你好:
我在项目中使用AM3359,出现如下问题:
NAND设备已经使用了GPMC_AD0 ~GPMC_AD7。LCD的RGB信号为565格式。
BOOT[15:0]配置如下:
由于管脚紧张,想使用GPMC_AD8 ~ GPMC_AD15的GPIO功能控制LED灯。目前调试时发现对应管脚上无电平变化。
还有,这样做是否会影响LCD的显示?因为下文中将其屏蔽。
附录:
1. LINUX内核board-am335xevm.c文件中,修改如下:
/* Module pin mux for LCDC */
static struct pinmux_config lcdc_pin_mux[] = {
{"lcd_data0.lcd_data0", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data1.lcd_data1", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data2.lcd_data2", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data3.lcd_data3", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data4.lcd_data4", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data5.lcd_data5", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data6.lcd_data6", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data7.lcd_data7", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data8.lcd_data8", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data9.lcd_data9", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data10.lcd_data10", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data11.lcd_data11", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data12.lcd_data12", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data13.lcd_data13", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data14.lcd_data14", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
{"lcd_data15.lcd_data15", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
| AM33XX_PULL_DISA},
// {"gpmc_ad8.lcd_data23", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
// {"gpmc_ad9.lcd_data22", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
// {"gpmc_ad10.lcd_data21", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
// {"gpmc_ad11.lcd_data20", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
// {"gpmc_ad12.lcd_data19", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
// {"gpmc_ad13.lcd_data18", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
// {"gpmc_ad14.lcd_data17", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
// {"gpmc_ad15.lcd_data16", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
{"lcd_vsync.lcd_vsync", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT},
{"lcd_hsync.lcd_hsync", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT},
{"lcd_pclk.lcd_pclk", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT},
{"lcd_ac_bias_en.lcd_ac_bias_en", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT},
{NULL, 0},
/* Pin mux for GPMC bus */
static struct pinmux_config gpmc_pin_mux[] = {
{"gpmc_ad0.gpmc_ad0", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
{"gpmc_ad1.gpmc_ad1", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
{"gpmc_ad2.gpmc_ad2", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
{"gpmc_ad3.gpmc_ad3", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
{"gpmc_ad4.gpmc_ad4", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
{"gpmc_ad5.gpmc_ad5", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
{"gpmc_ad6.gpmc_ad6", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
