Part Number: SK-AM62
Other Parts Discussed in Thread: AM625
经过快速入门选择SD卡写入WIC Image镜像后,关机再次重启会出现内核错误,如何正确关机?
日志如下
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~# /etc/init.d/weston restart
Stopping Weston
Starting Weston
Waiting for input device...
root@am62xx-evm:~#
root@am62xx-evm:~# [ 1926.169420] omap_i2c 20010000.i2c: controller timed out
/etc/init.d/weston restart[ 1929.241393] omap_i2c 20010000.i2c: controller timed out
root@am62xx-evm:~# ifconfig[ 1932.313369] omap_i2c 20010000.i2c: controller timed out
/etc/init.d/weston restart[ 1935.385369] omap_i2c 20010000.i2c: controller timed out
root@am62xx-evm:~# /etc/init.d/weston restart[ 1938.457430] omap_i2c 20010000.i2c: controller timed out
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 metric 1
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:23:dc:bf:54 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 metric 1
ether 34:08:e1:80:87:08 txqueuelen 1000 (Ethernet)
eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 metric 1
inet6 fe80::c4fe:4eff:fe4b:ff3b prefixlen 64 scopeid 0x20<link>
ether c6:fe:4e:4b:ff:3b txqueuelen 1000 (Ethernet)
RX packets 126 bytes 19058 (18.6 KiB)
TX packets 58 bytes 11956 (11.6 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 metric 1
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 82 bytes 6220 (6.0 KiB)
TX packets 82 bytes 6220 (6.0 KiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 metric 1
ether 3c:e4:b0:74:0f:5c txqueuelen 1000 (Ethernet)
wlan1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 metric 1
inet 192.168.43.1 netmask 255.255.255.0 broadcast 192.168.43.255
inet6 fe80::3ee4:b0ff:fe74:f5d prefixlen 64 scopeid 0x20<link>
ether 3c:e4:b0:74:0f:5d txqueuelen 1000 (Ethernet)
RX packets 2608 bytes 215368 (210.3 KiB)
TX packets 491 bytes 226240 (220.9 KiB)
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~# /etc/init.d/matrix-gui-2.0 start
/home/root
Starting Matrix GUI application.
root@am62xx-evm:~# [ 2063.256614] startwlanap.sh[881]: wlan1: AP-STA-DISCONNECTED 58:fb:84:73:c9:9f
[ 2223.789354] usb 1-1: new low-speed USB device number 2 using xhci-hcd
[ 2223.940664] usb 1-1: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[ 2223.940691] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2223.940699] usb 1-1: Product: USB Optical Mouse
[ 2223.940703] usb 1-1: Manufacturer: PixArt
[ 2223.985825] input: PixArt USB Optical Mouse as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.3.auto/usb1/1-1/1-1:1.0/0003:093A:2510.0001/input/input0
[ 2223.986168] hid-generic 0003:093A:2510.0001: input: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-xhci-hcd.3.auto-1/input0
[ 2223.987805] usbcore: registered new interface driver usbhid
[ 2223.987824] usbhid: USB HID core driver
[ 2233.817366] omap_i2c 20010000.i2c: controller timed out
[ 2236.889372] omap_i2c 20010000.i2c: controller timed out
[ 2239.961370] omap_i2c 20010000.i2c: controller timed out
[ 2243.033401] omap_i2c 20010000.i2c: controller timed out
[ 2246.105385] omap_i2c 20010000.i2c: controller timed out
root@am62xx-evm:~# [ 2266.553447] omap_i2c 20010000.i2c: controller timed out
root@am62xx-evm:~# [ 2269.625463] omap_i2c 20010000.i2c: controller timed out
[ 2272.665390] omap_i2c 20010000.i2c: controller timed out
[ 2275.737377] omap_i2c 20010000.i2c: controller timed out
[ 2278.809373] omap_i2c 20010000.i2c: controller timed out
[ 2278.848233] alloc_contig_range: [dd600, dd900) PFNs busy
[ 2278.848745] alloc_contig_range: [dd600, dda00) PFNs busy
[ 2278.848867] alloc_contig_range: [dd800, ddb00) PFNs busy
root@am62xx-evm:~#
root@am62xx-evm:~# java -veresion
-sh: java: command not found
root@am62xx-evm:~# java -version
root@am62xx-evm:~# php -v
PHP 7.4.33 (cli) (built: Feb 24 2023 07:39:25) ( NTS )
Copyright (c) The PHP Group
Zend Engine v3.4.0, Copyright (c) Zend Technologies
root@am62xx-evm:~# shut down -h now
-sh: shut: command not found
root@am62xx-evm:~# shutdown -h now
Stopping Session c1 of user root.
