk_init+0xe0/0x324) [ 0.000000] r5:c088177c r4:00003517 [ 0.000000] [<c07936a8>] (omap3xxx_clk_init+0x0/0x324) from [<c078e45c>] (am33xx_init_early+0x3c/0x40) [ 0.000000] r7:c07e82bc r6:c0da1040 r5:c088177c r4:c07b7f94 [ 0.000000] [<c078e420>] (am33xx_init_early+0x0/0x40) from [<c078ae04>] (setup_arch+0x700/0x7f0) [ 0.000000] [<c078a704>] (setup_arch+0x0/0x7f0) from [<c0787574>] (start_kernel+0x78/0x2dc) [ 0.000000] [<c07874fc>] (start_kernel+0x0/0x2dc) from [<80008040>] (0x80008040) [ 0.000000] r6:c07b94d0 r5:c07e0044 r4:10c53c7d [ 0.000000] ---[ end trace 1b75b31a2719ed1c ]--- [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 mem=512M rootwait [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Memory: 512MB = 512MB total [ 0.000000] Memory: 509896k/509896k available, 14392k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB) [ 0.000000] .text : 0xc0008000 - 0xc0787000 (7676 kB) [ 0.000000] .init : 0xc0787000 - 0xc07dd000 ( 344 kB) [ 0.000000] .data : 0xc07de000 - 0xc08472b0 ( 421 kB) [ 0.000000] .bss : 0xc08472d4 - 0xc099f190 (1376 kB) [ 0.000000] NR_IRQS:396 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] Total of 128 interrupts on 1 active controller [ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz [ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz [ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000396] Calibrating delay loop... 298.59 BogoMIPS (lpj=1492992) [ 0.067230] pid_max: default: 32768 minimum: 301 [ 0.067565] Security Framework initialized [ 0.067718] Mount-cache hash table entries: 512 [ 0.068572] CPU: Testing write buffer coherency: ok [ 0.068695] ftrace: allocating 22058 entries in 65 pages [ 0.205383] omap_hwmod: gfx: failed to hardreset [ 0.225341] omap_hwmod: pruss: failed to hardreset [ 0.227020] print_constraints: dummy: [ 0.227478] NET: Registered protocol family 16 [ 0.229827] OMAP GPIO hardware version 0.1 [ 0.232238] omap_mux_init: Add partition: #1: core, flags: 0 [ 0.234649] omap_i2c.1: alias fck already exists [ 0.235778] omap2_mcspi.1: alias fck already exists [ 0.236053] omap2_mcspi.2: alias fck already exists [ 0.236511] edma.0: alias fck already exists [ 0.236541] edma.0: alias fck already exists [ 0.236602] edma.0: alias fck already exists [ 0.259674] bio: create slab <bio-0> at 0 [ 0.261779] SCSI subsystem initialized [ 0.263549] usbcore: registered new interface driver usbfs [ 0.263824] usbcore: registered new interface driver hub [ 0.264099] usbcore: registered new device driver usb [ 0.264709] registerd cppi-dma Intr @ IRQ 17 [ 0.264739] Cppi41 Init Done Qmgr-base(e087a000) dma-base(e0878000) [ 0.264770] Cppi41 Init Done [ 0.264831] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3 [ 0.265167] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1 [ 0.286010] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz [ 1.279815] omap_i2c omap_i2c.1: controller timed out [ 1.299682] tps65910 1-002d: could not be detected [ 1.300842] Advanced Linux Sound Architecture Driver Version 1.0.24. [ 1.302062] Bluetooth: Core ver 2.16 [ 1.302185] NET: Registered protocol family 31 [ 1.302215] Bluetooth: HCI device and connection manager initialized [ 1.302246] Bluetooth: HCI socket layer initialized [ 1.302276] Bluetooth: L2CAP socket layer initialized [ 1.302337] Bluetooth: SCO socket layer initialized [ 1.302734] Switching to clocksource gp timer [ 