{"gpmc_ad7.gpmc_ad7", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
{"gpmc_ad8.gpio0_22", OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT},
{"gpmc_ad9.gpio0_23", OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT},
{"gpmc_ad10.gpio0_26", OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT},
{"gpmc_ad11.gpio0_27", OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT},
{"gpmc_ad12.gpio1_12", OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT},
{"gpmc_ad13.gpio1_13", OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT},
{"gpmc_ad14.gpio1_14", OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT},
{"gpmc_ad15.gpio1_15", OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT},
{"gpmc_wait0.gpmc_wait0", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
{"gpmc_wpn.gpmc_wpn", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT_PULLUP},
{"gpmc_csn1.gpmc_csn1", OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
{"gpmc_advn_ale.gpmc_advn_ale", OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
{"gpmc_oen_ren.gpmc_oen_ren", OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
{"gpmc_wen.gpmc_wen", OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
{"gpmc_ben0_cle.gpmc_ben0_cle", OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
{"gpmc_clk.gpmc_clk", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT},
{"ecap0_in_pwm0_out.xdma_event_intr2", OMAP_MUX_MODE6 | AM33XX_PIN_INPUT}, // DMAREQ
{NULL, 0},
2. LINUX内核mux33xx.c文件中,对应如下:
_AM33XX_MUXENTRY(GPMC_AD8, 0,
"gpmc_ad8", "lcd_data23", "mmc1_dat0", "mmc2_dat4",
NULL, NULL, NULL, "gpio0_22"),
_AM33XX_MUXENTRY(GPMC_AD9, 0,
"gpmc_ad9", "lcd_data22", "mmc1_dat1", "mmc2_dat5",
"ehrpwm2B", NULL, NULL, "gpio0_23"),
_AM33XX_MUXENTRY(GPMC_AD10, 0,
"gpmc_ad10", "lcd_data21", "mmc1_dat2", "mmc2_dat6",
NULL, NULL, NULL, "gpio0_26"),
_AM33XX_MUXENTRY(GPMC_AD11, 0,
"gpmc_ad11", "lcd_data20", "mmc1_dat3", "mmc2_dat7",
NULL, NULL, NULL, "gpio0_27"),
_AM33XX_MUXENTRY(GPMC_AD12, 0,
"gpmc_ad12", "lcd_data19", "mmc1_dat4", "mmc2_dat0",
NULL, NULL, NULL, "gpio1_12"),
_AM33XX_MUXENTRY(GPMC_AD13, 0,
"gpmc_ad13", "lcd_data18", "mmc1_dat5", "mmc2_dat1",
NULL, NULL, NULL, "gpio1_13"),
_AM33XX_MUXENTRY(GPMC_AD14, 0,
"gpmc_ad14", "lcd_data17", "mmc1_dat6", "mmc2_dat2",
NULL, NULL, NULL, "gpio1_14"),
_AM33XX_MUXENTRY(GPMC_AD15, 0,
"gpmc_ad15", "lcd_data16", "mmc1_dat7", "mmc2_dat3",
NULL, NULL, NULL, "gpio1_15"),
3. GPIO的驱动程序如下:
#define DEVICE_NAME "gpioCtl"
#define GPIO_TO_PIN(bank, gpio) (32 * (bank) + (gpio))
struct gpio_qset;
/*设备编号存储结构体*/
struct dev_num
dev_t devNum;
unsigned int major;
unsigned int minor;
unsigned int minor_first;
unsigned int count;
struct dev_num gpio_dev_num;
/*设备描述结构体*/
struct gpio_dev
struct cdev cdev;
struct gpio_qset* dptr; //设备数据存储链表第一项
unsigned long size; //链表长度(随着申请的GPIO端口数增长)
struct gpio_dev *gpio_devp;
/*设备数据存储结构体(采用链式存储,不理解的可以看《数据结构》)*/
struct gpio_qset
unsigned long port; //端口号 #define GPIO_TO_PIN(bank, gpio) (32 * (bank) + (gpio))
unsigned int ddr; //方向(输入(0)或输出(1))
char value; //高(1)低(0)电平
unsigned long num; //当前编号(按照申请顺序编号)
char label[10]; //申请的GPIO使用名称