[ OK ] Removed slice system-systemd\x2dcoredump.slice.
[ OK ] Stopped target Multi-User System.
[ OK ] Stopped target Login Prompts.
[ OK ] Stopped target RPC Port Mapper.
[ OK ] Stopped target Sound Card.
[ OK ] Stopped target Timers.
[ OK ] Stopped Daily rotation of log files.
[ OK ] Stopped Daily Cleanup of Temporary Directories.
[ OK ] Stopped target Hardware activated USB gadget.
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopping Save/Restore Sound Card State...
Stopping Job spooling tools...
Stopping Avahi mDNS/DNS-SD Stack...
Stopping Periodic Command Scheduler...
Stopping Docker Application Container Engine...
Stopping Getty on tty1...
Stopping irqbalance daemon...
Stopping Reboot and dump vmcore via kexec...
Stopping Lighttpd Daemon...
Stopping NFS status monitor for NFSv2/3 locking....
Stopping Serial Getty on ttyS2...
Stopping Simple Network Ma…ent Protocol (SNMP) Daemon....
[ OK ] Stopped startwlanap.
[ OK ] Stopped startwlansta.
Stopping strongSwan IPsec …Ev2 daemon using ipsec.conf...
Stopping Load/Save Random Seed...
Stopping TEE Supplicant...
Stopping thermal-zone-init.service...
[ OK ] Stopped Job spooling tools.
[ OK ] Stopped Periodic Command Scheduler.
[ OK ] Stopped irqbalance daemon.
[ OK ] Stopped TEE Supplicant.
[ OK ] Stopped Avahi mDNS/DNS-SD Stack.
[ OK ] Stopped NFS status monitor for NFSv2/3 locking..
[ OK ] Stopped Simple Network Man…ement Protocol (SNMP) Daemon..
[ OK ] Stopped Getty on tty1.
[ OK ] Stopped Serial Getty on ttyS2.
[ OK ] Stopped strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
[ OK ] Stopped Lighttpd Daemon.
[ OK ] Stopped Save/Restore Sound Card State.
[ OK ] Stopped Reboot and dump vmcore via kexec.
[ OK ] Stopped Load/Save Random Seed.
[ OK ] Stopped thermal-zone-init.service.
[ OK ] Stopped Session c1 of user root.
[ OK ] Removed slice system-getty.slice.
[ OK ] Removed slice system-serial\x2dgetty.slice.
Stopping LSB: start and stop docker...
Stopping LSB: network benchmark...
Stopping LSB: Expand Rootfs of boot device...
Stopping Login Service...
Stopping User Manager for UID 0...
[ OK ] Stopped LSB: network benchmark.
[ OK ] Stopped LSB: start and stop docker.
[ OK ] Stopped LSB: Expand Rootfs of boot device.
[ OK ] Stopped target Host and Network Name Lookups.
[ OK ] Stopped target System Time Synchronized.
[ OK ] Stopped target System Time Set.
Stopping telnetd.service...
[ OK ] Stopped User Manager for UID 0.
[ OK ] Stopped telnetd.service.
Stopping User Runtime Directory /run/user/0...
Stopping weston.service...
[ OK ] Unmounted /run/user/0.
[ OK ] Stopped Login Service.
[ OK ] Stopped User Runtime Directory /run/user/0.
[ OK ] Stopped Docker Application Container Engine.
[ OK ] Stopped weston.service.
[ OK ] Removed slice User Slice of UID 0.
[ OK ] Stopped target Network is Online.
Stopping D-Bus System Message Bus...
Stopping rc.pvr.service...
Stopping Permit User Sessions...
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped Permit User Sessions.
[ OK ] Stopped target Network.
[ OK ] Stopped target Remote File Systems.
Stopping Network Name Resolution...
[ OK ] Stopped Network Name Resolution.
Stopping Network Service...
[ OK ] Stopped Network Service.
[ OK ] Stopped target Network (Pre).
[ OK ] Stopped IPv6 Packet Filtering Framework.
[ OK ] Stopped IPv4 Packet Filtering Framework.
[ OK ] Stopped rc.pvr.service.
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Paths.
[ OK ] Stopped Dispatch Password …ts to Console Directory Watch.
[ OK ] Stopped Forward Password R…uests to Wall Directory Watch.
[ OK ] Stopped target Slices.
