ccs3.3仿5402装载程序时,出现---------------------------
RTDX Configuration Control
Unable to determine default Pin/Port configuration!
确定
请教解决方法
确定
请教解决方法
查了一下,这个是仿真器驱动的bug, 没有修复。
The error message comes up when the plugin makes an RTDX_configure emulation driver call with a Get_Config parameter. Also as the C54 emulation code has not changed in years and ideally the above call shouldn't fail it might take some effort to figure out the cause of the source and fix it.
