Other Parts Discussed in Thread: UNIFLASH, TPS65910, TPS65217, FLASHTOOL, AM3358
大家好,
最近在AM335x BeagleBone Black 上完整验证了下eMMC的烧写,总结了一篇文档共享出来,欢迎拍砖。
附件是文档中所描述的debrick.sh,烧写用的文件系统在后面的跟帖,这篇帖子可以和“AM335x Flash Tool -- UniFlash 烧写工具使用简介及问题解决方案汇总”互为参考。
您好 , 我使用BBB SDK 2.0 eMMC 燒錄 後發現重開機一直只能夠停在下列的階段...重複開關機次都一樣...請問有甚麼方式解決或是清除可以讓我重新再燒錄?謝謝!
U-Boot SPL 2013.01.01 (Sep 01 2016 - 00:31:54)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
有時候會會出現下列訊息 :
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
Hi Jian工 您好~
請問我燒錄完後都會出現下列訊息,似乎是敘述空間不夠需要刪掉程序...等等
下列是Log & uniflash & debrick 內容 :
[eMMC 燒錄訊息] :
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
U-Boot SPL 2013.01.01 (Oct 21 2014 - 14:08:51)
Using default environment
usb_ether
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC 1c:ba:8c:96:0d:6a
HOST MAC de:ad:be:af:00:00
RNDIS ready
musb-hdrc: peripheral reset irq lost!
high speed config #2: 2 mA, Ethernet Gadget, using RNDIS
USB RNDIS network up!
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
Using usb_ether device
TFTP from server 192.168.100.1; our IP address is 192.168.100.2
Filename 'u-boot-restore.img'.
Load address: 0x807fffc0
Loading: #########################
873 KiB/s
done
Bytes transferred = 365104 (59230 hex)
U-Boot 2013.01.01 (Oct 21 2014 - 14:08:51)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - readenv() failed, using default environment
USB Host mode controller at 47401800 using PIO, IRQ 0
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw, usb_ether
Hit any key to stop autoboot: 0
RNDIS ready
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 192.168.100.2
RNDIS ready
Filename 'uImage'.
Load address: 0x81000000
Loading: T #################################################################
1.4 MiB/s
done
Bytes transferred = 12228888 (ba9918 hex)
## Booting kernel from Legacy Image at 81000000 ...
Image Name: Linux-3.2.0
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 12228824 Bytes = 11.7 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 3.2.0 (matthew@matthew-ubuntu) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #2 Fri Apr 10 11:53:58 EDT 2015
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: am335xevm
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: root=/dev/mmcblk0p2 rootwait console=ttyO0,115200
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 512MB = 512MB total
[ 0.000000] Memory: 499160k/499160k available, 25128k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc04ee000 (5016 kB)
[ 0.000000] .init : 0xc04ee000 - 0xc138d000 (14972 kB)
[ 0.000000] .data : 0xc138e000 - 0xc13ed0a8 ( 381 kB)
[ 0.000000] .bss : 0xc13ed0cc - 0xc141b344 ( 185 kB)
[ 0.000000] NR_IRQS:396
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000091] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.088836] pid_max: default: 32768 minimum: 301
[ 0.088928] Security Framework initialized
[ 0.089019] Mount-cache hash table entries: 512
[ 0.089324] CPU: Testing write buffer coherency: ok
[ 0.108612] omap_hwmod: pruss: failed to hardreset
[ 0.109527] print_constraints: dummy:
[ 0.109802] NET: Registered protocol family 16
[ 0.111450] OMAP GPIO hardware version 0.1
[ 0.113403] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.114868] omap_i2c.1: alias fck already exists
[ 0.115539] omap2_mcspi.1: alias fck already exists
[ 0.115692] omap2_mcspi.2: alias fck already exists
[ 0.116394] edma.0: alias fck already exists
[ 0.116424] edma.0: alias fck already exists
[ 0.131195] bio: create slab <bio-0> at 0
[ 0.132812] SCSI subsystem initialized
[ 0.134063] usbcore: registered new interface driver usbfs
[ 0.134277] usbcore: registered new interface driver hub
[ 0.134429] usbcore: registered new device driver usb
[ 0.134674] registerd cppi-dma Intr @ IRQ 17
[ 0.134704] Cppi41 Init Done Qmgr-base(e087a000) dma-base(e0878000)
[ 0.134704] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[ 0.134948] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[ 0.135772] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[ 0.136840] tps65910 1-002d: could not be detected
[ 0.138549] Switching to clocksource gp timer
[ 0.150054] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.150207] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[ 0.150451] MUSB0 controller's USBSS revision = 4ea20800
[ 0.150482] musb0: Enabled SW babble control
[ 0.151214] musb-hdrc musb-hdrc.0: USB OTG mode controller at e083c000 using DMA, IRQ 18
[ 0.151336] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[ 0.151580] MUSB1 controller's USBSS revision = 4ea20800
[ 0.151580] musb1: Enabled SW babble control
[ 0.151916] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.151977] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.152099] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.152099] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.152099] usb usb1: Product: MUSB HDRC host driver
[ 0.152130] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[ 0.152130] usb usb1: SerialNumber: musb-hdrc.1
[ 0.152770] hub 1-0:1.0: USB hub found
[ 0.152801] hub 1-0:1.0: 1 port detected
[ 0.153228] musb-hdrc musb-hdrc.1: USB Host mode controller at e083e800 using DMA, IRQ 19
[ 0.153564] NET: Registered protocol family 2
[ 0.153717] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.153961] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.154174] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.154296] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.154296] TCP reno registered
[ 0.154327] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.154327] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.154479] NET: Registered protocol family 1
[ 0.154663] RPC: Registered named UNIX socket transport module.
