Part Number: SK-AM62A-LP
SK-AM62A-LP的linux sdk包编译报错,找不到文件
在构建wic镜像时,运行这步clone失败,如下:
edu118@ubuntu:~/ti-processor-sdk-linux-am62axx-evm-08.06.00.45/tisdk$ ./oe-layertool-setup.sh -f configs/processor-sdk/processor-sdk-08.06.00-config.txt
/home/edu118/ti-processor-sdk-linux-am62axx-evm-08.06.00.45/tisdk
cloning repo bitbake
Fetching origin
Previous HEAD position was 0784db7d server/process: Disable gc around critical section
Switched to branch '1.46'
Your branch is up to date with 'origin/1.46'.
Already up to date.
Note: checking out '0784db7'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b <new-branch-name>
HEAD is now at 0784db7d server/process: Disable gc around critical section
cloning repo meta-processor-sdk
Fetching origin
Previous HEAD position was fab130c edgeai-components: Add tags for EDGEAI_APP_STACK_08_06_00_02
Switched to branch 'dunfell'
Your branch is up to date with 'origin/dunfell'.
Already up to date.
Note: checking out '08.06.00'.
HEAD is now at fab130c edgeai-components: Add tags for EDGEAI_APP_STACK_08_06_00_02
cloning repo meta-arago
Fetching origin
Previous HEAD position was e4fcc247 ltp-ddt: CI/CD Auto-Merger: cicd.dunfell.202302211800
Already up to date.
Note: checking out '08.06.00.007'.
HEAD is now at e4fcc247 ltp-ddt: CI/CD Auto-Merger: cicd.dunfell.202302211800
cloning repo meta-qt5
Fetching origin
fatal: unable to access 'github.com/.../': gnutls_handshake() failed: Error in the pull function.
error: Could not fetch origin
git failed... remaining attempts: 4 sleeping 15 seconds
Fetching origin
fatal: unable to access 'github.com/.../': Empty reply from server
git failed... remaining attempts: 3 sleeping 30 seconds
Fetching origin
Already up to date.
Note: checking out '5ef3a0f'.
HEAD is now at 5ef3a0f qtdeclarative: Fix build with gcc-11
cloning repo meta-virtualization
Fetching origin
Already up to date.
Note: checking out 'beea119eb529b4a11f266004aee8b548427aea39'.
HEAD is now at beea119 openvswitch: CVE-2021-3905 External triggered memory leak
cloning repo meta-openembedded
Fetching origin
Previous HEAD position was 875713450 zeromq: 4.3.2 -> 4.3.4
Already up to date.
Note: checking out '87571345059f82fb7599e3aa82e6fdcfbd361098'.
HEAD is now at 875713450 zeromq: 4.3.2 -> 4.3.4
cloning repo meta-ti
Fetching origin
Previous HEAD position was 45bdaf7d linux-ti-staging-rt: RC Auto-Merger: 08.06.00.007
Already up to date.
HEAD is now at 45bdaf7d linux-ti-staging-rt: RC Auto-Merger: 08.06.00.007
cloning repo meta-arm
Fetching origin
Previous HEAD position was c4f04f3f arm/trusted-firmware-a: add branch name for mbedtls
Already up to date.
Note: checking out 'c4f04f3fb66f8f4365b08b553af8206372e90a63'.
HEAD is now at c4f04f3f arm/trusted-firmware-a: add branch name for mbedtls
cloning repo oe-core
Fetching origin
Previous HEAD position was daaee6fcb0 build-appliance-image: Update to dunfell head revision
Already up to date.
Note: checking out 'daaee6fcb0d201f041678af433d8e1cd6f924d09'.
HEAD is now at daaee6fcb0 build-appliance-image: Update to dunfell head revision
cloning repo meta-sysrepo
Fetching origin
fatal: unable to access 'github.com/.../': Failed to connect to github.com port 443: Connection refused
Fetching origin
Fetching origin
git failed... remaining attempts: 2 sleeping 45 seconds
Fetching origin
git failed... remaining attempts: 1 sleeping 60 seconds
Fetching origin
Previous HEAD position was 8bcc615 Merge pull request #5 from synther/master
Switched to branch 'master'
Your branch is up to date with 'origin/master'.
Already up to date.
Note: checking out '8bcc6151897c0e67c2931c78340477bf3a12d8cb'.
HEAD is now at 8bcc615 Merge pull request #5 from synther/master
cloning repo meta-jupyter
Cloning into '/home/edu118/ti-processor-sdk-linux-am62axx-evm-08.06.00.45/tisdk/sources/meta-jupyter'...
^C
还有如何单独烧入kernel镜像
我这边是安装好sdk后
./setup.sh
然后直接
make all
这个问题解决了吗?
请安装以下命令所需的所有软件包:
sudo apt-get install build-essential autoconf automake bison flex libssl-dev bc u-boot-tools swig
然后
make all
看一下是否有报错。