1.342376] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host) [ 1.342895] musb-hdrc musb-hdrc.0: dma type: dma-cppi41 [ 1.343322] MUSB0 controller's USBSS revision = 4ea20800 [ 1.343414] musb0: Enabled SW babble control [ 1.345245] musb-hdrc musb-hdrc.0: USB OTG mode controller at e083c000 using DMA, IRQ 18 [ 1.345672] musb-hdrc musb-hdrc.1: dma type: dma-cppi41 [ 1.346069] MUSB1 controller's USBSS revision = 4ea20800 [ 1.346130] musb1: Enabled SW babble control [ 1.347076] musb-hdrc musb-hdrc.1: MUSB HDRC host driver [ 1.347259] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1 [ 1.347534] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.347564] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.347595] usb usb1: Product: MUSB HDRC host driver [ 1.347625] usb usb1: Manufacturer: Linux 3.2.0-00274-g03a35a5-dirty musb-hcd [ 1.347656] usb usb1: SerialNumber: musb-hdrc.1 [ 1.348815] hub 1-0:1.0: USB hub found [ 1.348876] hub 1-0:1.0: 1 port detected [ 1.349731] musb-hdrc musb-hdrc.1: USB Host mode controller at e083e800 using DMA, IRQ 19 [ 1.350463] NET: Registered protocol family 2 [ 1.350860] IP route cache hash table entries: 4096 (order: 2, 16384 bytes) [ 1.351654] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 1.352355] TCP bind hash table entries: 16384 (order: 4, 65536 bytes) [ 1.352935] TCP: Hash tables configured (established 16384 bind 16384) [ 1.352966] TCP reno registered [ 1.352996] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 1.353057] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 1.353546] NET: Registered protocol family 1 [ 1.354095] RPC: Registered named UNIX socket transport module. [ 1.354125] RPC: Registered udp transport module. [ 1.354156] RPC: Registered tcp transport module. [ 1.354187] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.354705] NetWinder Floating Point Emulator V0.97 (double precision) [ 1.632781] ashmem: initialized [ 1.633422] VFS: Disk quotas dquot_6.5.2 [ 1.633544] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.635437] fuse init (API version 7.17) [ 1.635955] msgmni has been set to 995 [ 1.638305] io scheduler noop registered [ 1.638336] io scheduler deadline registered [ 1.638488] io scheduler cfq registered (default) [ 2.633361] omap_i2c omap_i2c.1: controller timed out [ 2.653350] Could not set LED4 to fully on [ 3.653472] omap_i2c omap_i2c.1: controller timed out [ 4.673461] omap_i2c omap_i2c.1: controller timed out [ 5.693664] omap_i2c omap_i2c.1: controller timed out [ 5.714996] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0 [ 6.598693] console [ttyO0] enabled [ 6.603210] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 [ 6.611328] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 [ 6.619476] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3 [ 6.627563] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4 [ 6.635681] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5 [ 6.644073] [drm] Initialized drm 1.1.0 20060810 [ 6.662597] brd: module loaded [ 6.673309] loop: module loaded [ 6.677062] i2c-core: driver [tsl2550] using legacy suspend method [ 6.683624] i2c-core: driver [tsl2550] using legacy resume method [ 6.690185] at24 1-0051: 4096 byte 24c32 EEPROM, writable, 32 bytes/write [ 7.693481] omap_i2c omap_i2c.1: controller timed out [ 8.733459] omap_i2c omap_i2c.1: controller timed out [ 8.773437] No