[ 0.154693] RPC: Registered udp transport module.
[ 0.154693] RPC: Registered tcp transport module.
[ 0.154693] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.238922] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.255798] VFS: Disk quotas dquot_6.5.2
[ 0.255859] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.256317] msgmni has been set to 974
[ 0.258758] alg: No test for stdrng (krng)
[ 0.259307] io scheduler noop registered
[ 0.259338] io scheduler deadline registered
[ 0.259399] io scheduler cfq registered (default)
[ 0.260345] Could not set LED4 to fully on
[ 0.299499] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 0.871337] console [ttyO0] enabled
[ 0.875366] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 0.883087] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 0.890777] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 0.898437] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 0.906127] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 0.914184] omap4_rng omap4_rng: OMAP4 Random Number Generator ver. 2.00
[ 0.928070] brd: module loaded
[ 0.935028] loop: module loaded
[ 0.938446] i2c-core: driver [tsl2550] using legacy suspend method
[ 0.944946] i2c-core: driver [tsl2550] using legacy resume method
[ 0.951385] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.049224] No daughter card found
[ 1.052795] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.067993] Board name: A335BNLT
[ 1.071380] Board version: 000C
[ 1.074645] The board is a AM335x Beaglebone Black.
[ 1.081817] tps65217 1-0024: TPS65217 ID 0xe version 1.2
[ 1.089355] print_constraints: DCDC1: 900 <--> 1800 mV at 1500 mV
[ 1.097747] print_constraints: DCDC2: 900 <--> 3300 mV at 1325 mV
[ 1.106140] print_constraints: DCDC3: 900 <--> 1500 mV at 1125 mV
[ 1.114532] print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV
[ 1.122924] print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV
[ 1.131195] print_constraints: LDO3: 1800 <--> 3300 mV at 1800 mV
[ 1.139587] print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV
[ 1.146545] Maximum current provided by the USB port is 500mA which is not sufficient
[ 1.146545] when operating @OPP120 and OPPTURBO. The current requirement for some
[ 1.146545] use-cases using OPP100 might also exceed the maximum current that the
[ 1.146575] USB port can provide. Unless you are fully confident that the current
[ 1.146575] requirements for OPP100 use-case don't exceed the USB limits, switching
[ 1.146575] to AC power is recommended.
[ 1.190551] omap_hsmmc.0: alias fck already exists
[ 1.195953] omap_hsmmc.1: alias fck already exists
[ 1.201324] omap_i2c.3: alias fck already exists
[ 1.206512] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 100 kHz
[ 1.213989] registered am33xx_sr device
[ 1.219543] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.226562] omap2-nand driver initializing
[ 1.231018] OneNAND driver initializing
[ 1.235961] CAN device driver interface
[ 1.240020] CAN bus driver for Bosch D_CAN controller 1.0
[ 1.245941] usbcore: registered new interface driver cdc_ether
[ 1.252166] usbcore: registered new interface driver cdc_eem
[ 1.258178] usbcore: registered new interface driver dm9601
[ 1.264038] cdc_ncm: 04-Aug-2011
[ 1.267547] usbcore: registered new interface driver cdc_ncm
[ 1.273468] Initializing USB Mass Storage driver...
[ 1.278747] usbcore: registered new interface driver usb-storage
[ 1.285034] USB Mass Storage support registered.
[ 1.289916] gadget: using random self ethernet address
[ 1.295379] gadget: using random host ethernet address
[ 1.301330] usb0: MAC f6:78:5c:fc:60:b4
[ 1.305328] usb0: HOST MAC 4a:0f:cd:66:2c:b2
[ 1.309875] gadget: Ethernet Gadget, version: Memorial Day 2008
[ 1.316162] gadget: g_ether ready
[ 1.319732] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 1.325347] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 1.333190] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.340301] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.347839] usb usb2: Product: MUSB HDRC host driver
[ 1.353027] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
[ 1.358581] usb usb2: SerialNumber: musb-hdrc.0
[ 1.363983] hub 2-0:1.0: USB hub found
[ 1.367919] hub 2-0:1.0: 1 port detected
[ 1.372863] mousedev: PS/2 mouse device common for all mice
[ 1.379638] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as rtc0
[ 1.386657] am33xx-rtc: already running
[ 1.390869] i2c /dev entries driver
[ 1.670013] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.677581] cpuidle: using governor ladder
[ 1.681884] gadget: high-speed config #2: RNDIS
[ 1.687225] cpuidle: using governor menu
[ 1.694793] omap4_aes_mod_init: loading AM33X AES driver
[ 1.700469] omap4-aes omap4-aes: AM33X AES hw accel rev: 3.02
[ 1.706878] omap4_aes_probe: probe() done
[ 1.711486] omap4_sham_mod_init: loading AM33X SHA/MD5 driver
[ 1.717681] omap4-sham omap4-sham: AM33X SHA/MD5 hw accel rev: 4.03
[ 1.747558] omap4_sham_probe: probe() done
[ 1.752502] oprofile: hardware counters not available
[ 1.757812] oprofile: using timer interrupt.
