Part Number: TDA4VM-Q1
Other Parts Discussed in Thread: SK-TDA4VM
制作了一张SD卡来作为启动卡,这个SD卡可以在SK-TDA4VM板子上正常的跑起来文件系统,但是在我自己的板子上无法启动文件系统,具体LOG信息如下,帮忙看看是因为什么原因:
U-Boot SPL 2021.01-dirty (May 07 2023 - 20:37:00 +0800)
Model: Texas Instruments K3 J721E SoC
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed 1
Board: J721EX-PM1-SOM rev E2
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.7(release):v2.7.0-359-g1309c6c805-dirty
NOTICE: BL31: Built : 07:46:16, Dec 18 2022
I/TC:
I/TC: OP-TEE version: 3.19.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Sun Dec 18 07:46:21 UTC 2022 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check optee.readthedocs.io/.../porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2021.01-dirty (May 07 2023 - 20:36:58 +0800)
U-Boot 2021.01-dirty (May 07 2023 - 20:36:58 +0800)
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT... i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
cdns,sierra serdes@5000000: PHY not found 0x7364 vs 0x0
Sierra init failed:-22
Net: Could not get PHY for ethernet@46000000port@1: addr 0
am65_cpsw_nuss_port ethernet@46000000port@1: phy_connect() failed
No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
** Unrecognized filesystem type **
18608640 bytes read in 781 ms (22.7 MiB/s)
111990 bytes read in 14 ms (7.6 MiB/s)
## Flattened Device Tree blob at 88000000
Booting using the fdt blob at 0x88000000
Loading Device Tree to 000000008fee1000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.153-g90c3a58fd2 (root@ubuntu) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Fri Feb 24 20:19:31 PST 2023
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff]
[ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff]
[ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000abffffff]
[ 0.000000] node 0: [mem 0x00000000ac000000-0x00000000adffffff]
[ 0.000000] node 0: [mem 0x00000000ae000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Reserved 400 MiB at 0x00000000e7000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=bb4483c1-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000e3000000-0x00000000e7000000] (64MB)
[ 0.000000] Memory: 3386436K/4194304K available (10880K kernel code, 1148K rwdata, 4212K rodata, 1792K init, 432K bss, 398268K reserved, 409600K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000880030000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008387] Console: colour dummy device 80x25
[ 0.012948] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023618] pid_max: default: 32768 minimum: 301
[ 0.028374] LSM: Security Framework initializing
[ 0.033129] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.040705] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.049463] rcu: Hierarchical SRCU implementation.
[ 0.054511] Platform MSI: msi-controller@1820000 domain created
[ 0.060745] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070046] EFI services will not be available.
[ 0.074778] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[ 0.088047] Detected PIPT I-cache on CPU1
[ 0.088070] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.088081] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
[ 0.088115] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.088163] smp: Brought up 1 node, 2 CPUs
[ 0.117506] SMP: Total of 2 processors activated.
[ 0.122311] CPU features: detected: 32-bit EL0 Support
[ 0.127565] CPU features: detected: CRC32 instructions
[ 0.141396] CPU: All CPU(s) started at EL2
[ 0.145594] alternatives: patching kernel code
[ 0.150593] devtmpfs: initialized
[ 0.159528] KASLR disabled due to lack of seed
[ 0.164169] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.174132] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.185709] pinctrl core: initialized pinctrl subsystem
[ 0.191343] DMI not present or invalid.
[ 0.195577] NET: Registered protocol family 16
[ 0.200790] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.208095] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.216141] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.224426] thermal_sys: Registered thermal governor 'step_wise'
[ 0.224429] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.230990] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.244624] ASID allocator initialised with 65536 entries
[ 0.269645] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.276500] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.283346] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.290192] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.297631] cryptd: max_cpu_qlen set to 1000
[ 0.303697] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.312517] vsys_3v3: supplied by evm_12v0
[ 0.316879] vsys_5v0: supplied by evm_12v0
[ 0.321620] iommu: Default domain type: Translated
[ 0.326784] SCSI subsystem initialized
[ 0.330945] mc: Linux media interface: v0.10
[ 0.335322] videodev: Linux video capture interface: v2.00
[ 0.340959] pps_core: LinuxPPS API ver. 1 registered
[ 0.346030] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.355370] PTP clock support registered
[ 0.359391] EDAC MC: Ver: 3.0.0
[ 0.363193] FPGA manager framework
[ 0.366707] Advanced Linux Sound Architecture Driver Initialized.