[ OK ] Removed slice User and Session Slice.
[ OK ] Stopped target Sockets.
[ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Closed Docker Socket for the API.
[ OK ] Closed dropbear.socket.
[ OK ] Stopped target System Initialization.
Stopping Hardware RNG Entropy Gatherer Daemon...
[ OK ] Stopped Apply Kernel Variables.
[ OK ] Stopped Load Kernel Modules.
Stopping Network Time Synchronization...
[ OK ] Stopped Update is Completed.
[ OK ] Stopped Rebuild Dynamic Linker Cache.
[ OK ] Stopped Rebuild Journal Catalog.
[ OK ] Stopped Network Time Synchronization.
[ OK ] Stopped Hardware RNG Entropy Gatherer Daemon.
[ OK ] Stopped Create Volatile Files and Directories.
[ OK ] Stopped target Local File Systems.
Unmounting /media/mmcblk1p1...
Unmounting /media/ram...
Unmounting /run/media/mmcblk0p1...
Unmounting /run/media/mmcblk1p1...
Unmounting Temporary Directory (/tmp)...
Unmounting /var/volatile...
[ OK ] Unmounted /media/mmcblk1p1.
[ OK ] Unmounted /media/ram.
[ OK ] Unmounted /run/media/mmcblk0p1.
[ OK ] Unmounted /run/media/mmcblk1p1.
[ OK ] Unmounted Temporary Directory (/tmp).
[ OK ] Unmounted /var/volatile.
[ OK ] Stopped target Swap.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped File System Check on /dev/mmcblk0p1.
[ OK ] Stopped File System Check on /dev/mmcblk1p1.
[ OK ] Removed slice system-systemd\x2dfsck.slice.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Stopped Create System Users.
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Reached target Shutdown.
[ OK ] Reached target Final Step.
[ OK ] Started Power-Off.
[ OK ] Reached target Power-Off.
[ 2537.639757] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 2541.647582] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 2541.662460] systemd-journald[231]: Failed to send WATCHDOG=1 notification message: Connection refused
[ 2541.663584] systemd-journald[231]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 2541.857366] wlcore: down
[ 2541.861887] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 2541.877706] systemd-shutdown[1]: Unmounting file systems.
[ 2541.880741] [2056]: Remounting '/' read-only in with options '(null)'.
[ 2543.441561] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 2543.457392] systemd-shutdown[1]: All filesystems unmounted.
[ 2543.457431] systemd-shutdown[1]: Deactivating swaps.
[ 2543.457692] systemd-shutdown[1]: All swaps deactivated.
[ 2543.457705] systemd-shutdown[1]: Detaching loop devices.
[ 2543.461210] systemd-shutdown[1]: All loop devices detached.
[ 2543.461226] systemd-shutdown[1]: Detaching DM devices.
[ 2543.461758] systemd-shutdown[1]: All DM devices detached.
[ 2543.461777] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
[ 2543.471573] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 2543.473145] systemd-shutdown[1]: Powering off.
[ 2543.562171] reboot: Power down
[ 2543.562189] printk: enabled sync mode
[ 2543.568985] printk: console [ttyS2]: printing thread stopped
ERROR: System Off: operation not handled.
U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:37:51 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
SPL initial stack usage: 13424 bytes
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Starting ATF on ARM64 core...
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE: BL31: Built : 05:33:19, Feb 24 2023
U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:36:12 +0000)
U-Boot 2021.01-g2ee8efd654 (Feb 24 2023 - 05:36:12 +0000)
SoC: AM62X SR1.0 GP
Model: Texas Instruments AM625 SK
EEPROM not available at 0x50, trying to read at 0x51
Board: AM62-SKEVM rev E3
DRAM: 2 GiB
MMC: mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
Loading Environment from MMC... OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: eth0: ethernet@8000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
1490 bytes read in 3 ms (484.4 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
1 bytes read in 3 ms (0 Bytes/s)
Already setup.
18862592 bytes read in 219 ms (82.1 MiB/s)
55666 bytes read in 5 ms (10.6 MiB/s)
## Flattened Device Tree blob at 88000000
Booting using the fdt blob at 0x88000000
Loading Device Tree to 000000008feef000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.10.168-rt83-gc1a1291911 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT_RT Fri Feb 24 05:50:07 UTC 2023
[ 0.000000] Machine model: Texas Instruments AM625 SK
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff]
[ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] On node 0 totalpages: 524288
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] cma: Reserved 512 MiB at 0x00000000dd000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 18 pages/cpu s35392 r8192 d30144 u73728
[ 0.000000] pcpu-alloc: s35392 r8192 d30144 u73728 alloc=18*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=df340b09-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1456224K/2097152K available (11008K kernel code, 1204K rwdata, 4272K rodata, 1792K init, 438K bss, 116640K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080030000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008533] Console: colour dummy device 80x25
[ 0.013127] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023807] pid_max: default: 32768 minimum: 301
[ 0.028630] LSM: Security Framework initializing
[ 0.033430] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.041013] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.051019] rcu: Hierarchical SRCU implementation.