daughter card found on AM335x EVM [ 8.778411] at24 1-0050: 4096 byte 24c32 EEPROM, writable, 32 bytes/write [ 8.785614] The board is a AM335x Starter Kit. [ 8.792022] omap_hsmmc.0: alias fck already exists [ 8.797607] omap_hsmmc.1: alias fck already exists [ 8.804473] da8xx_lcdc.0: alias fck already exists [ 8.810028] da8xx_lcdc da8xx_lcdc.0: GLCD: Found NHD-4.3-ATXI#-T-1 panel [ 8.830322] davinci-mcasp.1: alias fck already exists [ 8.837005] _regulator_get: l3_main.0 supply vdd_core not found, using dummy regulator [ 8.845581] am335x_opp_update: physical regulator not present for core(-22) [ 8.853393] (hci_tty): inside hci_tty_init [ 8.858123] (hci_tty): allocated 251, 0 [ 8.863281] NFC Driver for TI WiLink [ 8.868774] mtdoops: mtd device (mtddev=name/number) must be supplied [ 8.876129] omap2-nand driver initializing [ 8.880615] OneNAND driver initializing [ 8.885864] CAN device driver interface [ 8.889923] CAN bus driver for Bosch D_CAN controller 1.0 [ 8.943481] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 [ 8.950012] davinci_mdio davinci_mdio.0: detected phy mask f00fff00 [ 8.973114] davinci_mdio.0: probed [ 8.976806] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown [ 8.984252] davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown [ 8.991699] davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver unknown [ 8.999176] davinci_mdio davinci_mdio.0: phy[3]: device 0:03, driver unknown [ 9.006622] davinci_mdio davinci_mdio.0: phy[4]: device 0:04, driver unknown [ 9.014099] davinci_mdio davinci_mdio.0: phy[5]: device 0:05, driver unknown [ 9.021545] davinci_mdio davinci_mdio.0: phy[6]: device 0:06, driver unknown [ 9.028991] davinci_mdio davinci_mdio.0: phy[7]: device 0:07, driver AR8035 Gigabit Ethernet [ 9.037933] davinci_mdio davinci_mdio.0: phy[20]: device 0:14, driver unknown [ 9.045471] davinci_mdio davinci_mdio.0: phy[21]: device 0:15, driver unknown [ 9.053009] davinci_mdio davinci_mdio.0: phy[22]: device 0:16, driver unknown [ 9.060577] davinci_mdio davinci_mdio.0: phy[23]: device 0:17, driver unknown [ 9.068115] davinci_mdio davinci_mdio.0: phy[24]: device 0:18, driver unknown [ 9.075683] davinci_mdio davinci_mdio.0: phy[25]: device 0:19, driver unknown [ 9.083190] davinci_mdio davinci_mdio.0: phy[26]: device 0:1a, driver unknown [ 9.090759] davinci_mdio davinci_mdio.0: phy[27]: device 0:1b, driver unknown [ 9.098419] PPP generic driver version 2.4.2 [ 9.103332] PPP BSD Compression module registered [ 9.108337] PPP Deflate Compression module registered [ 9.113952] usbcore: registered new interface driver cdc_ether [ 9.120239] usbcore: registered new interface driver cdc_eem [ 9.126373] usbcore: registered new interface driver dm9601 [ 9.132385] usbcore: registered new interface driver cdc_subset [ 9.138732] cdc_ncm: 04-Aug-2011 [ 9.142272] usbcore: registered new interface driver cdc_ncm [ 9.148498] usbcore: registered new interface driver cdc_acm [ 9.154510] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 9.162933] Initializing USB Mass Storage driver... [ 9.168395] usbcore: registered new interface driver usb-storage [ 9.174743] USB Mass Storage support registered. [ 9.180023] usbcore: registered new interface driver usbserial [ 9.186340] USB Serial support registered for generic [ 9.191802] usbcore: registered new interface driver usbserial_generic [ 9.198730] usbserial: USB Serial Driver core [ 9.203491] USB Serial support registered for GSM modem (1-port) [ 9.210174] usbcore: registered new interface driver option [ 9.216094] option: v0.7.2:USB Driver for GSM modems [ 9.224975] gadget: Mass Storage Function, version: 2009/09/11 [ 9.231231] gadget: Number of LUNs=1 [ 9.235137] lun0: LUN: removable file: (no medium) [ 9.240844] gadget: android_usb ready [ 9.244873] musb-hdrc musb-hdrc.0: MUSB HDRC host driver [ 9.250610] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2 [ 9.258666] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 9.265869] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 9.273529] usb usb2: Product: MUSB HDRC host driver [ 9.278778] usb usb2: Manufacturer: Linux 3.2.0-00274-g03a35a5-dirty musb-hcd [ 9.286315] usb usb2: SerialNumber: musb-hdrc.0 [ 9.292205] hub 2-0:1.0: USB hub found [ 9.296234] hub 2-0:1.0: 1 port detected [ 9.301971] mousedev: PS/2 mouse device common for all mice [ 9.309356] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input0 [ 9.319213] using rtc device, am33xx-rtc, for alarms [ 9.324462] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as rtc0 [ 9.331939] i2c /dev entries driver [ 9.336120] Linux video capture interface: v2.00 [ 9.341613] usbcore: registered new interface driver uvcvideo [ 9.347747] USB Video Class driver (1.1.1) [ 9.613464] usb 2-1: new high-speed USB device number 2 using musb-hdrc [ 9.755004] usb 2-1: New USB device found, idVendor=05e3, idProduct=0608 [ 9.762115] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 9.769653] usb 2-1: Product: USB2.0 Hub [ 9.775329] hub 2-1:1.0: USB hub found [ 9.779663] hub 2-1:1.0: 4 ports detected [ 10.343444] omap_i2c omap_i2c.1: controller timed out [ 11.363739] omap_i2c omap_i2c.1: controller timed out [ 12.383422] omap_i2c omap_i2c.1: controller timed out [ 13.403686] omap_i2c omap_i2c.1: controller timed out [ 14.423461] omap_i2c omap_i2c.1: controller timed out [ 15.443420] omap_i2c omap_i2c.1: controller timed out [ 16.463562] omap_i2c omap_i2c.1: controller timed out [ 17.483428] omap_i2c omap_i2c.1: controller timed out [ 17.504608] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 17.511383] device-mapper: uevent: version 1.0.3 [ 17.516754] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com [ 17.525695] Bluetooth: HCI UART driver ver 2.2 [ 17.530395] Bluetooth: HCI H4 protocol initialized [ 17.535491] Bluetooth: HCILL protocol initialized [ 17.540435] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0 [ 17.547424] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator [ 17.556274] cpuidle: using governor ladder [ 17.560913] cpuidle: using governor menu [ 17.570709] usbcore: registered new interface driver usbhid [ 17.576690] usbhid: USB HID core driver [ 17.581695] logger: created 256K log 'log_main' [ 17.586791] logger: created 256K log 'log_events' [ 17.592010] logger: created 256K log 'log_radio' [ 17.597106] logger: created 256K log 'log_system' [ 17.603271] tiadc tiadc: attached adc driver [ 17.608703] usbcore: registered new interface driver snd-usb-audio [ 17.674438] mmc0: host does not support reading read-only switch. assuming write-enable. [ 17.684967] mmc0: new high speed SDHC card at address b368 [ 17.691680] mmcblk0: mmc0:b368 USD 7.45 GiB [ 17.698577] mmcblk0: p1 p2 [ 17.738067] mmc1: card claims to support voltages below the