[ 0.373290] clocksource: Switched to clocksource arch_sys_counter
[ 0.379610] VFS: Disk quotas dquot_6.6.0
[ 0.383640] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.393174] NET: Registered protocol family 2
[ 0.397900] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.406466] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.415220] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.423420] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.431218] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.438011] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.444904] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.452301] NET: Registered protocol family 1
[ 0.457010] RPC: Registered named UNIX socket transport module.
[ 0.463072] RPC: Registered udp transport module.
[ 0.467877] RPC: Registered tcp transport module.
[ 0.472679] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.479263] PCI: CLS 0 bytes, default 64
[ 0.483633] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.494082] Initialise system trusted keyrings
[ 0.498715] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.506831] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.513080] NFS: Registering the id_resolver key type
[ 0.518269] Key type id_resolver registered
[ 0.522539] Key type id_legacy registered
[ 0.526660] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.533507] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.541144] 9p: Installing v9fs 9p2000 file system support
[ 0.566398] Key type asymmetric registered
[ 0.570584] Asymmetric key parser 'x509' registered
[ 0.575582] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.583141] io scheduler mq-deadline registered
[ 0.587765] io scheduler kyber registered
[ 0.593515] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.599694] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.608644] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.614924] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.621278] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.627694] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.635672] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.642091] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.650027] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.656450] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.664377] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.670703] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.678638] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.684962] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 0.694678] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.702915] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.711129] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.718162] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.726582] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.739622] brd: module loaded
[ 0.746054] loop: module loaded
[ 0.749791] megasas: 07.714.04.00-rc1
[ 0.755571] tun: Universal TUN/TAP device driver, 1.6
[ 0.761032] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.767441] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.773514] sky2: driver version 1.30
[ 0.777869] VFIO - User Level meta-driver version: 0.3
[ 0.783661] i2c /dev entries driver
[ 0.788176] sdhci: Secure Digital Host Controller Interface driver
[ 0.794497] sdhci: Copyright(c) Pierre Ossman
[ 0.799162] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.805596] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.811942] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.819346] optee: probing for conduit method.
[ 0.823911] optee: revision 3.19 (afacf356)
[ 0.824039] optee: dynamic shared memory is enabled
[ 0.833496] optee: initialized driver
[ 0.838621] NET: Registered protocol family 17
[ 0.843237] 9pnet: Installing 9P2000 support
[ 0.847627] Key type dns_resolver registered
[ 0.852079] Loading compiled-in X.509 certificates
[ 0.862863] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.869213] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.878770] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
[ 0.950829] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 0.958713] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.964816] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.971284] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.977816] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.984633] pca953x 3-0020: using no AI
[ 1.009334] pca953x 3-0020: failed writing register
[ 1.014369] pca953x: probe of 3-0020 failed with error -121
[ 1.020449] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 1.027247] pca953x 3-0022: using AI
[ 1.030959] pca953x 3-0022: failed writing register
[ 1.035982] pca953x: probe of 3-0022 failed with error -121
[ 1.041720] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.048189] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 1.058426] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
[ 1.064775] pca953x 6-0020: supply vcc not found, using dummy regulator
[ 1.071593] pca953x 6-0020: using no AI
[ 1.097337] pca953x 6-0020: failed writing register
[ 1.102371] pca953x: probe of 6-0020 failed with error -121
[ 1.108496] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[ 1.114591] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[ 1.120587] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[ 1.126890] pca953x 9-0020: supply vcc not found, using dummy regulator
[ 1.133706] pca953x 9-0020: using no AI
[ 2.145293] omap_i2c 2060000.i2c: timeout waiting for bus ready
[ 2.151346] pca953x 9-0020: failed writing register
[ 2.156378] pca953x: probe of 9-0020 failed with error -16
[ 2.162038] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[ 2.168534] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 2.178514] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 2.187337] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 2.197207] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 2.209814] cdns-sierra-phy: probe of 5000000.serdes failed with error -22
[ 2.228555] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 2.236368] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 2.244648] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 2.252925] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.261857] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.269537] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.277812] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.286092] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.294910] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 2.302585] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 2.310860] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 2.319141] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.328432] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 2.338319] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 2.345080] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 2.354172] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 2.364318] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 2.371077] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 2.379066] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 2.388473] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[ 2.397218] printk: console [ttyS2] enabled
[ 2.405654] printk: bootconsole [ns16550a0] disabled
[ 2.416128] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[ 2.425086] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[ 2.435962] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 2.446470] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 2.456622] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 2.466859] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 2.478066] scsi host0: ufshcd
[ 2.487511] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 2.533296] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.541219] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[ 2.547942] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 2.560787] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.567995] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.574327] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 2.584523] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 2.694237] mmc0: CQHCI version 5.10
