如何查看开发板ROM revision ?
本人用的是TI公司生产的OMAPL138(LCDK)开发板,请问如何查看开发板的  ROM revision  是不是d800k008 ?开发板如下图所示:
  • 你好,请看下面步骤:
    To check the version of your device,
    perform the following steps.
    1. Connect to the device in the Code Composer Studio™ software.
    2. Select View → Memory.
    3. Enter the address of the beginning of the ROM, 0xFFFD0000, at the top of the memory window.
    4. Select Character mode at the bottom.
    The text d800k008 should appear in the memory window at offset 0x08. For earlier ROM revisions, the
    text could also appear as d800k002, d800k004, or d800k006. It’s important to know your ROM revision
    when generating boot images. If you don’t see any of these values in the memory window, this document
    is not applicable to your device. An abbreviated summary of the ROM boot loader revision history can be
    found in Appendix E.
    http://www.ti.com/lit/an/sprab41e/sprab41e.pdf