defined range. These will be ignored. [ 17.758453] mmc1: queuing unknown CIS tuple 0x91 (3 bytes) [ 17.766082] mmc1: new SDIO card at address 0001 [ 18.613464] omap_i2c omap_i2c.1: controller timed out [ 19.633758] omap_i2c omap_i2c.1: controller timed out [ 20.653472] omap_i2c omap_i2c.1: controller timed out [ 21.673461] omap_i2c omap_i2c.1: controller timed out [ 22.693634] omap_i2c omap_i2c.1: controller timed out [ 23.713470] omap_i2c omap_i2c.1: controller timed out [ 24.733459] omap_i2c omap_i2c.1: controller timed out [ 25.753631] omap_i2c omap_i2c.1: controller timed out [ 26.773468] omap_i2c omap_i2c.1: controller timed out [ 27.793457] omap_i2c omap_i2c.1: controller timed out [ 28.813537] omap_i2c omap_i2c.1: controller timed out [ 29.833465] omap_i2c omap_i2c.1: controller timed out [ 30.853454] omap_i2c omap_i2c.1: controller timed out [ 31.873565] omap_i2c omap_i2c.1: controller timed out [ 32.893463] omap_i2c omap_i2c.1: controller timed out [ 33.913482] omap_i2c omap_i2c.1: controller timed out [ 34.933532] omap_i2c omap_i2c.1: controller timed out [ 35.953460] omap_i2c omap_i2c.1: controller timed out [ 36.973449] omap_i2c omap_i2c.1: controller timed out [ 37.993560] omap_i2c omap_i2c.1: controller timed out [ 39.013458] omap_i2c omap_i2c.1: controller timed out [ 40.033447] omap_i2c omap_i2c.1: controller timed out [ 41.053527] omap_i2c omap_i2c.1: controller timed out [ 42.073455] omap_i2c omap_i2c.1: controller timed out [ 43.093444] omap_i2c omap_i2c.1: controller timed out [ 44.113555] omap_i2c omap_i2c.1: controller timed out [ 45.133453] omap_i2c omap_i2c.1: controller timed out [ 46.153533] omap_i2c omap_i2c.1: controller timed out [ 47.173461] omap_i2c omap_i2c.1: controller timed out [ 48.193420] omap_i2c omap_i2c.1: controller timed out [ 49.213439] omap_i2c omap_i2c.1: controller timed out [ 50.233520] omap_i2c omap_i2c.1: controller timed out [ 51.253479] omap_i2c omap_i2c.1: controller timed out [ 52.273559] omap_i2c omap_i2c.1: controller timed out [ 53.293457] omap_i2c omap_i2c.1: controller timed out [ 54.313415] omap_i2c omap_i2c.1: controller timed out [ 55.333435] omap_i2c omap_i2c.1: controller timed out [ 56.353546] omap_i2c omap_i2c.1: controller timed out [ 57.373443] omap_i2c omap_i2c.1: controller timed out [ 58.393524] omap_i2c omap_i2c.1: controller timed out [ 59.413452] omap_i2c omap_i2c.1: controller timed out [ 60.433441] omap_i2c omap_i2c.1: controller timed out [ 61.453552] omap_i2c omap_i2c.1: controller timed out [ 62.473449] omap_i2c omap_i2c.1: controller timed out [ 63.493438] omap_i2c omap_i2c.1: controller timed out [ 64.513519] omap_i2c omap_i2c.1: controller timed out [ 65.533447] omap_i2c omap_i2c.1: controller timed out [ 66.553466] omap_i2c omap_i2c.1: controller timed out [ 67.573547] omap_i2c omap_i2c.1: controller timed out [ 68.593444] omap_i2c omap_i2c.1: controller timed out [ 69.613433] omap_i2c omap_i2c.1: controller timed out [ 70.633514] omap_i2c omap_i2c.1: controller timed out [ 71.653442] omap_i2c omap_i2c.1: controller timed out [ 72.673431] omap_i2c omap_i2c.1: controller timed out [ 73.693572] omap_i2c omap_i2c.1: controller timed out [ 74.713470] omap_i2c omap_i2c.1: controller timed out [ 75.733459] omap_i2c omap_i2c.1: controller timed out [ 76.753509] omap_i2c omap_i2c.1: controller timed out [ 77.773437] omap_i2c omap_i2c.1: controller timed out [ 78.793457] omap_i2c omap_i2c.1: controller timed out [ 79.813537] omap_i2c omap_i2c.1: controller timed out [ 80.833465] omap_i2c omap_i2c.1: controller timed out [ 81.853454] omap_i2c omap_i2c.1: controller timed out [ 82.873504] omap_i2c omap_i2c.1: controller timed out [ 83.893463] omap_i2c omap_i2c.1: controller timed out [ 84.913452] omap_i2c omap_i2c.1: controller timed out [ 85.933593] omap_i2c omap_i2c.1: controller timed out [ 86.953460] omap_i2c omap_i2c.1: controller timed out [ 87.973449] omap_i2c omap_i2c.1: controller timed out [ 88.993530] omap_i2c omap_i2c.1: controller timed out [ 90.013458] omap_i2c omap_i2c.1: controller timed out [ 91.033447] omap_i2c omap_i2c.1: controller timed out [ 92.053588] omap_i2c omap_i2c.1: controller timed out [ 93.073455] omap_i2c omap_i2c.1: controller timed out [ 94.093444] omap_i2c omap_i2c.1: controller timed out [ 95.113555] omap_i2c omap_i2c.1: controller timed out [ 96.133483] omap_i2c omap_i2c.1: controller timed out [ 97.153594] omap_i2c omap_i2c.1: controller timed out [ 98.173583] omap_i2c omap_i2c.1: controller timed out [ 98.195159] asoc: tlv320aic32x4-hifi <-> davinci-mcasp.1 mapping ok [ 98.203582] ALSA device list: [ 98.206756] #0: AM335X EVM [ 98.209777] oprofile: hardware counters not available [ 98.215148] oprofile: using timer interrupt. [ 98.219909] Netfilter messages via NETLINK v0.30. [ 98.225128] nf_conntrack version 0.5.0 (7967 buckets, 31868 max) [ 98.232238] ctnetlink v0.93: registering with nfnetlink. [ 98.238037] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 98.245391] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 98.252227] xt_time: kernel timezone is -0000 [ 98.257354] ip_tables: (C) 2000-2006 Netfilter Core Team [ 98.263488] arp_tables: (C) 2002 David S. Miller [ 98.268524] TCP cubic registered [ 98.272277] NET: Registered protocol family 10 [ 98.278686] Mobile IPv6 [ 98.281372] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 98.287536] IPv6 over IPv4 tunneling driver [ 98.293304] NET: Registered protocol family 17 [ 98.298156] NET: Registered protocol family 15 [ 98.302856] can: controller area network core (rev 20090105 abi 8) [ 98.309631] NET: Registered protocol family 29 [ 98.314392] can: raw protocol (rev 20090105) [ 98.318878] can: broadcast manager protocol (rev 20090105 t) [ 98.325256] Bluetooth: RFCOMM TTY layer initialized [ 98.330474] Bluetooth: RFCOMM socket layer initialized [ 98.335937] Bluetooth: RFCOMM ver 1.11 [ 98.339904] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 98.345520] Bluetooth: BNEP filters: protocol multicast [ 98.351043] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 98.357666] Registering the dns_resolver key type [ 98.362731] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 98.370910] ThumbEE CPU extension supported. [ 98.375549] mux: Failed to setup hwmod io irq -22 [ 98.381896] Power Management for AM33XX family [ 98.387023] Trying to load am335x-pm-firmware.bin (60 secs timeout) [ 98.393920] Copied the M3 firmware to UMEM [ 98.398406] Cortex M3 Firmware Version = 0x181 [ 98.412200] clock: disabling unused clocks to save power [ 98.420776] Detected MACID=1c:ba:8c:96:42:75 [ 98.427581] cpsw: Detected MACID = 1c:ba:8c:96:42:77 [ 98.436859] input: gpio-keys as /devices/platform/gpio-keys/input/input1 [ 98.444763] omap_rtc am33xx-rtc: setting system