[ 1.762359] nf_conntrack version 0.5.0 (7799 buckets, 31196 max)
[ 1.769104] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.774810] TCP cubic registered
[ 1.778198] NET: Registered protocol family 17
[ 1.782897] can: controller area network core (rev 20090105 abi 8)
[ 1.789459] NET: Registered protocol family 29
[ 1.794097] can: raw protocol (rev 20090105)
[ 1.798583] can: broadcast manager protocol (rev 20090105 t)
[ 1.804534] Registering the dns_resolver key type
[ 1.809539] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 1.817596] ThumbEE CPU extension supported.
[ 1.822143] mux: Failed to setup hwmod io irq -22
[ 1.827636] Power Management for AM33XX family
[ 1.832519] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[ 1.839263] Copied the M3 firmware to UMEM
[ 1.843627] Cortex M3 Firmware Version = 0x181
[ 1.849121] create_regulator: DCDC2: Failed to create debugfs directory
[ 1.856719] smartreflex smartreflex: am33xx_sr_probe: Driver initialized
[ 1.867797] clock: disabling unused clocks to save power
[ 1.880035] mmc1: new high speed MMC card at address 0001
[ 1.888702] mmcblk0: mmc1:0001 MMC04G 3.60 GiB
[ 1.893829] mmcblk0boot0: mmc1:0001 MMC04G partition 1 2.00 MiB
[ 1.903472] mmcblk0boot1: mmc1:0001 MMC04G partition 2 2.00 MiB
[ 1.914276] mmcblk0: unknown partition table
[ 1.924163] mmcblk0boot1: unknown partition table
[ 1.934143] mmcblk0boot0: unknown partition table
[ 2.228240] omap_rtc am33xx-rtc: setting system clock to 2014-02-17 19:23:33 UTC (1392665013)
[ 2.255279] Freeing init memory: 14972K
INIT: version 2.88 booting
Starting udev
[ 4.197204] EXT3-fs (mmcblk0): error: can't find ext3 filesystem on dev mmcblk0.
[ 4.205596] EXT2-fs (mmcblk0): error: can't find an ext2 filesystem on dev mmcblk0.
[ 4.214111] FAT-fs (mmcblk0): bogus number of reserved sectors
[ 4.220214] FAT-fs (mmcblk0): Can't find a valid FAT filesystem
[ 4.240173] cramfs: wrong magic
[ 4.244049] FAT-fs (mmcblk0): bogus number of reserved sectors
[ 4.250183] FAT-fs (mmcblk0): Can't find a valid FAT filesystem
[ 4.523223] EXT3-fs (mmcblk0boot1): error: can't find ext3 filesystem on dev mmcblk0boot1.
[ 4.533782] EXT2-fs (mmcblk0boot1): error: can't find an ext2 filesystem on dev mmcblk0boot1.
[ 4.543823] FAT-fs (mmcblk0boot1): invalid media value (0x63)
[ 4.549896] FAT-fs (mmcblk0boot1): Can't find a valid FAT filesystem
[ 4.570007] EXT3-fs (mmcblk0boot0): error: can't find ext3 filesystem on dev mmcblk0boot0.
[ 4.584381] EXT2-fs (mmcblk0boot0): error: can't find an ext2 filesystem on dev mmcblk0boot0.
[ 4.594329] FAT-fs (mmcblk0boot0): bogus number of reserved sectors
[ 4.600921] FAT-fs (mmcblk0boot0): Can't find a valid FAT filesystem
[ 4.613067] cramfs: wrong magic
[ 4.620727] FAT-fs (mmcblk0boot1): invalid media value (0x63)
[ 4.626770] FAT-fs (mmcblk0boot1): Can't find a valid FAT filesystem
[ 4.640991] cramfs: wrong magic
[ 4.647369] FAT-fs (mmcblk0boot0): bogus number of reserved sectors
[ 4.654022] FAT-fs (mmcblk0boot0): Can't find a valid FAT filesystem
Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device
done.
Collected errors:
INIT: Entering runlevel: 5ot create lock file /var/lib/opkg/lock: No such fil
Starting syslogd/klogd: done
Sitara Flash Fetcher Script - 07/28/2014
udhcpc (v1.20.2) started
Sending discover...
Sending discover...
