用的开发平台式6678L,用edma 从一个固定地址搬运数据,固定地址src_addr中数据位*(src_addr)=0x5555。代码如下,编译成功之后运行发现有时候pingInBuff和pongInBuff中有数据,有时候没有,不知道是不是哪里没有配置好。
#include <stdio.h>
#include <ti/csl/csl_edma3.h>
#include <ti/csl/csl_edma3Aux.h>
#include <ti/csl/csl_cacheAux.h>
#define BUFF_SZ 256
#define TRANS_SZ 256
#define ELEMENT_WID_8BIT 1
#define ELEMENT_WID_16BIT 2 //acnt
CSL_TpccRegs* gEDMACC0Regs = (CSL_TpccRegs*)CSL_EDMA0CC_REGS;
CSL_TpccRegs* gEDMACC1Regs = (CSL_TpccRegs*)CSL_EDMA1CC_REGS;
CSL_TpccRegs* gEDMACC2Regs = (CSL_TpccRegs*)CSL_EDMA2CC_REGS;
Uint16 *src_addr=(Uint16*)0x0C000000;
Uint16 *dst_addr=(Uint16*)0x0C000010;
Uint16 src_val=2;
Uint16 srcBuff[BUFF_SZ];
Uint16 pingInBuff[BUFF_SZ];
Uint16 pongInBuff[BUFF_SZ];
Uint16 pingOutBuff[BUFF_SZ];
Uint16 pongOutBuff[BUFF_SZ];
int main()
CACHE_invL1d ((void *)srcBuff, 2*BUFF_SZ, CACHE_WAIT);
CACHE_invL2 ((void *)srcBuff, 2*BUFF_SZ, CACHE_WAIT);
CACHE_invL1d ((void *)pingInBuff,2*BUFF_SZ , CACHE_WAIT);
CACHE_invL2 ((void *)pingInBuff, 2*BUFF_SZ, CACHE_WAIT);
CACHE_invL1d ((void *)pongInBuff,2*BUFF_SZ , CACHE_WAIT);
CACHE_invL2 ((void *)pongInBuff, 2*BUFF_SZ, CACHE_WAIT);
CACHE_invL1d ((void *)pingOutBuff,2*BUFF_SZ , CACHE_WAIT);
CACHE_invL2 ((void *)pingOutBuff, 2*BUFF_SZ, CACHE_WAIT);
CACHE_invL1d ((void *)pongOutBuff,2*BUFF_SZ , CACHE_WAIT);
CACHE_invL2 ((void *)pongOutBuff, 2*BUFF_SZ, CACHE_WAIT);
_mfence();
Int32 instNum=0;
CSL_Edma3Handle hModule;
CSL_Edma3Obj edmaObj;
Uint8 channelNum_in=0;
CSL_Edma3ChannelObj chObj_in;
CSL_Edma3ChannelHandle hChannel_in;
CSL_Edma3ChannelAttr chAttr_in;
Uint8 channelNum_out=1;
CSL_Edma3ChannelObj chObj_out;
CSL_Edma3ChannelHandle hChannel_out;
CSL_Edma3ChannelAttr chAttr_out;
CSL_Edma3ParamSetup pingInParam;
CSL_Edma3ParamSetup pongInParam;
CSL_Edma3ParamHandle hPingInParam;
CSL_Edma3ParamHandle hPongInParam;
CSL_Edma3ParamSetup pingOutParam;
CSL_Edma3ParamSetup pongOutParam;
CSL_Edma3ParamHandle hPingOutParam;
CSL_Edma3ParamHandle hPongOutParam;
CSL_Edma3CmdIntr regionIntr;
CSL_Edma3Context context;
CSL_Status status;
int i;
for(i=0;i<BUFF_SZ;i++)
srcBuff[i]=src_val;
pingInBuff[i]=0;
pongInBuff[i]=0;
pingOutBuff[i]=2;
pongOutBuff[i]=2;
printf ("init is finished。。。。\n");
*(src_addr)=0x5555;//src_val;
/***************************init the edma moudle*****************************************************/
if (CSL_edma3Init(&context) != CSL_SOK)
printf ("Error: EDMA module initialization failed\n");
return -1;
hModule = CSL_edma3Open(&edmaObj, instNum, NULL, &status);
if ( (hModule == NULL) || (status != CSL_SOK))
printf ("Error: EDMA module open failed\n");
return -1;
printf("step 1 is done !!!\n");
/************************************init the channel_in and channel_out of the edma moudle**********/
chAttr_in.regionNum = CSL_EDMA3_REGION_GLOBAL;
chAttr_in.chaNum = channelNum_in;
hChannel_in = CSL_edma3ChannelOpen(&chObj_in, instNum, &chAttr_in, &status);