clock to 2000-01-01 00:01:30 UTC (946684890) [ 98.461242] kjournald starting. Commit interval 5 seconds [ 98.475952] EXT3-fs (mmcblk0p2): using internal journal [ 98.481506] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode [ 98.488891] VFS: Mounted root (ext3 filesystem) on device 179:2. [ 98.496368] Freeing init memory: 344K [ 99.140991] init: ureadahead main process (88) terminated with status 5 [ 105.854431] omap_i2c omap_i2c.1: controller timed out [ 106.894470] omap_i2c omap_i2c.1: controller timed out [ 107.924407] omap_i2c omap_i2c.1: controller timed out [ 108.944396] omap_i2c omap_i2c.1: controller timed out [ 109.965972] omap_i2c omap_i2c.1: controller timed out [ 110.984436] omap_i2c omap_i2c.1: controller timed out [ 112.005981] omap_i2c omap_i2c.1: controller timed out /bin/wig_tune_cpufreq: line 3: cd: /sys/devices/system/cpu/cpu0/cpufreq: No such file or directory [ 113.034606] omap_i2c omap_i2c.1: controller timed out Ubuntu 12.04.4 LTS ubuntu-armhf ttyO0 ubuntu-armhf login: root Password: [ 114.054382] omap_i2c omap_i2c.1: controller timed out [ 115.074371] omap_i2c omap_i2c.1: controller timed out [ 116.094360] omap_i2c omap_i2c.1: controller timed out [ 117.114349] omap_i2c omap_i2c.1: controller timed out [ 118.134368] omap_i2c omap_i2c.1: controller timed out [ 119.154357] omap_i2c omap_i2c.1: controller timed out [ 120.204376] omap_i2c omap_i2c.1: controller timed out [ 121.224395] omap_i2c omap_i2c.1: controller timed out Login incorrect ubuntu-armhf login: r[ 122.244354] omap_i2c omap_i2c.1: controller timed out [ 123.264373] omap_i2c omap_i2c.1: controller timed out [ 124.284362] omap_i2c omap_i2c.1: controller timed out [ 125.304382] omap_i2c omap_i2c.1: controller timed out [ 126.324371] omap_i2c omap_i2c.1: controller timed out [ 127.344360] omap_i2c omap_i2c.1: controller timed out oot[ 128.394439] omap_i2c omap_i2c.1: controller timed out Password: [ 129.414367] omap_i2c omap_i2c.1: controller timed out [ 130.434417] omap_i2c omap_i2c.1: controller timed out [ 131.454467] omap_i2c omap_i2c.1: controller timed out [ 132.494415] omap_i2c omap_i2c.1: controller timed out [ 133.524444] omap_i2c omap_i2c.1: controller timed out [ 134.554412] omap_i2c omap_i2c.1: controller timed out [ 135.584381] omap_i2c omap_i2c.1: controller timed out Last login: Sat Jan 1 00:01:12 UTC 2000 on ttyO0 [ 136.604400] omap_i2c omap_i2c.1: controller timed out [ 137.624389] omap_i2c omap_i2c.1: controller timed out Welcome to Ubuntu 12.04.4 LTS (GNU/Linux 3.2.0-00274-g03a35a5-dirty armv7l) * Documentation: https://help.ubuntu.com/ [ 138.644683] omap_i2c omap_i2c.1: controller timed out [ 139.664764] omap_i2c omap_i2c.1: controller timed out [ 140.684448] omap_i2c omap_i2c.1: controller timed out root@ubuntu-armhf:~# root@ubuntu-armhf:~# [ 141.704467] omap_i2c omap_i2c.1: controller timed out [ 142.724426] omap_i2c omap_i2c.1: controller timed out [ 143.744354] omap_i2c omap_i2c.1: controller timed out [ 144.764617] omap_i2c omap_i2c.1: controller timed out [ 145.784362] omap_i2c omap_i2c.1: controller timed out [ 146.804351] omap_i2c omap_i2c.1: controller timed out [ 147.824371] omap_i2c omap_i2c.1: controller timed out [ 148.844421] omap_i2c omap_i2c.1: controller timed out [ 149.864379] omap_i2c omap_i2c.1: controller timed out [ 149.884460] Right Input Mixer DAPM update failed: -1 [ 150.884368] omap_i2c