Part Number: AM5718
使用SDK06.03.00.106版本在dts、mux_data.h修改或添加mmc2节点的内容后可正常在EMMC启动,但该版本不支持DFU操作;
根据论坛的提示,使用SDK04.03.00.05版本,在uboot阶段使用DFU向EMMC的烧录操作,但无法成功。
是否是我遗漏了某些操作?
以下是串口端的打印信息:
U-Boot SPL 2017.01-00458-ga36af91b60-dirty (Apr 12 2023 - 14:50:27)
DRA722-GP ES2.0
Trying to boot from DFU
Using default environment
#########DOWNLOAD ... OK
Ctrl+C to exit ...
U-Boot 2019.01 (Mar 31 2023 - 14:58:45 +0800)
CPU : DRA722-GP ES2.0
Model: TI AM5718 IDK
Board: AM571x IDK REV RV1.0
DRAM: 512 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Hit any key to stop autoboot: 0
=> mmc dev 1
switch to partitions #0, OK
mmc1(part 0) is current device
=> mmc part
Partition Map for MMC device 1 -- Partition Type: EFI
Part Start LBA End LBA Name
Attributes
Type GUID
Partition GUID
1 0x00000300 0x000010ff "bootloader"
attrs: 0x0000000000000000
type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
type: data
guid: c5b7024d-51ea-43ff-9a87-0a4a990a8ed1
2 0x00001500 0x00e8ffde "rootfs"
type: data
guid: 2fe12c68-23d8-49e4-80d3-d998bc3c0e28
=> setenv dfu_alt_info ${dfu_alt_info_emmc}
=> dfu 0 mmc 1
##CACHE: Misaligned operation at range [9e73f010, 9e73f050]
** Unable to use mmc 1:1 for fatwrite **
dfu: Read error!
ERROR: Deferred dfu_flush() failed!
at ../common/dfu.c:78/run_usb_dnl_gadget()