Sending discover...
Sending select for 192.168.100.22...
Lease of 192.168.100.22 obtained, lease time 600
Getting flasher script from server: 192.168.100.1
Sitara Flash Fetcher is complete. Executing debrick.sh.
Calling Script=debrick.sh with SERVER_IP=192.168.100.1
Sitara Example Flashing Script - 02/11/2014
Getting files from server: 192.168.100.1
1+0 records in
1+0 records out
BusyBox v1.20.2 (2014-02-17 12:53:20 CST) multi-call binary.
Usage: tftp [OPTIONS] HOST [PORT]
Command exited with non-zero status 1
real 0m 0.03s
user 0m 0.00s
sys 0m 0.00s
No partition found. Continuing.
Partitioning the eMMC...
Checking that no-one is using th[ 12.145385] mmcblk0: unknown partition table
is disk right now ...
OK
[ 12.157867] mmcblk0: p1 p2rs, 255 heads, 63 sectors/track
sfdisk: ERROR: sector 0 does not have an msdos signature
sfdisk: /dev/mmcblk0: unrecognized partition table type
Old situation:
sfdisk: No partitions found
New situation:
Units = cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End #cyls #blocks Id System
/dev/mmcblk0p1 * 0+ 8 9- 72261 c W95 FAT32 (LBA)
/dev/mmcblk0p2 10 469 460 3694950 83 Linux
/dev/mmcblk0p3 0 - 0 0 0 Empty
/dev/mmcblk0p4 0 - 0 0 0 Empty
Successfully wrote the new partition table
Re-reading the partition table ...
If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes: dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
[ 13.124206] EXT3-fs (mmcblk0p1): error: can't find ext3 filesystem on dev mmcblk0p1.
[ 13.134887] EXT3-fs (mmcblk0p2): error: can't find ext3 filesystem on dev mmcblk0p2.
[ 13.144927] EXT2-fs (mmcblk0p1): error: can't find an ext2 filesystem on dev mmcblk0p1.
[ 13.155273] EXT2-fs (mmcblk0p2): error: can't find an ext2 filesystem on dev mmcblk0p2.
[ 13.166168] FAT-fs (mmcblk0p1): bogus number of reserved sectors
[ 13.172546] FAT-fs (mmcblk0p1): Can't find a valid FAT filesystem
[ 13.182067] FAT-fs (mmcblk0p2): bogus number of reserved sectors
[ 13.188476] FAT-fs (mmcblk0p2): Can't find a valid FAT filesystem
real 0m 1.38s
user 0m 0.01s
sys 0m 0.27s
[ 13.287139] cramfs: wrong magic
[ 13.294219] FAT-fs (mmcblk0p1): bogus number of reserved sectors
[ 13.300628] FAT-fs (mmcblk0p1): Can't find a valid FAT filesystem
[ 13.317962] cramfs: wrong magic
[ 13.325073] FAT-fs (mmcblk0p2): bogus number of reserved sectors
[ 13.331420] FAT-fs (mmcblk0p2): Can't find a valid FAT filesystem
1+0 records in
1+0 records out
Formatting the eMMC into 2 partitions...
mkfs.vfat 2.11 (12 Mar 2005)
mke2fs 1.42.1 (17-Feb-2012)
Discarding device blocks: done
Filesystem label=rootfs
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
231072 inodes, 923737 blocks
46186 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=947912704
29 block groups
32768 blocks per group, 32768 fragments per group
7968 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736
Allocating group tables: done
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
Formatting done.
[ 30.076599] kjournald starting. Commit interval 5 seconds
[ 30.085540] EXT3-fs (mmcblk0p2): using internal journal
[ 30.091094] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
Copying Files...
real 0m 1.08s
user 0m 0.46s
sys 0m 0.40s
Boot partition done.
tar: no gzip/bzip2 magic
real 0m 0.00s
user 0m 0.00s
sys 0m 0.00s
tar: can't open '-C': No such file or directory
real 0m 0.00s
user 0m 0.00s
sys 0m 0.00s
RootFS partition done.
It took 20 seconds to complete this task...
Sitara Example Flash Script is complete.
