am35xx tv out/cvbs problems
Other Parts Discussed in Thread: AM3505
dear, friends;
      1  ENV:
         AM3505  Linux 2.6.32  frome TI' web
      2   Problems:
     。cvbs play error
       cvbs drv  creat /dev/video0-3  and /dev/fb0; is ok;
      vga ok :use av-example form sdk; saMmapDisplay.c   display on vga is ok(corlor bars);
     cvbs display error and was configed to Composite Venc:
                      echo "tv" > /sys/xx/overlayx/manager  ;echo 1 > /sys/xx/overlayx/enable
    and tips on driver:
                          “error,paddr=0”;
                           set display tv out mode  return error; Check it,can't enable it on tv mode
                         cat  /sys/xx/overlayx/manager      ;     tv
                        cat  /sys/xx/overlayx/enable         ;     0
    。tv capture error:
                 run the example form sdk,
                capture is ok,but corlor is wrong!
    We need you help. Thanks!
