By default, all the startup command is part of /opt/ipnc/autorun.sh which starts the camera
automatically after power ON.
/opt/ipnc/autorun.sh这个在rdk包里面是没有的?是怎么回事? ipnc下面有autorun_ipnc.sh, autorun_capturedisplay.sh,就是没有autorun.sh,求指教
我用的是GA_Release_3.5.0,里面的IPNC_RDK_InstallGuide里面就写明是all the startup command is part of /opt/ipnc/autorun.sh。哪里对不上,请指教,或者能给我个匹配的autorun.sh吗?谢谢了
我用的包是GA_Release_3.5.0的,查看的是IPNC_RDK_InstallGuide文档的。是哪里不同步,或者能给我个相匹配的autorun.sh吗,谢谢了