[ 2.697871] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 2.710922] pca953x 4-0020: supply vcc not found, using dummy regulator
[ 2.717594] pca953x 4-0020: using no AI
[ 2.745303] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 2.745333] pca953x 4-0020: failed writing register
[ 2.757761] pca953x: probe of 4-0020 failed with error -121
[ 2.763792] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 2.770646] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 2.777619] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 2.784555] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 2.791433] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 2.801883] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 2.809378] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 2.817466] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 2.825546] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.834246] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.841744] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.849830] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.857909] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.866521] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 2.874015] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 2.882099] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 2.890183] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.899396] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 2.899675] cdns-ufshcd 4e84000.ufs: link startup failed 1
[ 2.910119] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 2.913402] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[ 2.927117] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[ 2.928033] spi-nor spi7.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[ 2.933382] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[ 2.940257] spi-nor: probe of spi7.0 failed with error -2
[ 2.946667] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[ 2.946670] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[ 2.954389] spi-nor spi8.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[ 2.958922] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[ 2.965529] spi-nor: probe of spi8.0 failed with error -2
[ 2.972380] cdns-ufshcd 4e84000.ufs: Clk gate=1
[ 2.979142] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 2.984146] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[ 2.995881] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 3.002678] cdns-ufshcd 4e84000.ufs: last intr at 2813268 us, last intr status=0x404
[ 3.010006] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 3.017912] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[ 3.025803] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 3.033270] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[ 3.041398] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.050344] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[ 3.059077] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 3.064611] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[ 3.072082] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 3.078348] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[ 3.086398] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 3.092484] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[ 3.100568] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.106630] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[ 3.115247] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 3.127029] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[ 3.134536] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 3.140832] host_regs: 00000010: 00000000 00000000 00000000 00000000
[ 3.148902] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 3.155235] host_regs: 00000020: 00000000 00000470 00000000 00000000
[ 3.163307] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.169638] host_regs: 00000030: 00000008 00000001 00000000 00000000
[ 3.181851] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 3.184230] host_regs: 00000040: 00000000 00000000 00000000 00000000
[ 3.191799] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 3.198018] host_regs: 00000050: 00000000 00000000 00000000 00000000
[ 3.206146] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 3.212430] host_regs: 00000060: 00000000 00000000 00000000 00000000
[ 3.220502] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.226833] host_regs: 00000070: 00000000 00000000 00000000 00000000
[ 3.235781] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 3.241414] host_regs: 00000080: 00000000 00000000 00000000 00000000
[ 3.241418] host_regs: 00000090: 00000000 00000000 00000000 00000000
[ 3.248917] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 3.255230] cdns-ufshcd 4e84000.ufs: No record of pa_err
[ 3.261584] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 3.269643] cdns-ufshcd 4e84000.ufs: No record of dl_err
[ 3.269646] cdns-ufshcd 4e84000.ufs: No record of nl_err
[ 3.275030] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.283023] cdns-ufshcd 4e84000.ufs: No record of tl_err
[ 3.288787] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 3.293626] cdns-ufshcd 4e84000.ufs: No record of dme_err
[ 3.293630] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[ 3.301908] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 3.307181] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[ 3.314660] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 3.320038] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 2814389 us
[ 3.326208] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.334272] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[ 3.340748] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 3.347924] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[ 3.355124] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 3.363278] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[ 3.363280] cdns-ufshcd 4e84000.ufs: No record of host_reset
[ 3.363283] cdns-ufshcd 4e84000.ufs: No record of task_abort
[ 3.370190] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 3.413479] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 3.420816] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 3.428157] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 3.435865] mmc0: Command Queue Engine enabled
[ 3.436637] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 3.440315] mmc0: new HS200 MMC card at address 0001
[ 3.447788] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 3.452243] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[ 3.459683] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 3.464068] mmcblk0boot0: mmc0:0001 G1M15L partition 1 31.5 MiB
[ 3.472054] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 3.478047] mmcblk0boot1: mmc0:0001 G1M15L partition 2 31.5 MiB
[ 3.486035] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.500246] mmcblk0rpmb: mmc0:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
[ 3.500849] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 3.515077] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 3.523197] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 3.531288] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.540303] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 3.547802] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 3.555889] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 3.563973] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.588342] ALSA device list:
[ 3.589964] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 3.591309] No soundcards found.
[ 3.598800] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 3.610240] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 3.618334] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.626996] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 3.634493] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 3.642578] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 3.650658] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.659087] Waiting for root device PARTUUID=bb4483c1-02...
[ 33.841301] tlv71033: disabling