[ 0.056465] Platform MSI: msi-controller@1820000 domain created
[ 0.062858] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.072152] EFI services will not be available.
[ 0.077112] smp: Bringing up secondary CPUs ...
[ 0.082530] Detected VIPT I-cache on CPU1
[ 0.086665] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.093701] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
[ 0.101135] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.108691] Detected VIPT I-cache on CPU2
[ 0.112815] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.119847] GICv3: CPU2: using allocated LPI pending table @0x0000000080060000
[ 0.127266] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.134752] Detected VIPT I-cache on CPU3
[ 0.138874] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.145907] GICv3: CPU3: using allocated LPI pending table @0x0000000080070000
[ 0.153321] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.160090] smp: Brought up 1 node, 4 CPUs
[ 0.164295] SMP: Total of 4 processors activated.
[ 0.169113] CPU features: detected: 32-bit EL0 Support
[ 0.174374] CPU features: detected: CRC32 instructions
[ 0.186792] CPU: All CPU(s) started at EL2
[ 0.190998] alternatives: patching kernel code
[ 0.196753] devtmpfs: initialized
[ 0.208382] KASLR disabled due to lack of seed
[ 0.213105] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.223084] futex hash table entries: 1024 (order: 5, 131072 bytes, linear)
[ 0.244841] pinctrl core: initialized pinctrl subsystem
[ 0.250809] DMI not present or invalid.
[ 0.255451] NET: Registered protocol family 16
[ 0.262008] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.269382] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.277486] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.286301] thermal_sys: Registered thermal governor 'step_wise'
[ 0.286919] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.300102] ASID allocator initialised with 65536 entries
[ 0.332716] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.339627] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.346491] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.353381] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.361275] cryptd: max_cpu_qlen set to 1000
[ 0.368779] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[ 0.377949] vcc_5v0: supplied by vmain_pd
[ 0.382508] vcc_3v3_sys: supplied by vmain_pd
[ 0.387476] vcc_1v8: supplied by vcc_3v3_sys
[ 0.393073] iommu: Default domain type: Translated
[ 0.398483] SCSI subsystem initialized
[ 0.402790] mc: Linux media interface: v0.10
[ 0.407194] videodev: Linux video capture interface: v2.00
[ 0.412885] pps_core: LinuxPPS API ver. 1 registered
[ 0.417960] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.427309] PTP clock support registered
[ 0.431346] EDAC MC: Ver: 3.0.0
[ 0.435308] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[ 0.442519] FPGA manager framework
[ 0.446104] Advanced Linux Sound Architecture Driver Initialized.
[ 0.453302] clocksource: Switched to clocksource arch_sys_counter
[ 0.459792] VFS: Disk quotas dquot_6.6.0
[ 0.463865] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.477051] NET: Registered protocol family 2
[ 0.481833] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.490640] tcp_listen_portaddr_hash hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.499461] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.507711] TCP bind hash table entries: 16384 (order: 7, 917504 bytes, linear)
[ 0.516102] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.523206] UDP hash table entries: 1024 (order: 5, 131072 bytes, linear)
[ 0.530332] UDP-Lite hash table entries: 1024 (order: 5, 131072 bytes, linear)
[ 0.538125] NET: Registered protocol family 1
[ 0.543225] RPC: Registered named UNIX socket transport module.
[ 0.549329] RPC: Registered udp transport module.
[ 0.554140] RPC: Registered tcp transport module.