struct gpio_qset* next; //指向链表下一项的指针
* 功能:初始化gpio_dev
* *inode:
* *filp:
* 描述:用户空间调用open时运行
* int (*open) (struct inode *, struct file *);
* 返回值:0
static int gpio_open(struct inode *inode, struct file *filp)
struct gpio_dev *dev;
//由container_of获得结构体指针inode中结构体cdev的指针,
//让结构体指针dev指向上述的指针所指的地址,
//再让file->private指向这一地址,
dev = container_of(inode->i_cdev, struct gpio_dev, cdev);
filp->private_data = dev;
dev->dptr = NULL;
dev->size = 0;
//printk(KERN_ERR "gpio_open success!\n");
return 0;
* 功能:释放申请的GPIO端口以及释放链表(gpio_qset)
* *inode:
* *filp:
* 描述:用户空间调用close时运行
* int (*release) (struct inode *, struct file *);
* 返回值:0
static int gpio_close(struct inode *inode, struct file *filp)
struct gpio_dev *dev = filp->private_data;
struct gpio_qset *qset, *qsetTmp;
qsetTmp = (struct gpio_qset *)kzalloc(sizeof(struct gpio_qset), GFP_KERNEL);
for(qset = dev->dptr; qset->next !=NULL; qset=qsetTmp)
qsetTmp = qset->next;
gpio_free(qset->port); //释放申请的端口
kfree(qset); //释放gpio_qset内存
gpio_free(qsetTmp->port);
kfree(qsetTmp);
//printk(KERN_ERR "gpio release!\n");
return 0;
* 功能:申请新的gpio_qset的内存,确定相应的GPIO端口功能
* *inode:
* *filp:
* cmd:实现的功能,
* 0:读,
* 1:写,
* 2:释放GPIO端口
* arg:执行操作的GPIO端口
* 描述:用户空间调用ioctl时运行
* long (*unlocked_ioctl) (struct file *, unsigned int, unsigned long);
* 返回值:成功返回操作的GPIO端口号
* 错误返回相应的错误码
static long gpio_ioctl(struct file *filp, unsigned int cmd, unsigned long arg)
int ret;
struct gpio_qset *qset;
//cmd == 2 设计成为释放arg端口的功能,之后申请内存的任务便不必执行了,所以直接返回
if(cmd == 2)
gpio_free(arg);
return arg;
dev->size++;
if(dev->dptr == NULL)
dev->dptr = (struct gpio_qset *)kzalloc(sizeof(struct gpio_qset), GFP_KERNEL);
qset = dev->dptr;
else
for(qset = dev->dptr; qset->next != NULL; qset = qset->next); //找到链表最后一项
qset->next = (struct gpio_qset *)kzalloc(sizeof(struct gpio_qset), GFP_KERNEL);
qset = qset->next;
/*链表数据*/
qset->num = dev->size; //确定自己的编号
qset->ddr = cmd; //确定方向
qset->port = arg; //确定端口号
qset->next = NULL; //最后一项地址清空
//printk(KERN_ERR "qset->num=%d,qset->ddr=%d,qset->port=%d\n", qset->num, qset->ddr, qset->port);
sprintf(qset->label, "gpio%ld", qset->port); //确定申请的GPIO使用名称(和端口直接相关)
ret = gpio_request(qset->port, qset->label); //申请端口
/*由于gpio_requset会自己判断成功与否并且退出函数,故注释掉对ret的判断
if(ret < 0)
printk(KERN_ERR "%s_requset failled!%d \n", qset->label, ret);
/*判断GPIO工作方向(输出或输出)*/
switch(qset->ddr)
case 0: ret = gpio_direction_input(qset->port);
if(ret < 0)
printk(KERN_ERR "gpio_direction_input failled!\n");
break;
case 1: ret = gpio_direction_output(qset->port, 1);
if(ret < 0)
printk(KERN_ERR "gpio_direction_output failled!\n");
break;
default:
return -EPERM; /* Operation not permitted */
return qset->num;
* 功能:获取相应端口电平,写入相应的qset_dev->value,写到用户空间的readBuf
* *inode:
* *filp:
* *readBuf:读数据缓存指针,用户空间的指针
* port:被读取的GPIO端口号
* *offp:
* 描述:用户空间调用read时运行
* ssize_t (*read) (struct file *, char __user *, size_t, loff_t *);
* 返回值:成功返回qset->value
* 错误返回相应的错误码
static ssize_t gpio_read (struct file *filp, char __user *readBuf, size_t port, loff_t *offp)
long ret;
return -ENODEV; /* No such device */
for(qset = dev->dptr; qset != NULL; qset = qset->next)