Stopping Bootlog daemon: bootlogd.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm ttyO0
Arago 2013.05 am335x-evm ttyO0
am335x-evm login: [ 78.645782] tftp invoked oom-killer: gfp_mask=0x200d2, order=0, oom_adj=0, oom_score_adj=0
[ 78.654510] Backtrace:
[ 78.657104] [<c0017dbc>] (dump_backtrace+0x0/0x10c) from [<c039e638>] (dump_stack+0x18/0x1c)
[ 78.665924] r6:000200d2 r5:00000000 r4:ddd09280 r3:c13b13e8
[ 78.671875] [<c039e620>] (dump_stack+0x0/0x1c) from [<c007d29c>] (dump_header.isra.14+0x54/0x150)
[ 78.681182] [<c007d248>] (dump_header.isra.14+0x0/0x150) from [<c007d5ac>] (oom_kill_process.constprop.19+0x70/0x22c)
[ 78.692291] r8:ddea1cc0 r7:00000001 r6:000200d2 r5:00000000 r4:ddea1cc0
[ 78.699310] [<c007d53c>] (oom_kill_process.constprop.19+0x0/0x22c) from [<c007daf4>] (out_of_memory+0x23c/0x2d0)
[ 78.709960] [<c007d8b8>] (out_of_memory+0x0/0x2d0) from [<c00809c4>] (__alloc_pages_nodemask+0x640/0x664)
[ 78.719970] [<c0080384>] (__alloc_pages_nodemask+0x0/0x664) from [<c007b0c4>] (grab_cache_page_write_begin+0x54/0xc0)
[ 78.731079] [<c007b070>] (grab_cache_page_write_begin+0x0/0xc0) from [<c00c4b94>] (simple_write_begin+0x28/0x108)
[ 78.741821] [<c00c4b6c>] (simple_write_begin+0x0/0x108) from [<c0079f8c>] (generic_file_buffered_write+0x1a8/0x26c)
[ 78.752746] [<c0079de4>] (generic_file_buffered_write+0x0/0x26c) from [<c007ba98>] (__generic_file_aio_write+0x244/0x478)
[ 78.764221] [<c007b854>] (__generic_file_aio_write+0x0/0x478) from [<c007bd30>] (generic_file_aio_write+0x64/0xd0)
[ 78.775054] [<c007bccc>] (generic_file_aio_write+0x0/0xd0) from [<c00a602c>] (do_sync_write+0xac/0xec)
[ 78.784820] [<c00a5f80>] (do_sync_write+0x0/0xec) from [<c00a67a8>] (vfs_write+0xa4/0x148)
[ 78.793457] [<c00a6704>] (vfs_write+0x0/0x148) from [<c00a6a48>] (sys_write+0x40/0x78)
[ 78.801727] r8:00001000 r7:0009702c r6:c0820140 r5:00000000 r4:1da33000
[ 78.808776] [<c00a6a08>] (sys_write+0x0/0x78) from [<c0014740>] (ret_fast_syscall+0x0/0x30)
[ 78.817504] r8:c00148e8 r7:00000004 r6:00000004 r5:0009702c r4:00001000
[ 78.824554] Mem-info:
[ 78.826904] Normal per-cpu:
[ 78.829833] CPU 0: hi: 186, btch: 31 usd: 138
[ 78.834838] active_anon:324 inactive_anon:36 isolated_anon:0
[ 78.834838] active_file:897 inactive_file:0 isolated_file:0
[ 78.834838] unevictable:124715 dirty:0 writeback:0 unstable:0
[ 78.834869] free:702 slab_reclaimable:581 slab_unreclaimable:719
[ 78.834869] mapped:202 shmem:49 pagetables:43 bounce:0
[ 78.864593] Normal free:2808kB min:2884kB low:3604kB high:4324kB active_anon:1296kB inactive_anon:144kB active_file:3588kB inactive_file:0kB unevictable:498860kB isolated(anon):0kB isolated(file):0kB present:520192kB mlocked:0kB dirty:0kB writeback:0kB mapped:808kB shmem:196kB slab_reclaimable:2324kB slab_unreclaimable:2876kB kernel_stack:368kB pagetables:172kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:124715 all_unreclaimable? yes
[ 78.905853] lowmem_reserve[]: 0 0
[ 78.909332] Normal: 0*4kB 1*8kB 1*16kB 1*32kB 1*64kB 1*128kB 0*256kB 1*512kB 0*1024kB 1*2048kB 0*4096kB 0*8192kB = 2808kB
[ 78.920837] 125661 total pagecache pages
[ 78.924926] 0 pages in swap cache
[ 78.928405] Swap cache stats: add 0, delete 0, find 0/0
[ 78.933868] Free swap = 0kB
[ 78.936859] Total swap = 0kB
[ 78.957305] 131072 pages of RAM
[ 78.960632] 936 free pages
[ 78.963470] 2539 reserved pages
[ 78.966766] 1300 slab pages
[ 78.969665] 1193 pages shared
[ 78.972778] 0 pages swap cached
[ 78.976074] [ pid ] uid tgid total_vm rss cpu oom_adj oom_score_adj name
[ 78.983886] [ 763] 0 763 444 178 0 -17 -1000 udevd
[ 78.991729] [ 941] 0 941 470 196 0 -17 -1000 udevd
[ 78.999572] [ 955] 0 955 443 190 0 -17 -1000 udevd
[ 79.007446] [ 1277] 0 1277 457 139 0 0 0 syslogd
[ 79.015472] [ 1280] 0 1280 457 133 0 0 0 klogd
[ 79.023345] [ 1297] 0 1297 457 58 0 0 0 udhcpc