[ 0.558947] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.565553] NET: Registered protocol family 44
[ 0.570112] PCI: CLS 0 bytes, default 64
[ 0.575057] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.587474] Initialise system trusted keyrings
[ 0.592274] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.603613] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.610333] NFS: Registering the id_resolver key type
[ 0.615584] Key type id_resolver registered
[ 0.619874] Key type id_legacy registered
[ 0.624069] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.630933] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.638745] 9p: Installing v9fs 9p2000 file system support
[ 0.679932] Key type asymmetric registered
[ 0.684156] Asymmetric key parser 'x509' registered
[ 0.689200] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.696784] io scheduler mq-deadline registered
[ 0.701437] io scheduler kyber registered
[ 0.707865] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.714316] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.728696] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.750286] brd: module loaded
[ 0.762405] loop: module loaded
[ 0.766631] megasas: 07.714.04.00-rc1
[ 0.774663] tun: Universal TUN/TAP device driver, 1.6
[ 0.780498] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.786943] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.793068] sky2: driver version 1.30
[ 0.797904] VFIO - User Level meta-driver version: 0.3
[ 0.804331] i2c /dev entries driver
[ 0.809132] sdhci: Secure Digital Host Controller Interface driver
[ 0.815473] sdhci: Copyright(c) Pierre Ossman
[ 0.820314] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.827540] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.835854] optee: probing for conduit method.
[ 0.840496] optee: revision 3.20 (8e74d476)
[ 0.840802] optee: dynamic shared memory is enabled
[ 0.850321] optee: initialized driver
[ 0.856278] NET: Registered protocol family 17
[ 0.861043] 9pnet: Installing 9P2000 support
[ 0.865535] Key type dns_resolver registered
[ 0.870319] printk: bootconsole [ns16550a0]: printing thread started
[ 0.870371] Loading compiled-in X.509 certificates
[ 0.883087] ti-sci 44043000.system-controller: lpm region is required for suspend but not provided.
[ 0.883175] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
[ 0.948648] davinci-mcasp 2b10000.mcasp: IRQ common not found
[ 0.951448] omap-gpmc 3b000000.memory-controller: GPMC revision 6.0
[ 0.951466] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 0.954787] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ H0.956831] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.957525] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[ 0.979739] printk: console [ttyS2]: printing thread started
[ 0.957716] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 0.979756] printk: console [ttyS2] enabled
[ 0.979760] printk: bootconsole [ns16550a0] disabled
[ 1.002572] printk: bootconsole [ns16550a0]: printing thread stopped
[ 1.008430] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.008484] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[ 1.008490] Creating 7 MTD partitions on "fc40000.spi.0":
[ 1.008496] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.010009] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.011243] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.012409] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 1.013715] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 1.014988] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.016206] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.024696] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.061318] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.063516] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.063531] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[ 1.063634] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 1.063905] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[ 1.063920] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.063927] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.064703] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[ 1.069106] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.073275] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[ 1.073424] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:07 UTC (7)
[ 1.176555] mmc0: CQHCI version 5.10
[ 1.179000] davinci-mcasp 2b10000.mcasp: IRQ common not found
[ 1.194724] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 1.194881] pca953x 1-0022: using AI
[ 1.220943] sii902x 1-003b: supply iovcc not found, using dummy regulator
[ 1.221089] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[ 1.224095] i2c i2c-1: Added multiplexed i2c bus 2
[ 1.226519] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[ 1.228371] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 1.311826] mmc0: Command Queue Engine enabled
[ 1.311850] mmc0: new HS200 MMC card at address 0001
[ 1.312581] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 1.312783] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[ 1.312983] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[ 1.313174] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[ 1.314718] mmcblk0: p1 p2
[ 4.249316] omap_i2c 20010000.i2c: controller timed out
[ 7.321313] omap_i2c 20010000.i2c: controller timed out
[ 10.393310] omap_i2c 20010000.i2c: controller timed out
[ 13.465312] omap_i2c 20010000.i2c: controller timed out
[ 16.537310] omap_i2c 20010000.i2c: controller timed out
[ 16.597220] Console: switching to colour frame buffer device 128x48
[ 16.613267] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
[ 16.622417] vdd_mmc1: supplied by vcc_3v3_sys
[ 16.624396] wlan_lten: supplied by vcc_3v3_sys
[ 16.626852] debugfs: Directory 'pd:53' with parent 'pm_genpd' already present!
[ 16.626904] wlan_en: supplied by wlan_lten
[ 16.626932] debugfs: Directory 'pd:52' with parent 'pm_genpd' already present!
[ 16.626972] debugfs: Directory 'pd:51' with parent 'pm_genpd' already present!
[ 16.627294] mmc2: CQHCI version 5.10
[ 16.627331] mmc1: CQHCI version 5.10
[ 16.627471] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 16.641940] ALSA device list:
[ 16.641956] No soundcards found.
[ 16.671957] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[ 16.677860] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
[ 16.682007] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 16.682613] Waiting for root device PARTUUID=df340b09-02...
