#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <termios.h>
#include <stdio.h>
#define BAUDRATE B115200
#define UART_DEVICE "/dev/ttyS0" //change to ttys0,originally it is ttys3
#define FALSE -1
#define TRUE 0
*@brief 设置串口通信速率
*@param fd 类型 int 打开串口的文件句柄
*@param speed 类型 int 串口速度
*@return void
int speed_arr[] = {B115200, B38400, B19200, B9600, B4800, B2400, B1200, B300,
B115200, B38400, B19200, B9600, B4800, B2400, B1200, B300, };
int name_arr[] = {115200, 38400, 19200, 9600, 4800, 2400, 1200, 300,
115200, 38400, 19200, 9600, 4800, 2400, 1200, 300, };
void set_speed(int fd, int speed){
int i;
int status;
struct termios Opt;
tcgetattr(fd, &Opt);
for ( i= 0; i < sizeof(speed_arr) / sizeof(int); i++) {
if (speed == name_arr[i]) {
tcflush(fd, TCIOFLUSH);
cfsetispeed(&Opt, speed_arr[i]);
cfsetospeed(&Opt, speed_arr[i]);
status = tcsetattr(fd, TCSANOW, &Opt);
if (status != 0) {
perror("tcsetattr fd1");
return;
tcflush(fd,TCIOFLUSH);
*@brief 设置串口数据位,停止位和效验位
*@param fd 类型 int 打开的串口文件句柄
*@param databits 类型 int 数据位 取值 为 7 或者8
*@param stopbits 类型 int 停止位 取值为 1 或者2
*@param parity 类型 int 效验类型 取值为N,E,O,,S
int set_Parity(int fd,int databits,int stopbits,int parity)
struct termios options;
if ( tcgetattr( fd,&options) != 0) {
perror("SetupSerial 1");
return(FALSE);
options.c_cflag &= ~CSIZE;
switch (databits) /*设置数据位数*/
case 7:
options.c_cflag |= CS7;
break;
case 8:
options.c_cflag |= CS8;
break;
default:
fprintf(stderr,"Unsupported data size\n"); return (FALSE);
switch (parity)
case 'n':
case 'N':
options.c_cflag &= ~PARENB; /* Clear parity enable */
options.c_iflag &= ~INPCK; /* Enable parity checking */
break;
case 'o':
case 'O':
options.c_cflag |= (PARODD | PARENB); /* 设置为奇效验*/
options.c_iflag |= INPCK; /* Disnable parity checking */
break;
case 'e':
case 'E':
options.c_cflag |= PARENB; /* Enable parity */
options.c_cflag &= ~PARODD; /* 转换为偶效验*/
break;
case 'S':
case 's': /*as no parity*/
options.c_cflag &= ~CSTOPB;break;
default:
fprintf(stderr,"Unsupported parity\n");
return (FALSE);
/* 设置停止位*/
switch (stopbits)
case 1:
break;
case 2:
options.c_cflag |= CSTOPB;
break;
default:
fprintf(stderr,"Unsupported stop bits\n");
return (FALSE);
/* Set input parity option */
if (parity != 'n')
tcflush(fd,TCIFLUSH);
options.c_cc[VTIME] = 150; /* 设置超时15 seconds*/
options.c_cc[VMIN] = 0; /* Update the options and do it NOW */
if (tcsetattr(fd,TCSANOW,&options) != 0)
return (FALSE);
options.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG); /*Input*/
options.c_oflag &= ~OPOST; /*Output*/
return (TRUE);
int main(int argc, char *argv[])
int fd, c=0, res;
char buf[256];
printf("Start...\n");
fd = open(UART_DEVICE, O_RDWR);
if (fd < 0) {
perror(UART_DEVICE);
exit(1);
printf("Open...\n");
set_speed(fd,115200);
if (set_Parity(fd,8,1,'N') == FALSE) {
printf("Set Parity Error\n");
exit (0);
printf("Reading...\n");
while(1) {
res = read(fd, buf, 255);
if(res==0)
continue;
buf[res]=0;
printf("%s", buf);
if (buf[0] == 0x0d)
printf("\n");
if (buf[0] == '@') break;
printf("Close...\n");
close(fd);
return 0;
用地上面的网上找的代码,编译运行后报错:
tcsetattr fd1:Input/Output error
SetupSerial1:Input/Output error
Set Parity Error
我的板子是编译的ti-sdk-am335x-evm-07.00.00.00