[ 79.031311] [ 1304] 0 1304 424 98 0 0 0 time
[ 79.039062] [ 1309] 0 1309 457 130 0 0 0 tftp
[ 79.046813] [ 1422] 0 1422 393 124 0 0 0 getty
[ 79.054687] [ 1423] 0 1423 393 124 0 0 0 getty
[ 79.062561] Out of memory: Kill process 1277 (syslogd) score 1 or sacrifice child
[ 79.070404] Killed process 1277 (syslogd) total-vm:1828kB, anon-rss:60kB, file-rss:496kB
[ 79.176849] tftp invoked oom-killer: gfp_mask=0x200d2, order=0, oom_adj=0, oom_score_adj=0
[ 79.185546] Backtrace:
[ 79.188140] [<c0017dbc>] (dump_backtrace+0x0/0x10c) from [<c039e638>] (dump_stack+0x18/0x1c)
[ 79.196960] r6:000200d2 r5:00000000 r4:ddd09280 r3:c13b13e8
[ 79.202911] [<c039e620>] (dump_stack+0x0/0x1c) from [<c007d29c>] (dump_header.isra.14+0x54/0x150)
[ 79.212188] [<c007d248>] (dump_header.isra.14+0x0/0x150) from [<c007d5ac>] (oom_kill_process.constprop.19+0x70/0x22c)
[ 79.223297] r8:c0843980 r7:00000001 r6:000200d2 r5:00000000 r4:c0843980
[ 79.230316] [<c007d53c>] (oom_kill_process.constprop.19+0x0/0x22c) from [<c007daf4>] (out_of_memory+0x23c/0x2d0)
[ 79.240997] [<c007d8b8>] (out_of_memory+0x0/0x2d0) from [<c00809c4>] (__alloc_pages_nodemask+0x640/0x664)
[ 79.251007] [<c0080384>] (__alloc_pages_nodemask+0x0/0x664) from [<c007b0c4>] (grab_cache_page_write_begin+0x54/0xc0)
[ 79.262207] [<c007b070>] (grab_cache_page_write_begin+0x0/0xc0) from [<c00c4b94>] (simple_write_begin+0x28/0x108)
[ 79.272949] [<c00c4b6c>] (simple_write_begin+0x0/0x108) from [<c0079f8c>] (generic_file_buffered_write+0x1a8/0x26c)
[ 79.283874] [<c0079de4>] (generic_file_buffered_write+0x0/0x26c) from [<c007ba98>] (__generic_file_aio_write+0x244/0x478)
[ 79.295349] [<c007b854>] (__generic_file_aio_write+0x0/0x478) from [<c007bd30>] (generic_file_aio_write+0x64/0xd0)
[ 79.306182] [<c007bccc>] (generic_file_aio_write+0x0/0xd0) from [<c00a602c>] (do_sync_write+0xac/0xec)
[ 79.315917] [<c00a5f80>] (do_sync_write+0x0/0xec) from [<c00a67a8>] (vfs_write+0xa4/0x148)
[ 79.324584] [<c00a6704>] (vfs_write+0x0/0x148) from [<c00a6a48>] (sys_write+0x40/0x78)
[ 79.332855] r8:00001000 r7:0009702c r6:c0820140 r5:00000000 r4:1dad0000
[ 79.339904] [<c00a6a08>] (sys_write+0x0/0x78) from [<c0014740>] (ret_fast_syscall+0x0/0x30)
[ 79.348632] r8:c00148e8 r7:00000004 r6:00000004 r5:0009702c r4:00001000
[ 79.355651] Mem-info:
[ 79.358032] Normal per-cpu:
[ 79.360961] CPU 0: hi: 186, btch: 31 usd: 113
[ 79.366027] active_anon:309 inactive_anon:36 isolated_anon:0
[ 79.366027] active_file:0 inactive_file:0 isolated_file:0
[ 79.366027] unevictable:125769 dirty:0 writeback:0 unstable:0
[ 79.366027] free:708 slab_reclaimable:468 slab_unreclaimable:719
[ 79.366027] mapped:196 shmem:49 pagetables:39 bounce:0
[ 79.395599] Normal free:2832kB min:2884kB low:3604kB high:4324kB active_anon:1236kB inactive_anon:144kB active_file:0kB inactive_file:0kB unevictable:503076kB isolated(anon):0kB isolated(file):0kB present:520192kB mlocked:0kB dirty:0kB writeback:0kB mapped:784kB shmem:196kB slab_reclaimable:1872kB slab_unreclaimable:2876kB kernel_stack:360kB pagetables:156kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:1054 all_unreclaimable? yes
[ 79.436431] lowmem_reserve[]: 0 0
[ 79.439910] Normal: 58*4kB 1*8kB 0*16kB 1*32kB 0*64kB 2*128kB 1*256kB 2*512kB 1*1024kB 0*2048kB 0*4096kB 0*8192kB = 2832kB
[ 79.451507] 125818 total pagecache pages
[ 79.455627] 0 pages in swap cache
[ 79.459106] Swap cache stats: add 0, delete 0, find 0/0
[ 79.464569] Free swap = 0kB
[ 79.467559] Total swap = 0kB
[ 79.487884] 131072 pages of RAM
[ 79.491210] 913 free pages
[ 79.494018] 2539 reserved pages
[ 79.497314] 1187 slab pages
[ 79.500213] 1070 pages shared
[ 79.503326] 0 pages swap cached
[ 79.506591] [ pid ] uid tgid total_vm rss cpu oom_adj oom_score_adj name
[ 79.514373] [ 763] 0 763 444 178 0 -17 -1000 udevd
[ 79.522186] [ 941] 0 941
到這邊就停住了....