[ 16.690787] mmc2: new high speed SDIO card at address 0001
[ 16.733508] mmc1: new ultra high speed SDR104 SDXC card at address b368
[ 16.734322] mmcblk1: mmc1:b368 NCard 58.2 GiB
[ 16.735959] mmcblk1: p1 p2
[ 16.748181] EXT4-fs (mmcblk1p2): ext4_check_descriptors: Block bitmap for group 320 not in group (block 11399762326618118)!
[ 16.748208] EXT4-fs (mmcblk1p2): group descriptors corrupted!
[ 16.748334] VFS: Cannot open root device "PARTUUID=df340b09-02" or unknown-block(179,98): error -117
[ 16.748340] Please append a correct "root=" boot option; here are the available partitions:
[ 16.748356] 0100 4096 ram0
[ 16.748361] (driver?)
[ 16.748367] 0101 4096 ram1
[ 16.748371] (driver?)
[ 16.748376] 0102 4096 ram2
[ 16.748379] (driver?)
[ 16.748384] 0103 4096 ram3
[ 16.748387] (driver?)
[ 16.748392] 0104 4096 ram4
[ 16.748395] (driver?)
[ 16.748400] 0105 4096 ram5
[ 16.748404] (driver?)
[ 16.748408] 0106 4096 ram6
[ 16.748412] (driver?)
[ 16.748416] 0107 4096 ram7
[ 16.748420] (driver?)
[ 16.748429] 0108 4096 ram8
[ 16.748432] (driver?)
[ 16.748437] 0109 4096 ram9
[ 16.748441] (driver?)
[ 16.748445] 010a 4096 ram10
[ 16.748449] (driver?)
[ 16.748454] 010b 4096 ram11
[ 16.748457] (driver?)
[ 16.748462] 010c 4096 ram12
[ 16.748465] (driver?)
[ 16.748470] 010d 4096 ram13
[ 16.748474] (driver?)
[ 16.748479] 010e 4096 ram14
[ 16.748482] (driver?)
[ 16.748487] 010f 4096 ram15
[ 16.748490] (driver?)
[ 16.748507] 1f00 512 mtdblock0
[ 16.748511] (driver?)
[ 16.748516] 1f01 2048 mtdblock1
[ 16.748520] (driver?)
[ 16.748525] 1f02 4096 mtdblock2
[ 16.748529] (driver?)
[ 16.748534] 1f03 256 mtdblock3
[ 16.748538] (driver?)
[ 16.748543] 1f04 256 mtdblock4
[ 16.748546] (driver?)
[ 16.748552] 1f05 57088 mtdblock5
[ 16.748556] (driver?)
[ 16.748561] 1f06 256 mtdblock6
[ 16.748565] (driver?)
[ 16.748574] b300 15540224 mmcblk0
[ 16.748578] driver: mmcblk
[ 16.748584] b301 16384 mmcblk0p1 28b8bf0e-01
[ 16.748588]
[ 16.748591] b302 15522816 mmcblk0p2 28b8bf0e-02
[ 16.748595]
[ 16.748603] b360 61069312 mmcblk1
[ 16.748607] driver: mmcblk
[ 16.748610] b361 136762 mmcblk1p1 df340b09-01
[ 16.748614]
[ 16.748617] b362 60931072 mmcblk1p2 df340b09-02
[ 16.748621]
[ 16.748625] Kernel panic - not syncing:
[ 16.748628] VFS: Unable to mount root fs on unknown-block(179,98)
[ 16.748633] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 5.10.168-rt83-gc1a1291911 #1
[ 16.748642] Hardware name: Texas Instruments AM625 SK (DT)
[ 16.748648] Call trace:
[ 16.748650] dump_backtrace+0x0/0x1b0
[ 16.748669] show_stack+0x18/0x38
[ 16.748677] dump_stack+0xe8/0x124
[ 16.748685] panic+0xdc/0x388
[ 16.748693] mount_block_root+0x1c4/0x254
[ 16.748703] mount_root+0x10c/0x140
[ 16.748708] prepare_namespace+0x130/0x170
[ 16.748716] kernel_init_freeable+0x26c/0x298
[ 16.748721] kernel_init+0x14/0x114
[ 16.748728] ret_from_fork+0x10/0x30
[ 17.048852] SMP: stopping secondary CPUs
[ 17.052780] Kernel Offset: disabled
[ 17.056256] CPU features: 0x00040002,2000200c
[ 17.060601] Memory Limit: none
[ 17.063649] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,98) ]---