if(qset->port == port)
break;
if(qset->next == NULL)
if(qset->ddr != 0) //判断是否ioctl设置为读操作
qset->value = gpio_get_value(qset->port);
//printk(KERN_ERR "qset->port:%d, qset->value:%d\n", qset->port, qset->value);
switch(qset->value)
case 0: ret = copy_to_user(readBuf, "0", 1);
break;
case 1: ret = copy_to_user(readBuf, "1", 1);
break;
return qset->value;
* 功能:写入相应端口电平,写入相应的qset_dev->value,数据来自用户空间的writeBuf
* *inode:
* *filp:
* *writeBuf:写数据缓存指针,用户空间的指针
* port:被写入的GPIO端口号
* *offp:
* 描述:用户空间调用write时运行
* ssize_t (*write) (struct file *, const char __user *, size_t, loff_t *);
* 错误返回相应的错误码
static ssize_t gpio_write (struct file *filp, const char __user *writeBuf, size_t port, loff_t *offp)
long ret;
// printk(KERN_ERR "qset->port=%d,port=%d\n", qset->port, port);
break;
if(qset->ddr != 1) //判断是否ioctl设置为写操作
ret = copy_from_user(&qset->value, writeBuf, 1);
//printk(KERN_ERR "write:%d\n", qset->value);
switch(qset->value)
case '0': qset->value = 0;
gpio_set_value(qset->port, 0);
break;
default : qset->value = 1;
gpio_set_value(qset->port, 1);
break;
return qset->value;
/*文件操作结构体*/
static const struct file_operations gpio_fops = {
.owner = THIS_MODULE,
.open = gpio_open,
.unlocked_ioctl = gpio_ioctl,
.write = gpio_write,
.read = gpio_read,
.release = gpio_close,
/*cdev注册函数*/
static void gpio_setup_cdev(struct gpio_dev *dev, int index)
int ret,devno = gpio_dev_num.devNum + index;
cdev_init(&dev->cdev, &gpio_fops);
dev->cdev.owner = THIS_MODULE;
dev->cdev.ops = &gpio_fops;
ret = cdev_add(&dev->cdev, devno, 1);
if(ret)
printk(KERN_ERR "error %d : adding gpioCtl%d",ret,index);
/*设备初始化函数*/
static int __init omap3gpio_init(void)
int ret;
gpio_dev_num.count = 1;
gpio_dev_num.minor_first = 0;
ret = alloc_chrdev_region(&gpio_dev_num.devNum, gpio_dev_num.minor_first, gpio_dev_num.count, DEVICE_NAME);
if(ret < 0)
return ret;
gpio_dev_num.major = MAJOR(gpio_dev_num.devNum);
gpio_dev_num.minor = MINOR(gpio_dev_num.devNum);
gpio_devp = kzalloc(sizeof(struct gpio_dev),GFP_KERNEL);
gpio_setup_cdev(gpio_devp, 0);
printk(KERN_ERR "gpio alloc_chrdev_region success, major = %d\n", gpio_dev_num.major);
return 0;
/*设备释放函数*/
static void __exit omap3gpio_exit(void)
/*test*/
//struct file *filp;
//struct inode *inode;
//inode = container_of(&gpio_devp->cdev, struct inode, i_cdev);
//filp = container_of(gpio_devp, struct file, private_data);
//gpio_close(inode, filp);
/*test*/
cdev_del(&gpio_devp->cdev);
kfree(gpio_devp);
unregister_chrdev_region(gpio_dev_num.devNum, 1);
printk(KERN_ERR "gpio unregister_chrdev_region success, major = %d\n", gpio_dev_num.major);
MODULE_LICENSE("Dual BSD/GPL");
MODULE_AUTHOR("Mlo_Lv,Tute-421E-studio");
MODULE_DESCRIPTION("This module is used to conrtol omap3 gpio");
module_init(omap3gpio_init);
module_exit(omap3gpio_exit);
说明:
该GPIO驱动程序,在应用程序中确定使用的GPIO序号,且同一应用程序中供多个GPIO使用,如下:
ioctl(fd, 1, GPIO_TO_PIN(0, 22)); //设置为输出, 用于DO2
write(fd,"0",GPIO_TO_PIN(0, 22));
ioctl(fd, 1, GPIO_TO_PIN(0, 23)); //设置为输出, 用于DO2
write(fd,"0",GPIO_TO_PIN(0, 23));
ioctl(fd, 1, GPIO_TO_PIN(0, 26)); //设置为输出, 用于DO2
write(fd,"0",GPIO_TO_PIN(0, 26));
该驱动程序已经成功用于本板其他的GPIO。