[Uniflash 狀態]
[debrick.sh]
echo "****************************************************"
echo ""
echo "Sitara Example Flashing Script - 02/11/2014"
echo ""
STARTTIME=$(date +%s)
##---------Start of variables---------------------##
## Set Server IP here
SERVER_IP="192.168.100.1"
## Names of the images to grab from TFTP server
BOOT_PARTITION="boot_partition.tar.gz"
## Rename rootfs as needed depending on use of tar or img
ROOTFS_PARTITION="rootfs_partition.tar.gz"
##ROOTFS_USR="usr.tar.gz"
## ROOTFS_PARTITION="rootfs_partition/"
## ROOTFS_PARTITION="rootfs_partition.img.gz"
## Declare eMMC device name here
DRIVE="/dev/mmcblk0"
##----------End of variables-----------------------##
## TFTP files from host. Edit the files and host IP address for your application.
## We are grabbing two files, one an archive with files to populate a FAT partion,
## which we will create. Another for a filesystem image to 'dd' onto an unmounted partition.
## Using a compressed tarball can be easier to implement, however, with a large file system
## with a lot of small files, we recommend a 'dd' image of the partition to speed up writes.
echo "Getting files from server: ${SERVER_IP}"
time tftp -b 4096 -g -r ${BOOT_PARTITION} ${SERVER_IP} &
boot_pid=$!
time tftp -b 4096 -g -r ${ROOTFS_PARTITION} ${SERVER_IP} &
rootfs_pid=$!
time tftp -b 4096 -g -r ${ROOTFS_USR} ${SERVER_IP} &
rootfs_pid=$!
## Kill any partition info that might be there
dd if=/dev/zero of=$DRIVE bs=4k count=1
sync
sync
## Figure out how big the eMMC is in bytes
SIZE=`fdisk -l $DRIVE | grep Disk | awk '{print $5}'`
## Translate size into segments, which traditional tools call Cylinders. eMMC is not a spinning disk.
## We are basically ignoring what FDISK and SFDISK are reporting because it is not really accurate.
## we are translating this info to something that makes more sense for eMMC.
CYLINDERS=`echo $SIZE/255/63/512 | bc`
## Check to see if the eMMC partitions have automatically loaded from the old MBR.
## This might have occured during the boot process if the kernel detected a filesystem
## before we killed the MBR. We will need to unmount and kill them by writing 4k zeros to the
## partitions that were found.
check_mounted(){
is_mounted=$(grep ${DRIVE}p /proc/mounts | awk '{print $2}')
if grep -q ${DRIVE}p /proc/mounts; then
echo "Found mounted partition(s) on " ${DRIVE}": " $is_mounted
umount $is_mounted
counter=1
for i in $is_mounted; do \
echo "4k erase on ${DRIVE}p${counter}";
dd if=/dev/zero of=${DRIVE}p${counter} bs=4k count=1;
counter=$((counter+1));
done
else
echo "No partition found. Continuing."
fi
check_mounted;
## Partitioning the eMMC using information gathered.
## Here is where you can add/remove partitions.
## We are building 2 partitions:
## 1. FAT, size = 9 cylinders * 255 heads * 63 sectors * 512 bytes/sec = ~70MB
## 2. EXT3, size = 223 ($CYLINDERS-[9 for fat]) cylinders * 255 heads * 63 sectors * 512 bytes/sec = ~1l.7GB
## You will need to change the lines ",9,0c0C,*", "10,,,-" to suit your needs. Adding is similar,
## but you will need to be aware of partition sizes and boundaries. Use the man page for sfdisk.
echo "Partitioning the eMMC..."
sfdisk -D -H 255 -S 63 -C $CYLINDERS $DRIVE << EOF
,9,0x0C,*
10,,,-
EOF
## This sleep is necessary as there is a service which attempts
## to automount any filesystems that it finds as soon as sfdisk
## finishes partitioning. We sleep to let it run. May need to
## be lengthened if you have more partitions.
sleep 2
## Check here if there has been a partition that automounted.
## This will eliminate the old partition that gets
## automatically found after the sfdisk command. It ONLY
## gets found if there was a previous file system on the same
## partition boundary. Happens when running this script more than once.
## To fix, we just unmount and write some zeros to it.
check_mounted;
## Clean up the dos (FAT) partition as recommended by SFDISK
dd if=/dev/zero of=${DRIVE}p1 bs=512 count=1
## Make sure posted writes are cleaned up
sync
sync
## Format the eMMC into 2 partitions
echo "Formatting the eMMC into 2 partitions..."
