U-Boot > boot
Loading from NAND 256MiB 3,3V 8-bit, offset 0x300000
Image Name: Linux-3.3.0
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2772992 Bytes = 2.6 MB
Load Address: c0008000
Entry Point: c0008000
## Booting kernel from Legacy Image at c0700000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
如上所述,内核停在这里不动静了。
后来在menuconfig 打开“Kernel low-level debugging functions”。并在相应的位置添加了一些打印信息(必须调用汇编里的printascii函数才能打印出来,printk打印不出来)。启动信息如下:
Starting kernel ...
HuanYi-----lockdep_init OK!!
HuanYi-----smp_setup_processor_id OK!!
HuanYi-----debug_objects_early_init OK!!
HuanYi-----boot_init_stack_canary OK!!
HuanYi-----cgroup_init_early OK!!
HuanYi-----local_irq_disable OK!!
HuanYi-----tick_init OK!!
HuanYi-----boot_cpu_init OK!!
HuanYi-----page_address_init OK!!
HuanYi-----setup_processor OK!!
HuanYi-----setup_machine OK!!
HuanYi-----parse_early_param OK!!
HuanYi-----sanity_check_meminfo OK!!
HuanYi-----arm_memblock_init OK!!
HuanYi-----memblock_set_current_limit OK!!
HuanYi-----build_mem_type_table OK!!
HuanYi-----prepare_page_table OK!!
HuanYi-----map_lowmem OK!!
HuanYi-----arch/arm/mm/mmu.c devicemaps_init Enter!!
HuanYi----create_mapping_3 OK!!
HuanYi----create_mapping_5 OK!!
HuanYi-----/arch/arm/include/ars/Tlbflush.h local_flush_tlb_all Enter!!
HuanYi-----TLB_WB OK!!
HuanYi-----TLB_V4_D_FULL | TLB_V6_D_FULL OK!!
HuanYi-----TLB_V4_I_FULL | TLB_V6_I_FULL OK!!
HuanYi-----TLB_V7_UIS_FULL END!!
HuanYi-----local_flush_tlb_all Return!!
`IžãoœooÍcoÉbpŒ“nàA“n“÷oàoïón€ìlclˆlh`ˆ“OàñnœonÍboÍcoýcà1sNØócà1“obìñopp’oÄ“ncà1sOc6ƒnÁânÜ“O|`ãcèÆœóopƒoœ8’o|`óypcn’'oœnoÍcoÍcoADZ`ló
Í““Ælblˆlh`ˆ“oàñnœooÍcoÍcoA
出现一些乱码后就不动了。
进一步跟踪,发现在/arch/arm/mmu.c里devicemaps_init(0这个函数里的:mdesc->map_io(); 有问题,把这个注释掉就不会有乱码,但内核仍然启动不了;把这个加上去就有乱码了,内核也仍然运行不起来。
我找了两天了,基本排除ID号不对、串口号不对的问题。不知是何原因,还请高手指点, 不胜感激!!!