if ((hChannel_in == NULL) || (status != CSL_SOK))
printf ("Error: Unable to open EDMA Channel_in:%d\n", channelNum_in);
return -1;
else
printf ("EDMA channel_in open success !\n");
chAttr_out.regionNum = CSL_EDMA3_REGION_GLOBAL;
chAttr_out.chaNum = channelNum_out;
hChannel_out = CSL_edma3ChannelOpen(&chObj_out, instNum, &chAttr_out, &status);
if ((hChannel_out == NULL) || (status != CSL_SOK))
printf ("Error: Unable to open EDMA Channel_out:%d\n", channelNum_in);
return -1;
else
printf ("EDMA channel_out open success !\n");
printf("step 2 is done !!!\n");
/********************************* map the channel to the param set and build the handle to the param structure********/
CSL_edma3MapDMAChannelToParamBlock (hModule, channelNum_in, 2);
hPingInParam = CSL_edma3GetParamHandle(hChannel_in, 2, &status);
if (hPingInParam == NULL)
printf ("Error: EDMA Get Parameter Entry failed for 2.\n");
return -1;
hPongInParam = CSL_edma3GetParamHandle(hChannel_in, 1, &status);
if (hPongInParam == NULL)
printf ("Error: EDMA Get Parameter Entry failed for 1.\n");
return -1;
CSL_edma3MapDMAChannelToParamBlock (hModule, channelNum_out, 4);
hPingOutParam = CSL_edma3GetParamHandle(hChannel_out, 4, &status);
printf ("Error: EDMA Get Parameter Entry failed for 4.\n");
return -1;
hPongOutParam = CSL_edma3GetParamHandle(hChannel_out, 3, &status);
printf ("Error: EDMA Get Parameter Entry failed for 3.\n");
return -1;
printf("step 3 is done !!!\n");
/******************************************set the param structure in the memory***********************************************************/
/********** pingInParam **************************************************************************************/
pingInParam.option = CSL_EDMA3_OPT_MAKE(CSL_EDMA3_ITCCH_DIS, \
CSL_EDMA3_TCCH_DIS, \
CSL_EDMA3_ITCINT_DIS, \
CSL_EDMA3_TCINT_EN, \
0, CSL_EDMA3_TCC_NORMAL,\
CSL_EDMA3_FIFOWIDTH_NONE, \
CSL_EDMA3_STATIC_DIS, \
CSL_EDMA3_SYNC_A, \
CSL_EDMA3_ADDRMODE_INCR, \
CSL_EDMA3_ADDRMODE_INCR );// 上半部分不用修改,全当成incr来做,只不过修改acntbcnt
pingInParam.srcAddr = (Uint32)src_addr;//srcBuff;
pingInParam.aCntbCnt = CSL_EDMA3_CNT_MAKE(2,TRANS_SZ);//(2*TRANS_SZ,1);
pingInParam.dstAddr = (Uint32)pingInBuff;
pingInParam.srcDstBidx = CSL_EDMA3_BIDX_MAKE(0,2);//(1,1); //?????????????????
pingInParam.linkBcntrld= CSL_EDMA3_LINKBCNTRLD_MAKE(hPongInParam,0);
pingInParam.srcDstCidx = CSL_EDMA3_CIDX_MAKE(0,1);
pingInParam.cCnt = 1;
/********** pongInParam **************************************************************************************/
pongInParam.option = CSL_EDMA3_OPT_MAKE(CSL_EDMA3_ITCCH_DIS, \
CSL_EDMA3_SYNC_A, \
pongInParam.srcAddr = (Uint32)src_addr;//srcBuff;
pongInParam.aCntbCnt = CSL_EDMA3_CNT_MAKE(2,TRANS_SZ);//(2*TRANS_SZ,1);
pongInParam.dstAddr = (Uint32)pongInBuff;
pongInParam.srcDstBidx = CSL_EDMA3_BIDX_MAKE(0,2);//(1,1); //?????????????????
