最好是有中文的资料啊,3Q
DRA744
Starting linux (3276670 bytes in 5447 ticks)...
[ 1.549285] omap-gpmc omap-gpmc: failed to reserve memory
[ 1.590087] omap_l3_noc ocp.2: couldn't find resource 2
[ 1.670715] edma-dma-engine edma-dma-engine.0: Can't allocate PaRAM dummy slot
[ 1.816986] generic_dpi_panel display0: probe lq080y5dz06 successful
[ 1.841125] gccore gccore.0: opp_get_opp_count: device OPP not found (-19)
[ 1.900573] atmel_mxt_ts 1-004b: __mxt_read_reg: i2c transfer failed (-121)
[ 2.107330] Failed to clk_get cpts clk
[ 2.111297] RW - Current Multi (784cfe13), Shift (29)
我参照公司的脚本编译的内核有上面的错误,所以我想了解一下这个开发的流程,从最基础入手,我之前没做过。
另外这些错误是什么原因导致的呢?
DRA744属于NDA器件。请联系您当地的TI销售或着代理商。
www.ti.com.cn/home_b_dist