omap_i2c.1: controller timed out [ 151.904418] omap_i2c omap_i2c.1: controller timed out [ 152.924407] omap_i2c omap_i2c.1: controller timed out [ 152.944427] Right Input Mixer DAPM update failed: -1 [ 153.944396] omap_i2c omap_i2c.1: controller timed out [ 154.964416] omap_i2c omap_i2c.1: controller timed out [ 155.985046] omap_i2c omap_i2c.1: controller timed out [ 156.004425] Right Input Mixer DAPM update failed: -1 [ 157.004364] omap_i2c omap_i2c.1: controller timed out [ 158.024383] omap_i2c omap_i2c.1: controller timed out [ 159.044372] omap_i2c omap_i2c.1: controller timed out [ 159.064422] Left Input Mixer DAPM update failed: -1 [ 160.064361] omap_i2c omap_i2c.1: controller timed out [ 161.084381] omap_i2c omap_i2c.1: controller timed out [ 162.104370] omap_i2c omap_i2c.1: controller timed out [ 162.126495] Left Input Mixer DAPM update failed: -1 [ 163.124359] omap_i2c omap_i2c.1: controller timed out [ 164.144409] omap_i2c omap_i2c.1: controller timed out [ 165.164398] omap_i2c omap_i2c.1: controller timed out [ 165.184448] Left Input Mixer DAPM update failed: -1 [ 166.184356] omap_i2c omap_i2c.1: controller timed out [ 167.224365] omap_i2c omap_i2c.1: controller timed out [ 168.244354] omap_i2c omap_i2c.1: controller timed out [ 169.284820] omap_i2c omap_i2c.1: controller timed out [ 170.304351] omap_i2c omap_i2c.1: controller timed out [ 170.324462] Right Input Mixer DAPM update failed: -1 [ 171.324401] omap_i2c omap_i2c.1: controller timed out [ 172.344390] omap_i2c omap_i2c.1: controller timed out [ 172.364471] Right Input Mixer DAPM update failed: -1 [ 173.364379] omap_i2c omap_i2c.1: controller timed out [ 174.384368] omap_i2c omap_i2c.1: controller timed out [ 174.404449] Right Input Mixer DAPM update failed: -1 [ 175.404357] omap_i2c omap_i2c.1: controller timed out [ 176.424346] omap_i2c omap_i2c.1: controller timed out [ 176.444427] Left Input Mixer DAPM update failed: -1 [ 177.444396] omap_i2c omap_i2c.1: controller timed out [ 178.464355] omap_i2c omap_i2c.1: controller timed out [ 178.484436] Left Input Mixer DAPM update failed: -1 [ 179.484375] omap_i2c omap_i2c.1: controller timed out [ 180.504364] omap_i2c omap_i2c.1: controller timed out [ 180.524566] Left Input Mixer DAPM update failed: -1 [ 181.524353] omap_i2c omap_i2c.1: controller timed out [ 182.544372] omap_i2c omap_i2c.1: controller timed out [ 182.564422] LOR Output Mixer DAPM update failed: -1 [ 183.564392] omap_i2c omap_i2c.1: controller timed out [ 184.584350] omap_i2c omap_i2c.1: controller timed out [ 184.604431] HPR Output Mixer DAPM update failed: -1 [ 185.604370] omap_i2c omap_i2c.1: controller timed out [ 186.624389] omap_i2c omap_i2c.1: controller timed out [ 187.644348] omap_i2c omap_i2c.1: controller timed out [ 187.664459] HPR Output Mixer DAPM update failed: -1 [ 188.664367] omap_i2c omap_i2c.1: controller timed out [ 189.684387] omap_i2c omap_i2c.1: controller timed out [ 189.704437] LOL Output Mixer DAPM update failed: -1 [ 190.704406] omap_i2c omap_i2c.1: controller timed out [ 191.724365] omap_i2c omap_i2c.1: controller timed out [ 191.744384] HPL Output Mixer DAPM update failed: -1 [ 192.744415] omap_i2c omap_i2c.1: controller timed out [ 193.764404] omap_i2c omap_i2c.1: controller timed out [ 194.784362] omap_i2c omap_i2c.1: controller timed out [ 194.804412] HPL Output Mixer DAPM update failed: -1