pongInParam.linkBcntrld= CSL_EDMA3_LINKBCNTRLD_MAKE(hPingInParam,0);
pongInParam.srcDstCidx = CSL_EDMA3_CIDX_MAKE(0,1);
pongInParam.cCnt = 1;
/********** pingOutParam**************************************************************************************/
pingOutParam.option = CSL_EDMA3_OPT_MAKE(CSL_EDMA3_ITCCH_DIS, \
CSL_EDMA3_SYNC_A, \
pingOutParam.srcAddr = (Uint32)pingOutBuff;//srcBuff;
pingOutParam.aCntbCnt = CSL_EDMA3_CNT_MAKE(2,TRANS_SZ);//(2*TRANS_SZ,1);
pingOutParam.dstAddr = (Uint32)dst_addr;
pingOutParam.srcDstBidx = CSL_EDMA3_BIDX_MAKE(2,0);//(1,1); //?????????????????
pingOutParam.linkBcntrld= CSL_EDMA3_LINKBCNTRLD_MAKE(hPongOutParam,0);
pingOutParam.srcDstCidx = CSL_EDMA3_CIDX_MAKE(0,1);
pingOutParam.cCnt = 1;
/********** pongOutParam**************************************************************************************/
pongOutParam.option = CSL_EDMA3_OPT_MAKE(CSL_EDMA3_ITCCH_DIS, \
CSL_EDMA3_SYNC_A, \
pongOutParam.srcAddr = (Uint32)pongOutBuff;//srcBuff;
pongOutParam.aCntbCnt = CSL_EDMA3_CNT_MAKE(2,TRANS_SZ);//(2*TRANS_SZ,1);
pongOutParam.dstAddr = (Uint32)dst_addr;
pongOutParam.srcDstBidx = CSL_EDMA3_BIDX_MAKE(2,0);//(1,1); //?????????????????
pongOutParam.linkBcntrld= CSL_EDMA3_LINKBCNTRLD_MAKE(hPingOutParam,0);
pongOutParam.srcDstCidx = CSL_EDMA3_CIDX_MAKE(0,1);
pongOutParam.cCnt = 1;
/************************set up the param set with the param structure******************/
if (CSL_edma3ParamSetup(hPingInParam,&pingInParam) != CSL_SOK)
printf ("Error: EDMA Parameter Entry Setup failed\n");
return -1;
if (CSL_edma3ParamSetup(hPongInParam,&pongInParam) != CSL_SOK)
return -1;
if (CSL_edma3ParamSetup(hPingOutParam,&pingOutParam) != CSL_SOK)
return -1;
if (CSL_edma3ParamSetup(hPongOutParam,&pongOutParam) != CSL_SOK)
return -1;
printf("step 4 is done !!!\n");
regionIntr.region = CSL_EDMA3_REGION_GLOBAL;
regionIntr.intr = 0x3;
regionIntr.intrh = 0x0000;
CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_INTR_ENABLE,®ionIntr);
/* Trigger channel */
int cnt;
for(cnt=0;cnt<2*TRANS_SZ;cnt++)
CSL_edma3HwChannelControl(hChannel_in,CSL_EDMA3_CMD_CHANNEL_SET,NULL);
CSL_edma3HwChannelControl(hChannel_out,CSL_EDMA3_CMD_CHANNEL_SET,NULL);
printf("step 5 is done !!!\n");
/* Close channel */
if (CSL_edma3ChannelClose(hChannel_in) != CSL_SOK)
printf("Error: EDMA Channel_in Close failed\n");
return -1;
if (CSL_edma3ChannelClose(hChannel_out) != CSL_SOK)
printf("Error: EDMA Channel_out Close failed\n");
return -1;
/* Close EDMA module */
if (CSL_edma3Close(hModule) != CSL_SOK)
printf("Error: EDMA Module Close failed\n");
return -1;
/* The test passed. */
printf("the test passed !!!\n");
return 0;
