I start working on C6416 VCP. I hava refered the code of C6416BerCalculation.zip ( http://e2e.ti.com/cfs-file.ashx/__key/CommunityServer-Components-PostAttachments/00-00-17-15-03/C6416BerCalculation.zip). But the program hangs on in asm(" IDLE"); I can not get a verified example.
I am not very sure whether because of 2 tab before asm language of IDLE or just the configuration is wrong. The program was tested in CCS3.3 with 6416 simulator.
I also tested the program with deleting 2 tab before IDLE. the program could run to finish, but the result was wrong.
hope for your hint.
Thanks a lot
