TMS320DM8168+VS dautor + DVRRDK_01.09.01.21
Other Parts Discussed in Thread: TMS320DM8168
运 行 环境TMS320DM8168+VS dautor  +  DVRRDK_01.09.01.21 :
我发现 DVRRDK_01.09.01.21里没有文件系统,所以自己从
ti-ezsdk_dm816x-evm_5_03_01_15/filesystem/ezsdk-dm816x-evm-rootfs.tar.gz 制作 nfs文件系统
出现如下的问题,我该怎样解决呢?
PRCM Initialization completed
SysLink version : 2.00.04.83
SysLink module created on Date:Mar 19 2012 Time:10:18:15
FIRMWARE: Memory map bin file not passed
Usage : firmware_loader <Processor Id> <Location of Firmware> <start|stop> [Loc]
FIRMWARE: Default memory configuration is used
MemCfg: DCMM (Dynamically Configurable Memory Map) Version :  2.1.1.1
FIRMWARE: Memory Configuration status : In Progress
FIRMWARE: 1 start Successful
Loading HDVPSS Firmware
FIRMWARE: 2 start Successful
notify_shm_drv_sendevent failed! status = 0xfffffff0
notify_send_event failed! status = 0xfffffff0
VPSS_CORE : Failed to init fvid2 interface,
vpss: probe of vpss failed with error -22
VPSS_CORE : failed to register ti81xx-vpss driver
FATAL: Error inserting vpss (/lib/modules/2.6.37/kernel/drivers/video/ti81xx/vpe
FATAL: Error inserting ti81xxfb (/lib/modules/2.6.37/kernel/drivers/video/ti81xe
open /dev/fb0: No such file or directory
FATAL: Error inserting ti81xxhdmi (/lib/modules/2.6.37/kernel/drivers/video/ti8e
Starting system message bus: dbus.
Starting telnet daemon.
ipv6: disagrees about version of symbol contig_page_data
ipv6: Unknown symbol contig_page_data (err -22)
ipv6: disagrees about version of symbol __alloc_pages_nodemask
ipv6: Unknown symbol __alloc_pages_nodemask (err -22)
ipv6: Unknown symbol page_address (err 0)
modprobe: FATAL: Error inserting ipv6 (/lib/modules/2.6.37/kernel/net/ipv6/ipv6)
Starting syslogd/klogd: done
Starting thttpdipv6: disagrees about version of symbol contig_page_data
expr: syntax error
Linux Frame Buffer Device Configuration Version 2.1 (23/06/1999)
(C) Copyright 1995-1999 by Geert Uytterhoeven
Usage: fbset [options] [mode]
Valid options:
  General options:
    -h, --help         : display this usage information
    --test             : don't change, just test whether the mode is valid
    -s, --show         : display video mode settings
    -i, --info         : display all frame buffer information
    -v, --verbose      : verbose mode
    -V, --version      : print version information
    -x, --xfree86      : XFree86 compatibility mode
    -a, --all          : change all virtual consoles on this device
  Frame buffer special device nodes:
    -fb <device>       : processed frame buffer device
                         (default is /dev/fb0)
  Video mode database:
    -db <file>         : video mode database file
                         (default is /etc/fb.modes)
  Display geometry:
    -xres <value>      : horizontal resolution (in pixels)
    -yres <value>      : vertical resolution (in pixels)
    -vxres <value>     : virtual horizontal resolution (in pixels)
    -vyres <value>     : virtual vertical resolution (in pixels)
    -depth <value>     : display depth (in bits per pixel)
    -nonstd <value>    : select nonstandard video mode
    -g, --geometry ... : set all geometry parameters at once
    -match             : set virtual vertical resolution by virtual resolution
  Display timings:
    -pixclock <value>  : pixel clock (in picoseconds)
    -left <value>      : left margin (in pixels)
    -right <value>     : right margin (in pixels)
    -upper <value>     : upper margin (in pixel lines)
    -lower <value>     : lower margin (in pixel lines)
    -hslen <value>     : horizontal sync length (in pixels)
    -vslen <value>     : vertical sync length (in pixel lines)
    -t, --timings ...  : set all timing parameters at once
  Display flags:
    -accel <value>     : hardware text acceleration enable (false or true)
    -hsync <value>     : horizontal sync polarity (low or high)
    -vsync <value>     : vertical sync polarity (low or high)
    -csync <value>     : composite sync polarity (low or high)
    -gsync <value>     : synch on green (false or true)
    -extsync <value>   : external sync enable (false or true)
    -bcast <value>     : broadcast enable (false or true)
    -laced <value>     : interlace enable (false or true)
    -double <value>    : doublescan enable (false or true)
    -rgba <r,g,b,a>    : recommended length of color entries
    -grayscale <value> : grayscale enable (false or true)
  Display positioning:
    -move <directionpvrsrvkm: disagrees about version of symbol contig_page_data
>  : move the vipvrsrvkm: Unknown symbol contig_page_data (err -22)
sible part (left, right, up or dpvrsrvkm: disagrees about version of symbol __ak
own)
    -step pvrsrvkm: Unknown symbol __alloc_pages_nodemask (err -22)
<value>      : step increment (in pixels or pixel lines)
                         (default is 8 horizontal, 2 vertical)
Starting PVR
insmod: error inserting '/lib/modules/2.6.37/kernel/drivers/gpu/pvr/pvrsrvkm.kos
pvrsrvkm: disagrees about version of symbol __alloc_pages_nodemask
WARNING: Error inserting vpss (/lib/modules/2.6.37/kernel/drivers/video/ti81xx/t
FATAL: Error inserting omaplfb (/lib/modules/2.6.37/kernel/drivers/gpu/pvr/omapa
argument
FATAL: Error inserting bufferclass_ti (/lib/modules/2.6.37/kernel/drivers/gpu/pt
BusyBox v1.13.2 (2011-12-09 14:43:32 IST) multi-call binary
Usage: mknod [OPTIONS] NAME TYPE MAJOR MINOR
Create a special file (block, character, or pipe)
Options:
        -m      Create the special file using the specified mode (default a=rw)
TYPEs include:
        b:      Make a block device
        c or u: Make a character device
        p:      Make a named pipe (MAJOR and MINOR are ignored)
chmod: /dev/pvrsrvkm: No such file or directory
/dev/mem opened.
Memory mapped at address 0x4027f000.
Read at address  0x48180F04 (0x4027ff04): 0x00000001
Write at address 0x48180F04 (0x4027ff04): 0x00000000, readback 0x00000000
/dev/mem opened.
Memory mapped at address 0x40141000.
Read at address  0x48180900 (0x40141900): 0x00000002
Write at address 0x48180900 (0x40141900): 0x00000002, readback 0x00000002
/dev/mem opened.
Memory mapped at address 0x4023c000.
Read at address  0x48180920 (0x4023c920): 0x00070000
Write at address 0x48180920 (0x4023c920): 0x00000002, readback 0x00000002
Starting Matrix GUI application.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org dm816x-evm ttyO2
Arago 2011.09 dm816x-evm ttyO2
dm816x-evm login: root
root@dm816x-evm:~# lsmod
Module                  Size  Used by
syslink              1108439  0
