有没有人重新编译DVSDK4.0时遇到下面问题?
make[1]: Entering directory `/opt/mv_pro_5.0/DVSDK/codec-engine_2_26_02_11/examples/ti/sdo/ce/examples/codecs' make -C viddec1_copy clean make[2]: Entering directory `/opt/mv_pro_5.0/DVSDK/codec-engine_2_26_02_11/examples/ti/sdo/ce/examples/codecs/viddec1_copy' /opt/mv_pro_5.0/DVSDK/codec-engine_2_26_02_11/examples/ti/sdo/ce/examples/codecs/viddec1_copy/../../../../../../xdcpaths.mak:655: *** CGTOOLS_V5T/CC_V5T is set to "/opt/mv_pro_5.0/linux-devkit//bin/arm-arago-linux-gnueabi-gcc", which is invalid (could not find file "/opt/mv_pro_5.0/linux-devkit//bin/arm-arago-linux-gnueabi-gcc"). Set this in /xdcpaths.mak! See the build documentation to correct this error.. Stop. make[2]: Leaving directory `/opt/mv_pro_5.0/DVSDK/codec-engine_2_26_02_11/examples/ti/sdo/ce/examples/codecs/viddec1_copy' make[1]: *** [clean] Error 2 make[1]: Leaving directory `/opt/mv_pro_5.0/DVSDK/codec-engine_2_26_02_11/examples/ti/sdo/ce/examples/codecs' make: *** [ceexamples_codecs_clean] Error 2
该问题明显提示/opt/mv_pro_5.0/linux-devkit//bin/arm-arago-linux-gnueabi-gcc命令找不到,原因是 CGTOOLS_V5T/CC_V5T替换得到的命令找不到,然后我修改/opt/mv_pro_5.0/DVSDK/codec-engine_2_26_02_11/examples/xdcpaths.mak路径下文件的CGTOOLS_V5T,想让路径变成/opt/mv_pro_5.0/linux-devkit/bin/arm-arago-linux-gnueabi-gcc,但是任然编译出错,请高手帮忙解决一下!