## Format the boot partition to fat32
mkfs.vfat -F 32 -n "boot" ${DRIVE}p1
## Format the rootfs to ext3 (or ext4, etc.) if using a tar file.
## We DO NOT need to format this partition if we are 'dd'ing an image
## Comment out this line if using 'dd' of an image.
mkfs.ext3 -L "rootfs" ${DRIVE}p2
sync
sync
echo "Formatting done."
## Make temp directories for mountpoints
mkdir tmp_boot
## Comment this line out if using 'dd' of an image. It is not needed.
mkdir tmp_rootfs
## Mount partitions for tarball extraction. NOT for 'dd'.
mount -t vfat ${DRIVE}p1 tmp_boot
## If 'dd'ing the rootfs, there is no need to mount it. Comment out the below.
mount -t ext3 ${DRIVE}p2 tmp_rootfs
## Wait for boot to finish tftp
wait $boot_pid
echo "Copying Files..."
time tar -xf ${BOOT_PARTITION} -C tmp_boot
sync
sync
umount ${DRIVE}p1
rm ${BOOT_PARTITION}
echo "Boot partition done."
## Wait for rootfs to finish tftp
wait $rootfs_pid
## If using a tar archive, untar it with the below.
## If using 'dd' of an img, comment these lines out and use the below.
#time tar -zxvf ${ROOTFS_PARTITION} -C
time tar -xf ${ROOTFS_PARTITION} -C tmp_rootfs
#time cp -r ${ROOTFS_PARTITION} tmp_rootfs
sync
sync
time tar -xf ${ROOTFS_USR} -C tmp_rootfs
sync
sync
umount ${DRIVE}p2
rm ${ROOTFS_PARTITION}
echo "RootFS partition done."
## If using 'dd' of an img, uncomment these lines.
## If using a tar archive, comment out these lines and use the above.
## time gunzip -c ${ROOTFS_PARTITION} | dd of=${DRIVE}p2 bs=4k
## sync
## sync
## echo "Rootfs partition done."
## The block below is only necessary if using 'dd'.
## Force check the filesystem for consistency and fix errors if any.
## Resize partition to the length specified by the MBR.
## /sbin/e2fsck -fy ${DRIVE}p2
## /sbin/resize2fs ${DRIVE}p2
ENDTIME=$(date +%s)
echo "It took $(($ENDTIME - $STARTTIME)) seconds to complete this task..."
## Reboot
echo ""
echo "********************************************"
echo "Sitara Example Flash Script is complete."
echo ""
重新啟動後僅能進入UBOOT MODE :
U-Boot SPL 2015.07-00114-gf5078ef-dirty (Feb 23 2016 - 18:30:35)
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
U-Boot 2015.07-00114-gf5078ef-dirty (Feb 23 2016 - 18:30:35 +0800)
Watchdog enabled
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
Card did not respond to voltage select!
** Bad device mmc 0 **
cpsw, usb_ether
switch to partitions #0, OK
mmc1(part 0) is current device
SD/MMC found on device 1
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
** Unable to read file uEnv.txt **
** File not found /boot/zImage **
Booting from nand ...
no devices available
Bad Linux ARM zImage magic!
U-Boot#
或是有相關建議的朋友可以給予建議與指導,非常感謝!!
周工 你好 :
我现在按照您提供的文档,用sdk6的代码可以usb烧录了,但我想移植到我自己的板子使用,用debrick.sh脚本将系统文件写入emmc后,烧录自己板子的uboot后卡在这里:
U-Boot SPL 2011.09 (Jun 18 2014 - 09:38:14)
ZHD-AM335x-Evaluation.
boot mode - RAW
mkimage signature not found - ih_magic = 0
Assuming u-boot.bin ..
我怀疑是不是烧写系统时偏移地址的问题,因为和我现在uboot的偏移地址不对应,因为uboot之前是别的同事移植的,我不熟悉这方面的烧写,我想问下:
7,9,0x0C,*
10,,,-
EOF
这一段是什么含义,怎么使用sfdisk命令,怎么设置分区时的初始地址,我的emmc大小是16G,网上找不到sfdisk具体操作、、
#define MLO_ADDR 0x20000
#define MLO_SIZE (1024*100)
#define UBOOT_ADDR 0x60000
#define UBOOT_SIZE (1024*256)
#define KERNEL_ADDR 0x100000
#define KERNEL_SIZE (1024*1024*2.5)
#define ROOTFS_ADDR 0x500000
#define ROOTFS_SIZE (1024*1024*2.8)
这个是我自己板子的uboot需要偏移的地址说明,按照这个我要怎么用sfdisk去调整参数分区,或者是还有没有其它方法命令可以去执行?
有点急 ,麻烦大家了!!谢谢!!
烧录的整个过程都是正确的么?你烧录的Linux应该不是TI的SDK吧?
jian zhou 你好 我使用的是sdk6.0版本的 按照您这个文档做的emmc烧写,现在遇见一个 问题,在uniflash下载软件中的 进度条进行到27%的时候就不能运行了
下面是我串口接收到的数据
